path: root/include/linux/ethtool.h
2011-06-30net: add external loopback test in ethtool self testAmit Kumar Salecha
External loopback test can be performed by application without any driver support on normal Ethernet cards. But on CNA devices, where multiple functions share same physical port. Here internal loopback test and external loopback test can be initiated by multiple functions at same time. To co exist all functions, firmware need to regulate what test can be run by which function. So before performing external loopback test, command need to send to firmware, which will quiescent other functions. User may not want to run external loopback test always. As special cable need to be connected for this test. So adding explicit flag in ethtool self test, which will specify interface to perform external loopback test. ETH_TEST_FL_EXTERNAL_LB: Application set to request external loopback test ETH_TEST_FL_EXTERNAL_LB_DONE: Driver ack if test performed Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-09ethtool.h: fix typosYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-08v2 ethtool: remove support for ETHTOOL_GRXNTUPLEAlexander Duyck
This change is meant to remove all support for displaying an ntuple as strings via ETHTOOL_GRXNTUPLE. The reason for this change is due to the fact that multiple issues have been found including: - Multiple buffer overruns for strings being displayed. - Incorrect filters displayed, cleared filters with ring of -2 are displayed - Setting get_rx_ntuple displays no rules if defined. - Endianess wrong on displayed values. - Hard limit of 1024 filters makes display functionality extremely limited The only driver that had supported this interface was ixgbe. Since it no longer uses the interface and due to the issues mentioned above I am submitting this patch to remove it. v2: Updated based on comments from Ben Hutchings - Left ETH_SS_NTUPLE_FILTERS in code but commented on it being deprecated - Removed ethtool_rx_ntuple_list and ethtool_rx_ntuple_flow_spec_container - Left ETHTOOL_GRXNTUPLE but commented it as deprecated Also cleaned up set_rx_ntuple since there is no flow spec container to maintain we can drop all the code for the alloc and free of it and just return ops->set_rx_ntuple(). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13ethtool: Added support for FW dumpAnirban Chakraborty
Added code to take FW dump via ethtool. Dump level can be controlled via setting the dump flag. A get function is provided to query the current setting of the dump flag. Dump data is obtained from the driver via a separate get function. Changes from v3: Fixed buffer length issue in ethtool_get_dump_data function. Updated kernel doc for ethtool_dump struct and get_dump_flag function. Changes from v2: Provided separate commands for get flag and data. Check for minimum of the two buffer length obtained via ethtool and driver and use that for dump buffer Pass up the driver return error codes up to the caller. Added kernel doc comments. Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ethtool: Add 20G bit definitionsYaniv Rosner
Add 20G supported and advertising bit definitions. 20G will be supported with the 57840 chips. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> ------ include/linux/ethtool.h | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ethtool: remove phys_id from ethtool_opsStephen Hemminger
After that all the upstream kernel drivers now use phys_id, and the old ethtool_ops interface (phys_id) can be removed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Call ethtool's get/set_settings callbacks with cleaned dataDavid Decotigny
This makes sure that when a driver calls the ethtool's get/set_settings() callback of another driver, the data passed to it is clean. This guarantees that speed_hi will be zeroed correctly if the called callback doesn't explicitely set it: we are sure we don't get a corrupted speed from the underlying driver. We also take care of setting the cmd field appropriately (ETHTOOL_GSET/SSET). This applies to dev_ethtool_get_settings(), which now makes sure it sets up that ethtool command parameter correctly before passing it to drivers. This also means that whoever calls dev_ethtool_get_settings() does not have to clean the ethtool command parameter. This function also becomes an exported symbol instead of an inline. All drivers visible to make allyesconfig under x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetics: enforce const-ness in ethtool_cmd_speedDavid Decotigny
The 'ep' argument of ethtool_cmd_speed is not altered: advertise it in protoype. +Indentation fix. Also add comments to advise using the ethtool_cmd_speed API to get/set the link speed. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14ethtool: allow custom interval for physical identificationAllan, Bruce W
