path: root/include/linux/file.h
2011-03-15New kind of open files - "location only".Al Viro
New flag for open(2) - O_PATH. Semantics: * pathname is resolved, but the file itself is _NOT_ opened as far as filesystem is concerned. * almost all operations on the resulting descriptors shall fail with -EBADF. Exceptions are: 1) operations on descriptors themselves (i.e. close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD), fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD), fcntl(fd, F_SETFD, ...)) 2) fcntl(fd, F_GETFL), for a common non-destructive way to check if descriptor is open 3) "dfd" arguments of ...at(2) syscalls, i.e. the starting points of pathname resolution * closing such descriptor does *NOT* affect dnotify or posix locks. * permissions are checked as usual along the way to file; no permission checks are applied to the file itself. Of course, giving such thing to syscall will result in permission checks (at the moment it means checking that starting point of ....at() is a directory and caller has exec permissions on it). fget() and fget_light() return NULL on such descriptors; use of fget_raw() and fget_raw_light() is needed to get them. That protects existing code from dealing with those things. There are two things still missing (they come in the next commits): one is handling of symlinks (right now we refuse to open them that way; see the next commit for semantics related to those) and another is descriptor passing via SCM_RIGHTS datagrams. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-17fs: Remove unlikely() from fput_light()Steven Rostedt
In fput_light(), there's an unlikely(fput_needed), which running on my normal desktop doing firefox, xchat, evolution and part of my distcc farm, and running the annotate branch profiler shows that the unlikely is not very unlikely. correct incorrect % Function File Line ------- --------- - -------- ---- ---- 0 48 100 fput_light file.h 26 115828710 897415279 88 fput_light file.h 26 865271179 5286128445 85 fput_light file.h 26 19568539 8923664 31 fput_light file.h 26 12353677 3562279 22 fput_light file.h 26 267691 67062 20 fput_light file.h 26 15014853 348172 2 fput_light file.h 26 209258 205 0 fput_light file.h 26 1364164 0 0 fput_light file.h 26 Which gives 1032903812 times it was correct and 6203351846 times it was incorrect, or 85% incorrect. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27get rid of the magic around f_count in aioAl Viro
__aio_put_req() plays sick games with file refcount. What it wants is fput() from atomic context; it's almost always done with f_count > 1, so they only have to deal with delayed work in rare cases when their reference happens to be the last one. Current code decrements f_count and if it hasn't hit 0, everything is fine. Otherwise it keeps a pointer to struct file (with zero f_count!) around and has delayed work do __fput() on it. Better way to do it: use atomic_long_add_unless( , -1, 1) instead of !atomic_long_dec_and_test(). IOW, decrement it only if it's not the last reference, leave refcount alone if it was. And use normal fput() in delayed work. I've made that atomic_long_add_unless call a new helper - fput_atomic(). Drops a reference to file if it's safe to do in atomic (i.e. if that's not the last one), tells if it had been able to do that. aio.c converted to it, __fput() use is gone. req->ki_file *always* contributes to refcount now. And __fput() became static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16get rid of init_file()Al Viro
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-08-01[PATCH] merge locate_fd() and get_unused_fd()Al Viro
New primitive: alloc_fd(start, flags). get_unused_fd() and get_unused_fd_flags() become wrappers on top of it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-25[PATCH] sanitize unshare_files/reset_files_structAl Viro
* let unshare_files() give caller the displaced files_struct * don't bother with grabbing reference only to drop it in the caller if it hadn't been shared in the first place * in that form unshare_files() is trivially implemented via unshare_fd(), so we eliminate the duplicate logics in fork.c * reset_files_struct() is not just only called for current; it will break the system if somebody ever calls it for anything else (we can't modify ->files of somebody else). Lose the task_struct * argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: create helper to drop file write accessDave Hansen
If someone decides to demote a file from r/w to just r/o, they can use this same code as __fput(). NFS does just that, and will use this in the next patch. AV: drop write access in __fput() only after we evict from file list. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Erez Zadok <ezk@cs.sunysb.edu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J Bruce Fields" <bfields@fieldses.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-13include/linux: Remove all users of FASTCALL() macroHarvey Harrison
FASTCALL() is always expanded to empty, remove it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17r/o bind mounts: filesystem helpers for custom 'struct file'sDave Hansen
