path: root/include/linux/fsl_devices.h
2012-09-24powerpc/usb: remove checking PHY_CLK_VALID for UTMI PHYShengzhou Liu
PHY_CLK_VALID bit doesn't work properly with UTMI PHY. e.g. This bit is always zero on P5040, etc. There is no need to check this bit for UTMI PHY, just keep checking for ULPI PHY to prevent system hanging. This patch should be squashed into previous commit 3735ba8db8e6e "powerpc/usb: fix bug of CPU hang when missing USB PHY clock" Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-21fsl/usb: Add support for USB controller version 2.4Ramneek Mehresh
Add support for USB controller version 2.4 Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05powerpc/usb: fix bug of CPU hang when missing USB PHY clockShengzhou Liu
when missing USB PHY clock, kernel booting up will hang during USB initialization. We should check USBGP[PHY_CLK_VALID] bit to avoid CPU hanging in this case. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18fsl/usb: Add controller version based ULPI and UTMI phy supportRamneek Mehresh
Add support for ULPI and UTMI PHYs based on usb controller version info read from device-tree Example of USB Controller versioning info: Version 1.2 and below : MPC8536, MPC8315, etc Version 1.6 : P1020, P1010, P2020, P5020, etc Version 2.2 : PSC9131, PSC9132, P3060, etc No changes for non-DT users Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-05-02USB: extend ehci-fsl and fsl_udc_core driver for OTG operationAnatolij Gustschin
Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Li Yang <leoli@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02USB: ehci-fsl: add MPC5121E specific suspend and resumeAnatolij Gustschin
Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22mxc_udc: add workaround for ENGcm09152 for i.MX35Eric Bénard
this patch gives the possibility to workaround bug ENGcm09152 on i.MX35 when the hardware workaround is also implemented on the board. It covers the workaround described on page 25 of the following Errata : http://cache.freescale.com/files/dsp/doc/errata/IMX35CE.pdf Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: add USB EHCI support for MPC5121 SoCAnatolij Gustschin
Extends FSL EHCI platform driver glue layer to support MPC5121 USB controllers. MPC5121 Rev 2.0 silicon EHCI registers are in big endian format. The appropriate flags are set using the information in the platform data structure. MPC83xx system interface registers are not available on MPC512x, so the access to these registers is isolated in MPC512x case. Furthermore the USB controller clocks must be enabled before 512x register accesses which is done by providing platform specific init callback. The MPC512x internal USB PHY doesn't provide supply voltage. For boards using different power switches allow specifying DRVVBUS and PWR_FAULT signal polarity of the MPC5121 internal PHY using "fsl,invert-drvvbus" and "fsl,invert-pwr-fault" properties in the device tree USB nodes. Adds documentation for this new device tree bindings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-24powerpc: Fix build of some FSL platformsBenjamin Herrenschmidt
Commit 87ec0e98cfdd8b68da6a7f9e70142ffc0e404fbb in kumar's next branch broke one of my test configs since it looks like Anton forgot about that mpc832x_rdb platform which still uses the old style probing for the SPI stuff. I'll let them do a cleaner fix that probably involves changing the probing method and getting rid of the platform device but for now this will do to fix it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-11powerpc/fsl: Make fsl_deep_sleep() usable w/ modules and non-83xx buildsAnton Vorontsov
Export is needed for modular builds, and a static inline stub is needed for non-MPC83xx builds. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-11spi_mpc8xxx: Turn qe_mode into flagsAnton Vorontsov
Soon there will be more flags introduced in subsequent patches, so let's turn qe_mode into flags. Also introduce mpc8xxx_spi_strmode() and print current SPI mode. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-18mpc52xx_psc_spi: convert to cs_control callbackAnton Vorontsov
mpc52xx_psc_spi driver is the last user of the legacy activate_cs and deactivate_cs callbacks, so convert the driver to the cs_control hook and remove the legacy callbacks from fsl_spi_platform_data struct. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-22Merge branch 'merge' of git://git.secretlab.ca/git/linux-2.6 into mergePaul Mackerras
2009-04-16powerpc/5200: Bring the legacy fsl_spi_platform_data hooks backAnton Vorontsov
In commit 364fdbc00fbdd409ade63500710123fe323aa164 ("spi_mpc83xx: rework chip selects handling"), I merged activate_cs and deactivate_cs hooks into cs_control, but I overlooked that mpc52xx_psc_spi driver is using these hooks too. And that resulted in the following build failure: CC drivers/spi/mpc52xx_psc_spi.o drivers/spi/mpc52xx_psc_spi.c: In function 'mpc52xx_psc_spi_do_probe': drivers/spi/mpc52xx_psc_spi.c:398: error: 'struct fsl_spi_platform_data' has no member named 'activate_cs' drivers/spi/mpc52xx_psc_spi.c:399: error: 'struct fsl_spi_platform_data' has no member named 'deactivate_cs' make[2]: *** [drivers/spi/mpc52xx_psc_spi.o] Error 1 This patch simply adds the legacy hooks back for 2.6.30, and for 2.6.31 we'll convert the driver to ->cs_control. Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-04-08powerpc: Document new FSL I2C bindings and cleanupWolfgang Grandegger