When physical identification of an adapter is done by toggling the mechanism on and off through software utilizing the set_phys_id operation, it is done with a fixed duration for both on and off states. Some drivers may want to set a custom duration for the on/off intervals. This patch changes the API so the return code from the driver's entry point when it is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to cycle the on/off states, and updates the drivers that have already been converted to use the new set_phys_id and use the synchronous method for identifying an adapter. The physical identification frequency set in the updated drivers is based on how it was done prior to the introduction of set_phys_id. Compile tested only. Also fixes a compiler warning in sfc. v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE v3: fold patchset into single patch and cleanup per Ben's feedback Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Sathya Perla <sathya.perla@emulex.com> Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com> Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: Don Fry <pcnet32@frontier.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com> Cc: Steve Hodgson <shodgson@solarflare.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Carlson <mcarlson@broadcom.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-13net: ethtool support to configure number of channelsamit salecha
Ethtool support to configure RX, TX and other channels. combined field in struct ethtool_channels to reflect set of channel (RX, TX or other). Other channel can be link interrupts, SR-IOV coordination etc. ETHTOOL_GCHANNELS will report max and current number of RX channels, max and current number of TX channels, max and current number of other channel or max and current number of combined channel. Number of channel can be modify upto max number of channel through ETHTOOL_SCHANNELS command. Ben Hutchings: o define 'combined' and 'other' types. Most multiqueue drivers pair up RX and TX queues so that most channels combine RX and TX work. o Please could you use a kernel-doc comment to describe the structure. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11v3 ethtool: add ntuple flow specifier data to network flow classifierAlexander Duyck
This change is meant to add an ntuple data extensions to the rx network flow classification specifiers. The idea is to allow ntuple to be displayed via the network flow classification interface. The first patch had some left over stuff from the original flow extension flags I had added. That bit is removed in this patch. The second had some left over comments that stated we ignored bits in the masks when we actually match them. This work is based on input from Ben Hutchings. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-05ethtool: Change ETHTOOL_PHYS_ID implementation to allow dropping RTNLBen Hutchings
The ethtool ETHTOOL_PHYS_ID command runs for an arbitrarily long period of time, holding the RTNL lock. This blocks routing updates, device enumeration, and various important operations that one might want to keep running while hunting for the flashing LED. We need to drop the RTNL lock during this operation, but currently the core implementation is a thin wrapper around a driver operation and drivers may well depend upon holding the lock. Define a new driver operation 'set_phys_id' with an argument that sets the ID indicator on/off/inactive/active (the last optional, for any driver or firmware that prefers to handle blinking asynchronously). When this is defined, the ethtool core drops the lock while waiting and only acquires it around calls to this operation. Deprecate the 'phys_id' operation in favour of this. It can be removed once all in-tree drivers are converted. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-05ethtool: Fill out and update comment for struct ethtool_opsBen Hutchings
Briefly document all operations (except get_rx_ntuple), including whether they may return an error code and whether they are deprecated. Also mention some things that should be handled by the ethtool core rather than by drivers. Briefly document general requirements for callers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-04-05ethtool: Convert struct ethtool_ops comment to kernel-doc formatBen Hutchings
2011-03-27net: fix ethtool->set_flags not intended -EINVAL return valueStanislaw Gruszka
After commit d5dbda23804156ae6f35025ade5307a49d1db6d7 "ethtool: Add support for vlan accleration.", drivers that have NETIF_F_HW_VLAN_TX, and/or NETIF_F_HW_VLAN_RX feature, but do not allow enable/disable vlan acceleration via ethtool set_flags, always return -EINVAL from that function. Fix by returning -EINVAL only if requested features do not match current settings and can not be changed by driver. Change any driver that define ethtool->set_flags to use ethtool_invalid_flags() to avoid similar problems in the future (also on drivers that do not have the problem). Tested with modified (to reproduce this bug) myri10ge driver. Cc: stable@kernel.org # 2.6.37+ Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-22net: implement dev_disable_lro() hw_features compatibilityMichał Mirosław
Implement compatibility with new hw_features for dev_disable_lro(). This is a transition path - dev_disable_lro() should be later integrated into netdev_fix_features() after all drivers are converted. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18ethtool: Compat handling for struct ethtool_rxnfcBen Hutchings
This structure was accidentally defined such that its layout can differ between 32-bit and 64-bit processes. Add compat structure definitions and an ioctl wrapper function. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Cc: stable@kernel.org [2.6.30+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23net: Implement SFEATURES compatibility for not updated driversMichał Mirosław
Use discrete setting ops for not updated drivers. This will not make them conform to full G/SFEATURES semantics, though. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: introduce NETIF_F_RXCSUMMichał Mirosław
