[ Upstream commit 4df2bf466a9c9c92f40d27c4aa9120f4e8227bfc ]
Otherwise loading a "snapshot" table using the same device for the
origin and COW devices, e.g.:
echo "0 20971520 snapshot 253:3 253:3 P 8" | dmsetup create snap
will trigger:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000098
[ 1958.979934] IP: [<ffffffffa040efba>] dm_exception_store_set_chunk_size+0x7a/0x110 [dm_snapshot]
[ 1958.989655] PGD 0
[ 1958.991903] Oops: 0000 [#1] SMP
[ 1959.059647] CPU: 9 PID: 3556 Comm: dmsetup Tainted: G IO 4.5.0-rc5.snitm+ #150
[ 1959.083517] task: ffff8800b9660c80 ti: ffff88032a954000 task.ti: ffff88032a954000
[ 1959.091865] RIP: 0010:[<ffffffffa040efba>] [<ffffffffa040efba>] dm_exception_store_set_chunk_size+0x7a/0x110 [dm_snapshot]
[ 1959.104295] RSP: 0018:ffff88032a957b30 EFLAGS: 00010246
[ 1959.110219] RAX: 0000000000000000 RBX: 0000000000000008 RCX: 0000000000000001
[ 1959.118180] RDX: 0000000000000000 RSI: 0000000000000008 RDI: ffff880329334a00
[ 1959.126141] RBP: ffff88032a957b50 R08: 0000000000000000 R09: 0000000000000001
[ 1959.134102] R10: 000000000000000a R11: f000000000000000 R12: ffff880330884d80
[ 1959.142061] R13: 0000000000000008 R14: ffffc90001c13088 R15: ffff880330884d80
[ 1959.150021] FS: 00007f8926ba3840(0000) GS:ffff880333440000(0000) knlGS:0000000000000000
[ 1959.159047] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1959.165456] CR2: 0000000000000098 CR3: 000000032f48b000 CR4: 00000000000006e0
[ 1959.173415] Stack:
[ 1959.175656] ffffc90001c13040 ffff880329334a00 ffff880330884ed0 ffff88032a957bdc
[ 1959.183946] ffff88032a957bb8 ffffffffa040f225 ffff880329334a30 ffff880300000000
[ 1959.192233] ffffffffa04133e0 ffff880329334b30 0000000830884d58 00000000569c58cf
[ 1959.200521] Call Trace:
[ 1959.203248] [<ffffffffa040f225>] dm_exception_store_create+0x1d5/0x240 [dm_snapshot]
[ 1959.211986] [<ffffffffa040d310>] snapshot_ctr+0x140/0x630 [dm_snapshot]
[ 1959.219469] [<ffffffffa0005c44>] ? dm_split_args+0x64/0x150 [dm_mod]
[ 1959.226656] [<ffffffffa0005ea7>] dm_table_add_target+0x177/0x440 [dm_mod]
[ 1959.234328] [<ffffffffa0009203>] table_load+0x143/0x370 [dm_mod]
[ 1959.241129] [<ffffffffa00090c0>] ? retrieve_status+0x1b0/0x1b0 [dm_mod]
[ 1959.248607] [<ffffffffa0009e35>] ctl_ioctl+0x255/0x4d0 [dm_mod]
[ 1959.255307] [<ffffffff813304e2>] ? memzero_explicit+0x12/0x20
[ 1959.261816] [<ffffffffa000a0c3>] dm_ctl_ioctl+0x13/0x20 [dm_mod]
[ 1959.268615] [<ffffffff81215eb6>] do_vfs_ioctl+0xa6/0x5c0
[ 1959.274637] [<ffffffff81120d2f>] ? __audit_syscall_entry+0xaf/0x100
[ 1959.281726] [<ffffffff81003176>] ? do_audit_syscall_entry+0x66/0x70
[ 1959.288814] [<ffffffff81216449>] SyS_ioctl+0x79/0x90
[ 1959.294450] [<ffffffff8167e4ae>] entry_SYSCALL_64_fastpath+0x12/0x71
[ 1959.323277] RIP [<ffffffffa040efba>] dm_exception_store_set_chunk_size+0x7a/0x110 [dm_snapshot]
[ 1959.333090] RSP <ffff88032a957b30>
[ 1959.336978] CR2: 0000000000000098
[ 1959.344121] ---[ end trace b049991ccad1169e ]---
Fixes: https://bugzilla.redhat.com/show_bug.cgi?id=1195899
Cc: stable@vger.kernel.org
Signed-off-by: Ding Xiang <dingxiang@huawei.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
There is no need for DM to export a wrapper around the already exported
blk_lld_busy().