This patch documents the new bindings for the MPC I2C bus driver. Furthermore, it removes obsolete FSL device related definitions for I2C. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-07Merge branch 'next' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
2009-04-01spi_mpc83xx: add OF platform driver bindingsAnton Vorontsov
Implement full support for OF SPI bindings. Now the driver can manage its own chip selects without any help from the board files and/or fsl_soc constructors. The "legacy" code is well isolated and could be removed as time goes by. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <david-b@pacbell.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01spi_mpc83xx: rework chip selects handlingAnton Vorontsov
The main purpose of this patch is to pass 'struct spi_device' to the chip select handling routines. This is needed so that we could implement full-fledged OpenFirmware support for this driver. While at it, also: - Replace two {de,activate}_cs routines by single cs_contol(). - Don't duplicate platform data callbacks in mpc83xx_spi struct. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <david-b@pacbell.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31powerpc: Remove unused symbols from fsl_devices.hGrant Likely
Remove old artifacts leftover from the platform driver gianfar and fsl_i2c drivers. These symbols became unused when the drivers were migrated over to use the of_platform bus. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-16gianfar: Convert gianfar to an of_platform_driverAndy Fleming
Does the same for the accompanying MDIO driver, and then modifies the TBI configuration method. The old way used fields in einfo, which no longer exists. The new way is to create an MDIO device-tree node for each instance of gianfar, and create a tbi-handle property to associate ethernet controllers with the TBI PHYs they are connected to. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31gianfar: Fix race in TBI/SerDes configurationTrent Piepho
The init_phy() function attaches to the PHY, then configures the SerDes<->TBI link (in SGMII mode). The TBI is on the MDIO bus with the PHY (sort of) and is accessed via the gianfar's MDIO registers, using the functions gfar_local_mdio_read/write(), which don't do any locking. The previously attached PHY will start a work-queue on a timer, and probably an irq handler as well, which will talk to the PHY and thus use the MDIO bus. This uses phy_read/write(), which have locking, but not against the gfar_local_mdio versions. The result is that PHY code will try to use the MDIO bus at the same time as the SerDes setup code, corrupting the transfers. Setting up the SerDes before attaching to the PHY will insure that there is no race between the SerDes code and *our* PHY, but doesn't fix everything. Typically the PHYs for all gianfar devices are on the same MDIO bus, which is associated with the first gianfar device. This means that the first gianfar's SerDes code could corrupt the MDIO transfers for a different gianfar's PHY. The lock used by phy_read/write() is contained in the mii_bus structure, which is pointed to by the PHY. This is difficult to access from the gianfar drivers, as there is no link between a gianfar device and the mii_bus which shares the same MDIO registers. As far as the device layer and drivers are concerned they are two unrelated devices (which happen to share registers). Generally all gianfar devices' PHYs will be on the bus associated with the first gianfar. But this might not be the case, so simply locking the gianfar's PHY's mii bus might not lock the mii bus that the SerDes setup code is going to use. We solve this by having the code that creates the gianfar platform device look in the device tree for an mdio device that shares the gianfar's registers. If one is found the ID of its platform device is saved in the gianfar's platform data. A new function in the gianfar mii code, gfar_get_miibus(), can use the bus ID to search through the platform devices for a gianfar_mdio device with the right ID. The platform device's driver data is the mii_bus structure, which the SerDes setup code can use to lock the current bus. Signed-off-by: Trent Piepho <tpiepho@freescale.com> CC: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-16gianfar: Add magic packet and suspend/resume support.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16powerpc/mpc83xx: Power Management supportScott Wood
Basic PM support for 83xx. Standby is implemented as sleep. Suspend-to-RAM is implemented as "deep sleep" (with the processor turned off) on 831x. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-07-18Fix RGMII-ID handling in gianfarAndy Fleming
The TSEC/eTSEC can detect the interface to the PHY automatically, but it isn't able to detect whether the RGMII connection needs internal delay. So we need to detect that change in the device tree, propagate it to the platform data, and then check it if we're in RGMII. This fixes a bug on the 8641D HPCN board where the Vitesse PHY doesn't use the delay for RGMII. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-07-17spi_mpc83xx.c: support QE enabled 83xx CPU's like mpc832xJoakim Tjernlund
Quicc Engine enabled mpc83xx CPU's has a somewhat different HW interface to the SPI controller. This patch adds a qe_mode knob that sees to that needed adaptions are performed. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[POWERPC] 8xx: mpc885ads pcmcia supportVitaly Bordug
