path: root/include/linux/crypto.h
2012-03-24Merge tag 'bug-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/bug.h> cleanup from Paul Gortmaker: "The changes shown here are to unify linux's BUG support under the one <linux/bug.h> file. Due to historical reasons, we have some BUG code in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in linux/kernel.h predates the addition of linux/bug.h, but old code in kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h was including <asm/bug.h> to pseudo link them. This has caused confusion[1] and general yuck/WTF[2] reactions. Here is an example that violates the principle of least surprise: CC lib/string.o lib/string.c: In function 'strlcat': lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON' make[2]: *** [lib/string.o] Error 1 $ $ grep linux/bug.h lib/string.c #include <linux/bug.h> $ We've included <linux/bug.h> for the BUG infrastructure and yet we still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh - very confusing for someone who is new to kernel development. With the above in mind, the goals of this changeset are: 1) find and fix any include/*.h files that were relying on the implicit presence of BUG code. 2) find and fix any C files that were consuming kernel.h and hence relying on implicitly getting some/all BUG code. 3) Move the BUG related code living in kernel.h to <linux/bug.h> 4) remove the asm/bug.h from kernel.h to finally break the chain. During development, the order was more like 3-4, build-test, 1-2. But to ensure that git history for bisect doesn't get needless build failures introduced, the commits have been reorderd to fix the problem areas in advance. [1] https://lkml.org/lkml/2012/1/3/90 [2] https://lkml.org/lkml/2012/1/17/414" Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul and linux-next. * tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: kernel.h: doesn't explicitly use bug.h, so don't include it. bug: consolidate BUILD_BUG_ON with other bug code BUG: headers with BUG/BUG_ON etc. need linux/bug.h bug.h: add include of it to various implicit C users lib: fix implicit users of kernel.h for TAINT_WARN spinlock: macroize assert_spin_locked to avoid bug.h dependency x86: relocate get/set debugreg fcns to include/asm/debugreg.
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-26crypto: Add bulk algorithm registration interfaceMark Brown
Hardware crypto engines frequently need to register a selection of different algorithms with the core. Simplify their code slightly, especially the error handling, by providing functions to register a number of algorithms in a single call. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-13crypto: Add CRYPTO_ALG_KERN_DRIVER_ONLY flagNikos Mavrogiannopoulos
The added CRYPTO_ALG_KERN_DRIVER_ONLY indicates whether a cipher is only available via a kernel driver. If the cipher implementation might be available by using an instruction set or by porting the kernel code, then it must not be set. Signed-off-by: Nikos Mavrogiannopoulos <nmav@gnutls.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31crypto.h: remove unused crypto_tfm_alg_modname() inlinePaul Gortmaker
The <linux/crypto.h> (which is in turn in common headers like tcp.h) wants to use module_name() in an inline fcn. But having all of <linux/module.h> along for the ride is overkill and slows down compiles by a measureable amount, since it in turn includes lots of headers. Since the inline is never used anywhere in the kernel[1], we can just remove it, and then also remove the module.h include as well. In all the many crypto modules, there were some relying on crypto.h including module.h -- for them we now explicitly call out module.h for inclusion. [1] git grep shows some staging drivers also define the same static inline, but they also never ever use it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-21crypto: Add a flag to identify crypto instancesSteffen Klassert
The upcomming crypto user configuration api needs to identify crypto instances. This patch adds a flag that is set if the algorithm is an instance that is build from templates. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-19crypto: Use ARCH_KMALLOC_MINALIGN for CRYPTO_MINALIGN now that it's exposedDavid Woodhouse
Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-10-19crypto: hash - Remove cra_u.{digest,hash}Benjamin Gilbert
Remove unused digest_alg and hash_alg structs from crypto_alg union and kill their definitions. This also ensures that old-style digest/hash algorithms maintained out of tree will break at build time rather than oopsing at runtime. Signed-off-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Remove old_ahash_algHerbert Xu
Now that all ahash implementations have been converted to the new ahash type, we can remove old_ahash_alg and its associated support. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Convert to new style algorithmsHerbert Xu
This patch converts crypto_ahash to the new style. The old ahash algorithm type is retained until the existing ahash implementations are also converted. All ahash users will automatically get the new crypto_ahash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-12crypto: async - Use kzfree for requestsHerbert Xu
This patch changes the kfree call to kzfree for async requests. As the request may contain sensitive data it needs to be zeroed before it can be reallocated by others. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: compress - Add pcomp interfaceGeert Uytterhoeven