The "dm snapshot: suspend origin when doing exception handover" commit
fixed a exception store handover bug associated with pending exceptions
to the "snapshot-origin" target.
However, a similar problem exists in snapshot merging. When snapshot
merging is in progress, we use the target "snapshot-merge" instead of
"snapshot-origin". Consequently, during exception store handover, we
must find the snapshot-merge target and suspend its associated
mapped_device.
To avoid lockdep warnings, the target must be suspended and resumed
without holding _origins_lock.
Introduce a dm_hold() function that grabs a reference on a
mapped_device, but unlike dm_get(), it doesn't crash if the device has
the DMF_FREEING flag set, it returns an error in this case.
In snapshot_resume() we grab the reference to the origin device using
dm_hold() while holding _origins_lock (_origins_lock guarantees that the
device won't disappear). Then we release _origins_lock, suspend the
device and grab _origins_lock again.
NOTE to stable@ people:
When backporting to kernels 3.18 and older, use dm_internal_suspend and
dm_internal_resume instead of dm_internal_suspend_fast and
dm_internal_resume_fast.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
For blk-mq request-based DM the responsibility of allocating a cloned
request is transfered from DM core to the target type. Doing so
enables the cloned request to be allocated from the appropriate
blk-mq request_queue's pool (only the DM target, e.g. multipath, can
know which block device to send a given cloned request to).
Care was taken to preserve compatibility with old-style block request
completion that requires request-based DM _not_ acquire the clone
request's queue lock in the completion path. As such, there are now 2
different request-based DM target_type interfaces:
1) the original .map_rq() interface will continue to be used for
non-blk-mq devices -- the preallocated clone request is passed in
from DM core.
2) a new .clone_and_map_rq() and .release_clone_rq() will be used for
blk-mq devices -- blk_get_request() and blk_put_request() are used
respectively from these hooks.
dm_table_set_type() was updated to detect if the request-based target is
being stacked on blk-mq devices, if so DM_TYPE_MQ_REQUEST_BASED is set.
DM core disallows switching the DM table's type after it is set. This
means that there is no mixing of non-blk-mq and blk-mq devices within
the same request-based DM table.
[This patch was started by Keith and later heavily modified by Mike]
Tested-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Keith Busch <keith.busch@intel.com>
Remove exports for dm_dispatch_request, dm_requeue_unmapped_request,
and dm_kill_unmapped_request.
The DM thin-pool target now must undo the changes performed during
pool_presuspend() so introduce presuspend_undo hook in target_type.
Acked-by: Joe Thornber <ejt@redhat.com>
There is no need for code other than DM core to use dm_set_device_limits
so remove its EXPORT_SYMBOL_GPL. Also, cleanup a couple whitespace nits.
The function dm_accept_partial_bio allows the target to specify how many
sectors of the current bio it will process. If the target only wants to
accept part of the bio, it calls dm_accept_partial_bio and the DM core
sends the rest of the data in next bio.
Introduce dm_table_run_md_queue_async() to run the request_queue of the
mapped_device associated with a request-based DM table.
Also add dm_md_get_queue() wrapper to extract the request_queue from a
mapped_device.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Remove dm_get_mapinfo() because no target uses it. Targets can allocate
per-bio data using ti->per_bio_data_size, this is much more flexible
than union map_info.
Leave union map_info only for the request-based multipath target's use.
Also delete the unused "unsigned long long ll" field of union map_info.
Workaround the SCSI layer's problematic WRITE SAME heuristics by
disabling WRITE SAME in the DM multipath device's queue_limits if an
underlying device disabled it.
The WRITE SAME heuristics, with both the original commit 5db44863b6eb
("[SCSI] sd: Implement support for WRITE SAME") and the updated commit
66c28f971 ("[SCSI] sd: Update WRITE SAME heuristics"), default to enabling
WRITE SAME(10) even without successfully determining it is supported.