Why do we need r/o bind mounts? This feature allows a read-only view into a read-write filesystem. In the process of doing that, it also provides infrastructure for keeping track of the number of writers to any given mount. This has a number of uses. It allows chroots to have parts of filesystems writable. It will be useful for containers in the future because users may have root inside a container, but should not be allowed to write to somefilesystems. This also replaces patches that vserver has had out of the tree for several years. It allows security enhancement by making sure that parts of your filesystem read-only (such as when you don't trust your FTP server), when you don't want to have entire new filesystems mounted, or when you want atime selectively updated. I've been using the following script to test that the feature is working as desired. It takes a directory and makes a regular bind and a r/o bind mount of it. It then performs some normal filesystem operations on the three directories, including ones that are expected to fail, like creating a file on the r/o mount. This patch: Some filesystems forego the vfs and may_open() and create their own 'struct file's. This patch creates a couple of helper functions which can be used by these filesystems, and will provide a unified place which the r/o bind mount code may patch. Also, rename an existing, static-scope init_file() to a less generic name. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16O_CLOEXEC for SCM_RIGHTSUlrich Drepper
Part two in the O_CLOEXEC saga: adding support for file descriptors received through Unix domain sockets. The patch is once again pretty minimal, it introduces a new flag for recvmsg and passes it just like the existing MSG_CMSG_COMPAT flag. I think this bit is not used otherwise but the networking people will know better. This new flag is not recognized by recvfrom and recv. These functions cannot be used for that purpose and the asymmetry this introduces is not worse than the already existing MSG_CMSG_COMPAT situations. The patch must be applied on the patch which introduced O_CLOEXEC. It has to remove static from the new get_unused_fd_flags function but since scm.c cannot live in a module the function still hasn't to be exported. Here's a test program to make sure the code works. It's so much longer than the actual patch... #include <errno.h> #include <error.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #include <unistd.h> #include <sys/socket.h> #include <sys/un.h> #ifndef O_CLOEXEC # define O_CLOEXEC 02000000 #endif #ifndef MSG_CMSG_CLOEXEC # define MSG_CMSG_CLOEXEC 0x40000000 #endif int main (int argc, char *argv[]) { if (argc > 1) { int fd = atol (argv[1]); printf ("child: fd = %d\n", fd); if (fcntl (fd, F_GETFD) == 0 || errno != EBADF) { puts ("file descriptor valid in child"); return 1; } return 0; } struct sockaddr_un sun; strcpy (sun.sun_path, "./testsocket"); sun.sun_family = AF_UNIX; char databuf[] = "hello"; struct iovec iov[1]; iov[0].iov_base = databuf; iov[0].iov_len = sizeof (databuf); union { struct cmsghdr hdr; char bytes[CMSG_SPACE (sizeof (int))]; } buf; struct msghdr msg = { .msg_iov = iov, .msg_iovlen = 1, .msg_control = buf.bytes, .msg_controllen = sizeof (buf) }; struct cmsghdr *cmsg = CMSG_FIRSTHDR (&msg); cmsg->cmsg_level = SOL_SOCKET; cmsg->cmsg_type = SCM_RIGHTS; cmsg->cmsg_len = CMSG_LEN (sizeof (int)); msg.msg_controllen = cmsg->cmsg_len; pid_t child = fork (); if (child == -1) error (1, errno, "fork"); if (child == 0) { int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (bind (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "bind"); if (listen (sock, SOMAXCONN) < 0) error (1, errno, "listen"); int conn = accept (sock, NULL, NULL); if (conn == -1) error (1, errno, "accept"); *(int *) CMSG_DATA (cmsg) = sock; if (sendmsg (conn, &msg, MSG_NOSIGNAL) < 0) error (1, errno, "sendmsg"); return 0; } /* For a test suite this should be more robust like a barrier in shared memory. */ sleep (1); int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (connect (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "connect"); unlink (sun.sun_path); *(int *) CMSG_DATA (cmsg) = -1; if (recvmsg (sock, &msg, MSG_CMSG_CLOEXEC) < 0) error (1, errno, "recvmsg"); int fd = *(int *) CMSG_DATA (cmsg); if (fd == -1) error (1, 0, "no descriptor received"); char fdname[20]; snprintf (fdname, sizeof (fdname), "%d", fd); execl ("/proc/self/exe", argv[0], fdname, NULL); puts ("execl failed"); return 1; } [akpm@linux-foundation.org: Fix fastcall inconsistency noted by Michael Buesch] [akpm@linux-foundation.org: build fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Buesch <mb@bu3sch.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] fdtable: Provide free_fdtable() wrapperVadim Lobanov
Christoph Hellwig has expressed concerns that the recent fdtable changes expose the details of the RCU methodology used to release no-longer-used fdtable structures to the rest of the kernel. The trivial patch below addresses these concerns by introducing the appropriate free_fdtable() calls, which simply wrap the release RCU usage. Since free_fdtable() is a one-liner, it makes sense to promote it to an inline helper. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] fdtable: Implement new pagesize-based fdtable allocatorVadim Lobanov
This patch provides an improved fdtable allocation scheme, useful for expanding fdtable file descriptor entries. The main focus is on the fdarray, as its memory usage grows 128 times faster than that of an fdset. The allocation algorithm sizes the fdarray in such a way that its memory usage increases in easy page-sized chunks. The overall algorithm expands the allowed size in powers of two, in order to amortize the cost of invoking vmalloc() for larger allocation sizes. Namely, the following sizes for the fdarray are considered, and the smallest that accommodates the requested fd count is chosen: pagesize / 4 pagesize / 2 pagesize <- memory allocator switch point pagesize * 2 pagesize * 4 ...etc... Unlike the current implementation, this allocation scheme does not require a loop to compute the optimal fdarray size, and can be done in efficient straightline code. Furthermore, since the fdarray overflows the pagesize boundary long before any of the fdsets do, it makes sense to optimize run-time by allocating both fdsets in a single swoop. Even together, they will still be, by far, smaller than the fdarray. The fdtable->open_fds is now used as the anchor for the fdset memory allocation. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] fdtable: Remove the free_files fieldVadim Lobanov