The current "comp" crypto interface supports one-shot (de)compression only, i.e. the whole data buffer to be (de)compressed must be passed at once, and the whole (de)compressed data buffer will be received at once. In several use-cases (e.g. compressed file systems that store files in big compressed blocks), this workflow is not suitable. Furthermore, the "comp" type doesn't provide for the configuration of (de)compression parameters, and always allocates workspace memory for both compression and decompression, which may waste memory. To solve this, add a "pcomp" partial (de)compression interface that provides the following operations: - crypto_compress_{init,update,final}() for compression, - crypto_decompress_{init,update,final}() for decompression, - crypto_{,de}compress_setup(), to configure (de)compression parameters (incl. allocating workspace memory). The (de)compression methods take a struct comp_request, which was mimicked after the z_stream object in zlib, and contains buffer pointer and length pairs for input and output. The setup methods take an opaque parameter pointer and length pair. Parameters are supposed to be encoded using netlink attributes, whose meanings depend on the actual (name of the) (de)compression algorithm. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-18crypto: api - Fix crypto_alloc_tfm/create_create_tfm return conventionHerbert Xu
This is based on a report and patch by Geert Uytterhoeven. The functions crypto_alloc_tfm and create_create_tfm return a pointer that needs to be adjusted by the caller when successful and otherwise an error value. This means that the caller has to check for the error and only perform the adjustment if the pointer returned is valid. Since all callers want to make the adjustment and we know how to adjust it ourselves, it's much easier to just return adjusted pointer directly. The only caveat is that we have to return a void * instead of struct crypto_tfm *. However, this isn't that bad because both of these functions are for internal use only (by types code like shash.c, not even algorithms code). This patch also moves crypto_alloc_tfm into crypto/internal.h (crypto_create_tfm is already there) to reflect this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-05crypto: api - Fix zeroing on freeHerbert Xu
Geert Uytterhoeven pointed out that we're not zeroing all the memory when freeing a transform. This patch fixes it by calling ksize to ensure that we zero everything in sight. Reported-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Export shash through hashHerbert Xu
This patch allows shash algorithms to be used through the old hash interface. This is a transitional measure so we can convert the underlying algorithms to shash before converting the users across. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Add import/export interfaceHerbert Xu
It is often useful to save the partial state of a hash function so that it can be used as a base for two or more computations. The most prominent example is HMAC where all hashes start from a base determined by the key. Having an import/export interface means that we only have to compute that base once rather than for each message. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Export shash through ahashHerbert Xu
This patch allows shash algorithms to be used through the ahash interface. This is required before we can convert digest algorithms over to shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Add shash interfaceHerbert Xu
The shash interface replaces the current synchronous hash interface. It improves over hash in two ways. Firstly shash is reentrant, meaning that the same tfm may be used by two threads simultaneously as all hashing state is stored in a local descriptor. The other enhancement is that shash no longer takes scatter list entries. This is because shash is specifically designed for synchronous algorithms and as such scatter lists are unnecessary. All existing hash users will be converted to shash once the algorithms have been completely converted. There is also a new finup function that combines update with final. This will be extended to ahash once the algorithm conversion is done. This is also the first time that an algorithm type has their own registration function. Existing algorithm types will be converted to this way in due course. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: api - Rebirth of crypto_alloc_tfmHerbert Xu
This patch reintroduces a completely revamped crypto_alloc_tfm. The biggest change is that we now take two crypto_type objects when allocating a tfm, a frontend and a backend. In fact this simply formalises what we've been doing behind the API's back. For example, as it stands crypto_alloc_ahash may use an actual ahash algorithm or a crypto_hash algorithm. Putting this in the API allows us to do this much more cleanly. The existing types will be converted across gradually. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: api - Move type exit function into crypto_tfmHerbert Xu
The type exit function needs to undo any allocations done by the type init function. However, the type init function may differ depending on the upper-level type of the transform (e.g., a crypto_blkcipher instantiated as a crypto_ablkcipher). So we need to move the exit function out of the lower-level structure and into crypto_tfm itself. As it stands this is a no-op since nobody uses exit functions at all. However, all cases where a lower-level type is instantiated as a different upper-level type (such as blkcipher as ablkcipher) will be converted such that they allocate the underlying transform and use that instead of casting (e.g., crypto_ablkcipher casted into crypto_blkcipher). That will need to use a different exit function depending on the upper-level type. This patch also allows the type init/exit functions to call (or not) cra_init/cra_exit instead of always calling them from the top level. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Use test infrastructureHerbert Xu
This patch makes use of the new testing infrastructure by requiring algorithms to pass a run-time test before they're made available to users. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Move ahash functions into crypto/hash.hHerbert Xu
