path: root/include/linux/debug_locks.h
2010-08-17lockdep: Remove __debug_show_held_locksJohn Kacur
There is no longer any functional difference between __debug_show_held_locks() and debug_show_held_locks(), so remove the former. Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1281021054-4228-1-git-send-email-jkacur@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14lockdep: warn about lockdep disabling after kernel taint, fixIngo Molnar
Impact: build fix for Sparc and s390 Stephen Rothwell reported that the Sparc build broke: In file included from kernel/panic.c:12: include/linux/debug_locks.h: In function '__debug_locks_off': include/linux/debug_locks.h:15: error: implicit declaration of function 'xchg' due to: 9eeba61: lockdep: warn about lockdep disabling after kernel taint There is some inconsistency between architectures about where exactly xchg() is defined. The traditional place is in system.h but the more logical point for it is in atomic.h - where most architectures (especially new ones) have it defined. These architecture also still offer it via system.h. Some, such as Sparc or s390 only have it in asm/system.h and not available via asm/atomic.h at all. Use the widest set of headers in debug_locks.h and also include asm/system.h. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20090414144317.026498df.sfr@canb.auug.org.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-12lockdep: warn about lockdep disabling after kernel taintFrederic Weisbecker
Impact: provide useful missing info for developers Kernel taint can occur in several situations such as warnings, load of prorietary or staging modules, bad page, etc... But when such taint happens, a developer might still be working on the kernel, expecting that lockdep is still enabled. But a taint disables lockdep without ever warning about it. Such a kernel behaviour doesn't really help for kernel development. This patch adds this missing warning. Since the taint is done most of the time after the main message that explain the real source issue, it seems safe to warn about it inside add_taint() so that it appears at last, without hurting the main information. v2: Use a generic helper to disable lockdep instead of an open coded xchg(). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1239412638-6739-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-12lock debug: sit tight when we are already in a panicAndrew Morton
in: > http://bugzilla.kernel.org/show_bug.cgi?id=11543 The panic code called the kexec code which called mutex_trylock() which called spin_lock_mutex() which then stupidly went and blurted a load of debug stuff because of in_interrupt(). Keep the lock debug code from escallating an already crappy situation. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-05Move _RET_IP_ and _THIS_IP_ to include/linux/kernel.hEduard - Gabriel Munteanu
These two macros are useful beyond lock debugging. Moved definitions from include/linux/debug_locks.h to include/linux/kernel.h, so code that needs them does not have to include the former, which would have been a less intuitive choice of a header. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25softlockup: automatically detect hung TASK_UNINTERRUPTIBLE tasksIngo Molnar
this patch extends the soft-lockup detector to automatically detect hung TASK_UNINTERRUPTIBLE tasks. Such hung tasks are printed the following way: ------------------> INFO: task prctl:3042 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message prctl D fd5e3793 0 3042 2997 f6050f38 00000046 00000001 fd5e3793 00000009 c06d8264 c06dae80 00000286 f6050f40 f6050f00 f7d34d90 f7d34fc8 c1e1be80 00000001 f6050000 00000000 f7e92d00 00000286 f6050f18 c0489d1a f6050f40 00006605 00000000 c0133a5b Call Trace: [<c04883a5>] schedule_timeout+0x6d/0x8b [<c04883d8>] schedule_timeout_uninterruptible+0x15/0x17 [<c0133a76>] msleep+0x10/0x16 [<c0138974>] sys_prctl+0x30/0x1e2 [<c0104c52>] sysenter_past_esp+0x5f/0xa5 ======================= 2 locks held by prctl/3042: #0: (&sb->s_type->i_mutex_key#5){--..}, at: [<c0197d11>] do_fsync+0x38/0x7a #1: (jbd_handle){--..}, at: [<c01ca3d2>] journal_start+0xc7/0xe9 <------------------ the current default timeout is 120 seconds. Such messages are printed up to 10 times per bootup. If the system has crashed already then the messages are not printed. if lockdep is enabled then all held locks are printed as well. this feature is a natural extension to the softlockup-detector (kernel locked up without scheduling) and to the NMI watchdog (kernel locked up with IRQs disabled). [ Gautham R Shenoy <ego@in.ibm.com>: CPU hotplug fixes. ] [ Andrew Morton <akpm@linux-foundation.org>: build warning fix. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2006-12-22[PATCH] lock debugging: fix DEBUG_LOCKS_WARN_ON() & debug_locks_silentIngo Molnar
Matthew Wilcox noticed that the debug_locks_silent use should be inverted in DEBUG_LOCKS_WARN_ON(). This bug was causing spurious stacktraces and incorrect failures in the locking self-test on the parisc kernel. Bug-found-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: show more details about self-test failuresIngo Molnar
Make the locking self-test failures (of 'FAILURE' type) easier to debug by printing more information. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] Need forward decl of task_struct in linux/debug_locks.hKyle McMartin
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-08-06[PATCH] debug_locks.h: add "struct task_struct;"Alexey Dobriyan
Removes many, many "declared inside parameter list" warnings on parisc. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: better lock debuggingIngo Molnar
Generic lock debugging: - generalized lock debugging framework. For example, a bug in one lock subsystem turns off debugging in all lock subsystems. - got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from the mutex/rtmutex debugging code: it caused way too much prototype hackery, and lockdep will give the same information anyway. - ability to do silent tests - check lock freeing in vfree too. - more finegrained debugging options, to allow distributions to turn off more expensive debugging features. There's no separate 'held mutexes' list anymore - but there's a 'held locks' stack within lockdep, which unifies deadlock detection across all lock classes. (this is independent of the lockdep validation stuff - lockdep first checks whether we are holding a lock already) Here are the current debugging options: CONFIG_DEBUG_MUTEXES=y CONFIG_DEBUG_LOCK_ALLOC=y which do: config DEBUG_MUTEXES bool "Mutex debugging, basic checks" config DEBUG_LOCK_ALLOC bool "Detect incorrect freeing of live mutexes" Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