After the first failed WRITE SAME the SCSI layer will disable WRITE SAME
for the device (by setting sdkp->device->no_write_same which results in
'max_write_same_sectors' in device's queue_limits to be set to 0).
When a device is stacked ontop of such a SCSI device any changes to that
SCSI device's queue_limits do not automatically propagate up the stack.
As such, a DM multipath device will not have its WRITE SAME support
disabled. This causes the block layer to continue to issue WRITE SAME
requests to the mpath device which causes paths to fail and (if mpath IO
isn't configured to queue when no paths are available) it will result in
actual IO errors to the upper layers.
This fix doesn't help configurations that have additional devices
stacked ontop of the mpath device (e.g. LVM created linear DM devices
ontop). A proper fix that restacks all the queue_limits from the bottom
of the device stack up will need to be explored if SCSI will continue to
use this model of optimistically allowing op codes and then disabling
them after they fail for the first time.
Before this patch:
EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
device-mapper: multipath: XXX snitm debugging: got -EREMOTEIO (-121)
device-mapper: multipath: XXX snitm debugging: failing WRITE SAME IO with error=-121
end_request: critical target error, dev dm-6, sector 528
dm-6: WRITE SAME failed. Manually zeroing.
device-mapper: multipath: Failing path 8:112.
end_request: I/O error, dev dm-6, sector 4616
end_request: I/O error, dev dm-6, sector 5640
end_request: I/O error, dev dm-6, sector 6664
end_request: I/O error, dev dm-6, sector 7688
end_request: I/O error, dev dm-6, sector 524288
Buffer I/O error on device dm-6, logical block 65536
lost page write due to I/O error on dm-6
JBD2: Error -5 detected when updating journal superblock for dm-6-8.
end_request: I/O error, dev dm-6, sector 524296
Aborting journal on device dm-6-8.
# cat /sys/block/sdh/queue/write_same_max_bytes
0
# cat /sys/block/dm-6/queue/write_same_max_bytes
33553920
After this patch:
device-mapper: multipath: XXX snitm debugging: WRITE SAME I/O failed with error=-121
0
0
It should be noted that WRITE SAME support wasn't enabled in DM
multipath until v3.10.
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: stable@vger.kernel.org # 3.10+
Support the collection of I/O statistics on user-defined regions of
a DM device. If no regions are defined no statistics are collected so
there isn't any performance impact. Only bio-based DM devices are
currently supported.
Each user-defined region specifies a starting sector, length and step.
Individual statistics will be collected for each step-sized area within
the range specified.
The I/O statistics counters for each step-sized area of a region are
in the same format as /sys/block/*/stat or /proc/diskstats but extra
counters (12 and 13) are provided: total time spent reading and
writing in milliseconds. All these counters may be accessed by sending
the @stats_print message to the appropriate DM device via dmsetup.
The creation of DM statistics will allocate memory via kmalloc or
fallback to using vmalloc space. At most, 1/4 of the overall system
memory may be allocated by DM statistics. The admin can see how much
memory is used by reading
/sys/module/dm_mod/parameters/stats_current_allocated_bytes
See Documentation/device-mapper/statistics.txt for more details.
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This patch removes "io_lock" and "map_lock" in struct mapped_device and
"holders" in struct dm_table and replaces these mechanisms with
sleepable-rcu.
Previously, the code would call "dm_get_live_table" and "dm_table_put" to
get and release table. Now, the code is changed to call "dm_get_live_table"
and "dm_put_live_table". dm_get_live_table locks sleepable-rcu and
dm_put_live_table unlocks it.
dm_get_live_table_fast/dm_put_live_table_fast can be used instead of
dm_get_live_table/dm_put_live_table. These *_fast functions use
non-sleepable RCU, so the caller must not block between them.
If the code changes active or inactive dm table, it must call
dm_sync_table before destroying the old table.
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Document iterate_devices in device-mapper.h.
Add a num_write_bios function to struct target.
If an instance of a target sets this, it will be queried before the
target's mapping function is called on a write bio, and the response
controls the number of copies of the write bio that the target will
receive.
