path: root/include/linux/dw_apb_timer.h
2013-07-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner: "The timer changes contain: - posix timer code consolidation and fixes for odd corner cases - sched_clock implementation moved from ARM to core code to avoid duplication by other architectures - alarm timer updates - clocksource and clockevents unregistration facilities - clocksource/events support for new hardware - precise nanoseconds RTC readout (Xen feature) - generic support for Xen suspend/resume oddities - the usual lot of fixes and cleanups all over the place The parts which touch other areas (ARM/XEN) have been coordinated with the relevant maintainers. Though this results in an handful of trivial to solve merge conflicts, which we preferred over nasty cross tree merge dependencies. The patches which have been committed in the last few days are bug fixes plus the posix timer lot. The latter was in akpms queue and next for quite some time; they just got forgotten and Frederic collected them last minute." * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits) hrtimer: Remove unused variable hrtimers: Move SMP function call to thread context clocksource: Reselect clocksource when watchdog validated high-res capability posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting posix_timers: fix racy timer delta caching on task exit posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule() selftests: add basic posix timers selftests posix_cpu_timers: consolidate expired timers check posix_cpu_timers: consolidate timer list cleanups posix_cpu_timer: consolidate expiry time type tick: Sanitize broadcast control logic tick: Prevent uncontrolled switch to oneshot mode tick: Make oneshot broadcast robust vs. CPU offlining x86: xen: Sync the CMOS RTC as well as the Xen wallclock x86: xen: Sync the wallclock when the system time is set timekeeping: Indicate that clock was set in the pvclock gtod notifier timekeeping: Pass flags instead of multiple bools to timekeeping_update() xen: Remove clock_was_set() call in the resume path hrtimers: Support resuming with two or more CPUs online (but stopped) timer: Fix jiffies wrap behavior of round_jiffies_common() ...
2013-06-18Revert "dw_apb_timer_of.c: Remove parts that were picoxcell-specific"John Stultz
This reverts commit 55a68c23e0a675b2b8ac2656fd6edbf98b78e4c6. In order to avoid a collision with dw_apb_timer changes in the arm-soc tree, revert this change. I'm leaving it to the arm-soc folks to sort out if they want to keep the other side of the collision or if they're just going to back it all out and try again during the next release cycle. Reported-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-06-12clocksource: dw_apb_timer_of: use clocksource_of_initHeiko Stuebner
dw_apb_timer_init used to search the devicetree for matching timer devices, making calls to it from board files necessary. Change the dw_apb_timer_init to work with CLOCKSOURCE_OF_DECLARE. With this change the function gets called once for each timer node and tracks these number of calls to attach clockevent and clocksource devices to the nodes. Also remove the calls to dw_apb_timer_init from all previous users, as clocksource_of_init is the default for init_time now. Tested on the upcoming rk3066 code. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Dinh Nguyen <dinguyen@altera.com>
2013-05-28dw_apb_timer_of.c: Remove parts that were picoxcell-specificPavel Machek
It seems we made a mistake when creating dw_apb_timer_of.c: picoxcell sched_clock had parts that were not related to dw_apb_timer, yet we moved them to dw_apb_timer_of, and tried to use them on socfpga. This results in system where user/system time is not measured properly, as demonstrated by time dd if=/dev/urandom of=/dev/zero bs=100000 count=100 So this patch switches sched_clock to hardware that exists on both platforms, and adds missing of_node_put() in dw_apb_timer_init(). Signed-off-by: Pavel Machek <pavel@denx.de> Acked-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-05-16clocksource: apb_timer: Remove unsused functionThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <john.stultz@linaro.org> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Link: http://lkml.kernel.org/r/20130425143435.558006195@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-07-19ARM: socfpga: initial support for Altera's SOCFPGA platformDinh Nguyen
Adding core definitions for Altera's SOCFPGA ARM platform. Mininum support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Reviewed-by: Pavel Machek <pavel@denx.de> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-04dw_apb_timer: constify clocksource nameJamie Iles
The clocksource name should be const for correctness. Cc: John Stultz <johnstul@us.ibm.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-27clocksource: apb: Share APB timer code with other platformsJamie Iles
The APB timers are an IP block from Synopsys (DesignWare APB timers) and are also found in other systems including ARM SoC's. This patch adds functions for creating clock_event_devices and clocksources from APB timers but does not do the resource allocation. This is handled in a higher layer to allow the timers to be created from multiple methods such as platform_devices. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
