commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
* 'for-linus' of git://git.kernel.dk/linux-block:
floppy: use del_timer_sync() in init cleanup
blk-cgroup: be able to remove the record of unplugged device
block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request
mm: Add comment explaining task state setting in bdi_forker_thread()
mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread()
block: simplify force plug flush code a little bit
block: change force plug flush call order
block: Fix queue_flag update when rq_affinity goes from 2 to 1
block: separate priority boosting from REQ_META
block: remove READ_META and WRITE_META
xen-blkback: fixed indentation and comments
xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
Purely in-memory filesystems do not use the inode hash as the dcache
tells us if an entry already exists. As a result, they do not call
unlock_new_inode, and thus directory inodes do not get put into a
different lockdep class for i_sem.
We need the different lockdep classes, because the locking order for
i_mutex is different for directory inodes and regular inodes. Directory
inodes can do "readdir()", which takes i_mutex *before* possibly taking
mm->mmap_sem (due to a page fault while copying the directory entry to
user space).
In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem
before accessing i_mutex.
The two cases can never happen for the same inode, so no real deadlock
can occur, but without the different lockdep classes, lockdep cannot
understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this
can lead to false positives from lockdep like below:
find/645 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac
but task is already holding lock:
(&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>]
vfs_readdir+0x5b/0xb4
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}:
[<ffffffff8108ac26>] lock_acquire+0xbf/0x103
[<ffffffff814db822>] __mutex_lock_common+0x4c/0x361
[<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45
[<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110
[<ffffffff81111557>] mmap_region+0x258/0x432
[<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306
[<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a
[<ffffffff8100c858>] sys_mmap+0x22/0x24
[<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7
[<ffffffff81109541>] might_fault+0x89/0xac
[<ffffffff81149cff>] filldir+0x6f/0xc7
[<ffffffff811586ea>] dcache_readdir+0x67/0x205
[<ffffffff81149f54>] vfs_readdir+0x7b/0xb4
[<ffffffff8114a073>] sys_getdents+0x7e/0xd1
This patch moves the directory vs file lockdep annotation into a helper
function that can be called by in-memory filesystems and has hugetlbfs
call it.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Replace all occurnanced of the undocumented READ_META with READ | REQ_META
and remove the unused WRITE_META define.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
The inode structure layout is largely random, and some of the vfs paths
really do care. The path lookup in particular is already quite D$
intensive, and profiles show that accessing the 'inode->i_op->xyz'
fields is quite costly.
We already optimized the dcache to not unnecessarily load the d_op
structure for members that are often NULL using the DCACHE_OP_xyz bits
in dentry->d_flags, and this does something very similar for the inode
ops that are used during pathname lookup.
It also re-orders the fields so that the fields accessed by 'stat' are
together at the beginning of the inode structure, and roughly in the
order accessed.
The effect of this seems to be in the 1-2% range for an empty kernel
"make -j" run (which is fairly kernel-intensive, mostly in filename
lookup), so it's visible. The numbers are fairly noisy, though, and
likely depend a lot on exact microarchitecture. So there's more tuning
to be done.
Some inodes (pipes, sockets, ...) are not hashed, no need to take
contended inode_hash_lock at dismantle time.
nice speedup on SMP machines on socket intensive workloads.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
merge fchmod() and fchmodat() guts, kill ancient broken kludge
xfs: fix misspelled S_IS...()
xfs: get rid of open-coded S_ISREG(), etc.
vfs: document locking requirements for d_move, __d_move and d_materialise_unique
omfs: fix (mode & S_IFDIR) abuse
btrfs: S_ISREG(mode) is not mode & S_IFREG...
ima: fmode_t misspelled as mode_t...
pci-label.c: size_t misspelled as mode_t
jffs2: S_ISLNK(mode & S_IFMT) is pointless
snd_msnd ->mode is fmode_t, not mode_t
v9fs_iop_get_acl: get rid of unused variable
vfs: dont chain pipe/anon/socket on superblock s_inodes list
Documentation: Exporting: update description of d_splice_alias
fs: add missing unlock in default_llseek()
Workloads using pipes and sockets hit inode_sb_list_lock contention.
superblock s_inodes list is needed for quota, dirty, pagecache and
fsnotify management. pipe/anon/socket fs are clearly not candidates for
these.