This provides a convenient way for a target to send the same data to
more than one device. The new cache target uses this in writethrough
mode, to send the data both to the cache and the backing device.
Use 'bio' in the name of variables and functions that deal with
bios rather than 'request' to avoid confusion with the normal
block layer use of 'request'.
No functional changes.
Avoid returning a truncated table or status string instead of setting
the DM_BUFFER_FULL_FLAG when the last target of a table fills the
buffer.
When processing a table or status request, the function retrieve_status
calls ti->type->status. If ti->type->status returns non-zero,
retrieve_status assumes that the buffer overflowed and sets
DM_BUFFER_FULL_FLAG.
However, targets don't return non-zero values from their status method
on overflow. Most targets returns always zero.
If a buffer overflow happens in a target that is not the last in the
table, it gets noticed during the next iteration of the loop in
retrieve_status; but if a buffer overflow happens in the last target, it
goes unnoticed and erroneously truncated data is returned.
In the current code, the targets behave in the following way:
* dm-crypt returns -ENOMEM if there is not enough space to store the
key, but it returns 0 on all other overflows.
* dm-thin returns errors from the status method if a disk error happened.
This is incorrect because retrieve_status doesn't check the error
code, it assumes that all non-zero values mean buffer overflow.
* all the other targets always return 0.
This patch changes the ti->type->status function to return void (because
most targets don't use the return code). Overflow is detected in
retrieve_status: if the status method fills up the remaining space
completely, it is assumed that buffer overflow happened.
This patch removes map_info from bio-based device mapper targets.
map_info is still used for request-based targets.
This patch moves target_request_nr from map_info to dm_target_io and
makes it accessible with dm_bio_get_target_request_nr.
This patch is a preparation for the next patch that removes map_info.
Introduce a field per_bio_data_size in struct dm_target.
Targets can set this field in the constructor. If a target sets this
field to a non-zero value, "per_bio_data_size" bytes of auxiliary data
are allocated for each bio submitted to the target. These data can be
used for any purpose by the target and help us improve performance by
removing some per-target mempools.
Per-bio data is accessed with dm_per_bio_data. The
argument data_size must be the same as the value per_bio_data_size in
dm_target.
If the target has a pointer to per_bio_data, it can get a pointer to
the bio with dm_bio_from_per_bio_data() function (data_size must be the
same as the value passed to dm_per_bio_data).
Allow targets to opt in to WRITE SAME support by setting
'num_write_same_requests' in the dm_target structure.
A dm device will only advertise WRITE SAME support if all its
targets and all its underlying devices support it.
Commit outstanding metadata before returning the status for a dm thin
pool so that the numbers reported are as up-to-date as possible.
The commit is not performed if the device is suspended or if
the DM_NOFLUSH_FLAG is supplied by userspace and passed to the target
through a new 'status_flags' parameter in the target's dm_status_fn.
The userspace dmsetup tool will support the --noflush flag with the
'dmsetup status' and 'dmsetup wait' commands from version 1.02.76
onwards.
Tested-by: Mike Snitzer <snitzer@redhat.com>
Use boolean bit fields for flags in struct dm_target.
Allow targets to override the 'supports flush' calculation.
Set 'flush_supported' if a target needs to receive flushes regardless of
whether or not its underlying devices have support.
Signed-off-by: Joe Thornber <ejt@redhat.com>
This patch introduces a new variable split_discard_requests. It can be
set by targets so that discard requests are split on max_io_len
boundaries.
When split_discard_requests is not set, discard requests are only split on
boundaries between targets, as was the case before this patch.
Remove the restriction that limits a target's specified maximum incoming
I/O size to be a power of 2.
Rename this setting from 'split_io' to the less-ambiguous 'max_io_len'.
Change it from sector_t to uint32_t, which is plenty big enough, and
introduce a wrapper function dm_set_target_max_io_len() to set it.
Use sector_div() to process it now that it is not necessarily a power of 2.
Remove unused dm_flush_fn .flush target method from header.
This was left-over from the FLUSH/FUA conversion and is no longer used.
Introduce DM_TARGET_IMMUTABLE to indicate that the target type cannot be mixed
with any other target type, and once loaded into a device, it cannot be
replaced with a table containing a different type.
