The only caller to this function (__print_array) was getting it wrong by
passing the array length instead of buffer length. As the element size
was already being passed for other reasons it seems reasonable to push
the calculation of buffer length into the function.
Link: http://lkml.kernel.org/r/1430320727-14582-1-git-send-email-alex.bennee@linaro.org
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Pull perf changes from Ingo Molnar:
"Core kernel changes:
- One of the more interesting features in this cycle is the ability
to attach eBPF programs (user-defined, sandboxed bytecode executed
by the kernel) to kprobes.
This allows user-defined instrumentation on a live kernel image
that can never crash, hang or interfere with the kernel negatively.
(Right now it's limited to root-only, but in the future we might
allow unprivileged use as well.)
(Alexei Starovoitov)
- Another non-trivial feature is per event clockid support: this
allows, amongst other things, the selection of different clock
sources for event timestamps traced via perf.
This feature is sought by people who'd like to merge perf generated
events with external events that were measured with different
clocks:
- cluster wide profiling
- for system wide tracing with user-space events,
- JIT profiling events
etc. Matching perf tooling support is added as well, available via
the -k, --clockid <clockid> parameter to perf record et al.
(Peter Zijlstra)
Hardware enablement kernel changes:
- x86 Intel Processor Trace (PT) support: which is a hardware tracer
on steroids, available on Broadwell CPUs.
The hardware trace stream is directly output into the user-space
ring-buffer, using the 'AUX' data format extension that was added
to the perf core to support hardware constraints such as the
necessity to have the tracing buffer physically contiguous.
This patch-set was developed for two years and this is the result.
A simple way to make use of this is to use BTS tracing, the PT
driver emulates BTS output - available via the 'intel_bts' PMU.
More explicit PT specific tooling support is in the works as well -
will probably be ready by 4.2.
(Alexander Shishkin, Peter Zijlstra)
- x86 Intel Cache QoS Monitoring (CQM) support: this is a hardware
feature of Intel Xeon CPUs that allows the measurement and
allocation/partitioning of caches to individual workloads.
These kernel changes expose the measurement side as a new PMU
driver, which exposes various QoS related PMU events. (The
partitioning change is work in progress and is planned to be merged
as a cgroup extension.)
(Matt Fleming, Peter Zijlstra; CPU feature detection by Peter P
Waskiewicz Jr)
- x86 Intel Haswell LBR call stack support: this is a new Haswell
feature that allows the hardware recording of call chains, plus
tooling support. To activate this feature you have to enable it
via the new 'lbr' call-graph recording option:
perf record --call-graph lbr
perf report
or:
perf top --call-graph lbr
This hardware feature is a lot faster than stack walk or dwarf
based unwinding, but has some limitations:
- It reuses the current LBR facility, so LBR call stack and
branch record can not be enabled at the same time.
- It is only available for user-space callchains.
(Yan, Zheng)
- x86 Intel Broadwell CPU support and various event constraints and
event table fixes for earlier models.
(Andi Kleen)
- x86 Intel HT CPUs event scheduling workarounds. This is a complex
CPU bug affecting the SNB,IVB,HSW families that results in counter
value corruption. The mitigation code is automatically enabled and
is transparent.
