path: root/include/linux/dma-attrs.h
2008-07-22powerpc/cell: Add DMA_ATTR_WEAK_ORDERING dma attribute and use in Cell IOMMU ↵Mark Nelson
code Introduce a new dma attriblue DMA_ATTR_WEAK_ORDERING to use weak ordering on DMA mappings in the Cell processor. Add the code to the Cell's IOMMU implementation to use this code. Dynamic mappings can be weakly or strongly ordered on an individual basis but the fixed mapping has to be either completely strong or completely weak. This is currently decided by a kernel boot option (pass iommu_fixed=weak for a weakly ordered fixed linear mapping, strongly ordered is the default). Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-04-29dma: add dma_*map*_attrs() interfacesArthur Kepner
Introduce new interfaces, dma_*map*_attrs(), for passing architecture-specific attributes when memory is mapped and unmapped for DMA. Give the interfaces default implementations which ignore attributes. Also introduce the dma_{set|get}_attr() interfaces for setting and retrieving individual attributes. Define one attribute, DMA_ATTR_WRITE_BARRIER, in anticipation of its use by ia64/sn. Select whether architectures implement arch-specific versions of the dma_*map*_attrs() interfaces via HAVE_DMA_ATTRS in Kconfig. [markn@au1.ibm.com: dma_{set,get}_attr() have to be static inline] Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