The thin provisioning pool device will use this.
Add a target feature flag DM_TARGET_ALWAYS_WRITEABLE to indicate that a target
does not support read-only mode.
The initial implementation of the thin provisioning target uses this.
Introduce the concept of a singleton table which contains exactly one target.
If a target type sets the DM_TARGET_SINGLETON feature bit device-mapper
will ensure that any table that includes that target contains no others.
The thin provisioning pool target uses this.
printk_ratelimit() shares global ratelimiting state with all
other subsystems, so its usage is discouraged. Instead,
define and use dm's local state.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
If optional discard support in dm-crypt is enabled, discards requests
bypass the crypt queue and blocks of the underlying device are discarded.
For the read path, discarded blocks are handled the same as normal
ciphertext blocks, thus decrypted.
So if the underlying device announces discarded regions return zeroes,
dm-crypt must disable this flag because after decryption there is just
random noise instead of zeroes.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Move multipath target argument parsing code into dm-table so other
targets can share it.
Permit a target to support discards regardless of whether or not all its
underlying devices do.
Now that unplugging is done differently, the unplug_fn callback is
never called, so it can be completely discarded.
Signed-off-by: NeilBrown <neilb@suse.de>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Add per-target unplug callback support.
Cc: linux-raid@vger.kernel.org
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
DM currently implements congestion checking by checking on congestion
in each component device. For raid456 we need to also check if the
stripe cache is congested.
Add per-target congestion checker callback support.
Extending the target_callbacks structure with additional callback
functions allows for establishing multiple callbacks per-target (a
callback is also needed for unplug).
Split max_io_len_target_boundary out of max_io_len so that the discard
support can make use of it without duplicating max_io_len code.
Avoiding max_io_len's split_io logic enables DM's discard support to
submit the entire discard request to a target. But discards must still
be split on target boundaries.
Allow discards to be passed through to linear mappings if at least one
underlying device supports it. Discards will be forwarded only to
devices that support them.
A target that supports discards should set num_discard_requests to
indicate how many times each discard request must be submitted to it.
Verify table's underlying devices support discards prior to setting the
associated DM device as capable of discards (via QUEUE_FLAG_DISCARD).
Reviewed-by: Joe Thornber <thornber@redhat.com>
'target_request_nr' is a more generic name that reflects the fact that
it will be used for both flush and discard support.
Remove unused parameters(start and len) of dm_get_device()
and fix the callers.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
This patch adds the exported dm_suspended() function so that targets
can check whether or not they are suspended.
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Cc: Mike Anderson <andmike@linux.vnet.ibm.com>
This patch renames dm_suspended() to dm_suspended_md() and
keeps it internal to dm.
No functional change.
When swapping a new table into place, retain the old table until
its replacement is in place.
An old check for an empty table is removed because this is enforced
in populate_table().
__unbind() becomes redundant when followed by __bind().
Rename dm_get_table to dm_get_live_table.
Set sensible I/O hints for striped DM devices in the topology
infrastructure added for 2.6.31 for userspace tools to
obtain via sysfs.
Add .io_hints to 'struct target_type' to allow the I/O hints portion
(io_min and io_opt) of the 'struct queue_limits' to be set by each
target and implement this for dm-stripe.
Incorrect device area lengths are being passed to device_area_is_valid().
The regression appeared in 2.6.31-rc1 through commit
754c5fc7ebb417b23601a6222a6005cc2e7f2913.
With the dm-stripe target, the size of the target (ti->len) was used
instead of the stripe_width (ti->len/#stripes). An example of a
consequent incorrect error message is:
device-mapper: table: 254:0: sdb too small for target
This patch adds core functions for request-based dm.
When struct mapped device (md) is initialized, md->queue has
an I/O scheduler and the following functions are used for
request-based dm as the queue functions:
make_request_fn: dm_make_request()
pref_fn: dm_prep_fn()
request_fn: dm_request_fn()
softirq_done_fn: dm_softirq_done()
lld_busy_fn: dm_lld_busy()
Actual initializations are done in another patch (PATCH 2).