All new crypto interfaces should go into individual files as much as possible in order to ensure that crypto.h does not collapse under its own weight. This patch moves the ahash code into crypto/hash.h and crypto/internal/hash.h respectively. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Removed vestigial ahash fieldsHerbert Xu
The base field in ahash_tfm appears to have been cut-n-pasted from ablkcipher. It isn't needed here at all. Similarly, the info field in ahash_request also appears to have originated from its cipher counter-part and is vestigial. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] hash: Add asynchronous hash supportLoc Ho
This patch adds asynchronous hash and digest support. Signed-off-by: Loc Ho <lho@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] api: Make the crypto subsystem fully modularSebastian Siewior
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] api: Set default CRYPTO_MINALIGN to unsigned long longHerbert Xu
Thanks to David Miller for pointing out that the SLAB (or SLOB/SLUB) cache uses the alignment of unsigned long long if the architecture kmalloc/slab alignment macros are not defined. This patch changes the CRYPTO_MINALIGN so that it uses the same default value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Create default givcipher instancesHerbert Xu
This patch makes crypto_alloc_aead always return algorithms that is capable of generating their own IVs through givencrypt and givdecrypt. All existing AEAD algorithms already do. New ones must either supply their own or specify a generic IV generator with the geniv field. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Add aead_geniv_alloc/aead_geniv_freeHerbert Xu
This patch creates the infrastructure to help the construction of IV generator templates that wrap around AEAD algorithms by adding an IV generator to them. This is useful for AEAD algorithms with no built-in IV generator or to replace their built-in generator. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Add givcrypt operationsHerbert Xu
This patch adds the underlying givcrypt operations for aead and associated support elements. The rationale is identical to that of the skcipher givcrypt operations, i.e., sometimes only the algorithm knows how the IV should be generated. A new request type aead_givcrypt_request is added which contains an embedded aead_request structure with two new elements to support this operation. The new elements are seq and giv. The seq field should contain a strictly increasing 64-bit integer which may be used by certain IV generators as an input value. The giv field will be used to store the generated IV. It does not need to obey the alignment requirements of the algorithm because it's not used during the operation. The existing iv field must still be available as it will be used to store intermediate IVs and the output IV if chaining is desired. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] skcipher: Create default givcipher instancesHerbert Xu
This patch makes crypto_alloc_ablkcipher/crypto_grab_skcipher always return algorithms that are capable of generating their own IVs through givencrypt and givdecrypt. Each algorithm may specify its default IV generator through the geniv field. For algorithms that do not set the geniv field, the blkcipher layer will pick a default. Currently it's chainiv for synchronous algorithms and eseqiv for asynchronous algorithms. Note that if these wrappers do not work on an algorithm then that algorithm must specify its own geniv or it can't be used at all. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] skcipher: Add skcipher_geniv_alloc/skcipher_geniv_freeHerbert Xu
This patch creates the infrastructure to help the construction of givcipher templates that wrap around existing blkcipher/ablkcipher algorithms by adding an IV generator to them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] skcipher: Added geniv fieldHerbert Xu
This patch introduces the geniv field which indicates the default IV generator for each algorithm. It should point to a string that is not freed as long as the algorithm is registered. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] skcipher: Add givcrypt operations and givcipher typeHerbert Xu
Different block cipher modes have different requirements for intialisation vectors. For example, CBC can use a simple randomly generated IV while modes such as CTR must use an IV generation mechanisms that give a stronger guarantee on the lack of collisions. Furthermore, disk encryption modes have their own IV generation algorithms. Up until now IV generation has been left to the users of the symmetric key cipher API. This is inconvenient as the number of block cipher modes increase because the user needs to be aware of which mode is supposed to be paired with which IV generation algorithm. Therefore it makes sense to integrate the IV generation into the crypto API. This patch takes the first step in that direction by creating two new ablkcipher operations, givencrypt and givdecrypt that generates an IV before performing the actual encryption or decryption. The operations are currently not exposed to the user. That will be done once the underlying functionality has actually been implemented. It also creates the underlying givcipher type. Algorithms that directly generate IVs would use it instead of ablkcipher. All other algorithms (including all existing ones) would generate a givcipher algorithm upon registration. This givcipher algorithm will be constructed from the geniv string that's stored in every algorithm. That string will locate a template which is instantiated by the blkcipher/ablkcipher algorithm in question to give a givcipher algorithm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] skcipher: Add crypto_grab_skcipher interfaceHerbert Xu
