path: root/include/linux/drbd.h
2011-05-24drbd: Fix spellingBart Van Assche
Found these with the help of ispell -l. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
2011-05-24drbd: fix schedule in atomicLars Ellenberg
An administrative detach used to request a state change directly to D_DISKLESS, first suspending IO to avoid the last put_ldev() occuring from an endio handler, potentially in irq context. This is not enough on the receiving side (typically secondary), we may miss some peer_req on the way to local disk, which then may do the last put_ldev() from their drbd_peer_request_endio(). This patch makes the detach always go through the intermediate D_FAILED state. We may consider to rename it D_DETACHING. Alternative approach would be to create yet an other work item to be scheduled on the worker, do the destructor work from there, and get the timing right. manually picked commit 564040f from the drbd 8.4 branch. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: Remove unused function atodb_endio()Andreas Gruenbacher
2011-03-10drbd: Provide hints with the error message when clearing the sync pause flagPhilipp Reisner
When the user clears the sync-pause flag, and sync stays in pause state, give hints to the user, why it still is in pause state. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: Rename enum drbd_state_ret_codes to enum drbd_state_rvAndreas Gruenbacher
2011-03-10drbd: Rename enum drbd_ret_codes to enum drbd_ret_codeAndreas Gruenbacher
2011-03-10drbd: New packet for Ahead/Behind mode: P_OUT_OF_SYNCPhilipp Reisner
2011-03-10drbd: Implemented two new connection states Ahead/BehindPhilipp Reisner
In this connection mode, the ahead node no longer replicates application IO. The behind's disk becomes out dated. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: New configuration parameters for dealing with network congestionPhilipp Reisner
net { on_congestion {block|pull-ahead|disconnect}; congestion-fill {sectors}; congestion-extents {al-extents}; } Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-22drbd: Silenced an assertPhilipp Reisner
That assertion's condition needed adjustment for today's semantics Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-15drbd: add race-breaker to drbd_go_disklessLars Ellenberg
This adds a necessary race breaker to these commits: drbd: fix for possible deadlock on IO error during resync drbd: drop wrong debug asserts, fix recently introduced race What we do is get a refcount, check the state, then depending on the state and the requested minimum disk state, either hold it (success), or give it back immediately (failed "try lock"). Some code paths (flushing of drbd metadata) may still grab and hold a refcount even if we are D_FAILED (application IO won't). So even if we hit local_cnt == 0 once after being D_FAILED, we still need to wait for that again after we changed to D_DISKLESS. Once local_cnt reaches 0 while we are D_DISKLESS, we can be sure that no one will look at the protected members anymore, so only then is it safe to free them. We cannot easily convert to standard locking primitives here, as we want to be able to use it in atomic context (we always do a "try lock"), as well as hold references for a "long time" (from IO submission to completion callback). Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-14drbd: fix unlikely access after free and list corruptionLars Ellenberg
Various cleanup paths have been incomplete, for the very unlikely case that we cannot allocate enough bios from process context when submitting on behalf of the peer or resync process. Never observed. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-14drbd: Track the reasons to suspend IO in dedicated state bitsPhilipp Reisner
There are three ways to get IO suspended: * Loss of any access to data * Fence-peer-handler running * User requested to suspend IO Track those in different bits, so that one condition clearing its state bit does not interfere with the other two conditions. Only when the user resumes IO he overrules all three bits. The fact is hidden from the user, he sees only a single suspend bit. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-14drbd: Sending of big packets, for payloads from 64KByte to 4GBytePhilipp Reisner
2010-10-14drbd: Do not allow a fencing-policy of resource-and-stonith with protocol APhilipp Reisner
2010-10-14drbd: Finished the "on-no-data-accessible suspend-io;" functionalityPhilipp Reisner
When no data is accessible (no connection to the peer, nor a local disk) allow the user to select to freeze all IO operations instead of getting IO errors. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-08-07drbd: revert "delay probes", feature is being re-implemented differentlyLars Ellenberg
It was a now abandoned attempt to throttle resync bandwidth based on the delay it causes on the bulk data socket. It has no userbase yet, and has been disabled by 9173465ccb51c09cc3102a10af93e9f469a0af6f already. This removes the now unused code. The basic feature, namely using up "idle" bandwith of network and disk IO subsystem, with minimal impact to application IO, is being reimplemented differently. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-14drbd: Fixed a race between disk-attach and unexpected state changesPhilipp Reisner
This was a very hard to trigger race condition. If we got a state packet from the peer, after drbd_nl_disk() has already changed the disk state to D_NEGOTIATING but after_state_ch() was not yet run by the worker, then receive_state() might called drbd_sync_handshake(), which in turn crashed when accessing p_uuid. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-06-01Preparing 8.3.8rc2Philipp Reisner
2010-05-21drbd: This is now equivalent to drbd release 8.3.8rc1Philipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-18drbd: Implemented the --assume-clean option for drbdsetup resizePhilipp Reisner
2010-03-11drbd: --dry-run option for drbdsetup net ( drbdadm -- --dry-run connect <res> )Philipp Reisner
2010-01-12drbd: The kernel code is now equivalent to out of tree release 8.3.7Philipp Reisner
2009-11-25drbd: moved CN_IDX_DRBD and CN_VAL_DRBD to the right filePhilipp Reisner
2009-11-24DRBD: Now the code is 8.3.6 + 3 fixes (without compat crap)Philipp Reisner
2009-11-04Now it is equal to DRBD release 8.3.5 without compat crapPhilipp Reisner
2009-10-06drbd: Work on permission enforcementPhilipp Reisner
Now we have the capabilities of the sending process available, use them to enforce CAP_SYS_ADMIN. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01The DRBD driverPhilipp Reisner