Below is a brief summary of how request-based dm behaves, including:
- making request from bio
- cloning, mapping and dispatching request
- completing request and bio
- suspending md
- resuming md
bio to request
md->queue->make_request_fn() (dm_make_request()) calls __make_request()
for a bio submitted to the md.
Then, the bio is kept in the queue as a new request or merged into
another request in the queue if possible.
Cloning and Mapping
Cloning and mapping are done in md->queue->request_fn() (dm_request_fn()),
when requests are dispatched after they are sorted by the I/O scheduler.
dm_request_fn() checks busy state of underlying devices using
target's busy() function and stops dispatching requests to keep them
on the dm device's queue if busy.
It helps better I/O merging, since no merge is done for a request
once it is dispatched to underlying devices.
Actual cloning and mapping are done in dm_prep_fn() and map_request()
called from dm_request_fn().
dm_prep_fn() clones not only request but also bios of the request
so that dm can hold bio completion in error cases and prevent
the bio submitter from noticing the error.
(See the "Completion" section below for details.)
After the cloning, the clone is mapped by target's map_rq() function
and inserted to underlying device's queue using
blk_insert_cloned_request().
Completion
Request completion can be hooked by rq->end_io(), but then, all bios
in the request will have been completed even error cases, and the bio
submitter will have noticed the error.
To prevent the bio completion in error cases, request-based dm clones
both bio and request and hooks both bio->bi_end_io() and rq->end_io():
bio->bi_end_io(): end_clone_bio()
rq->end_io(): end_clone_request()
Summary of the request completion flow is below:
blk_end_request() for a clone request
=> blk_update_request()
=> bio->bi_end_io() == end_clone_bio() for each clone bio
=> Free the clone bio
=> Success: Complete the original bio (blk_update_request())
Error: Don't complete the original bio
=> blk_finish_request()
=> rq->end_io() == end_clone_request()
=> blk_complete_request()
=> dm_softirq_done()
=> Free the clone request
=> Success: Complete the original request (blk_end_request())
Error: Requeue the original request
end_clone_bio() completes the original request on the size of
the original bio in successful cases.
Even if all bios in the original request are completed by that
completion, the original request must not be completed yet to keep
the ordering of request completion for the stacking.
So end_clone_bio() uses blk_update_request() instead of
blk_end_request().
In error cases, end_clone_bio() doesn't complete the original bio.
It just frees the cloned bio and gives over the error handling to
end_clone_request().
end_clone_request(), which is called with queue lock held, completes
the clone request and the original request in a softirq context
(dm_softirq_done()), which has no queue lock, to avoid a deadlock
issue on submission of another request during the completion:
- The submitted request may be mapped to the same device
- Request submission requires queue lock, but the queue lock
has been held by itself and it doesn't know that
The clone request has no clone bio when dm_softirq_done() is called.
So target drivers can't resubmit it again even error cases.
Instead, they can ask dm core for requeueing and remapping
the original request in that cases.
suspend
Request-based dm uses stopping md->queue as suspend of the md.
For noflush suspend, just stops md->queue.
For flush suspend, inserts a marker request to the tail of md->queue.
And dispatches all requests in md->queue until the marker comes to
the front of md->queue. Then, stops dispatching request and waits
for the all dispatched requests to complete.
After that, completes the marker request, stops md->queue and
wake up the waiter on the suspend queue, md->wait.
resume
Starts md->queue.
Currently, device-mapper maintains a separate instance of 'struct
queue_limits' for each table of each device. When the configuration of
a device is to be changed, first its table is loaded and this structure
is populated, then the device is 'resumed' and the calculated
queue_limits are applied.
This places restrictions on how userspace may process related devices,
where it is often advantageous to 'load' tables for several devices
at once before 'resuming' them together. As the new queue_limits
only take effect after the 'resume', if they are changing and one
device uses another, the latter must be 'resumed' before the former
may be 'loaded'.
This patch moves the calculation of these queue_limits out of
the 'load' operation into 'resume'. Since we are no longer
pre-calculating this struct, we no longer need to maintain copies
within our dm structs.
dm_set_device_limits() now passes the 'start' of the device's
data area (aka pe_start) as the 'offset' to blk_stack_limits().
init_valid_queue_limits() is replaced by blk_set_default_limits().
Cc: martin.petersen@oracle.com
