commit ee296d7c5709440f8abd36b5b65c6b3e388538d9 upstream.
They just call file_inode and then the corresponding *_inode_file_wait
function. Just make them static inlines instead.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Cc: William Dauchy <william@gandi.net>
commit 29d01b22eaa18d8b46091d3c98c6001c49f78e4a upstream.
Allow callers to pass in an inode instead of a filp.
Reviewed-by: "J. Bruce Fields" <bfields@fieldses.org>
Tested-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 4bacc9c9234c7c8eec44f5ed4e960d9f96fa0f01 upstream.
Make file->f_path always point to the overlay dentry so that the path in
/proc/pid/fd is correct and to ensure that label-based LSMs have access to the
overlay as well as the underlay (path-based LSMs probably don't need it).
Using my union testsuite to set things up, before the patch I see:
[root@andromeda union-testsuite]# bash 5</mnt/a/foo107
[root@andromeda union-testsuite]# ls -l /proc/$$/fd/
lr-x------. 1 root root 64 Jun 5 14:38 5 -> /a/foo107
[root@andromeda union-testsuite]# stat /mnt/a/foo107
Device: 23h/35d Inode: 13381 Links: 1
[root@andromeda union-testsuite]# stat -L /proc/$$/fd/5
After the patch:
lr-x------. 1 root root 64 Jun 5 14:22 5 -> /mnt/a/foo107
Device: 23h/35d Inode: 40346 Links: 1
Note the change in where /proc/$$/fd/5 points to in the ls command. It was
pointing to /a/foo107 (which doesn't exist) and now points to /mnt/a/foo107
(which is correct).
The inode accessed, however, is the lower layer. The union layer is on device
25h/37d and the upper layer on 24h/36d.
Cc: "Kamata, Munehisa" <kamatam@amazon.com>
commit 1b852bceb0d111e510d1a15826ecc4a19358d512 upstream.
Fresh mounts of proc and sysfs are a very special case that works very
much like a bind mount. Unfortunately the current structure can not
preserve the MNT_LOCK... mount flags. Therefore refactor the logic
into a form that can be modified to preserve those lock bits.
Add a new filesystem flag FS_USERNS_VISIBLE that requires some mount
of the filesystem be fully visible in the current mount namespace,
before the filesystem may be mounted.
Move the logic for calling fs_fully_visible from proc and sysfs into
fs/namespace.c where it has greater access to mount namespace state.
commit fbabfd0f4ee2e8847bf56edf481249ad1bb8c44d upstream.
To ensure it is safe to mount proc and sysfs I need to check if
filesystems that are mounted on top of them are mounted on truly empty
directories. Given that some directories can gain entries over time,
knowing that a directory is empty right now is insufficient.
Therefore add supporting infrastructure for permantently empty
directories that proc and sysfs can use when they create mount points
for filesystems and fs_fully_visible can use to test for permanently
empty directories to ensure that nothing will be gained by mounting a
fresh copy of proc or sysfs.
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
I_DIO_WAKEUP is never directly used, but fix it up anyway.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
do_blockdev_direct_IO() increments and decrements the inode
->i_dio_count for each IO operation. It does this to protect against
truncate of a file. Block devices don't need this sort of protection.
For a capable multiqueue setup, this atomic int is the only shared
state between applications accessing the device for O_DIRECT, and it
presents a scaling wall for that. In my testing, as much as 30% of
system time is spent incrementing and decrementing this value. A mixed
read/write workload improved from ~2.5M IOPS to ~9.6M IOPS, with
better latencies too. Before:
clat percentiles (usec):
| 1.00th=[ 33], 5.00th=[ 34], 10.00th=[ 34], 20.00th=[ 34],
| 30.00th=[ 34], 40.00th=[ 34], 50.00th=[ 35], 60.00th=[ 35],
| 70.00th=[ 35], 80.00th=[ 35], 90.00th=[ 37], 95.00th=[ 80],
| 99.00th=[ 98], 99.50th=[ 151], 99.90th=[ 155], 99.95th=[ 155],
| 99.99th=[ 165]
After:
| 1.00th=[ 95], 5.00th=[ 108], 10.00th=[ 129], 20.00th=[ 149],
| 30.00th=[ 155], 40.00th=[ 161], 50.00th=[ 167], 60.00th=[ 171],
| 70.00th=[ 177], 80.00th=[ 185], 90.00th=[ 201], 95.00th=[ 270],
| 99.00th=[ 390], 99.50th=[ 398], 99.90th=[ 418], 99.95th=[ 422],
| 99.99th=[ 438]
In other setups, Robert Elliott reported seeing good performance
improvements:
https://lkml.org/lkml/2015/4/3/557
The more applications accessing the device, the worse it gets.
