path: root/include/linux/elf.h
2010-05-17[S390] add breaking event address for user spaceMartin Schwidefsky
Copy the last breaking event address from the lowcore to a new field in the thread_struct on each system entry. Add a new ptrace request PTRACE_GET_LAST_BREAK and a new utrace regset REGSET_LAST_BREAK to query the last breaking event. This is useful for debugging wild branches in user space code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-06elf coredump: add extended numbering supportDaisuke HATAYAMA
The current ELF dumper implementation can produce broken corefiles if program headers exceed 65535. This number is determined by the number of vmas which the process have. In particular, some extreme programs may use more than 65535 vmas. (If you google max_map_count, you can find some users facing this problem.) This kind of program never be able to generate correct coredumps. This patch implements ``extended numbering'' that uses sh_info field of the first section header instead of e_phnum field in order to represent upto 4294967295 vmas. This is supported by AMD64-ABI(http://www.x86-64.org/documentation.html) and Solaris(http://docs.sun.com/app/docs/doc/817-1984/). Of course, we are preparing patches for gdb and binutils. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: replace ELF_CORE_EXTRA_* macros by functionsDaisuke HATAYAMA
elf_core_dump() and elf_fdpic_core_dump() use #ifdef and the corresponding macro for hiding _multiline_ logics in functions. This patch removes #ifdef and replaces ELF_CORE_EXTRA_* by corresponding functions. For architectures not implemeonting ELF_CORE_EXTRA_*, we use weak functions in order to reduce a range of modification. This cleanup is for my next patches, but I think this cleanup itself is worth doing regardless of my firnal purpose. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-28Merge branch 'x86-ptrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-ptrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, ptrace: Remove set_stopped_child_used_math() in [x]fpregs_set x86, ptrace: Simplify xstateregs_get() ptrace: Fix ptrace_regset() comments and diagnose errors specifically parisc: Disable CONFIG_HAVE_ARCH_TRACEHOOK ptrace: Add support for generic PTRACE_GETREGSET/PTRACE_SETREGSET x86, ptrace: regset extensions to support xstate
2010-02-26[S390] Define new s390 ELF note sections in elf.hMichael Holzheu
S390 ELF core dump currently only contains the PSW, the general purpose registers, the floating point registers and the access registers stored in PRSTATUS/PRFPREG note sections. For analyzing s390 kernel problems additional registers are important. In order to be able to include these registers to a kernel ELF core dump, this patch adds the following five new note sections to elf.h: * NT_S390_TIMER: S390 timer register * NT_S390_TODCMP: S390 TOD comparator register * NT_S390_TODPREG: S390 TOD programmable register * NT_S390_CTRS: S390 control registers * NT_S390_PREFIX: S390 prefix register The new note sections have been already defined and accepted in the upstream binutils package. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-02-11ptrace: Add support for generic PTRACE_GETREGSET/PTRACE_SETREGSETSuresh Siddha
Generic support for PTRACE_GETREGSET/PTRACE_SETREGSET commands which export the regsets supported by each architecture using the correponding NT_* types. These NT_* types are already part of the userland ABI, used in representing the architecture specific register sets as different NOTES in an ELF core file. 'addr' parameter for the ptrace system call encode the REGSET type (using the corresppnding NT_* type) and the 'data' parameter points to the struct iovec having the user buffer and the length of that buffer. struct iovec iov = { buf, len}; ret = ptrace(PTRACE_GETREGSET/PTRACE_SETREGSET, pid, NT_XXX_TYPE, &iov); On successful completion, iov.len will be updated by the kernel specifying how much the kernel has written/read to/from the user's iov.buf. x86 extended state registers are primarily exported using this interface. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20100211195614.886724710@sbs-t61.sc.intel.com> Acked-by: Hongjiu Lu <hjl.tools@gmail.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-11x86, ptrace: regset extensions to support xstateSuresh Siddha
Add the xstate regset support which helps extend the kernel ptrace and the core-dump interfaces to support AVX state etc. This regset interface is designed to support all the future state that gets supported using xsave/xrstor infrastructure. Looking at the memory layout saved by "xsave", one can't say which state is represented in the memory layout. This is because if a particular state is in init state, in the xsave hdr it can be represented by bit '0'. And hence we can't really say by the xsave header wether a state is in init state or the state is not saved in the memory layout. And hence the xsave memory layout available through this regset interface uses SW usable bytes [464..511] to convey what state is represented in the memory layout. First 8 bytes of the sw_usable_bytes[464..467] will be set to OS enabled xstate mask(which is same as the 64bit mask returned by the xgetbv's xCR0). The note NT_X86_XSTATE represents the extended state information in the core file, using the above mentioned memory layout. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20100211195614.802495327@sbs-t61.sc.intel.com> Signed-off-by: Hongjiu Lu <hjl.tools@gmail.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-18[S390] rename NT_PRXSTATUS to NT_S390_HIGHREGSMartin Schwidefsky
