path: root/include/linux/drbd_limits.h
2013-06-28drbd: Allow online change of al-stripes and al-stripe-sizePhilipp Reisner
Allow to change the AL layout with an resize operation. For that the reisze command gets two new fields: al_stripes and al_stripe_size. In order to make the operation crash save: 1) Lock out all IO and MD-IO 2) Write the super block with MDF_PRIMARY_IND clear 3) write the bitmap to the new location (all zeros, since we allow only while connected) 4) Initialize the new AL-area 5) Write the super block with the restored MDF_PRIMARY_IND. 6) Unfreeze all IO Since the AL-layout has no influence on the protocol, this operation needs to be beforemed on both sides of a resource (if intended). Signed-off-by: Andreas Gruenbacher <agruen@linbit.com> Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-22drbd: adjust upper limit for activity log extentsLars Ellenberg
Now that the on-disk activity-log ring buffer size is adjustable, the maximum active set can become larger, and is now limited by the use of 16bit "labels". This increases the maximum working set from 6433 to 65534 extents, each of which covers an area of 4MiB. Which means that if you use the maximum, you'd have to resync more than 250 GiB after an unclean Primary shutdown. With capable backend storage and replication links, this is entirely feasible. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-08drbd: New disk option al-updatesPhilipp Reisner
By disabling al-updates one might increase performace. The price for that is that in case a crashed primary (that had al-updates disabled) is reintegraded, it will receive a full-resync instead of a bitmap based resync. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Load balancing of read requestsPhilipp Reisner
New config option for the disk secition "read-balancing", with the values: prefer-local, prefer-remote, round-robin, when-congested-remote. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: The minor_count module parameter is only a hint nowadaysPhilipp Reisner
* The max of minor_count is 255 * In drbdadm count the number of minors, instead of finding the highest minor number * No longer us the magic in the init script Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Fix the maximum accepted minor device numberAndreas Gruenbacher
The maximum minor device number allowed by the kernel is (1<<20 - 1). Reject device numbers higher than that to earlier catch possible errors. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Define scale factors in a single placeAndreas Gruenbacher
2012-11-08drbd: Changed some defaultsPhilipp Reisner
* Enabled the resync controller, with a fill target of 50Kib. That gives reasonable resync speeds without tuning. A much better default than the 250KiB/s fixed. * Enable bitmap compression. It is save to use, and most people have more CPU power than network bandwidth. * ko-count of 7: Abort a connection if the peer fails to process a write request within 42 seconds. * al-extents of 1237: ~5 GiB seems to be a much more sane default these days. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: detach from frozen backing devicePhilipp Reisner
* drbd-8.3: documentation: Documented detach's --force and disk's --disk-timeout drbd: Implemented the disk-timeout option drbd: Force flag for the detach operation drbd: Allow new IOs while the local disk in in FAILED state drbd: Bitmap IO functions can not return prematurely if the disk breaks drbd: Added a kref to bm_aio_ctx drbd: Hold a reference to ldev while doing meta-data IO drbd: Keep a reference to the bio until the completion handler finished drbd: Implemented wait_until_done_or_disk_failure() drbd: Replaced md_io_mutex by an atomic: md_io_in_use drbd: moved md_io into mdev drbd: Immediately allow completion of IOs, that wait for IO completions on a failed disk drbd: Keep a reference to barrier acked requests Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Fixes from the 8.3 development branchPhilipp Reisner
* commit 'ae57a0a': drbd: Only print sanitize state's warnings, if the state change happens drbd: we should write meta data updates with FLUSH FUA drbd: fix limit define, we support 1 PiByte now drbd: fix log message argument order drbd: Typo in user-visible message. drbd: Make "(rcv|snd)buf-size" and "ping-timeout" available for the proxy, too. drbd: Allow keywords to be used in multiple config sections. drbd: fix typos in comments. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: allow ping-timeout of up to 30 secondsLars Ellenberg
Allow up to 300 centi-seconds to be configured for the "ping timeout". There may be setups where heavy congestion, huge buffers, and asymmetric bandwidth limitations may need a "huge" ping-timeout as work-around for "spurious connection loss" problems. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Use more generic constant namesAndreas Gruenbacher
