path: root/include/linux/cpuset.h
2012-03-29Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: cpusets: Remove an unused variable sched/rt: Improve pick_next_highest_task_rt() sched: Fix select_fallback_rq() vs cpu_active/cpu_online sched/x86/smp: Do not enable IRQs over calibrate_delay() sched: Fix compiler warning about declared inline after use MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
2012-03-27sched: Fix select_fallback_rq() vs cpu_active/cpu_onlinePeter Zijlstra
Commit 5fbd036b55 ("sched: Cleanup cpu_active madness"), which was supposed to finally sort the cpu_active mess, instead uncovered more. Since CPU_STARTING is ran before setting the cpu online, there's a (small) window where the cpu has active,!online. If during this time there's a wakeup of a task that used to reside on that cpu select_task_rq() will use select_fallback_rq() to compute an alternative cpu to run on since we find !online. select_fallback_rq() however will compute the new cpu against cpu_active, this means that it can return the same cpu it started out with, the !online one, since that cpu is in fact marked active. This results in us trying to scheduling a task on an offline cpu and triggering a WARN in the IPI code. The solution proposed by Chuansheng Liu of setting cpu_active in set_cpu_online() is buggy, firstly not all archs actually use set_cpu_online(), secondly, not all archs call set_cpu_online() with IRQs disabled, this means we would introduce either the same race or the race from fd8a7de17 ("x86: cpu-hotplug: Prevent softirq wakeup on wrong CPU") -- albeit much narrower. [ By setting online first and active later we have a window of online,!active, fresh and bound kthreads have task_cpu() of 0 and since cpu0 isn't in tsk_cpus_allowed() we end up in select_fallback_rq() which excludes !active, resulting in a reset of ->cpus_allowed and the thread running all over the place. ] The solution is to re-work select_fallback_rq() to require active _and_ online. This makes the active,!online case work as expected, OTOH archs running CPU_STARTING after setting online are now vulnerable to the issue from fd8a7de17 -- these are alpha and blackfin. Reported-by: Chuansheng Liu <chuansheng.liu@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Frysinger <vapier@gentoo.org> Cc: linux-alpha@vger.kernel.org Link: http://lkml.kernel.org/n/tip-hubqk1i10o4dpvlm06gq7v6j@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-21cpuset: mm: reduce large amounts of memory barrier related damage v3Mel Gorman
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") wins a super prize for the largest number of memory barriers entered into fast paths for one commit. [get|put]_mems_allowed is incredibly heavy with pairs of full memory barriers inserted into a number of hot paths. This was detected while investigating at large page allocator slowdown introduced some time after 2.6.32. The largest portion of this overhead was shown by oprofile to be at an mfence introduced by this commit into the page allocator hot path. For extra style points, the commit introduced the use of yield() in an implementation of what looks like a spinning mutex. This patch replaces the full memory barriers on both read and write sides with a sequence counter with just read barriers on the fast path side. This is much cheaper on some architectures, including x86. The main bulk of the patch is the retry logic if the nodemask changes in a manner that can cause a false failure. While updating the nodemask, a check is made to see if a false failure is a risk. If it is, the sequence number gets bumped and parallel allocators will briefly stall while the nodemask update takes place. In a page fault test microbenchmark, oprofile samples from __alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The actual results were 3.3.0-rc3 3.3.0-rc3 rc3-vanilla nobarrier-v2r1 Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%) Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%) Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%) Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%) Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%) Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%) Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%) Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%) Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%) Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%) Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%) Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%) Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%) Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%) Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%) MMTests Statistics: duration Sys Time Running Test (seconds) 135.68 132.17 User+Sys Time Running Test (seconds) 164.2 160.13 Total Elapsed Time (seconds) 123.46 120.87 The overall improvement is small but the System CPU time is much improved and roughly in correlation to what oprofile reported (these performance figures are without profiling so skew is expected). The actual number of page faults is noticeably improved. For benchmarks like kernel builds, the overall benefit is marginal but the system CPU time is slightly reduced. To test the actual bug the commit fixed I opened two terminals. The first ran within a cpuset and continually ran a small program that faulted 100M of anonymous data. In a second window, the nodemask of the cpuset was continually randomised in a loop. Without the commit, the program would fail every so often (usually within 10 seconds) and obviously with the commit everything worked fine. With this patch applied, it also worked fine so the fix should be functionally equivalent. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28cpuset: Fix cpuset_cpus_allowed_fallback(), don't update tsk->rt.nr_cpus_allowedKOSAKI Motohiro
The rule is, we have to update tsk->rt.nr_cpus_allowed if we change tsk->cpus_allowed. Otherwise RT scheduler may confuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4DD4B3FA.5060901@jp.fujitsu.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-08sched: adjust when cpu_active and cpuset configurations are updated during ↵Tejun Heo