Adds support for PowerQuicc on-chip PCMCIA. The driver is implemented as of_device, so only arch/powerpc stuff is capable to use it, which now implies only mpc885ads reference board. To cope with the code that should be hooked inside driver, but is really board specific (like set_voltage), global structure mpc8xx_pcmcia_ops holds necessary function pointers that are filled in the BSP code. [akpm@linux-foundation.org: whitespace diddles] Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-28ucc_geth: migrate ucc_geth to phylibKim Phillips
migrate ucc_geth to use the common phylib code. There are several side effects from doing this: o deprecate 'interface' property specification present in some old device tree source files in favour of a split 'max-speed' and 'interface-type' description to appropriately match definitions in include/linux/phy.h. Note that 'interface' property is still honoured if max-speed or interface-type are not present (backward compatible). o compile-time CONFIG_UGETH_HAS_GIGA is eliminated in favour of probe time speed derivation logic. o adjust_link streamlined to only operate on maccfg2 and upsmr.r10m, instead of reapplying static initial values related to the interface-type. o Addition of UEC MDIO of_platform driver requires platform code add 'mdio' type to id list prior to calling of_platform_bus_probe (separate patch). o ucc_struct_init introduced to reduce ucc_geth_startup complexity. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-10[PPC] Fix compile failure do to introduction of PHY_POLLKumar Gala
PHY_POLL is defined in <linux/phy.h> include it in <linux/fsl_devices.h> so board code will have it defined. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-04[POWERPC] Add QUICC Engine (QE) infrastructureLi Yang
Add QUICC Engine (QE) configuration, header files, and QE management and library code that are used by QE devices drivers. Includes Leo's modifications up to, and including, the platform_device to of_device adaptation: "The series of patches add generic QE infrastructure called qe_lib, and MPC8360EMDS board support. Qe_lib is used by QE device drivers such as ucc_geth driver. This version updates QE interrupt controller to use new irq mapping mechanism, addresses all the comments received with last submission and includes some style fixes. v2: Change to use device tree for BCSR and MURAM; Remove I/O port interrupt handling code as it is not generic enough. v3: Address comments from Kumar; Update definition of several device tree nodes; Copyright style change." In addition, the following changes have been made: o removed typedefs o uint -> u32 conversions o removed following defines: QE_SIZEOF_BD, BD_BUFFER_ARG, BD_BUFFER_CLEAR, BD_BUFFER, BD_STATUS_AND_LENGTH_SET, BD_STATUS_AND_LENGTH, and BD_BUFFER_SET because they hid sizeof/in_be32/out_be32 operations from the reader. o fixed qe_snums_init() serial num assignment to use a const array o made CONFIG_UCC_FAST select UCC_SLOW o reduced NR_QE_IC_INTS from 128 to 64 o remove _IO_BASE, etc. defines (not used) o removed irrelevant comments, added others to resemble removed BD_ defines o realigned struct definitions in headers o various other style fixes including things like pinMask -> pin_mask o fixed a ton of whitespace issues o marked ioregs as __be32/__be16 o removed platform_device code and redundant get_qe_base() o removed redundant comments o added cpu_relax() to qe_reset o uncasted all get_property() assignments o eliminated unneeded casts o eliminated immrbar_phys_to_virt (not used) Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Shlomi Gridish <gridish@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-21[PATCH] spi: add spi master driver for Freescale MPC83xx SPI controllerKumar Gala
This driver supports the SPI controller on the MPC83xx SoC devices from Freescale. Note, this driver supports only the simple shift register SPI controller and not the descriptor based CPM or QUICCEngine SPI controller. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] USB: EHCI for Freescale 83xxRandy Vinson
Adding a Host Mode USB driver for the Freescale 83xx. This driver supports both the Dual-Role (DR) controller and the Multi-Port-Host (MPH) controller present in the Freescale MPC8349. It has been tested with the MPC8349CDS reference system. This driver depends on platform support code for setting up the pins on the device package in a manner appropriate for the board in use. Note that this patch requires selecting the EHCI controller option under the USB Host menu. Signed-off-by: Randy Vinson <rvinson@mvista.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-12[PATCH] gianfar: Use new PHY_ID_FMT macroKumar Gala
Make the driver produce the string used by phy_connect and have board specific code pass the integer mii bus id and phy device id for the specific controller instance. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-12[PATCH] gianfar mii: Use proper resource for MII memory regionKumar Gala
We can now have the gianfar mii platform device have a proper resource for the IO memory region for its registers. Previously we passed this information that the platform_data structure because we couldn't handle overlapping memory regions for platform devices. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] ppc32: 85xx PHY Platform UpdateAndy Fleming
This patch updates the 85xx platform code to support the new PHY Layer. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <Kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-21[PATCH] ppc32: Added support for new MPC8548 family of PowerQUICC III processorsKumar Gala
Added descriptions of the new MPC8548 family processors, e500 core and peripherals. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
