This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Get rid of this compile warning:
In file included from arch/s390/kernel/compat_linux.c:37:0:
include/linux/filter.h:139:23: warning: 'struct sk_buff' declared inside parameter list
In order to speedup packet filtering, here is an implementation of a
JIT compiler for x86_64
It is disabled by default, and must be enabled by the admin.
echo 1 >/proc/sys/net/core/bpf_jit_enable
It uses module_alloc() and module_free() to get memory in the 2GB text
kernel range since we call helpers functions from the generated code.
EAX : BPF A accumulator
EBX : BPF X accumulator
RDI : pointer to skb (first argument given to JIT function)
RBP : frame pointer (even if CONFIG_FRAME_POINTER=n)
r9d : skb->len - skb->data_len (headlen)
r8 : skb->data
To get a trace of generated code, use :
echo 2 >/proc/sys/net/core/bpf_jit_enable
Example of generated code :
# tcpdump -p -n -s 0 -i eth1 host 192.168.20.0/24
flen=18 proglen=147 pass=3 image=ffffffffa00b5000
JIT code: ffffffffa00b5000: 55 48 89 e5 48 83 ec 60 48 89 5d f8 44 8b 4f 60
JIT code: ffffffffa00b5010: 44 2b 4f 64 4c 8b 87 b8 00 00 00 be 0c 00 00 00
JIT code: ffffffffa00b5020: e8 24 7b f7 e0 3d 00 08 00 00 75 28 be 1a 00 00
JIT code: ffffffffa00b5030: 00 e8 fe 7a f7 e0 24 00 3d 00 14 a8 c0 74 49 be
JIT code: ffffffffa00b5040: 1e 00 00 00 e8 eb 7a f7 e0 24 00 3d 00 14 a8 c0
JIT code: ffffffffa00b5050: 74 36 eb 3b 3d 06 08 00 00 74 07 3d 35 80 00 00
JIT code: ffffffffa00b5060: 75 2d be 1c 00 00 00 e8 c8 7a f7 e0 24 00 3d 00
JIT code: ffffffffa00b5070: 14 a8 c0 74 13 be 26 00 00 00 e8 b5 7a f7 e0 24
JIT code: ffffffffa00b5080: 00 3d 00 14 a8 c0 75 07 b8 ff ff 00 00 eb 02 31
JIT code: ffffffffa00b5090: c0 c9 c3
BPF program is 144 bytes long, so native program is almost same size ;)
(000) ldh [12]
(001) jeq #0x800 jt 2 jf 8
(002) ld [26]
(003) and #0xffffff00
(004) jeq #0xc0a81400 jt 16 jf 5
(005) ld [30]
(006) and #0xffffff00
(007) jeq #0xc0a81400 jt 16 jf 17
(008) jeq #0x806 jt 10 jf 9
(009) jeq #0x8035 jt 10 jf 17
(010) ld [28]
(011) and #0xffffff00
(012) jeq #0xc0a81400 jt 16 jf 13
(013) ld [38]
(014) and #0xffffff00
(015) jeq #0xc0a81400 jt 16 jf 17
(016) ret #65535
(017) ret #0
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Hagen Paul Pfeifer <hagen@jauu.net>
sk_run_filter() doesnt write on skb, change its prototype to reflect
this.
Fix two af_packet comments.
Add SKF_AD_RXHASH and SKF_AD_CPU to filter ancillary mechanism,
to be able to build advanced filters.
This can help spreading packets on several sockets with a fast
selection, after RPS dispatch to N cpus for example, or to catch a
percentage of flows in one queue.
tcpdump -s 500 "cpu = 1" :
[0] ld CPU
[1] jeq #1 jt 2 jf 3
[2] ret #500
[3] ret #0
# take 12.5 % of flows (average)
tcpdump -s 1000 "rxhash & 7 = 2" :
[0] ld RXHASH
[1] and #7
[2] jeq #2 jt 3 jf 4
[3] ret #1000
[4] ret #0
Cc: Rui <wirelesser@gmail.com>
Acked-by: Changli Gao <xiaosuo@gmail.com>
Remove pc variable to avoid arithmetic to compute fentry at each filter
instruction. Jumps directly manipulate fentry pointer.
As the last instruction of filter[] is guaranteed to be a RETURN, and
all jumps are before the last instruction, we dont need to check filter
bounds (number of instructions in filter array) at each iteration, so we
remove it from sk_run_filter() params.
On x86_32 remove f_k var introduced in commit 57fe93b374a6b871
(filter: make sure filters dont read uninitialized memory)
Note : We could use a CONFIG_ARCH_HAS_{FEW|MANY}_REGISTERS in order to
avoid too many ifdefs in this code.
This helps compiler to use cpu registers to hold fentry and A
accumulator.
On x86_32, this saves 401 bytes, and more important, sk_run_filter()
runs much faster because less register pressure (One less conditional
branch per BPF instruction)
# size net/core/filter.o net/core/filter_pre.o
2948 0 0 2948 b84 net/core/filter.o
3349 0 0 3349 d15 net/core/filter_pre.o
on x86_64 :
5173 0 0 5173 1435 net/core/filter.o
5224 0 0 5224 1468 net/core/filter_pre.o
BPF_S_* are used internally, should not be exposed to the others.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Acked-by: Hagen Paul Pfeifer <hagen@jauu.net>
Gcc is currenlty not in the ability to optimize the switch statement in
sk_run_filter() because of dense case labels. This patch replace the
OR'd labels with ordered sequenced case labels. The sk_chk_filter()
function is modified to patch/replace the original OPCODES in a
ordered but equivalent form. gcc is now in the ability to transform the
switch statement in sk_run_filter into a jump table of complexity O(1).
