path: root/include/linux/cramfs_fs.h
2011-01-13cramfs: hide function prototypes behind __KERNEL__ macroAlexander Shishkin
Currently, 3 kernel function prototypes are present in a header file exported to userland. This patch fixes it. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11linux/magic.h: move cramfs magic out of cramfs_fs.hMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-17cramfs: error message about endianessAndi Drebes
The README file in the cramfs subdirectory says: "All data is currently in host-endian format; neither mkcramfs nor the kernel ever do swabbing." If somebody tries to mount a cramfs with the wrong endianess, cramfs only complains about a wrong magic but doesn't inform the user that only the endianess isn't right. The following patch adds an error message to the cramfs sources. If a user tries to mount a cramfs with the wrong endianess using the patched sources, cramfs will display the message "cramfs: wrong endianess". Signed-off-by: Andi Drebes <lists-receive@programmierforen.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] cramfs: make cramfs_uncompress_exit() return voidAlexey Dobriyan
It always returns 0, so relying on it is useless. The only caller isn't checking return value. In general, un-, de-, -free functions should return void. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-04Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h>David Woodhouse
