path: root/include/linux/crash_dump.h
2011-05-26fs/proc/vmcore.c: add hook to read_from_oldmem() to check for non-ram pagesOlaf Hering
The balloon driver in a Xen guest frees guest pages and marks them as mmio. When the kernel crashes and the crash kernel attempts to read the oldmem via /proc/vmcore a read from ballooned pages will generate 100% load in dom0 because Xen asks qemu-dm for the page content. Since the reads come in as 8byte requests each ballooned page is tried 512 times. With this change a hook can be registered which checks wether the given pfn is really ram. The hook has to return a value > 0 for ram pages, a value < 0 on error (because the hypercall is not known) and 0 for non-ram pages. This will reduce the time to read /proc/vmcore. Without this change a 512M guest with 128M crashkernel region needs 200 seconds to read it, with this change it takes just 2 seconds. Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-30ARM: 6485/5: proc/vmcore - allow archs to override vmcore_elf_check_arch()Mika Westerberg
Allow architectures to redefine this macro if needed. This is useful for example in architectures where 64-bit ELF vmcores are not supported. Specifying zero vmcore_elf64_check_arch() allows compiler to optimize away unnecessary parts of parse_crash_elf64_headers(). We also rename the macro to vmcore_elf64_check_arch() to reflect that it is used for 64-bit vmcores only. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23proc: move /proc/vmcore creation to fs/proc/vmcore.cAlexey Dobriyan
2008-10-20kdump: add is_vmcore_usable() and vmcore_unusable()Simon Horman
The usage of elfcorehdr_addr has changed recently such that being set to ELFCORE_ADDR_MAX is used by is_kdump_kernel() to indicate if the code is executing in a kernel executed as a crash kernel. However, arch/ia64/kernel/setup.c:reserve_elfcorehdr will rest elfcorehdr_addr to ELFCORE_ADDR_MAX on error, which means any subsequent calls to is_kdump_kernel() will return 0, even though they should return 1. Ok, at this point in time there are no subsequent calls, but I think its fair to say that there is ample scope for error or at the very least confusion. This patch add an extra state, ELFCORE_ADDR_ERR, which indicates that elfcorehdr_addr was passed on the command line, and thus execution is taking place in a crashdump kernel, but vmcore can't be used for some reason. This is tested for using is_vmcore_usable() and set using vmcore_unusable(). A subsequent patch makes use of this new code. To summarise, the states that elfcorehdr_addr can now be in are as follows: ELFCORE_ADDR_MAX: not a crashdump kernel ELFCORE_ADDR_ERR: crashdump kernel but vmcore is unusable any other value: crash dump kernel and vmcore is usable Signed-off-by: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20kdump: make elfcorehdr_addr independent of CONFIG_PROC_VMCOREVivek Goyal
o elfcorehdr_addr is used by not only the code under CONFIG_PROC_VMCORE but also by the code which is not inside CONFIG_PROC_VMCORE. For example, is_kdump_kernel() is used by powerpc code to determine if kernel is booting after a panic then use previous kernel's TCE table. So even if CONFIG_PROC_VMCORE is not set in second kernel, one should be able to correctly determine that we are booting after a panic and setup calgary iommu accordingly. o So remove the assumption that elfcorehdr_addr is under CONFIG_PROC_VMCORE. o Move definition of elfcorehdr_addr to arch dependent crash files. (Unfortunately crash dump does not have an arch independent file otherwise that would have been the best place). o kexec.c is not the right place as one can Have CRASH_DUMP enabled in second kernel without KEXEC being enabled. o I don't see sh setup code parsing the command line for elfcorehdr_addr. I am wondering how does vmcore interface work on sh. Anyway, I am atleast defining elfcoredhr_addr so that compilation is not broken on sh. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26crashdump: fix undefined reference to `elfcorehdr_addr'Ingo Molnar
fix build bug introduced by 95b68dec0d5 "calgary iommu: use the first kernels TCE tables in kdump": arch/x86/kernel/built-in.o: In function `calgary_iommu_init': (.init.text+0x8399): undefined reference to `elfcorehdr_addr' arch/x86/kernel/built-in.o: In function `calgary_iommu_init': (.init.text+0x856c): undefined reference to `elfcorehdr_addr' arch/x86/kernel/built-in.o: In function `detect_calgary': (.init.text+0x8c68): undefined reference to `elfcorehdr_addr' arch/x86/kernel/built-in.o: In function `detect_calgary': (.init.text+0x8d0c): undefined reference to `elfcorehdr_addr' make elfcorehdr_addr a generally available symbol. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-25calgary iommu: use the first kernels TCE tables in kdumpChandru
kdump kernel fails to boot with calgary iommu and aacraid driver on a x366 box. The ongoing dma's of aacraid from the first kernel continue to exist until the driver is loaded in the kdump kernel. Calgary is initialized prior to aacraid and creation of new tce tables causes wrong dma's to occur. Here we try to get the tce tables of the first kernel in kdump kernel and use them. While in the kdump kernel we do not allocate new tce tables but instead read the base address register contents of calgary iommu and use the tables that the registers point to. With these changes the kdump kernel and hence aacraid now boots normally. Signed-off-by: Chandru Siddalingappa <chandru@in.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] i386: Allow i386 crash kernels to handle x86_64 dumpsIan Campbell
The specific case I am encountering is kdump under Xen with a 64 bit hypervisor and 32 bit kernel/userspace. The dump created is 64 bit due to the hypervisor but the dump kernel is 32 bit for maximum compatibility. It's possibly less likely to be useful in a purely native scenario but I see no reason to disallow it. [akpm@linux-foundation.org: build fix] Signed-off-by: Ian Campbell <ian.campbell@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Horms <horms@verge.net.au> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Access dump file in elf format (/proc/vmcore)Vivek Goyal
From: "Vivek Goyal" <vgoyal@in.ibm.com> o Support for /proc/vmcore interface. This interface exports elf core image either in ELF32 or ELF64 format, depending on the format in which elf headers have been stored by crashed kernel. o Added support for CONFIG_VMCORE config option. o Removed the dependency on /proc/kcore. From: "Eric W. Biederman" <ebiederm@xmission.com> This patch has been refactored to more closely match the prevailing style in the affected files. And to clearly indicate the dependency between /proc/kcore and proc/vmcore.c From: Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that provides an ELF format interface to the previous kernel's memory post kexec reboot. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Retrieve elfcorehdr address from command lineVivek Goyal
This patch adds support for retrieving the address of elf core header if one is passed in command line. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Routines for copying dump pagesVivek Goyal
This patch provides the interfaces necessary to read the dump contents, treating it as a high memory device. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