cpu on/offlining Currently, when a cpu goes down, cpu_active is cleared before CPU_DOWN_PREPARE starts and cpuset configuration is updated from a default priority cpu notifier. When a cpu is coming up, it's set before CPU_ONLINE but cpuset configuration again is updated from the same cpu notifier. For cpu notifiers, this presents an inconsistent state. Threads which a CPU_DOWN_PREPARE notifier expects to be bound to the CPU can be migrated to other cpus because the cpu is no more inactive. Fix it by updating cpu_active in the highest priority cpu notifier and cpuset configuration in the second highest when a cpu is coming up. Down path is updated similarly. This guarantees that all other cpu notifiers see consistent cpu_active and cpuset configuration. cpuset_track_online_cpus() notifier is converted to cpuset_update_active_cpus() which just updates the configuration and now called from cpuset_cpu_[in]active() notifiers registered from sched_init_smp(). If cpuset is disabled, cpuset_update_active_cpus() degenerates into partition_sched_domains() making separate notifier for !CONFIG_CPUSETS unnecessary. This problem is triggered by cmwq. During CPU_DOWN_PREPARE, hotplug callback creates a kthread and kthread_bind()s it to the target cpu, and the thread is expected to run on that cpu. * Ingo's test discovered __cpuinit/exit markups were incorrect. Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Menage <menage@google.com>
2010-05-27cpusets: new round-robin rotor for SLAB allocationsJack Steiner
We have observed several workloads running on multi-node systems where memory is assigned unevenly across the nodes in the system. There are numerous reasons for this but one is the round-robin rotor in cpuset_mem_spread_node(). For example, a simple test that writes a multi-page file will allocate pages on nodes 0 2 4 6 ... Odd nodes are skipped. (Sometimes it allocates on odd nodes & skips even nodes). An example is shown below. The program "lfile" writes a file consisting of 10 pages. The program then mmaps the file & uses get_mempolicy(..., MPOL_F_NODE) to determine the nodes where the file pages were allocated. The output is shown below: # ./lfile allocated on nodes: 2 4 6 0 1 2 6 0 2 There is a single rotor that is used for allocating both file pages & slab pages. Writing the file allocates both a data page & a slab page (buffer_head). This advances the RR rotor 2 nodes for each page allocated. A quick confirmation seems to confirm this is the cause of the uneven allocation: # echo 0 >/dev/cpuset/memory_spread_slab # ./lfile allocated on nodes: 6 7 8 9 0 1 2 3 4 5 This patch introduces a second rotor that is used for slab allocations. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25cpuset,mm: fix no node to alloc memory when changing cpuset's memsMiao Xie
Before applying this patch, cpuset updates task->mems_allowed and mempolicy by setting all new bits in the nodemask first, and clearing all old unallowed bits later. But in the way, the allocator may find that there is no node to alloc memory. The reason is that cpuset rebinds the task's mempolicy, it cleans the nodes which the allocater can alloc pages on, for example: (mpol: mempolicy) task1 task1's mpol task2 alloc page 1 alloc on node0? NO 1 1 change mems from 1 to 0 1 rebind task1's mpol 0-1 set new bits 0 clear disallowed bits alloc on node1? NO 0 ... can't alloc page goto oom This patch fixes this problem by expanding the nodes range first(set newly allowed bits) and shrink it lazily(clear newly disallowed bits). So we use a variable to tell the write-side task that read-side task is reading nodemask, and the write-side task clears newly disallowed nodes after read-side task ends the current memory allocation. [akpm@linux-foundation.org: fix spello] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Paul Menage <menage@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-02sched: Make select_fallback_rq() cpuset friendlyOleg Nesterov
Introduce cpuset_cpus_allowed_fallback() helper to fix the cpuset problems with select_fallback_rq(). It can be called from any context and can't use any cpuset locks including task_lock(). It is called when the task doesn't have online cpus in ->cpus_allowed but ttwu/etc must be able to find a suitable cpu. I am not proud of this patch. Everything which needs such a fat comment can't be good even if correct. But I'd prefer to not change the locking rules in the code I hardly understand, and in any case I believe this simple change make the code much more correct compared to deadlocks we currently have. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091027.GA9155@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Kill the broken and deadlockable ↵Oleg Nesterov
cpuset_lock/cpuset_cpus_allowed_locked code This patch just states the fact the cpusets/cpuhotplug interaction is broken and removes the deadlockable code which only pretends to work. - cpuset_lock() doesn't really work. It is needed for cpuset_cpus_allowed_locked() but we can't take this lock in try_to_wake_up()->select_fallback_rq() path. - cpuset_lock() is deadlockable. Suppose that a task T bound to CPU takes callback_mutex. If cpu_down(CPU) happens before T drops callback_mutex stop_machine() preempts T, then migration_call(CPU_DEAD) tries to take cpuset_lock() and hangs forever because CPU is already dead and thus T can't be scheduled. - cpuset_cpus_allowed_locked() is deadlockable too. It takes task_lock() which is not irq-safe, but try_to_wake_up() can be called from irq. Kill them, and change select_fallback_rq() to use cpu_possible_mask, like we currently do without CONFIG_CPUSETS. Also, with or without this patch, with or without CONFIG_CPUSETS, the callers of select_fallback_rq() can race with each other or with set_cpus_allowed() pathes. The subsequent patches try to to fix these problems. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091003.GA9123@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-16cpuset,mm: update tasks' mems_allowed in timeMiao Xie
Fix allocating page cache/slab object on the unallowed node when memory spread is set by updating tasks' mems_allowed after its cpuset's mems is changed. In order to update tasks' mems_allowed in time, we must modify the code of memory policy. Because the memory policy is applied in the process's context originally. After applying this patch, one task directly manipulates anothers mems_allowed, and we use alloc_lock in the task_struct to protect mems_allowed and memory policy of the task. But in the fast path, we didn't use lock to protect them, because adding a lock may lead to performance regression. But if we don't add a lock,the task might see no nodes when changing cpuset's mems_allowed to some non-overlapping set. In order to avoid it, we set all new allowed nodes, then clear newly disallowed ones. [lee.schermerhorn@hp.com: The rework of mpol_new() to extract the adjusting of the node mask to apply cpuset and mpol flags "context" breaks set_mempolicy() and mbind() with MPOL_PREFERRED and a NULL nodemask--i.e., explicit local allocation. Fix this by adding the check for MPOL_PREFERRED and empty node mask to mpol_new_mpolicy(). Remove the now unneeded 'nodes = NULL' from mpol_new(). Note that mpol_new_mempolicy() is always called with a non-NULL 'nodes' parameter now that it has been removed from mpol_new(). Therefore, we don't need to test nodes for NULL before testing it for 'empty'. However, just to be extra paranoid, add a VM_BUG_ON() to verify this assumption.] [lee.schermerhorn@hp.com: I don't think the function name 'mpol_new_mempolicy' is descriptive enough to differentiate it from mpol_new(). This function applies cpuset set context, usually constraining nodes to those allowed by the cpuset. However, when the 'RELATIVE_NODES flag is set, it also translates the nodes. So I settled on 'mpol_set_nodemask()', because the comment block for mpol_new() mentions that we need to call this function to "set nodes". Some additional minor line length, whitespace and typo cleanup.] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Paul Menage <menage@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cpusets: replace zone allowed functions with node allowedDavid Rientjes
