path: root/include/linux/devpts_fs.h
2008-10-13Add an instance parameter devpts interfacesSukadev Bhattiprolu
Pass-in 'inode' or 'tty' parameter to devpts interfaces. With multiple devpts instances, these parameters will be used in subsequent patches to identify the instance of devpts mounted. The parameters also help simplify devpts implementation. Changelog[v3]: - minor changes due to merge with ttydev updates - rename parameters to emphasize they are ptmx or pts inodes - pass-in tty_struct * to devpts_pty_kill() (this will help cleanup the get_node() call in a subsequent patch) Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30devpts: factor out PTY index allocationSukadev Bhattiprolu
Factor out the code used to allocate/free a pts index into new interfaces, devpts_new_index() and devpts_kill_index(). This localizes the external data structures used in managing the pts indices. [akpm@linux-foundation.org: undo accidental mutex2sem conversion] Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
