path: root/include/linux/edd.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2009-01-30headers_check fix: linux/edd.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/edd.h:70: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2007-10-23Make asm-x86/bootparam.h includable from userspace.Rusty Russell
To actually write a bootloader (or, say, the lguest launcher) currently requires duplication of these structures. Making them includable from userspace is much nicer. We merge the common userspace-required definitions of e820_32/64.h into e820.h for export. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-07-12Remove old i386 setup codeH. Peter Anvin
This removes the old i386 setup code. This is done as a separate patch to avoid breaking git bisect as some of the i386 code was also used by the old x86-64 code. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] i386: Fix the EDD code misparsing the command lineH. Peter Anvin
The EDD code would scan the command line as a fixed array, without taking account of either whitespace, null-termination, the old command-line protocol, late overrides early, or the fact that the command line may not be reachable from INITSEG. This should fix those problems, and enable us to use a longer command line. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andi Kleen <ak@suse.de>
2005-05-01[PATCH] Increase number of e820 entries hard limit from 32 to 128Venkatesh Pallipadi
The specifications that talk about E820 map doesn't have an upper limit on the number of e820 entries. But, today's kernel has a hard limit of 32. With increase in memory size, we are seeing the number of E820 entries reaching close to 32. Patch below bumps the number upto 128. The patch changes the location of EDDBUF in zero-page (as it comes after E820). As, EDDBUF is not used by boot loaders, this patch should not have any effect on bootloader-setup code interface. Patch covers both i386 and x86-64. Tested on: * grub booting bzImage * lilo booting bzImage with EDID info enabled * pxeboot of bzImage Side-effect: bss increases by ~ 2K and init.data increases by ~7.5K on all systems, due to increase in size of static arrays. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
