path: root/include/linux/ecryptfs.h
2013-03-03eCryptfs: allow userspace messaging to be disabledKees Cook
When the userspace messaging (for the less common case of userspace key wrap/unwrap via ecryptfsd) is not needed, allow eCryptfs to build with it removed. This saves on kernel code size and reduces potential attack surface by removing the /dev/ecryptfs node. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2011-06-27eCryptfs: export global eCryptfs definitions to include/linux/ecryptfs.hRoberto Sassu
Some eCryptfs specific definitions, such as the current version and the authentication token structure, are moved to the new include file 'include/linux/ecryptfs.h', in order to be available for all kernel subsystems. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Acked-by: Gianluca Ramunno <ramunno@polito.it> Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
