path: root/include/linux/dm-io.h
2011-05-29dm io: use fixed initial mempool sizeMikulas Patocka
Replace the arbitrary calculation of an initial io struct mempool size with a constant. The code calculated the number of reserved structures based on the request size and used a "magic" multiplication constant of 4. This patch changes it to reserve a fixed number - itself still chosen quite arbitrarily. Further testing might show if there is a better number to choose. Note that if there is no memory pressure, we can still allocate an arbitrary number of "struct io" structures. One structure is enough to process the whole request. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm: eliminate some holes data structuresMike Snitzer
Eliminate a 4-byte hole in 'struct dm_io_memory' by moving 'offset' above the 'ptr' to which it applies (size reduced from 24 to 16 bytes). And by association, 1-4 byte hole is eliminated in 'struct dm_io_request' (size reduced from 56 to 48 bytes). Eliminate all 6 4-byte holes and 1 cache-line in 'struct dm_snapshot' (size reduced from 392 to 368 bytes). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm: move include filesAlasdair G Kergon
Publish the dm-io, dm-log and dm-kcopyd headers in include/linux. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
