path: root/include/linux/errqueue.h
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15net: new user space API for time stamping of incoming and outgoing packetsPatrick Ohly
User space can request hardware and/or software time stamping. Reporting of the result(s) via a new control message is enabled separately for each field in the message because some of the fields may require additional computation and thus cause overhead. User space can tell the different kinds of time stamps apart and choose what suits its needs. When a TX timestamp operation is requested, the TX skb will be cloned and the clone will be time stamped (in hardware or software) and added to the socket error queue of the skb, if the skb has a socket associated with it. The actual TX timestamp will reach userspace as a RX timestamp on the cloned packet. If timestamping is requested and no timestamping is done in the device driver (potentially this may use hardware timestamping), it will be done in software after the device's start_hard_xmit routine. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30headers_check fix: linux/errqueue.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/errqueue.h:6: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2006-09-28[NET]: struct sock_exterr_skb annotationsAl Viro
->port is net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