The cpuset_zone_allowed() variants are actually only a function of the zone's node. Cc: Paul Menage <menage@google.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30cpumask: use new cpumask_ functions in core code.Rusty Russell
Impact: cleanup Time to clean up remaining laggards using the old cpu_ functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Trond.Myklebust@netapp.com
2009-01-08cpuset: remove remaining pointers to cpumask_tLi Zefan
Impact: cleanups, use new cpumask API Final trivial cleanups: mainly s/cpumask_t/struct cpumask Note there is a FIXME in generate_sched_domains(). A future patch will change struct cpumask *doms to struct cpumask *doms[]. (I suppose Rusty will do this.) Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06oom: print triggering task's cpuset and mems allowedDavid Rientjes
When cpusets are enabled, it's necessary to print the triggering task's set of allowable nodes so the subsequently printed meminfo can be interpreted correctly. We also print the task's cpuset name for informational purposes. [rientjes@google.com: task lock current before dereferencing cpuset] Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19cpuset: update top cpuset's mems after adding a nodeMiao Xie
After adding a node into the machine, top cpuset's mems isn't updated. By reviewing the code, we found that the update function cpuset_track_online_nodes() was invoked after node_states[N_ONLINE] changes. It is wrong because N_ONLINE just means node has pgdat, and if node has/added memory, we use N_HIGH_MEMORY. So, We should invoke the update function after node_states[N_HIGH_MEMORY] changes, just like its commit says. This patch fixes it. And we use notifier of memory hotplug instead of direct calling of cpuset_track_online_nodes(). Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Paul Menage <menage@google.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-06sched: arch_reinit_sched_domains() must destroy domains to force rebuildMax Krasnyansky
What I realized recently is that calling rebuild_sched_domains() in arch_reinit_sched_domains() by itself is not enough when cpusets are enabled. partition_sched_domains() code is trying to avoid unnecessary domain rebuilds and will not actually rebuild anything if new domain masks match the old ones. What this means is that doing echo 1 > /sys/devices/system/cpu/sched_mc_power_savings on a system with cpusets enabled will not take affect untill something changes in the cpuset setup (ie new sets created or deleted). This patch fixes restore correct behaviour where domains must be rebuilt in order to enable MC powersaving flags. Test on quad-core Core2 box with both CONFIG_CPUSETS and !CONFIG_CPUSETS. Also tested on dual-core Core2 laptop. Lockdep is happy and things are working as expected. Signed-off-by: Max Krasnyansky <maxk@qualcomm.com> Tested-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-18cpu hotplug, sched: Introduce cpu_active_map and redo sched domain managment ↵Max Krasnyansky
(take 2) This is based on Linus' idea of creating cpu_active_map that prevents scheduler load balancer from migrating tasks to the cpu that is going down. It allows us to simplify domain management code and avoid unecessary domain rebuilds during cpu hotplug event handling. Please ignore the cpusets part for now. It needs some more work in order to avoid crazy lock nesting. Although I did simplfy and unify domain reinitialization logic. We now simply call partition_sched_domains() in all the cases. This means that we're using exact same code paths as in cpusets case and hence the test below cover cpusets too. Cpuset changes to make rebuild_sched_domains() callable from various contexts are in the separate patch (right next after this one). This not only boots but also easily handles while true; do make clean; make -j 8; done and while true; do on-off-cpu 1; done at the same time. (on-off-cpu 1 simple does echo 0/1 > /sys/.../cpu1/online thing). Suprisingly the box (dual-core Core2) is quite usable. In fact I'm typing this on right now in gnome-terminal and things are moving just fine. Also this is running with most of the debug features enabled (lockdep, mutex, etc) no BUG_ONs or lockdep complaints so far. I believe I addressed all of the Dmitry's comments for original Linus' version. I changed both fair and rt balancer to mask out non-active cpus. And replaced cpu_is_offline() with !cpu_active() in the main scheduler code where it made sense (to me). Signed-off-by: Max Krasnyanskiy <maxk@qualcomm.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Gregory Haskins <ghaskins@novell.com> Cc: dmitry.adamushko@gmail.com Cc: pj@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-28mm: filter based on a nodemask as well as a gfp_maskMel Gorman
The MPOL_BIND policy creates a zonelist that is used for allocations controlled by that mempolicy. As the per-node zonelist is already being filtered based on a zone id, this patch adds a version of __alloc_pages() that takes a nodemask for further filtering. This eliminates the need for MPOL_BIND to create a custom zonelist. A positive benefit of this is that allocations using MPOL_BIND now use the local node's distance-ordered zonelist instead of a custom node-id-ordered zonelist. I.e., pages will be allocated from the closest allowed node with available memory. [Lee.Schermerhorn@hp.com: Mempolicy: update stale documentation and comments] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask rework] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19cpuset: modify cpuset_set_cpus_allowed to use cpumask pointerMike Travis
* Modify cpuset_cpus_allowed to return the currently allowed cpuset via a pointer argument instead of as the function return value. * Use new set_cpus_allowed_ptr function. * Cleanup CPU_MASK_ALL and NODE_MASK_ALL uses. Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-11mempolicy: silently restrict nodemask to allowed nodesKOSAKI Motohiro