Introduce NETIF_F_RXCSUM to replace device-private flags for RX checksum offload. Integrate it with ndo_fix_features. ethtool_op_get_rx_csum() is removed altogether as nothing in-tree uses it. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: Introduce new feature setting opsMichał Mirosław
This introduces a new framework to handle device features setting. It consists of: - new fields in struct net_device: + hw_features - features that hw/driver supports toggling + wanted_features - features that user wants enabled, when possible - new netdev_ops: + feat = ndo_fix_features(dev, feat) - API checking constraints for enabling features or their combinations + ndo_set_features(dev) - API updating hardware state to match changed dev->features - new ethtool commands: + ETHTOOL_GFEATURES/ETHTOOL_SFEATURES: get/set dev->wanted_features and trigger device reconfiguration if resulting dev->features changed + ETHTOOL_GSTRINGS(ETH_SS_FEATURES): get feature bits names (meaning) Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10ethtool: Report link-down while interface is downBen Hutchings
While an interface is down, many implementations of ethtool_ops::get_link, including the default, ethtool_op_get_link(), will report the last link state seen while the interface was up. In general the current physical link state is not available if the interface is down. Define ETHTOOL_GLINK to reflect whether the interface *and* any physical port have a working link, and consistently return 0 when the interface is down. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21ethtool: Add support for vlan accleration.Jesse Gross
Now that vlan acceleration is handled consistently regardless of usage, it is possible to enable and disable it at will. This adds support for Ethtool operations that change the offloading status for debugging purposes, similar to other forms of hardware acceleration. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21ethtool: Add Ethernet MAC-level filtering/steeringBen Hutchings
2010-09-21ethtool: Define RX n-tuple action to clear a ruleBen Hutchings
2010-09-17ethtool: Add comments for valid use of flow typesBen Hutchings
2010-09-17ethtool, ixgbe: Move RX n-tuple mask fixup to ethtoolBen Hutchings
The ethtool utility does not set masks for flow parameters that are not specified, so if both value and mask are 0 then this must be treated as equivalent to a mask with all bits set. Currently that is done in the only driver that implements RX n-tuple filtering, ixgbe. Move it to the ethtool core. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ethtool: Remove unimplemented flow specification typesBen Hutchings
struct ethtool_rawip4_spec and struct ethtool_ether_spec are neither commented nor used by any driver, so remove them. Adjust padding in the user-visible unions that included these structures. Fix references to struct ethtool_rawip4_spec in ethtool_get_rx_ntuple(), which should use struct ethtool_usrip4_spec. struct ethtool_usrip4_spec cannot hold IPv6 host addresses and there is no separate structure that can, so remove ETH_RX_NFC_IP6 and the reference to it in niu. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ethtool: Complete kernel-doc comments for RX flow filter and hash controlBen Hutchings
There are now several interfaces within the ethtool API for getting and setting RX flow filtering and hashing behaviour, most of which are poorly documented. This adds kernel-doc comments for all these interfaces, based on the existing incomplete comments and on the initial implementations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07Merge branch 'master' of ↵David S. Miller
2010-06-30ethtool: Add support for control of RX flow hash indirectionBen Hutchings
Many NICs use an indirection table to map an RX flow hash value to one of an arbitrary number of queues (not necessarily a power of 2). It can be useful to remove some queues from this indirection table so that they are only used for flows that are specifically filtered there. It may also be useful to weight the mapping to account for user processes with the same CPU-affinity as the RX interrupts. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29ethtool: Fix potential user buffer overflow for ETHTOOL_{G, S}RXFHBen Hutchings
struct ethtool_rxnfc was originally defined in 2.6.27 for the ETHTOOL_{G,S}RXFH command with only the cmd, flow_type and data fields. It was then extended in 2.6.30 to support various additional commands. These commands should have been defined to use a new structure, but it is too late to change that now. Since user-space may still be using the old structure definition for the ETHTOOL_{G,S}RXFH commands, and since they do not need the additional fields, only copy the originally defined fields to and from user-space. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-14ethtool: Revert incorrect indentation changesBen Hutchings
commit 97f8aefbbfb5aa5c9944e5fa8149f1fdaf71c7b6 "net: fix ethtool coding style errors and warnings" changed the indentation of several macro definitions in ethtool.h. These definitions line up in the diff where there is an extra character at the start of each line, but not in the resulting file. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07net: fix ethtool coding style errors and warningschavey
Fix coding style errors and warnings output while running checkpatch.pl on the files net/core/ethtool.c and include/linux/ethtool.h Signed-off-by: chavey <chavey@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30netdev: ethtool RXHASH flagstephen hemminger
