path: root/include/linux/dcookies.h
2011-01-10headers: path.h reduxAlexey Dobriyan
Remove path.h from sched.h and other files. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make get_dcookie() use a struct path argumentJan Blunck
get_dcookie() is always called with a dentry and a vfsmount from a struct path. Make get_dcookie() take it directly as an argument. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[CELL] oprofile: add support to OProfile for profiling CELL BE SPUsBob Nelson
From: Maynard Johnson <mpjohn@us.ibm.com> This patch updates the existing arch/powerpc/oprofile/op_model_cell.c to add in the SPU profiling capabilities. In addition, a 'cell' subdirectory was added to arch/powerpc/oprofile to hold Cell-specific SPU profiling code. Exports spu_set_profile_private_kref and spu_get_profile_private_kref which are used by OProfile to store private profile information in spufs data structures. Also incorporated several fixes from other patches (rrn). Check pointer returned from kzalloc. Eliminated unnecessary cast. Better error handling and cleanup in the related area. 64-bit unsigned long parameter was being demoted to 32-bit unsigned int and eventually promoted back to unsigned long. Signed-off-by: Carl Love <carll@us.ibm.com> Signed-off-by: Maynard Johnson <mpjohn@us.ibm.com> Signed-off-by: Bob Nelson <rrnelson@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-08-01[PATCH] include/linux/dcookies.h: dummy functions must be "static inline"Adrian Bunk
We don't want these to be global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
