path: root/include/linux/davinci_emac.h
2011-03-22net: davinci_emac:Fix translation logic for buffer descriptorSriram
With recent changes to the driver(switch to new cpdma layer), the support for buffer descriptor address translation logic is broken. This affects platforms where the physical address of the descriptors as seen by the DMA engine is different from the physical address. Original Patch adding translation logic support: Commit: ad021ae8862209864dc8ebd3b7d3a55ce84b9ea2 Signed-off-by: Sriramakrishnan A G <srk@ti.com> Tested-By: Sekhar Nori <nsekhar@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-24net: davinci_emac: cleanup unused mdio emac codeCyril Chemparathy
This patch removes code that has been rendered useless by the previous patches in this series. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24net: davinci_emac: switch to new mdioCyril Chemparathy
This patch switches the emac implementation over to the newly separated MDIO driver. With this, the mdio bus frequency defaults to a safe 2.2MHz. Boards may optionally specify a bus frequency via platform data. The phy identification scheme has been modified to use a phy bus id instead of a mask. This largely serves to eliminate the "phy search" code in emac init. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24net: davinci_emac: separate out davinci mdioCyril Chemparathy
Davinci's MDIO controller is present on other TI devices, without an accompanying EMAC. For example, on tnetv107x, the same MDIO module is used in conjunction with a 3-port switch hardware. By separating the MDIO controller code into its own platform driver, this patch allows common logic to be reused on such platforms. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04TI Davinci EMAC : Abstract Buffer address translation logic.Sriramakrishnan
When programming the DMA engine, the next pointers must be programmed with physical address as seen from the DMA master address space. This address may be different from physical address of the buffer RAM area. This patch abstracts the buffer address translation logic. Signed-off-by: Sriramakrishnan <srk@ti.com> Acked-by: Chaithrika U S <chaithrika@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04TI Davinci EMAC : add platform specific interrupt enable/disable logic.Sriramakrishnan
On certain SOCs, the EMAC controller is interfaced with a wrapper logic for handling interrupts. This patch implements a platform specific hook to cater to platforms that require custom interrupt handling logic Signed-off-by: Sriramakrishnan <srk@ti.com> Acked-by: Chaithrika U S <chaithrika@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04TI Davinci EMAC : Re-use driver for other platforms.Sriramakrishnan
The davinci EMAC peripheral is also available on other TI platforms -notably TI AM3517 SoC. This patch modifies the config option and the platform structure header files so that the driver can be reused on non-davinci platforms as well. Signed-off-by: Sriramakrishnan <srk@ti.com> Acked-by: Chaithrika U S <chaithrika@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