Add a new direct-io flags, DIO_SKIP_DIO_COUNT, which tells
do_blockdev_direct_IO() that it need not worry about incrementing
or decrementing the inode i_dio_count for this caller.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Elliott, Robert (Server Storage) <elliott@hp.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
Let's show locks which are associated with a file descriptor in
its fdinfo file.
Currently we don't have a reliable way to determine who holds a lock. We
can find some information in /proc/locks, but PID which is reported there
can be wrong. For example, a process takes a lock, then forks a child and
dies. In this case /proc/locks contains the parent pid, which can be
reused by another process.
$ cat /proc/locks
6: FLOCK ADVISORY WRITE 324 00:13:13431 0 EOF
$ ps -C rpcbind
PID TTY TIME CMD
332 ? 00:00:00 rpcbind
$ cat /proc/332/fdinfo/4
pos: 0
flags: 0100000
mnt_id: 22
lock: 1: FLOCK ADVISORY WRITE 324 00:13:13431 0 EOF
$ ls -l /proc/332/fd/4
lr-x------ 1 root root 64 Mar 5 14:43 /proc/332/fd/4 -> /run/rpcbind.lock
$ ls -l /proc/324/fd/
total 0
lrwx------ 1 root root 64 Feb 27 14:50 0 -> /dev/pts/0
lrwx------ 1 root root 64 Feb 27 14:50 1 -> /dev/pts/0
lrwx------ 1 root root 64 Feb 27 14:49 2 -> /dev/pts/0
You can see that the process with the 324 pid doesn't hold the lock.
This information is required for proper dumping and restoring file
locks.
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Jonathan Corbet <corbet@lwn.net>
Acked-by: Jeff Layton <jlayton@poochiereds.net>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Joe Perches <joe@perches.com>
This patch removes mm->mmap_sem from mm->exe_file read side.
Also it kills dup_mm_exe_file() and moves exe_file duplication into
dup_mmap() where both mmap_sems are locked.
[akpm@linux-foundation.org: fix comment typo]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
Merge second patchbomb from Andrew Morton:
- the rest of MM
- various misc bits
- add ability to run /sbin/reboot at reboot time
- printk/vsprintf changes
- fiddle with seq_printf() return value
* akpm: (114 commits)
parisc: remove use of seq_printf return value
lru_cache: remove use of seq_printf return value
tracing: remove use of seq_printf return value
cgroup: remove use of seq_printf return value
proc: remove use of seq_printf return value
s390: remove use of seq_printf return value
cris fasttimer: remove use of seq_printf return value
cris: remove use of seq_printf return value
openrisc: remove use of seq_printf return value
ARM: plat-pxa: remove use of seq_printf return value
nios2: cpuinfo: remove use of seq_printf return value
microblaze: mb: remove use of seq_printf return value
ipc: remove use of seq_printf return value
rtc: remove use of seq_printf return value
power: wakeup: remove use of seq_printf return value
x86: mtrr: if: remove use of seq_printf return value
linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK
MAINTAINERS: CREDITS: remove Stefano Brivio from B43
.mailmap: add Ricardo Ribalda
CREDITS: add Ricardo Ribalda Delgado
[v1]
Without this patch, c/mtime is not updated correctly when mmap'ed page is
first read from and then written to.
A new xfstest is submitted for testing this (generic/080)
[v2]
Jan Kara has pointed out that if we add the
sb_start/end_pagefault pair in the new pfn_mkwrite we
are then fixing another bug where: A user could start
writing to the page while filesystem is frozen.
Signed-off-by: Yigal Korman <yigal@plexistor.com>
Signed-off-by: Boaz Harrosh <boaz@plexistor.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: <stable@vger.kernel.org>
vfs_readdir() was replaced by iterate_dir() in commit 5c0ba4e0762e
("[readdir] introduce iterate_dir() and dir_context").
Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com>
Pull file locking related changes from Jeff Layton:
"This set is mostly minor cleanups to the overhaul that went in last
cycle. The other noticeable items are the changes to the lm_get_owner
and lm_put_owner prototypes, and the fact that we no longer need to
use the i_lock to protect the i_flctx pointer"
* tag 'locks-v4.1-1' of git://git.samba.org/jlayton/linux:
locks: use cmpxchg to assign i_flctx pointer
locks: get rid of WE_CAN_BREAK_LSLK_NOW dead code
locks: change lm_get_owner and lm_put_owner prototypes
locks: don't allocate a lock context for an F_UNLCK request
locks: Add lockdep assertion for blocked_lock_lock
locks: remove extraneous IS_POSIX and IS_FLOCK tests
locks: Remove unnecessary IS_POSIX test
Pull second vfs update from Al Viro:
"Now that net-next went in... Here's the next big chunk - killing
->aio_read() and ->aio_write().