Kosaki Motohito noted that "numactl --interleave=all ..." failed in the presence of memoryless nodes. This patch attempts to fix that problem. Some background: numactl --interleave=all calls set_mempolicy(2) with a fully populated [out to MAXNUMNODES] nodemask. set_mempolicy() [in do_set_mempolicy()] calls contextualize_policy() which requires that the nodemask be a subset of the current task's mems_allowed; else EINVAL will be returned. A task's mems_allowed will always be a subset of node_states[N_HIGH_MEMORY] i.e., nodes with memory. So, a fully populated nodemask will be declared invalid if it includes memoryless nodes. NOTE: the same thing will occur when running in a cpuset with restricted mem_allowed--for the same reason: node mask contains dis-allowed nodes. mbind(2), on the other hand, just masks off any nodes in the nodemask that are not included in the caller's mems_allowed. In each case [mbind() and set_mempolicy()], mpol_check_policy() will complain [again, resulting in EINVAL] if the nodemask contains any memoryless nodes. This is somewhat redundant as mpol_new() will remove memoryless nodes for interleave policy, as will bind_zonelist()--called by mpol_new() for BIND policy. Proposed fix: 1) modify contextualize_policy logic to: a) remember whether the incoming node mask is empty. b) if not, restrict the nodemask to allowed nodes, as is currently done in-line for mbind(). This guarantees that the resulting mask includes only nodes with memory. NOTE: this is a [benign, IMO] change in behavior for set_mempolicy(). Dis-allowed nodes will be silently ignored, rather than returning an error. c) fold this code into mpol_check_policy(), replace 2 calls to contextualize_policy() to call mpol_check_policy() directly and remove contextualize_policy(). 2) In existing mpol_check_policy() logic, after "contextualization": a) MPOL_DEFAULT: require that in coming mask "was_empty" b) MPOL_{BIND|INTERLEAVE}: require that contextualized nodemask contains at least one node. c) add a case for MPOL_PREFERRED: if in coming was not empty and resulting mask IS empty, user specified invalid nodes. Return EINVAL. c) remove the now redundant check for memoryless nodes 3) remove the now redundant masking of policy nodes for interleave policy from mpol_new(). 4) Now that mpol_check_policy() contextualizes the nodemask, remove the in-line nodes_and() from sys_mbind(). I believe that this restores mbind() to the behavior before the memoryless-nodes patch series. E.g., we'll no longer treat an invalid nodemask with MPOL_PREFERRED as local allocation. [ Patch history: v1 -> v2: - Communicate whether or not incoming node mask was empty to mpol_check_policy() for better error checking. - As suggested by David Rientjes, remove the now unused cpuset_nodes_subset_current_mems_allowed() from cpuset.h v2 -> v3: - As suggested by Kosaki Motohito, fold the "contextualization" of policy nodemask into mpol_check_policy(). Looks a little cleaner. ] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: seqfile convert proc_pid_status to properly handle pid namespacesEric W. Biederman
Currently we possibly lookup the pid in the wrong pid namespace. So seq_file convert proc_pid_status which ensures the proper pid namespaces is passed in. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: s390 build fix] [akpm@linux-foundation.org: fix task_name() output] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19hotplug cpu: migrate a task within its cpusetCliff Wickman
When a cpu is disabled, move_task_off_dead_cpu() is called for tasks that have been running on that cpu. Currently, such a task is migrated: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any cpu which is both online and among that task's cpus_allowed It is typical of a multithreaded application running on a large NUMA system to have its tasks confined to a cpuset so as to cluster them near the memory that they share. Furthermore, it is typical to explicitly place such a task on a specific cpu in that cpuset. And in that case the task's cpus_allowed includes only a single cpu. This patch would insert a preference to migrate such a task to some cpu within its cpuset (and set its cpus_allowed to its entire cpuset). With this patch, migrate the task to: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any online cpu within the task's cpuset 3) to any cpu which is both online and among that task's cpus_allowed In order to do this, move_task_off_dead_cpu() must make a call to cpuset_cpus_allowed_locked(), a new subset of cpuset_cpus_allowed(), that will not block. (name change - per Oleg's suggestion) Calls are made to cpuset_lock() and cpuset_unlock() in migration_call() to set the cpuset mutex during the whole migrate_live_tasks() and migrate_dead_tasks() procedure. [akpm@linux-foundation.org: build fix] [pj@sgi.com: Fix indentation and spacing] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Christoph Lameter <clameter@sgi.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: make cpusets a client of cgroupsPaul Menage
Remove the filesystem support logic from the cpusets system and makes cpusets a cgroup subsystem The "cpuset" filesystem becomes a dummy filesystem; attempts to mount it get passed through to the cgroup filesystem with the appropriate options to emulate the old cpuset filesystem behaviour. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: compare cpuset mems_allowed instead of exclusive ancestorsDavid Rientjes
Instead of testing for overlap in the memory nodes of the the nearest exclusive ancestor of both current and the candidate task, it is better to simply test for intersection between the task's mems_allowed in their task descriptors. This does not require taking callback_mutex since it is only used as a hint in the badness scoring. Tasks that do not have an intersection in their mems_allowed with the current task are not explicitly restricted from being OOM killed because it is quite possible that the candidate task has allocated memory there before and has since changed its mems_allowed. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Memoryless nodes: Use N_HIGH_MEMORY for cpusetsChristoph Lameter
cpusets try to ensure that any node added to a cpuset's mems_allowed is on-line and contains memory. The assumption was that online nodes contained memory. Thus, it is possible to add memoryless nodes to a cpuset and then add tasks to this cpuset. This results in continuous series of oom-kill and apparent system hang. Change cpusets to use node_states[N_HIGH_MEMORY] [a.k.a. node_memory_map] in place of node_online_map when vetting memories. Return error if admin attempts to write a non-empty mems_allowed node mask containing only memoryless-nodes. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 1Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[PATCH] cpuset procfs warning fixAndrew Morton