These constants are useful for the same purpose in more than one place. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Rename DISK_SIZE_SECT -> DISK_SIZEAndreas Gruenbacher
We don't have the units in constant names in other places, either. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Fix the upper limit of resync-afterAndreas Gruenbacher
The 32-bit resync_after netlink field takes a device minor number as parameter, which is no longer limited to 255. We cannot statically verify which device numbers are valid, so set the ummer limit to the highest possible signed 32-bit integer. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: Refer to resync-rate consistently throughout the codeAndreas Gruenbacher
2012-11-08drbd: Also define the default values of boolean flags in a single placeAndreas Gruenbacher
2012-11-08drbd: Remove left-over unused defineAndreas Gruenbacher
2012-11-08drbd: Introduce protocol version 100 headersAndreas Gruenbacher
The 8 byte header finally becomes too small. With the protocol 100 header we have 16 bit for the volume number, proper 32 bit for the data length, and 32 bit for further extensions in the future. Previous versions of drbd are using version 80 headers for all packets short enough for protocol 80. They support both header versions in worker context, but only version 80 headers in asynchronous context. For backwards compatibility, continue to use version 80 headers for short packets before protocol version 100. From protocol version 100 on, use the same header version for all packets. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2012-11-08drbd: distribute former syncer_conf settings to disk, connection, and ↵Lars Ellenberg
resource level This commit breaks the API again. Move per-volume former syncer options into disk_conf. Move per-connection former syncer options into net_conf. Renamed the remainign sync_conf to res_opts Syncer settings have been changeable at runtime, so we need to prepare for these settings to be runtime-changeable in their new home as well. Introduce new configuration operations, and share the netlink attribute between "attach" (create new disk) and "disk-opts" (change options). Same for "connect" and "net-opts". Some fields cannot be changed at runtime, however. Introduce a new flag GENLA_F_INVARIANT to be able to trigger on that in the generated validation and assignment functions. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-10-14drbd: default to detach on-io-errorLars Ellenberg
Old default behaviour was "pass-on", which is not useful in production at all. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-10-14drbd: new on-disk activity log transaction formatLars Ellenberg
Use a new on-disk transaction format for the activity log, which allows for multiple changes to the active set per transaction. Using 4k transaction blocks, we can now get rid of the work-around code to deal with devices not supporting 512 byte logical block size. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-30drbd: fix limit define, we support 1 PiByte nowLars Ellenberg
2011-03-10drbd: Corrected off-by-one error in DRBD_MINOR_COUNT_MAXPhilipp Reisner
2011-03-10drbd: New configuration parameters for dealing with network congestionPhilipp Reisner
net { on_congestion {block|pull-ahead|disconnect}; congestion-fill {sectors}; congestion-extents {al-extents}; } Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-14drbd: Allow larger values for c-fill-target.Philipp Reisner
Connections through a compressing proxy might have more bits on the fly. 500MByte instead of 50MByte Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-14drbd: new configuration parameter c-min-rateLars Ellenberg
We now track the data rate of locally submitted resync related requests, and can thus detect non-resync activity on the lower level device. If the current sync rate is above c-min-rate, and the lower level device appears to be busy, we throttle the resyncer. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-10-14drbd: New sync parameters for the smart resync rate controllerPhilipp Reisner
2010-10-14drbd: Finished the "on-no-data-accessible suspend-io;" functionalityPhilipp Reisner
When no data is accessible (no connection to the peer, nor a local disk) allow the user to select to freeze all IO operations instead of getting IO errors. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-05-18drbd: Four new configuration settings for resync speed controlPhilipp Reisner
To reasonably control resync speed over drbd-proxy connections, drbd has to measure the current delay of packets transmitted over the (possibly congested) data socket vs the meta-data socket. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2009-11-04change default: by default, use socket buffer auto tuningLars Ellenberg
2009-10-01The DRBD driverPhilipp Reisner