There'll be one more pile today (direct_IO changes and
generic_write_checks() cleanups/fixes), but I'd prefer to keep that
one separate"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
->aio_read and ->aio_write removed
pcm: another weird API abuse
infinibad: weird APIs switched to ->write_iter()
kill do_sync_read/do_sync_write
fuse: use iov_iter_get_pages() for non-splice path
fuse: switch to ->read_iter/->write_iter
switch drivers/char/mem.c to ->read_iter/->write_iter
make new_sync_{read,write}() static
coredump: accept any write method
switch /dev/loop to vfs_iter_write()
serial2002: switch to __vfs_read/__vfs_write
ashmem: use __vfs_read()
export __vfs_read()
autofs: switch to __vfs_write()
new helper: __vfs_write()
switch hugetlbfs to ->read_iter()
coda: switch to ->read_iter/->write_iter
ncpfs: switch to ->read_iter/->write_iter
net/9p: remove (now-)unused helpers
p9_client_attach(): set fid->uid correctly
Pull vfs update from Al Viro:
"Part one:
- struct filename-related cleanups
- saner iov_iter_init() replacements (and switching the syscalls to
use of those)
- ntfs switch to ->write_iter() (Anton)
- aio cleanups and splitting iocb into common and async parts
(Christoph)
- assorted fixes (me, bfields, Andrew Elble)
There's a lot more, including the completion of switchover to
->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags
race fixes, etc, but that goes after #for-davem merge. David has
pulled it, and once it's in I'll send the next vfs pull request"
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits)
sg_start_req(): use import_iovec()
sg_start_req(): make sure that there's not too many elements in iovec
blk_rq_map_user(): use import_single_range()
sg_io(): use import_iovec()
process_vm_access: switch to {compat_,}import_iovec()
switch keyctl_instantiate_key_common() to iov_iter
switch {compat_,}do_readv_writev() to {compat_,}import_iovec()
aio_setup_vectored_rw(): switch to {compat_,}import_iovec()
vmsplice_to_user(): switch to import_iovec()
kill aio_setup_single_vector()
aio: simplify arguments of aio_setup_..._rw()
aio: lift iov_iter_init() into aio_setup_..._rw()
lift iov_iter into {compat_,}do_readv_writev()
NFS: fix BUG() crash in notify_change() with patch to chown_common()
dcache: return -ESTALE not -EBUSY on distributed fs race
NTFS: Version 2.1.32 - Update file write from aio_write to write_iter.
VFS: Add iov_iter_fault_in_multipages_readable()
drop bogus check in file_open_root()
switch security_inode_getattr() to struct path *
constify tomoyo_realpath_from_path()
... avoiding write_iter/fcntl races.
... returning -E... upon error and amount of data left in iter after
(possible) truncation upon success. Note, that normal case gives
a non-zero (positive) return value, so any tests for != 0 _must_ be
updated.
fs/ext4/file.c
all remaining callers are passing 0; some just obscure that fact.
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
And use iov_iter_rw() instead.
Most filesystems call through to these at some point, so we'll start
here.
no remaining users
all remaining instances of aio_{read,write} (all 4 of them) have explicit
->read and ->write resp.; do_sync_read/do_sync_write is never called by
__vfs_read/__vfs_write anymore and no other users had been left.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
just make const char iname[] the last member and compare name->name with
name->iname instead of checking name->separate
We need to make sure that out-of-line name doesn't end up allocated adjacent
to struct filename refering to it; fortunately, it's easy to achieve - just
allocate that struct filename with one byte in ->iname[], so that ->iname[0]
will be inside the same object and thus have an address different from that
of out-of-line name [spotted by Boqun Feng <boqun.feng@gmail.com>]
trivial conflict in net/socket.c and non-trivial one in crypto -
that one had evaded aio_complete() removal.
teach ->mremap() method to return an error and have it fail for
aio mappings in process of being killed
Note that in case of ->mremap() failure we need to undo move_page_tables()
we'd already done; we could call ->mremap() first, but then the failure of
move_page_tables() would require undoing whatever _successful_ ->mremap()
has done, which would be a lot more headache in general.