fs/proc/base.c:1869: warning: initialization discards qualifiers from pointer target type fs/proc/base.c:2150: warning: initialization discards qualifiers from pointer target type Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] cpuset: rework cpuset_zone_allowed apiPaul Jackson
Elaborate the API for calling cpuset_zone_allowed(), so that users have to explicitly choose between the two variants: cpuset_zone_allowed_hardwall() cpuset_zone_allowed_softwall() Until now, whether or not you got the hardwall flavor depended solely on whether or not you or'd in the __GFP_HARDWALL gfp flag to the gfp_mask argument. If you didn't specify __GFP_HARDWALL, you implicitly got the softwall version. Unfortunately, this meant that users would end up with the softwall version without thinking about it. Since only the softwall version might sleep, this led to bugs with possible sleeping in interrupt context on more than one occassion. The hardwall version requires that the current tasks mems_allowed allows the node of the specified zone (or that you're in interrupt or that __GFP_THISNODE is set or that you're on a one cpuset system.) The softwall version, depending on the gfp_mask, might allow a node if it was allowed in the nearest enclusing cpuset marked mem_exclusive (which requires taking the cpuset lock 'callback_mutex' to evaluate.) This patch removes the cpuset_zone_allowed() call, and forces the caller to explicitly choose between the hardwall and the softwall case. If the caller wants the gfp_mask to determine this choice, they should (1) be sure they can sleep or that __GFP_HARDWALL is set, and (2) invoke the cpuset_zone_allowed_softwall() routine. This adds another 100 or 200 bytes to the kernel text space, due to the few lines of nearly duplicate code at the top of both cpuset_zone_allowed_* routines. It should save a few instructions executed for the calls that turned into calls of cpuset_zone_allowed_hardwall, thanks to not having to set (before the call) then check (within the call) the __GFP_HARDWALL flag. For the most critical call, from get_page_from_freelist(), the same instructions are executed as before -- the old cpuset_zone_allowed() routine it used to call is the same code as the cpuset_zone_allowed_softwall() routine that it calls now. Not a perfect win, but seems worth it, to reduce this chance of hitting a sleeping with irq off complaint again. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] memory page_alloc zonelist caching speedupPaul Jackson
Optimize the critical zonelist scanning for free pages in the kernel memory allocator by caching the zones that were found to be full recently, and skipping them. Remembers the zones in a zonelist that were short of free memory in the last second. And it stashes a zone-to-node table in the zonelist struct, to optimize that conversion (minimize its cache footprint.) Recent changes: This differs in a significant way from a similar patch that I posted a week ago. Now, instead of having a nodemask_t of recently full nodes, I have a bitmask of recently full zones. This solves a problem that last weeks patch had, which on systems with multiple zones per node (such as DMA zone) would take seeing any of these zones full as meaning that all zones on that node were full. Also I changed names - from "zonelist faster" to "zonelist cache", as that seemed to better convey what we're doing here - caching some of the key zonelist state (for faster access.) See below for some performance benchmark results. After all that discussion with David on why I didn't need them, I went and got some ;). I wanted to verify that I had not hurt the normal case of memory allocation noticeably. At least for my one little microbenchmark, I found (1) the normal case wasn't affected, and (2) workloads that forced scanning across multiple nodes for memory improved up to 10% fewer System CPU cycles and lower elapsed clock time ('sys' and 'real'). Good. See details, below. I didn't have the logic in get_page_from_freelist() for various full nodes and zone reclaim failures correct. That should be fixed up now - notice the new goto labels zonelist_scan, this_zone_full, and try_next_zone, in get_page_from_freelist(). There are two reasons I persued this alternative, over some earlier proposals that would have focused on optimizing the fake numa emulation case by caching the last useful zone: 1) Contrary to what I said before, we (SGI, on large ia64 sn2 systems) have seen real customer loads where the cost to scan the zonelist was a problem, due to many nodes being full of memory before we got to a node we could use. Or at least, I think we have. This was related to me by another engineer, based on experiences from some time past. So this is not guaranteed. Most likely, though. The following approach should help such real numa systems just as much as it helps fake numa systems, or any combination thereof. 2) The effort to distinguish fake from real numa, using node_distance, so that we could cache a fake numa node and optimize choosing it over equivalent distance fake nodes, while continuing to properly scan all real nodes in distance order, was going to require a nasty blob of zonelist and node distance munging. The following approach has no new dependency on node distances or zone sorting. See comment in the patch below for a description of what it actually does. Technical details of note (or controversy): - See the use of "zlc_active" and "did_zlc_setup" below, to delay adding any work for this new mechanism until we've looked at the first zone in zonelist. I figured the odds of the first zone having the memory we needed were high enough that we should just look there, first, then get fancy only if we need to keep looking. - Some odd hackery was needed to add items to struct zonelist, while not tripping up the custom zonelists built by the mm/mempolicy.c code for MPOL_BIND. My usual wordy comments below explain this. Search for "MPOL_BIND". - Some per-node data in the struct zonelist is now modified frequently, with no locking. Multiple CPU cores on a node could hit and mangle this data. The theory is that this is just performance hint data, and the memory allocator will work just fine despite any such mangling. The fields at risk are the struct 'zonelist_cache' fields 'fullzones' (a bitmask) and 'last_full_zap' (unsigned long jiffies). It should all be self correcting after at most a one second delay. - This still does a linear scan of the same lengths as before. All I've