path: root/include/linux/dlm_device.h
2008-08-28dlm: allow multiple lockspace createsDavid Teigland
Add a count for lockspace create and release so that create can be called multiple times to use the lockspace from different places. Also add the new flag DLM_LSFL_NEWEXCL to create a lockspace with the previous behavior of returning -EEXIST if the lockspace already exists. Signed-off-by: David Teigland <teigland@redhat.com>
2008-04-21dlm: linux/{dlm,dlm_device}.h: cleanup for userspaceMike Frysinger
linux/dlm_device.h uses types from dlm.h and types.h, so pull them in. The dlm.h header should use __u## rather than uint##_t types and thus pull in linux/types.h for it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-04-21dlm: common max length definitionsDavid Teigland
Add central definitions for max lockspace name length and max resource name length. The lack of central definitions has resulted in scattered private definitions which we can now clean up, including an unused one in dlm_device.h. Signed-off-by: David Teigland <teigland@redhat.com>
2007-07-09[DLM] canceling deadlocked lockDavid Teigland
Add a function that can be used through libdlm by a system daemon to cancel another process's deadlocked lock. A completion ast with EDEADLK is returned to the process waiting for the lock. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] dlm_device interface changes [3/6]David Teigland
Change the user/kernel device interface used by libdlm: - Add ability for userspace to check the version of the interface. libdlm can now adapt to different versions of the kernel interface. - Increase the size of the flags passed in a lock request so all possible flags can be used from userspace. - Add an opaque "xid" value for each lock. This "transaction id" will be used later to associate locks with each other during deadlock detection. - Add a "timeout" value for each lock. This is used along with the DLM_LKF_TIMEOUT flag. Also, remove a fragment of unused code in device_read(). This patch requires updating libdlm which is backward compatible with older kernels. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-01[DLM] interface for purge (2/2)David Teigland
Add code to accept purge commands from userland. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-09[DLM] compat patchPatrick Caulfield
Here's a patch which add 32/64 bit compat to the DLM IOs and tidies the structures for alignment. As it causes an ABI change I had few qualms about adding the extra flag for "is64bit" as it simply uses a byte that would have been padding. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-23[DLM] Remove range locks from the DLMDavid Teigland
This patch removes support for range locking from the DLM Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