* 'for-3.1' of git://linux-nfs.org/~bfields/linux:
nfsd: don't break lease on CLAIM_DELEGATE_CUR
locks: rename lock-manager ops
nfsd4: update nfsv4.1 implementation notes
nfsd: turn on reply cache for NFSv4
nfsd4: call nfsd4_release_compoundargs from pc_release
nfsd41: Deny new lock before RECLAIM_COMPLETE done
fs: locks: remove init_once
nfsd41: check the size of request
nfsd41: error out when client sets maxreq_sz or maxresp_sz too small
nfsd4: fix file leak on open_downgrade
nfsd4: remember to put RW access on stateid destruction
NFSD: Added TEST_STATEID operation
NFSD: added FREE_STATEID operation
svcrpc: fix list-corrupting race on nfsd shutdown
rpc: allow autoloading of gss mechanisms
svcauth_unix.c: quiet sparse noise
svcsock.c: include sunrpc.h to quiet sparse noise
nfsd: Remove deprecated nfsctl system call and related code.
NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
fs: take the ACL checks to common code
bury posix_acl_..._masq() variants
kill boilerplates around posix_acl_create_masq()
generic_acl: no need to clone acl just to push it to set_cached_acl()
kill boilerplate around posix_acl_chmod_masq()
reiserfs: cache negative ACLs for v1 stat format
xfs: cache negative ACLs if there is no attribute fork
9p: do no return 0 from ->check_acl without actually checking
vfs: move ACL cache lookup into generic code
CIFS: Fix oops while mounting with prefixpath
xfs: Fix wrong return value of xfs_file_aio_write
fix devtmpfs race
caam: don't pass bogus S_IFCHR to debugfs_create_...()
get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose
asus-wmi: ->is_visible() can't return negative
fix jffs2 ACLs on big-endian with 16bit mode_t
9p: close ACL leaks
ocfs2_init_acl(): fix a leak
VFS : mount lock scalability for internal mounts
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits)
block: strict rq_affinity
backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu
block: fix patch import error in max_discard_sectors check
block: reorder request_queue to remove 64 bit alignment padding
CFQ: add think time check for group
CFQ: add think time check for service tree
CFQ: move think time check variables to a separate struct
fixlet: Remove fs_excl from struct task.
cfq: Remove special treatment for metadata rqs.
block: document blk_plug list access
block: avoid building too big plug list
compat_ioctl: fix make headers_check regression
block: eliminate potential for infinite loop in blkdev_issue_discard
compat_ioctl: fix warning caused by qemu
block: flush MEDIA_CHANGE from drivers on close(2)
blk-throttle: Make total_nr_queued unsigned
block: Add __attribute__((format(printf...) and fix fallout
fs/partitions/check.c: make local symbols static
block:remove some spare spaces in genhd.c
block:fix the comment error in blkdev.h
For a number of file systems that don't have a mount point (e.g. sockfs
and pipefs), they are not marked as long term. Therefore in
mntput_no_expire, all locks in vfs_mount lock are taken instead of just
local cpu's lock to aggregate reference counts when we release
reference to file objects. In fact, only local lock need to have been
taken to update ref counts as these file systems are in no danger of
going away until we are ready to unregister them.
The attached patch marks file systems using kern_mount without
mount point as long term. The contentions of vfs_mount lock
is now eliminated. Before un-registering such file system,
kern_unmount should be called to remove the long term flag and
make the mount point ready to be freed.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Fix build error when CONFIG_BLOCK is not enabled by providing a stub
inode_dio_wait() function.
mm/truncate.c:612: error: implicit declaration of function 'inode_dio_wait'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Big kernel lock had been removed and setlease now use the lock_flocks()
to hold a special spin lock file_lock_lock by Matthew.
So just remove the out-of-date NOTE.
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
This just gets us ready to support the SEEK_HOLE and SEEK_DATA flags. Turns out
using fiemap in things like cp cause more problems than it solves, so lets try
and give userspace an interface that doesn't suck. We need to match solaris
here, and the definitions are
*o* If /whence/ is SEEK_HOLE, the offset of the start of the
next hole greater than or equal to the supplied offset
is returned. The definition of a hole is provided near
the end of the DESCRIPTION.