optimized is making the scan faster, not algorithmically shorter. It is now able to scan a compact array of 'unsigned short' in the case of many full nodes, so one cache line should cover quite a few nodes, rather than each node hitting another one or two new and distinct cache lines. - If both Andi and Nick don't find this too complicated, I will be (pleasantly) flabbergasted. - I removed the comment claiming we only use one cachline's worth of zonelist. We seem, at least in the fake numa case, to have put the lie to that claim. - I pay no attention to the various watermarks and such in this performance hint. A node could be marked full for one watermark, and then skipped over when searching for a page using a different watermark. I think that's actually quite ok, as it will tend to slightly increase the spreading of memory over other nodes, away from a memory stressed node. =============== Performance - some benchmark results and analysis: This benchmark runs a memory hog program that uses multiple threads to touch alot of memory as quickly as it can. Multiple runs were made, touching 12, 38, 64 or 90 GBytes out of the total 96 GBytes on the system, and using 1, 19, 37, or 55 threads (on a 56 CPU system.) System, user and real (elapsed) timings were recorded for each run, shown in units of seconds, in the table below. Two kernels were tested - 2.6.18-mm3 and the same kernel with this zonelist caching patch added. The table also shows the percentage improvement the zonelist caching sys time is over (lower than) the stock *-mm kernel. number 2.6.18-mm3 zonelist-cache delta (< 0 good) percent GBs N ------------ -------------- ---------------- systime mem threads sys user real sys user real sys user real better 12 1 153 24 177 151 24 176 -2 0 -1 1% 12 19 99 22 8 99 22 8 0 0 0 0% 12 37 111 25 6 112 25 6 1 0 0 -0% 12 55 115 25 5 110 23 5 -5 -2 0 4% 38 1 502 74 576 497 73 570 -5 -1 -6 0% 38 19 426 78 48 373 76 39 -53 -2 -9 12% 38 37 544 83 36 547 82 36 3 -1 0 -0% 38 55 501 77 23 511 80 24 10 3 1 -1% 64 1 917 125 1042 890 124 1014 -27 -1 -28 2% 64 19 1118 138 119 965 141 103 -153 3 -16 13% 64 37 1202 151 94 1136 150 81 -66 -1 -13 5% 64 55 1118 141 61 1072 140 58 -46 -1 -3 4% 90 1 1342 177 1519 1275 174 1450 -67 -3 -69 4% 90 19 2392 199 192 2116 189 176 -276 -10 -16 11% 90 37 3313 238 175 2972 225 145 -341 -13 -30 10% 90 55 1948 210 104 1843 213 100 -105 3 -4 5% Notes: 1) This test ran a memory hog program that started a specified number N of threads, and had each thread allocate and touch 1/N'th of the total memory to be used in the test run in a single loop, writing a constant word to memory, one store every 4096 bytes. Watching this test during some earlier trial runs, I would see each of these threads sit down on one CPU and stay there, for the remainder of the pass, a different CPU for each thread. 2) The 'real' column is not comparable to the 'sys' or 'user' columns. The 'real' column is seconds wall clock time elapsed, from beginning to end of that test pass. The 'sys' and 'user' columns are total CPU seconds spent on that test pass. For a 19 thread test run, for example, the sum of 'sys' and 'user' could be up to 19 times the number of 'real' elapsed wall clock seconds. 3) Tests were run on a fresh, single-user boot, to minimize the amount of memory already in use at the start of the test, and to minimize the amount of background activity that might interfere. 4) Tests were done on a 56 CPU, 28 Node system with 96 GBytes of RAM. 5) Notice that the 'real' time gets large for the single thread runs, even though the measured 'sys' and 'user' times are modest. I'm not sure what that means - probably something to do with it being slow for one thread to be accessing memory along ways away. Perhaps the fake numa system, running ostensibly the same workload, would not show this substantial degradation of 'real' time for one thread on many nodes -- lets hope not. 6) The high thread count passes (one thread per CPU - on 55 of 56 CPUs) ran quite efficiently, as one might expect. Each pair of threads needed to allocate and touch the memory on the node the two threads shared, a pleasantly parallizable workload. 7) The intermediate thread count passes, when asking for alot of memory forcing them to go to a few neighboring nodes, improved the most with this zonelist caching patch. Conclusions: * This zonelist cache patch probably makes little difference one way or the other for most workloads on real numa hardware, if those workloads avoid heavy off node allocations. * For memory intensive workloads requiring substantial off-node allocations on real numa hardware, this patch improves both kernel and elapsed timings up to ten per-cent. * For fake numa systems, I'm optimistic, but will have to leave that up to Rohit Seth to actually test (once I get him a 2.6.18 backport.) Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Rohit Seth <rohitseth@google.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: David Rientjes <rientjes@cs.washington.edu> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] cpuset: top_cpuset tracks hotplug changes to node_online_mapPaul Jackson
Change the list of memory nodes allowed to tasks in the top (root) nodeset to dynamically track what cpus are online, using a call to a cpuset hook from the memory hotplug code. Make this top cpus file read-only. On systems that have cpusets configured in their kernel, but that aren't actively using cpusets (for some distros, this covers the majority of systems) all tasks end up in the top cpuset. If that system does support memory hotplug, then these tasks cannot make use of memory nodes that are added after system boot, because the memory nodes are not allowed in the top cpuset. This is a surprising regression over earlier kernels that didn't have cpusets enabled. One key motivation for this change is to remain consistent with the behaviour for the top_cpuset's 'cpus', which is also read-only, and which automatically tracks the cpu_online_map. This change also has the minor benefit that it fixes a long standing, little noticed, minor bug in cpusets. The cpuset performance tweak to short circuit the cpuset_zone_allowed() check on systems with just a single cpuset (see 'number_of_cpusets', in linux/cpuset.h) meant that simply changing the 'mems' of the top_cpuset had no affect, even though the change (the write system call) appeared to succeed. With the following change, that write to the 'mems' file fails -EACCES, and the 'mems' file stubbornly refuses to be changed via user space writes. Thus no one should be mislead into thinking they've changed the top_cpusets's 'mems' when in affect they haven't. In order to keep the behaviour of cpusets consistent between systems actively making use of them and systems not using them, this patch changes the behaviour of the 'mems' file in the top (root) cpuset, making it read only, and making it automatically track the value of node_online_map. Thus tasks in the top cpuset will have automatic use of hot plugged memory nodes allowed by their cpuset. [akpm@osdl.org: build fix] [bunk@stusta.de: build fix] Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread basic implementationPaul Jackson