This adds ethtool and device feature flag to allow control of receive hashing offload. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-05ethtool: Add direct access to ops->get_sset_countJeff Garzik
On 03/04/2010 09:26 AM, Ben Hutchings wrote: > On Thu, 2010-03-04 at 00:51 -0800, Jeff Kirsher wrote: >> From: Jeff Garzik<jgarzik@redhat.com> >> >> This patch is an alternative approach for accessing string >> counts, vs. the drvinfo indirect approach. This way the drvinfo >> space doesn't run out, and we don't break ABI later. > [...] >> --- a/net/core/ethtool.c >> +++ b/net/core/ethtool.c >> @@ -214,6 +214,10 @@ static noinline int ethtool_get_drvinfo(struct net_device *dev, void __user *use >> info.cmd = ETHTOOL_GDRVINFO; >> ops->get_drvinfo(dev,&info); >> >> + /* >> + * this method of obtaining string set info is deprecated; >> + * consider using ETHTOOL_GSSET_INFO instead >> + */ > > This comment belongs on the interface (ethtool.h) not the > implementation. Debatable -- the current comment is located at the callsite of ops->get_sset_count(), which is where an implementor might think to add a new call. Not all the numeric fields in ethtool_drvinfo are obtained from ->get_sset_count(). Hence the "some" in the attached patch to include/linux/ethtool.h, addressing your comment. > [...] >> +static noinline int ethtool_get_sset_info(struct net_device *dev, >> + void __user *useraddr) >> +{ > [...] >> + /* calculate size of return buffer */ >> + for (i = 0; i< 64; i++) >> + if (sset_mask& (1ULL<< i)) >> + n_bits++; > [...] > > We have a function for this: > > n_bits = hweight64(sset_mask); Agreed. I've attached a follow-up patch, which should enable my/Jeff's kernel patch to be applied, followed by this one. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
This patch is an alternative approach for accessing string counts, vs. the drvinfo indirect approach. This way the drvinfo space doesn't run out, and we don't break ABI later. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26Revert "ethtool: Add n-tuple string length to drvinfo and return it"David S. Miller
This reverts commit c79c5ffdce14abb4de3878c5aa8c3c6e5093c69b. As Jeff points out we can't break the user visible interface like this, we need to add this into the reserved[] thing. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26ethtool: Add n-tuple string length to drvinfo and return itPeter Waskiewicz
The drvinfo struct should include the number of strings that get_rx_ntuple will return. It will be variable if an underlying driver implements its own get_rx_ntuple routine, so userspace needs to know how much data is coming. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-14ethtool: Fix includes build breakDavid S. Miller
Based upon a patch by Oliver Hartkopp <oliver@hartkopp.net>. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-10ethtool: Introduce n-tuple filter programming supportPeter P Waskiewicz Jr
This patchset enables the ethtool layer to program n-tuple filters to an underlying device. The idea is to allow capable hardware to have static rules applied that can assist steering flows into appropriate queues. Hardware that is known to support these types of filters today are ixgbe and niu. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03tg3: Add some VPD preprocessor constantsMatt Carlson
This patch cleans up the VPD code by creating preprocessor definitions and using them in the place of hardcoded constants. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29ethtool: Add Direct Attach support to connector port reportingPJ Waskiewicz
This patch allows a base driver to specify Direct Attach as the type of port through the ethtool interface. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02gianfar: Basic Support for programming hash rulesSandeep Gopalpet
This patch provides basic hash rules programming via the ethtool interface. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07ethtool: Add reset operationBen Hutchings
After updating firmware stored in flash, users may wish to reset the relevant hardware and start the new firmware immediately. This should not be completely automatic as it may be disruptive. A selective reset may also be useful for debugging or diagnostics. This adds a separate reset operation which takes flags indicating the components to be reset. Drivers are allowed to reset only a subset of those requested, and must indicate the actual subset. This allows the use of generic component masks and some future expansion. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05ethtool: Remove support for obsolete string query operationsBen Hutchings
The in-tree implementations have all been converted to get_sset_count(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02net/ethtool: Add support for the ethtool feature to flash firmware image ↵Ajit Khaparde
from a specified file. This patch adds support to flash a firmware image to a device using ethtool. The driver gets the filename of the firmware image and flashes the image using the request firmware path. The region "on the chip" to be flashed can be specified by an option. It is upto the device driver to enumerate the region number passed by ethtool, to the region to be flashed. The default behavior is to flash all the regions on the chip. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