The elf notes number for the upper register halves is s390 specific. Change the name of the elf notes to include S390. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-10-06[S390] 64-bit register support for 31-bit processesHeiko Carstens
From: Heiko Carstens <heiko.carstens@de.ibm.com> From: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-30headers_check fix: linux/elf.hJaswinder Singh Rajput
fix the following 'make headers_check' warnings: usr/include/linux/elf.h:379: extern's make no sense in userspace usr/include/linux/elf.h:387: extern's make no sense in userspace usr/include/linux/elf.h:401: extern's make no sense in userspace usr/include/linux/elf.h:402: extern's make no sense in userspace Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-10-12x86: ioperm user_regsetRoland McGrath
This adds a user_regset type for the x86 io permissions bitmap. This makes it appear in core dumps (when ioperm has been used). It will also make it visible to debuggers in the future. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> [conflict resolutions: Signed-off-by: Ingo Molnar <mingo@elte.hu> ]
2008-07-01powerpc: Update for VSX core file and ptraceMichael Neuling
This correctly hooks the VSX dump into Roland McGrath core file infrastructure. It adds the VSX dump information as an additional elf note in the core file (after talking more to the tool chain/gdb guys). This also ensures the formats are consistent between signals, ptrace and core files. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-29ELF: Use EI_NIDENT instead of numeric valueCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branch 'for-2.6.25' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (69 commits) [POWERPC] Add SPE registers to core dumps [POWERPC] Use regset code for compat PTRACE_*REGS* calls [POWERPC] Use generic compat_sys_ptrace [POWERPC] Use generic compat_ptrace_request [POWERPC] Use generic ptrace peekdata/pokedata [POWERPC] Use regset code for PTRACE_*REGS* requests [POWERPC] Switch to generic compat_binfmt_elf code [POWERPC] Switch to using user_regset-based core dumps [POWERPC] Add user_regset compat support [POWERPC] Add user_regset_view definitions [POWERPC] Use user_regset accessors for GPRs [POWERPC] ptrace accessors for special regs MSR and TRAP [POWERPC] Use user_regset accessors for SPE regs [POWERPC] Use user_regset accessors for altivec regs [POWERPC] Use user_regset accessors for FP regs [POWERPC] mpc52xx: fix compile error introduce when rebasing patch [POWERPC] 4xx: PCIe indirect DCR spinlock fix. [POWERPC] Add missing native dcr dcr_ind_lock spinlock [POWERPC] 4xx: Fix offset value on Warp board [POWERPC] 4xx: Add 440EPx Sequoia ehci dts entry ...
2008-02-07Unexport asm/elf.hKirill A. Shutemov
Do not export asm/elf.h during make headers_install. Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[POWERPC] Add SPE registers to core dumpsRoland McGrath
This makes the SPE register data appear in ELF core dumps, using the new n_type value NT_PPC_SPE (0x101). This new note type is not used by any consumers of core files yet, but support can be added. I don't even have any hardware with SPE capabilities, so I've never seen such a note. But this demonstrates how simple it is to export register information in core dumps when the user_regset style is used for the low-level code. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-30x86: x86 core dump TLSRoland McGrath
This makes ELF core dumps of 32-bit processes include a new note type NT_386_TLS (0x200) giving the contents of the TLS slots in struct user_desc format. This lets post mortem examination figure out what the segment registers mean like the debugger does with get_thread_area on a live process. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17increase AT_VECTOR_SIZE to terminate saved_auxv properlyOlaf Hering
include/asm-powerpc/elf.h has 6 entries in ARCH_DLINFO. fs/binfmt_elf.c has 14 unconditional NEW_AUX_ENT entries and 2 conditional NEW_AUX_ENT entries. So in the worst case, saved_auxv does not get an AT_NULL entry at the end. The saved_auxv array must be terminated with an AT_NULL entry. Make the size of mm_struct->saved_auxv arch dependend, based on the number of ARCH_DLINFO entries. Signed-off-by: Olaf Hering <olh@suse.de> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17powerpc: add Altivec/VMX state to coredumpsMark Nelson