*o* If /whence/ is SEEK_DATA, the file pointer is set to the
start of the next non-hole file region greater than or
equal to the supplied offset.
So in the generic case the entire file is data and there is a virtual hole at
the end. That means we will just return i_size for SEEK_HOLE and will return
the same offset for SEEK_DATA. This is how Solaris does it so we have to do it
the same way.
Thanks,
Simple filesystems always pass inode->i_sb_bdev as the block device
argument, and never need a end_io handler. Let's simply things for
them and for my grepping activity by dropping these arguments. The
only thing not falling into that scheme is ext4, which passes and
end_io handler without needing special flags (yet), but given how
messy the direct I/O code there is use of __blockdev_direct_IO
in one instead of two out of three cases isn't going to make a large
difference anyway.
i_alloc_sem is a rather special rw_semaphore. It's the last one that may
be released by a non-owner, and it's write side is always mirrored by
real exclusion. It's intended use it to wait for all pending direct I/O
requests to finish before starting a truncate.
Replace it with a hand-grown construct:
- exclusion for truncates is already guaranteed by i_mutex, so it can
simply fall way
- the reader side is replaced by an i_dio_count member in struct inode
that counts the number of pending direct I/O requests. Truncate can't
proceed as long as it's non-zero
- when i_dio_count reaches non-zero we wake up a pending truncate using
wake_up_bit on a new bit in i_flags
- new references to i_dio_count can't appear while we are waiting for
it to read zero because the direct I/O count always needs i_mutex
(or an equivalent like XFS's i_iolock) for starting a new operation.
This scheme is much simpler, and saves the space of a spinlock_t and a
struct list_head in struct inode (typically 160 bits on a non-debug 64-bit
system).
Now we have a per-superblock shrinker implementation, we can add a
filesystem specific callout to it to allow filesystem internal
caches to be shrunk by the superblock shrinker.
Rather than perpetuate the multipurpose shrinker callback API (i.e.
nr_to_scan == 0 meaning "tell me how many objects freeable in the
cache), two operations will be added. The first will return the
number of objects that are freeable, the second is the actual
shrinker call.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
With context based shrinkers, we can implement a per-superblock
shrinker that shrinks the caches attached to the superblock. We
currently have global shrinkers for the inode and dentry caches that
split up into per-superblock operations via a coarse proportioning
method that does not batch very well. The global shrinkers also
have a dependency - dentries pin inodes - so we have to be very
careful about how we register the global shrinkers so that the
implicit call order is always correct.
With a per-sb shrinker callout, we can encode this dependency
directly into the per-sb shrinker, hence avoiding the need for
strictly ordering shrinker registrations. We also have no need for
any proportioning code for the shrinker subsystem already provides
this functionality across all shrinkers. Allowing the shrinker to
operate on a single superblock at a time means that we do less
superblock list traversals and locking and reclaim should batch more
effectively. This should result in less CPU overhead for reclaim and
potentially faster reclaim of items from each filesystem.
Both the filesystem and the lock manager can associate operations with a
lock. Confusingly, one of them (fl_release_private) actually has the
same name in both operation structures.
It would save some confusion to give the lock-manager ops different
names.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
With the inode LRUs moving to per-sb structures, there is no longer
a need for a global inode_lru_lock. The locking can be made more
fine-grained by moving to a per-sb LRU lock, isolating the LRU
operations of different filesytsems completely from each other.
The inode unused list is currently a global LRU. This does not match
the other global filesystem cache - the dentry cache - which uses
per-superblock LRU lists. Hence we have related filesystem object
types using different LRU reclaimation schemes.
To enable a per-superblock filesystem cache shrinker, both of these
caches need to have per-sb unused object LRU lists. Hence this patch
converts the global inode LRU to per-sb LRUs.
The patch only does rudimentary per-sb propotioning in the shrinker
infrastructure, as this gets removed when the per-sb shrinker
callouts are introduced later on.
not used anymore
not used by the instances anymore.
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of
them removes that bit.
not used in the instances anymore.