An fdtable can either be embedded inside a files_struct or standalone (after being expanded). When an fdtable is being discarded after all RCU references to it have expired, we must either free it directly, in the standalone case, or free the files_struct it is contained within, in the embedded case. Currently the free_files field controls this behavior, but we can get rid of it entirely, as all the necessary information is already recorded. We can distinguish embedded and standalone fdtables using max_fds, and if it is embedded we can divine the relevant files_struct using container_of(). Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Move filep_cachep to include/file.hChristoph Lameter
filp_cachep is only used in fs/file_table.c and in fs/dcache.c where it is defined. Move it to related definitions in linux/file.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Move files_cachep to include/file.hChristoph Lameter
Proper place is in file.h since files_cachep uses are rated to file I/O. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix unserialized task->files changingKirill Korotaev
Fixed race on put_files_struct on exec with proc. Restoring files on current on error path may lead to proc having a pointer to already kfree-d files_struct. ->files changing at exit.c and khtread.c are safe as exit_files() makes all things under lock. Found during OpenVZ stress testing. [akpm@osdl.org: add export] Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Shrinks sizeof(files_struct) and better layoutEric Dumazet
1) Reduce the size of (struct fdtable) to exactly 64 bytes on 32bits platforms, lowering kmalloc() allocated space by 50%. 2) Reduce the size of (files_struct), using a special 32 bits (or 64bits) embedded_fd_set, instead of a 1024 bits fd_set for the close_on_exec_init and open_fds_init fields. This save some ram (248 bytes per task) as most tasks dont open more than 32 files. D-Cache footprint for such tasks is also reduced to the minimum. 3) Reduce size of allocated fdset. Currently two full pages are allocated, that is 32768 bits on x86 for example, and way too much. The minimum is now L1_CACHE_BYTES. UP and SMP should benefit from this patch, because most tasks will touch only one cache line when open()/close() stdin/stdout/stderr (0/1/2), (next_fd, close_on_exec_init, open_fds_init, fd_array[0 .. 2] being in the same cache line) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] fix file countingDipankar Sarma
I have benchmarked this on an x86_64 NUMA system and see no significant performance difference on kernbench. Tested on both x86_64 and powerpc. The way we do file struct accounting is not very suitable for batched freeing. For scalability reasons, file accounting was constructor/destructor based. This meant that nr_files was decremented only when the object was removed from the slab cache. This is susceptible to slab fragmentation. With RCU based file structure, consequent batched freeing and a test program like Serge's, we just speed this up and end up with a very fragmented slab - llm22:~ # cat /proc/sys/fs/file-nr 587730 0 758844 At the same time, I see only a 2000+ objects in filp cache. The following patch I fixes this problem. This patch changes the file counting by removing the filp_count_lock. Instead we use a separate percpu counter, nr_files, for now and all accesses to it are through get_nr_files() api. In the sysctl handler for nr_files, we populate files_stat.nr_files before returning to user. Counting files as an when they are created and destroyed (as opposed to inside slab) allows us to correctly count open files with RCU. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] reorder struct files_structEric Dumazet
The file_lock spinlock sits close to mostly read fields of 'struct files_struct' In SMP (and NUMA) environments, each time a thread wants to open or close a file, it has to acquire the spinlock, thus invalidating the cache line containing this spinlock on other CPUS. So other threads doing read()/write()/... calls that use RCU to access the file table are going to ask further memory (possibly NUMA) transactions to read again this memory line. Move the spinlock to another cache line, so that concurrent threads can share the cache line containing 'count' and 'fdt' fields. It's worth up to 9% on a microbenchmark using a 4-thread 2-package x86 machine. See http://marc.theaimsgroup.com/?l=linux-kernel&m=112680448713342&w=2 Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] mm: rename kmem_cache_s to kmem_cachePekka J Enberg
This patch renames struct kmem_cache_s to kmem_cache so we can start using it instead of kmem_cache_t typedef. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: files struct with RCUDipankar Sarma
Patch to eliminate struct files_struct.file_lock spinlock on the reader side and use rcu refcounting rcuref_xxx api for the f_count refcounter. The updates to the fdtable are done by allocating a new fdtable structure and setting files->fdt to point to the new structure. The fdtable structure is protected by RCU thereby allowing lock-free lookup. For fd arrays/sets that are vmalloced, we use keventd to free them since RCU callbacks can't sleep. A global list of fdtable to be freed is not scalable, so we use a per-cpu list. If keventd is already handling the current cpu's work, we use a timer to defer queueing of that work. Since the last publication, this patch has been re-written to avoid using explicit memory barriers and use rcu_assign_pointer(), rcu_dereference() premitives instead. This required that the fd information is kept in a separate structure (fdtable) and updated atomically. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