Update dump_task_altivec() (which has so far never been put to use) so that it dumps the Altivec/VMX registers (VR[0] - VR[31], VSCR and VRSAVE) in the same format as the ptrace get_vrregs(), and add the appropriate glue typedef and #defines to make it work. A new note type of NT_PPC_VMX was chosen to be 0x100 (arbitrarily) because it allows the low range values to be used for more generic purposes and 0x100 seems an adequate starting point for PowerPC extensions. Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-19[POWERPC] spufs: Cleanup ELF coredump extra notes logicMichael Ellerman
To start with, arch_notes_size() etc. is a little too ambiguous a name for my liking, so change the function names to be more explicit. Calling through macros is ugly, especially with hidden parameters, so don't do that, call the routines directly. Use ARCH_HAVE_EXTRA_ELF_NOTES as the only flag, and based on it decide whether we want the extern declarations or the empty versions. Since we have empty routines, actually use them in the coredump code to save a few #ifdefs. We want to change the handling of foffset so that the write routine updates foffset as it goes, instead of using file->f_pos (so that writing to a pipe works). So pass foffset to the write routine, and for now just set it to file->f_pos at the end of writing. It should also be possible for the write routine to fail, so change it to return int and treat a non-zero return as failure. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[PATCH] i386: Relocate VDSO ELF headers to match mapped location with ↵Jeremy Fitzhardinge
COMPAT_VDSO Some versions of libc can't deal with a VDSO which doesn't have its ELF headers matching its mapped address. COMPAT_VDSO maps the VDSO at a specific system-wide fixed address. Previously this was all done at build time, on the grounds that the fixed VDSO address is always at the top of the address space. However, a hypervisor may reserve some of that address space, pushing the fixmap address down. This patch does the adjustment dynamically at runtime, depending on the runtime location of the VDSO fixmap. [ Patch has been through several hands: Jan Beulich wrote the orignal version; Zach reworked it, and Jeremy converted it to relocate phdrs as well as sections. ] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Zachary Amsden <zach@vmware.com> Cc: "Jan Beulich" <JBeulich@novell.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com>
2006-12-07[PATCH] elf.h: forward declare struct fileAndrew Morton
In file included from include/asm/patch.h:14, from arch/ia64/kernel/patch.c:10: include/linux/elf.h:375: warning: "struct file" declared inside parameter list include/linux/elf.h:375: warning: its scope is only this definition or declaration, which is probably not what you want Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] elf: Always define elf_addr_t in linux/elf.hMagnus Damm
Define elf_addr_t in linux/elf.h. The size of the type is determined using ELF_CLASS. This allows us to remove the defines that today are spread all over .c and .h files. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Cc: Daniel Jacobowitz <drow@false.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[POWERPC] coredump: Add SPU elf notes to coredump.Dwayne Grant McConnell
This patch adds SPU elf notes to the coredump. It creates a separate note for each of /regs, /fpcr, /lslr, /decr, /decr_status, /mem, /signal1, /signal1_type, /signal2, /signal2_type, /event_mask, /event_status, /mbox_info, /ibox_info, /wbox_info, /dma_info, /proxydma_info, /object-id. A new macro, ARCH_HAVE_EXTRA_NOTES, was created for architectures to specify they have extra elf core notes. A new macro, ELF_CORE_EXTRA_NOTES_SIZE, was created so the size of the additional notes could be calculated and added to the notes phdr entry. A new macro, ELF_CORE_WRITE_EXTRA_NOTES, was created so the new notes would be written after the existing notes. The SPU coredump code resides in spufs. Stub functions are provided in the kernel which are hooked into the spufs code which does the actual work via register_arch_coredump_calls(). A new set of __spufs_<file>_read/get() functions was provided to allow the coredump code to read from the spufs files without having to lock the SPU context for each file read from. Cc: <linux-arch@vger.kernel.org> Signed-off-by: Dwayne Grant McConnell <decimal@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-04-27Sanitise linux/audit.h for userspace consumption, split elf-em.h from elf.hDavid Woodhouse
Don't include <linux/sched.h> outside __KERNEL__, and split the EM_xxx definitions out of elf.h into elf-em.h so that audit.h can include just that and not pollute the namespace any further than it needs to. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-01-08[PATCH] ELF: symbol table type additionsJan Beulich
Needed for the Novell kernel debugger and perhaps some per-cpu data on x86_64 in the future. Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] auxiliary vector cleanupsH. J. Lu
The size of auxiliary vector is fixed at 42 in linux/sched.h. But it isn't very obvious when looking at linux/elf.h. This patch adds AT_VECTOR_SIZE so that we can change it if necessary when a new vector is added. Because of include file ordering problems, doing this necessitated the extraction of the AT_* symbols into a standalone header file. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