This patch provides the implementation and cpuset interface for an alternative memory allocation policy that can be applied to certain kinds of memory allocations, such as the page cache (file system buffers) and some slab caches (such as inode caches). The policy is called "memory spreading." If enabled, it spreads out these kinds of memory allocations over all the nodes allowed to a task, instead of preferring to place them on the node where the task is executing. All other kinds of allocations, including anonymous pages for a tasks stack and data regions, are not affected by this policy choice, and continue to be allocated preferring the node local to execution, as modified by the NUMA mempolicy. There are two boolean flag files per cpuset that control where the kernel allocates pages for the file system buffers and related in kernel data structures. They are called 'memory_spread_page' and 'memory_spread_slab'. If the per-cpuset boolean flag file 'memory_spread_page' is set, then the kernel will spread the file system buffers (page cache) evenly over all the nodes that the faulting task is allowed to use, instead of preferring to put those pages on the node where the task is running. If the per-cpuset boolean flag file 'memory_spread_slab' is set, then the kernel will spread some file system related slab caches, such as for inodes and dentries evenly over all the nodes that the faulting task is allowed to use, instead of preferring to put those pages on the node where the task is running. The implementation is simple. Setting the cpuset flags 'memory_spread_page' or 'memory_spread_cache' turns on the per-process flags PF_SPREAD_PAGE or PF_SPREAD_SLAB, respectively, for each task that is in the cpuset or subsequently joins that cpuset. In subsequent patches, the page allocation calls for the affected page cache and slab caches are modified to perform an inline check for these flags, and if set, a call to a new routine cpuset_mem_spread_node() returns the node to prefer for the allocation. The cpuset_mem_spread_node() routine is also simple. It uses the value of a per-task rotor cpuset_mem_spread_rotor to select the next node in the current tasks mems_allowed to prefer for the allocation. This policy can provide substantial improvements for jobs that need to place thread local data on the corresponding node, but that need to access large file system data sets that need to be spread across the several nodes in the jobs cpuset in order to fit. Without this patch, especially for jobs that might have one thread reading in the data set, the memory allocation across the nodes in the jobs cpuset can become very uneven. A couple of Copyright year ranges are updated as well. And a couple of email addresses that can be found in the MAINTAINERS file are removed. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cpuset oom lock fixPaul Jackson
The problem, reported in: http://bugzilla.kernel.org/show_bug.cgi?id=5859 and by various other email messages and lkml posts is that the cpuset hook in the oom (out of memory) code can try to take a cpuset semaphore while holding the tasklist_lock (a spinlock). One must not sleep while holding a spinlock. The fix seems easy enough - move the cpuset semaphore region outside the tasklist_lock region. This required a few lines of mechanism to implement. The oom code where the locking needs to be changed does not have access to the cpuset locks, which are internal to kernel/cpuset.c only. So I provided a couple more cpuset interface routines, available to the rest of the kernel, which simple take and drop the lock needed here (cpusets callback_sem). Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: remove test for null cpuset from alloc code pathPaul Jackson
Remove a couple of more lines of code from the cpuset hooks in the page allocation code path. There was a check for a NULL cpuset pointer in the routine cpuset_update_task_memory_state() that was only needed during system boot, after the memory subsystem was initialized, before the cpuset subsystem was initialized, to catch a NULL task->cpuset pointer. Add a cpuset_init_early() routine, just before the mem_init() call in init/main.c, that sets up just enough of the init tasks cpuset structure to render cpuset_update_task_memory_state() calls harmless. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: number_of_cpusets optimizationPaul Jackson
Easy little optimization hack to avoid actually having to call cpuset_zone_allowed() and check mems_allowed, in the main page allocation routine, __alloc_pages(). This saves several CPU cycles per page allocation on systems not using cpusets. A counter is updated each time a cpuset is created or removed, and whenever there is only one cpuset in the system, it must be the root cpuset, which contains all CPUs and all Memory Nodes. In that case, when the counter is one, all allocations are allowed. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: implement cpuset_mems_allowedPaul Jackson
Provide a cpuset_mems_allowed() method, which the sys_migrate_pages() code needed, to obtain the mems_allowed vector of a cpuset, and replaced the workaround in sys_migrate_pages() to call this new method. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: combine refresh_mems and update_memsPaul Jackson
The important code paths through alloc_pages_current() and alloc_page_vma(), by which most kernel page allocations go, both called cpuset_update_current_mems_allowed(), which in turn called refresh_mems(). -Both- of these latter two routines did a tasklock, got the tasks cpuset pointer, and checked for out of date cpuset->mems_generation. That was a silly duplication of code and waste of CPU cycles on an important code path. Consolidated those two routines into a single routine, called cpuset_update_task_memory_state(), since it updates more than just mems_allowed. Changed all callers of either routine to call the new consolidated routine. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: memory pressure meterPaul Jackson