Duplicate the flags argument into mask bitmap.
its value depends only on inode and does not change; we might as
well store it in ->i_op->check_acl and be done with that.
new helpers: atomic_inc_unless_negative()/atomic_dec_unless_positive()
convert the last remaining caller to inode_permission()
Call the given function for all superblocks of given type. Function
gets a superblock (with s_umount locked shared) and (void *) argument
supplied by caller of iterator.
fs_excl is a poor man's priority inheritance for filesystems to hint to
the block layer that an operation is important. It was never clearly
specified, not widely adopted, and will not prevent starvation in many
cases (like across cgroups).
fs_excl was introduced with the time sliced CFQ IO scheduler, to
indicate when a process held FS exclusive resources and thus needed
a boost.
It doesn't cover all file systems, and it was never fully complete.
Lets kill it.
Signed-off-by: Justin TerAvest <teravest@google.com>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Under heavy memory and filesystem load, users observe the assertion
mapping->nrpages == 0 in end_writeback() trigger. This can be caused by
page reclaim reclaiming the last page from a mapping in the following
race:
CPU0 CPU1
shrink_page_list()
__remove_mapping()
__delete_from_page_cache()
radix_tree_delete()
evict_inode()
truncate_inode_pages()
truncate_inode_pages_range()
pagevec_lookup() - finds nothing
end_writeback()
mapping->nrpages != 0 -> BUG
page->mapping = NULL
mapping->nrpages--
Fix the problem by doing a reliable check of mapping->nrpages under
mapping->tree_lock in end_writeback().
Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out
by Miklos Szeredi <mszeredi@suse.de>.
Cc: Jay <jinshan.xiong@whamcloud.com>
Cc: Miklos Szeredi <mszeredi@suse.de>
Cc: <stable@kernel.org>
Commit 13e12d14e2dc ("vfs: reorganize 'struct inode' layout a bit")
moved things around a bit changed i_state to be unsigned int instead of
unsigned long. That was to help structure layout for the 64-bit case,
and shrink 'struct inode' a bit (admittedly that only happened when
spinlock debugging was on and i_flags didn't pack with i_lock).
However, Meelis Roos reports that this results in unaligned exceptions
on sprc, and it turns out that the bit-locking primitives that we use
for the I_NEW bit want to use the bitops. Which want 'unsigned long',
not 'unsigned int'.
We really should fix the bit locking code to not have that kind of
requirement, but that's a much bigger change. So for now, revert that
field back to 'unsigned long' (but keep the other re-ordering changes
from the commit that caused this).
Andi points out that we have played games with this in 'struct page', so
it's solvable with other hacks too, but since right now the struct inode
size advantage only happens with some rare config options, it's not
worth fighting.
It _would_ be worth fixing the bitlocking code, though. Especially
since there is no type safety in the bitlocking code (this never caused
any warnings, and worked fine on x86-64, because the bitlocks take a
'void *' and x86-64 doesn't care that deeply about alignment). So it's
currently a very easy problem to trigger by mistake and never notice.
Reported-by: Meelis Roos <mroos@linux.ee>
Many stupid corrections of duplicated includes based on the output of
scripts/checkincludes.pl.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
This tries to make the 'struct inode' accesses denser in the data cache
by moving a commonly accessed field (i_security) closer to other fields
that are accessed often.
It also makes 'i_state' just an 'unsigned int' rather than 'unsigned
long', since we only use a few bits of that field, and moves it next to
the existing 'i_flags' so that we potentially get better structure
layout (although depending on config options, i_flags may already have
packed in the same word as i_lock, so this improves packing only for the
case of spinlock debugging)
Out 'struct inode' is still way too big, and we should probably move
some other fields around too (the acl fields in particular) for better
data cache access density. Other fields (like the inode hash) are
likely to be entirely irrelevant under most loads.
Caching "we have already removed suid/caps" was overenthusiastic as merged.
On network filesystems we might have had suid/caps set on another client,
silently picked by this client on revalidate, all of that *without* clearing
the S_NOSEC flag.
AFAICS, the only reasonably sane way to deal with that is
* new superblock flag; unless set, S_NOSEC is not going to be set.
* local block filesystems set it in their ->mount() (more accurately,
mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than
local block ones clear it)
* if any network filesystem (or a cluster one) wants to use S_NOSEC,
it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when
inode attribute changes are picked from other clients.