Note: From now on the collective of ablkcipher/blkcipher/givcipher will be known as skcipher, i.e., symmetric key cipher. The name blkcipher has always been much of a misnomer since it supports stream ciphers too. This patch adds the function crypto_grab_skcipher as a new way of getting an ablkcipher spawn. The problem is that previously we did this in two steps, first getting the algorithm and then calling crypto_init_spawn. This meant that each spawn user had to be aware of what type and mask to use for these two steps. This is difficult and also presents a problem when the type/mask changes as they're about to be for IV generators. The new interface does both steps together just like crypto_alloc_ablkcipher. As a side-effect this also allows us to be stronger on type enforcement for spawns. For now this is only done for ablkcipher but it's trivial to extend for other types. This patch also moves the type/mask logic for skcipher into the helpers crypto_skcipher_type and crypto_skcipher_mask. Finally this patch introduces the function crypto_require_sync to determine whether the user is specifically requesting a sync algorithm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] api: Sanitise mask when allocating ablkcipher/hashHerbert Xu
When allocating ablkcipher/hash objects, we use a mask that's wider than the usual type mask. This patch sanitises the mask supplied by the user so we don't end up using a narrower mask which may lead to unintended results. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Make authsize a run-time parameterHerbert Xu
As it is authsize is an algorithm paramter which cannot be changed at run-time. This is inconvenient because hardware that implements such algorithms would have to register each authsize that they support separately. Since authsize is a property common to all AEAD algorithms, we can add a function setauthsize that sets it at run-time, just like setkey. This patch does exactly that and also changes authenc so that authsize is no longer a parameter of its template. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ablkcipher: Add distinct ABLKCIPHER typeHerbert Xu
Up until now we have ablkcipher algorithms have been identified as type BLKCIPHER with the ASYNC bit set. This is suboptimal because ablkcipher refers to two things. On the one hand it refers to the top-level ablkcipher interface with requests. On the other hand it refers to and algorithm type underneath. As it is you cannot request a synchronous block cipher algorithm with the ablkcipher interface on top. This is a problem because we want to be able to eventually phase out the blkcipher top-level interface. This patch fixes this by making ABLKCIPHER its own type, just as we have distinct types for HASH and DIGEST. The type it associated with the algorithm implementation only. Which top-level interface is used for synchronous block ciphers is then determined by the mask that's used. If it's a specific mask then the old blkcipher interface is given, otherwise we go with the new ablkcipher interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-19crypto: convert crypto.h to UTF-8John Anthony Kazos Jr
Convert the encoding of <include/linux/crypto.h> from ISO-8859-1 to UTF-8. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10[CRYPTO] api: Fixed crypto_*_reqsize return typeHerbert Xu
This patch changes the return type of crypto_*_reqsize from int to unsigned int which matches what the underlying type is (and should be). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] ablkcipher: Remove queue pointer from common alg objectHerbert Xu
Since not everyone needs a queue pointer and those who need it can always get it from the context anyway the queue pointer in the common alg object is redundant. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] api: Add support for multiple template parametersHerbert Xu
This patch adds support for having multiple parameters to a template, separated by a comma. It also adds support for integer parameters in addition to the current algorithm parameter type. This will be used by the authenc template which will have four parameters: the authentication algorithm, the encryption algorithm, the authentication size and the encryption key length. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] api: Add aead crypto typeHerbert Xu
This patch adds crypto_aead which is the interface for AEAD (Authenticated Encryption with Associated Data) algorithms. AEAD algorithms perform authentication and encryption in one step. Traditionally users (such as IPsec) would use two different crypto algorithms to perform these. With AEAD this comes down to one algorithm and one operation. Of course if traditional algorithms were used we'd still be doing two operations underneath. However, real AEAD algorithms may allow the underlying operations to be optimised as well. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-07-11[CRYPTO] cipher: Remove obsolete fields from cipher_tfmHerbert Xu
This removes all the unused block cipher fields from cipher_tfm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] api: Add ablkcipher_request_set_tfmHerbert Xu
This patch adds ablkcipher_request_set_tfm for those users that need to manage the memory for ablkcipher requests directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] api: Add async blkcipher typeHerbert Xu
This patch adds the mid-level interface for asynchronous block ciphers. It also includes a generic queueing mechanism that can be used by other asynchronous crypto operations in future. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] templates: Pass type/mask when creating instancesHerbert Xu
This patch passes the type/mask along when constructing instances of templates. This is in preparation for templates that may support multiple types of instances depending on what is requested. For example, the planned software async crypto driver will use this construct. For the moment this allows us to check whether the instance constructed is of the correct type and avoid returning success if the type does not match. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