Until this patch gcc generates a sequence of conditional branches (O(n) of 567
byte .text segment size (arch x86_64):
7ff: 8b 06 mov (%rsi),%eax
801: 66 83 f8 35 cmp $0x35,%ax
805: 0f 84 d0 02 00 00 je adb <sk_run_filter+0x31d>
80b: 0f 87 07 01 00 00 ja 918 <sk_run_filter+0x15a>
811: 66 83 f8 15 cmp $0x15,%ax
815: 0f 84 c5 02 00 00 je ae0 <sk_run_filter+0x322>
81b: 77 73 ja 890 <sk_run_filter+0xd2>
81d: 66 83 f8 04 cmp $0x4,%ax
821: 0f 84 17 02 00 00 je a3e <sk_run_filter+0x280>
827: 77 29 ja 852 <sk_run_filter+0x94>
829: 66 83 f8 01 cmp $0x1,%ax
With the modification the compiler translate the switch statement into
the following jump table fragment:
7ff: 66 83 3e 2c cmpw $0x2c,(%rsi)
803: 0f 87 1f 02 00 00 ja a28 <sk_run_filter+0x26a>
809: 0f b7 06 movzwl (%rsi),%eax
80c: ff 24 c5 00 00 00 00 jmpq *0x0(,%rax,8)
813: 44 89 e3 mov %r12d,%ebx
816: e9 43 03 00 00 jmpq b5e <sk_run_filter+0x3a0>
81b: 41 89 dc mov %ebx,%r12d
81e: e9 3b 03 00 00 jmpq b5e <sk_run_filter+0x3a0>
Furthermore, I reordered the instructions to reduce cache line misses by
order the most common instruction to the start.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Add an SKF_AD_HATYPE field to the packet ancilliary data area, giving
access to skb->dev->type, as reported in the sll_hatype field.
When capturing packets on a PF_PACKET/SOCK_RAW socket bound to all
interfaces, there doesn't appear to be a way for the filter program to
actually find out the underlying hardware type the packet was captured
on. This patch adds such ability.
This patch also handles the case where skb->dev can be NULL, such as on
netlink sockets.
Signed-off-by: Paul Evans <leonerd@leonerd.org.uk>
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
It can help being able to filter packets on their queue_mapping.
If filter performance is not good, we could add a "numqueue" field
in struct packet_type, so that netif_nit_deliver() and other functions
can directly ignore packets with not expected queue number.
Lets experiment this simple filter extension first.
Allow bpf to set a filter to drop packets that dont
match a specific mark
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
SKF_AD_NLATTR allows us to find the first matching attribute in a
stream of netlink attributes from one offset to the end of the
netlink message. This is not suitable to look for a specific
matching inside a set of nested attributes.
For example, in ctnetlink messages, if we look for the CTA_V6_SRC
attribute in a message that talks about an IPv4 connection,
SKF_AD_NLATTR returns the offset of CTA_STATUS which has the same
value of CTA_V6_SRC but outside the nest. To differenciate
CTA_STATUS and CTA_V6_SRC, we would have to make assumptions on the
size of the attribute and the usual offset, resulting in horrible
BSF code.
This patch adds SKF_AD_NLATTR_NEST, which is a variant of
SKF_AD_NLATTR, that looks for an attribute inside the limits of
a nested attributes, but not further.
This patch validates that we have enough room to look for the
nested attributes - based on a suggestion from Patrick McHardy.
Acked-by: Patrick McHardy <kaber@trash.net>
SKF_ADF_NLATTR searches for a netlink attribute, which avoids manually
parsing and walking attributes. It takes the offset at which to start
searching in the 'A' register and the attribute type in the 'X' register
and returns the offset in the 'A' register. When the attribute is not
found it returns zero.
A top-level attribute can be located using a filter like this
(example for nfnetlink, using struct nfgenmsg):
/* A = offset of first attribute */
.code = BPF_LD | BPF_IMM,
.k = sizeof(struct nlmsghdr) + sizeof(struct nfgenmsg)
/* X = CTA_PROTOINFO */
.code = BPF_LDX | BPF_IMM,
.k = CTA_PROTOINFO,
/* A = netlink attribute offset */
.code = BPF_LD | BPF_B | BPF_ABS,
.k = SKF_AD_OFF + SKF_AD_NLATTR
/* Exit if not found */
.code = BPF_JMP | BPF_JEQ | BPF_K,
.k = 0,
.jt = <error>
A nested attribute below the CTA_PROTOINFO attribute would then
be parsed like this:
/* A += sizeof(struct nlattr) */
.code = BPF_ALU | BPF_ADD | BPF_K,
.k = sizeof(struct nlattr),
/* X = CTA_PROTOINFO_TCP */
.k = CTA_PROTOINFO_TCP,
The data of an attribute can be loaded into 'A' like this:
/* X = A (attribute offset) */
.code = BPF_MISC | BPF_TAX,
/* A = skb->data[X + k] */
.code = BPF_LD | BPF_B | BPF_IND,
The sk_filter function is too big to be inlined. This saves 2296 bytes
of text on allyesconfig.
Some minor style cleanups:
* Move __KERNEL__ definitions to one place in filter.h
* Use const for sk_filter_len
* Line wrapping
* Put EXPORT_SYMBOL next to function definition
Filter is attached in a separate function, so do the
same for filter detaching.
This also removes one variable sock_setsockopt().
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Function sk_filter() is called from tcp_v{4,6}_rcv() functions with arg
needlock = 0, while socket is not locked at that moment. In order to avoid
this and similar issues in the future, use rcu for sk->sk_filter field read
protection.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
It should return an unsigned value, and fix sk_filter() as well.
Signed-off-by: Kris Katterjohn <kjak@ispwest.com>
infrastructure for it.
Let it rip!