The current prototypes for these operations are somewhat awkward as they
deal with fl_owners but take struct file_lock arguments. In the future,
we'll want to be able to take references without necessarily dealing
with a struct file_lock.
Change them to take fl_owner_t arguments instead and have the callers
deal with assigning the values to the file_lock structs.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
Jan Kara pointed out that if there is an inode which is constantly
getting dirtied with I_DIRTY_PAGES, an inode with an updated timestamp
will never be written since inode->dirtied_when is constantly getting
updated. We fix this by adding an extra field to the inode,
dirtied_time_when, so inodes with a stale dirtytime can get detected
and handled.
In addition, if we have a dirtytime inode caused by an atime update,
and there is no write activity on the file system, we need to have a
secondary system to make sure these inodes get written out. We do
this by setting up a second delayed work structure which wakes up the
CPU much more rarely compared to writeback_expire_centisecs.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Pull file locking fixes from Jeff Layton:
"A small set of patches to fix problems with the recent file locking
changes that we discussed earlier this week"
* tag 'locks-v3.20-2' of git://git.samba.org/jlayton/linux:
locks: fix list insertion when lock is split in two
locks: remove conditional lock release in middle of flock_lock_file
locks: only remove leases associated with the file being closed
Revert "locks: keep a count of locks on the flctx lists"
Pull lazytime mount option support from Al Viro:
"Lazytime stuff from tytso"
* 'lazytime' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ext4: add optimization for the lazytime mount option
vfs: add find_inode_nowait() function
vfs: add support for a lazytime mount option
Pull iov_iter updates from Al Viro:
"More iov_iter work - missing counterpart of iov_iter_init() for
bvec-backed ones and vfs_read_iter()/vfs_write_iter() - wrappers for
sync calls of ->read_iter()/->write_iter()"
* 'iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: add vfs_iter_{read,write} helpers
new helper: iov_iter_bvec()
Pull getname/putname updates from Al Viro:
"Rework of getname/getname_kernel/etc., mostly from Paul Moore. Gets
rid of quite a pile of kludges between namei and audit..."
* 'getname2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
audit: replace getname()/putname() hacks with reference counters
audit: fix filename matching in __audit_inode() and __audit_inode_child()
audit: enable filename recording via getname_kernel()
simpler calling conventions for filename_mountpoint()
fs: create proper filename objects using getname_kernel()
fs: rework getname_kernel to handle up to PATH_MAX sized filenames
cut down the number of do_path_lookup() callers
This new function allows us to support hole-punch for DAX files by zeroing
a partial page, as opposed to the dax_truncate_page() function which can
only truncate to the end of the page. Reimplement dax_truncate_page() to
call dax_zero_page_range().
[ross.zwisler@linux.intel.com: ported to 3.13-rc2]
[akpm@linux-foundation.org: fix typos in comments]
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
The fewer Kconfig options we have the better. Use the generic
CONFIG_FS_DAX to enable XIP support in ext2 as well as in the core.
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
All callers of get_xip_mem() are now gone. Remove checks for it,
initialisers of it, documentation of it and the only implementation of it.
Also remove mm/filemap_xip.c as it is now empty. Also remove
documentation of the long-gone get_xip_page().
It takes a get_block parameter just like nobh_truncate_page() and
block_truncate_page()
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Instead of calling aops->get_xip_mem from the fault handler, the
filesystem passes a get_block_t that is used to find the appropriate
blocks.
This requires that all architectures implement copy_user_page(). At the
time of writing, mips and arm do not. Patches exist and are in progress.
[akpm@linux-foundation.org: remap_file_pages went away]
This is practically generic code; other filesystems will want to call it
from other places, but there's nothing ext2-specific about it.
Make it a little more generic by allowing it to take a count of the number
of bytes to zero rather than fixing it to a single page. Thanks to Dave
Hansen for suggesting that I need to call cond_resched() if zeroing more
than one page.
Use the generic AIO infrastructure instead of custom read and write
methods. In addition to giving us support for AIO, this adds the missing
locking between read() and truncate().
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Use an inode flag to tag inodes which should avoid using the page cache.
Convert ext2 to use it instead of mapping_is_xip(). Prevent I/Os to files
tagged with the DAX flag from falling back to buffered I/O.
This reverts commit 9bd0f45b7037fcfa8b575c7e27d0431d6e6dc3bb.
Linus rightly pointed out that I failed to initialize the counters
when adding them, so they don't work as expected. Just revert this
patch for now.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