Provide a simple per-cpuset metric of memory pressure, tracking the -rate- that the tasks in a cpuset call try_to_free_pages(), the synchronous (direct) memory reclaim code. This enables batch managers monitoring jobs running in dedicated cpusets to efficiently detect what level of memory pressure that job is causing. This is useful both on tightly managed systems running a wide mix of submitted jobs, which may choose to terminate or reprioritize jobs that are trying to use more memory than allowed on the nodes assigned them, and with tightly coupled, long running, massively parallel scientific computing jobs that will dramatically fail to meet required performance goals if they start to use more memory than allowed to them. This patch just provides a very economical way for the batch manager to monitor a cpuset for signs of memory pressure. It's up to the batch manager or other user code to decide what to do about it and take action. ==> Unless this feature is enabled by writing "1" to the special file /dev/cpuset/memory_pressure_enabled, the hook in the rebalance code of __alloc_pages() for this metric reduces to simply noticing that the cpuset_memory_pressure_enabled flag is zero. So only systems that enable this feature will compute the metric. Why a per-cpuset, running average: Because this meter is per-cpuset, rather than per-task or mm, the system load imposed by a batch scheduler monitoring this metric is sharply reduced on large systems, because a scan of the tasklist can be avoided on each set of queries. Because this meter is a running average, instead of an accumulating counter, a batch scheduler can detect memory pressure with a single read, instead of having to read and accumulate results for a period of time. Because this meter is per-cpuset rather than per-task or mm, the batch scheduler can obtain the key information, memory pressure in a cpuset, with a single read, rather than having to query and accumulate results over all the (dynamically changing) set of tasks in the cpuset. A per-cpuset simple digital filter (requires a spinlock and 3 words of data per-cpuset) is kept, and updated by any task attached to that cpuset, if it enters the synchronous (direct) page reclaim code. A per-cpuset file provides an integer number representing the recent (half-life of 10 seconds) rate of direct page reclaims caused by the tasks in the cpuset, in units of reclaims attempted per second, times 1000. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: mempolicy one more nodemask conversionPaul Jackson
Finish converting mm/mempolicy.c from bitmaps to nodemasks. The previous conversion had left one routine using bitmaps, since it involved a corresponding change to kernel/cpuset.c Fix that interface by replacing with a simple macro that calls nodes_subset(), or if !CONFIG_CPUSET, returns (1). Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <christoph@lameter.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] cpusets: confine oom_killer to mem_exclusive cpusetPaul Jackson
Now the real motivation for this cpuset mem_exclusive patch series seems trivial. This patch keeps a task in or under one mem_exclusive cpuset from provoking an oom kill of a task under a non-overlapping mem_exclusive cpuset. Since only interrupt and GFP_ATOMIC allocations are allowed to escape mem_exclusive containment, there is little to gain from oom killing a task under a non-overlapping mem_exclusive cpuset, as almost all kernel and user memory allocation must come from disjoint memory nodes. This patch enables configuring a system so that a runaway job under one mem_exclusive cpuset cannot cause the killing of a job in another such cpuset that might be using very high compute and memory resources for a prolonged time. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] cpusets: formalize intermediate GFP_KERNEL containmentPaul Jackson
This patch makes use of the previously underutilized cpuset flag 'mem_exclusive' to provide what amounts to another layer of memory placement resolution. With this patch, there are now the following four layers of memory placement available: 1) The whole system (interrupt and GFP_ATOMIC allocations can use this), 2) The nearest enclosing mem_exclusive cpuset (GFP_KERNEL allocations can use), 3) The current tasks cpuset (GFP_USER allocations constrained to here), and 4) Specific node placement, using mbind and set_mempolicy. These nest - each layer is a subset (same or within) of the previous. Layer (2) above is new, with this patch. The call used to check whether a zone (its node, actually) is in a cpuset (in its mems_allowed, actually) is extended to take a gfp_mask argument, and its logic is extended, in the case that __GFP_HARDWALL is not set in the flag bits, to look up the cpuset hierarchy for the nearest enclosing mem_exclusive cpuset, to determine if placement is allowed. The definition of GFP_USER, which used to be identical to GFP_KERNEL, is changed to also set the __GFP_HARDWALL bit, in the previous cpuset_gfp_hardwall_flag patch. GFP_ATOMIC and GFP_KERNEL allocations will stay within the current tasks cpuset, so long as any node therein is not too tight on memory, but will escape to the larger layer, if need be. The intended use is to allow something like a batch manager to handle several jobs, each job in its own cpuset, but using common kernel memory for caches and such. Swapper and oom_kill activity is also constrained to Layer (2). A task in or below one mem_exclusive cpuset should not cause swapping on nodes in another non-overlapping mem_exclusive cpuset, nor provoke oom_killing of a task in another such cpuset. Heavy use of kernel memory for i/o caching and such by one job should not impact the memory available to jobs in other non-overlapping mem_exclusive cpusets. This patch enables providing hardwall, inescapable cpusets for memory allocations of each job, while sharing kernel memory allocations between several jobs, in an enclosing mem_exclusive cpuset. Like Dinakar's patch earlier to enable administering sched domains using the cpu_exclusive flag, this patch also provides a useful meaning to a cpuset flag that had previously done nothing much useful other than restrict what cpuset configurations were allowed. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] cpuset: remove function attribute constBenoit Boissinot
gcc-4 warns with include/linux/cpuset.h:21: warning: type qualifiers ignored on function return type cpuset_cpus_allowed is declared with const extern const cpumask_t cpuset_cpus_allowed(const struct task_struct *p); First const should be __attribute__((const)), but the gcc manual explains that: "Note that a function that has pointer arguments and examines the data pointed to must not be declared const. Likewise, a function that calls a non-const function usually must not be const. It does not make sense for a const function to return void." The following patch remove const from the function declaration. Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