It's not an earth-shattering hole (anybody that can set suid on another client
will almost certainly be able to write to the file before doing that anyway),
but it's a bug that needs fixing.
Some recent benchmarking on btrfs showed that a major scaling bottleneck
on large systems on btrfs is currently the xattr lookup on every write.
Why xattr lookup on every write I hear you ask?
write wants to drop suid and security related xattrs that could set o
capabilities for executables. To do that it currently looks up
security.capability on EVERY write (even for non executables) to decide
whether to drop it or not.
In btrfs this causes an additional tree walk, hitting some per file system
locks and quite bad scalability. In a simple read workload on a 8S
system I saw over 90% CPU time in spinlocks related to that.
Chris Mason tells me this is also a problem in ext4, where it hits
the global mbcache lock.
This patch adds a simple per inode to avoid this problem. We only
do the lookup once per file and then if there is no xattr cache
the decision. All xattr changes clear the flag.
I also used the same flag to avoid the suid check, although
that one is pretty cheap.
A file system can also set this flag when it creates the inode,
if it has a cheap way to do so. This is done for some common file systems
in followon patches.
With this patch a major part of the lock contention disappears
for btrfs. Some testing on smaller systems didn't show significant
performance changes, but at least it helps the larger systems
and is generally more efficient.
v2: Rename is_sgid. add file system helper.
Cc: chris.mason@oracle.com
Cc: josef@redhat.com
Cc: viro@zeniv.linux.org.uk
Cc: agruen@linbit.com
Cc: Serge E. Hallyn <serue@us.ibm.com>
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or
anything else, so that the filesystem can track internally if it
needs to push out a transaction for fdatasync or not.
This is just the prototype change with no user for it yet. I plan
to push large XFS changes for the next merge window, and getting
this trivial infrastructure in this window would help a lot to avoid
tree interdependencies.
Also remove incorrect comments that ->dirty_inode can't block. That
has been changed a long time ago, and many implementations rely on it.
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem:
xen: cleancache shim to Xen Transcendent Memory
ocfs2: add cleancache support
ext4: add cleancache support
btrfs: add cleancache support
ext3: add cleancache support
mm/fs: add hooks to support cleancache
mm: cleancache core ops functions and config
fs: add field to superblock to support cleancache
mm/fs: cleancache documentation
Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
This second patch of eight in this cleancache series adds a field to
the generic superblock to squirrel away a pool identifier that is
dynamically provided by cleancache-enabled filesystems at mount time
to uniquely identify files and pages belonging to this mounted filesystem.
Details and a FAQ can be found in Documentation/vm/cleancache.txt
[v8: trivial merge conflict update]
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Apps are increasingly using more than 1024 file descriptors. See
discussion in several distro bug trackers, e.g. BugLink:
http://bugs.launchpad.net/bugs/663090
https://issues.rpath.com/browse/RPL-2054
You don't want to raise the default soft limit, since that might break
apps that use select(), but it's safe to raise the default hard limit;
that way, apps that know they need lots of file descriptors can raise
their soft limit without needing root, and without user intervention.
Ubuntu is doing this with a kernel change because they have a policy of
not changing kernel defaults in userland.
While 4096 might not be enough for *all* apps, it seems to be plenty for
the apps I've seen lately that are unhappy with 1024.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Dan Kegel <dank@kegel.com>
Straightforward conversion of i_mmap_lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Namhyung Kim <namhyung@gmail.com>
Hugh says:
"The only significant loser, I think, would be page reclaim (when
concurrent with truncation): could spin for a long time waiting for
the i_mmap_mutex it expects would soon be dropped? "
Counter points:
- cpu contention makes the spin stop (need_resched())
- zap pages should be freeing pages at a higher rate than reclaim
ever can
I think the simplification of the truncate code is definitely worth it.
Effectively reverts: 2aa15890f3c ("mm: prevent concurrent
unmap_mapping_range() on the same inode") and takes out the code that
caused its problem.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: fix FS_IOC_SETFLAGS ioctl
Btrfs: fix FS_IOC_GETFLAGS ioctl
fs: remove FS_COW_FL
Btrfs: fix easily get into ENOSPC in mixed case
Prevent oopsing in posix_acl_valid()