(Maria Dimakopoulou, Stephane Eranian)
The perf tooling side had a ton of changes in this cycle as well, so
I'm only able to list the user visible changes here, in addition to
the tooling changes outlined above:
User visible changes affecting all tools:
- Improve support of compressed kernel modules (Jiri Olsa)
- Save DSO loading errno to better report errors (Arnaldo Carvalho de Melo)
- Bash completion for subcommands (Yunlong Song)
- Add 'I' event modifier for perf_event_attr.exclude_idle bit (Jiri Olsa)
- Support missing -f to override perf.data file ownership. (Yunlong Song)
- Show the first event with an invalid filter (David Ahern, Arnaldo Carvalho de Melo)
User visible changes in individual tools:
'perf data':
New tool for converting perf.data to other formats, initially
for the CTF (Common Trace Format) from LTTng (Jiri Olsa,
Sebastian Siewior)
'perf diff':
Add --kallsyms option (David Ahern)
'perf list':
Allow listing events with 'tracepoint' prefix (Yunlong Song)
Sort the output of the command (Yunlong Song)
'perf kmem':
Respect -i option (Jiri Olsa)
Print big numbers using thousands' group (Namhyung Kim)
Allow -v option (Namhyung Kim)
Fix alignment of slab result table (Namhyung Kim)
'perf probe':
Support multiple probes on different binaries on the same command line (Masami Hiramatsu)
Support unnamed union/structure members data collection. (Masami Hiramatsu)
Check kprobes blacklist when adding new events. (Masami Hiramatsu)
'perf record':
Teach 'perf record' about perf_event_attr.clockid (Peter Zijlstra)
Support recording running/enabled time (Andi Kleen)
'perf sched':
Improve the performance of 'perf sched replay' on high CPU core count machines (Yunlong Song)
'perf report' and 'perf top':
Allow annotating entries in callchains in the hists browser (Arnaldo Carvalho de Melo)
Indicate which callchain entries are annotated in the
TUI hists browser (Arnaldo Carvalho de Melo)
Add pid/tid filtering to 'report' and 'script' commands (David Ahern)
Consider PERF_RECORD_ events with cpumode == 0 in 'perf top', removing one
cause of long term memory usage buildup, i.e. not processing PERF_RECORD_EXIT
events (Arnaldo Carvalho de Melo)
'perf stat':
Report unsupported events properly (Suzuki K. Poulose)
Output running time and run/enabled ratio in CSV mode (Andi Kleen)
'perf trace':
Handle legacy syscalls tracepoints (David Ahern, Arnaldo Carvalho de Melo)
Only insert blank duration bracket when tracing syscalls (Arnaldo Carvalho de Melo)
Filter out the trace pid when no threads are specified (Arnaldo Carvalho de Melo)
Dump stack on segfaults (Arnaldo Carvalho de Melo)
No need to explicitely enable evsels for workload started from perf, let it
be enabled via perf_event_attr.enable_on_exec, removing some events that take
place in the 'perf trace' before a workload is really started by it.
Allow mixing with tracepoints and suppressing plain syscalls. (Arnaldo Carvalho de Melo)
There's also been a ton of infrastructure work done, such as the
split-out of perf's build system into tools/build/ and other changes -
see the shortlog and changelog for details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (358 commits)
perf/x86/intel/pt: Clean up the control flow in pt_pmu_hw_init()
perf evlist: Fix type for references to data_head/tail
perf probe: Check the orphaned -x option
perf probe: Support multiple probes on different binaries
perf buildid-list: Fix segfault when show DSOs with hits
perf tools: Fix cross-endian analysis
perf tools: Fix error path to do closedir() when synthesizing threads
perf tools: Fix synthesizing fork_event.ppid for non-main thread
perf tools: Add 'I' event modifier for exclude_idle bit
perf report: Don't call map__kmap if map is NULL.
perf tests: Fix attr tests
perf probe: Fix ARM 32 building error
perf tools: Merge all perf_event_attr print functions
perf record: Add clockid parameter
perf sched replay: Use replay_repeat to calculate the runavg of cpu usage instead of the default value 10
perf sched replay: Support using -f to override perf.data file ownership
perf sched replay: Fix the EMFILE error caused by the limitation of the maximum open files
perf sched replay: Handle the dead halt of sem_wait when create_tasks() fails for any task
perf sched replay: Fix the segmentation fault problem caused by pr_err in threads
perf sched replay: Realloc the memory of pid_to_task stepwise to adapt to the different pid_max configurations
Several tracepoints use the helper functions __print_symbolic() or
__print_flags() and pass in enums that do the mapping between the
binary data stored and the value to print. This works well for reading
the ASCII trace files, but when the data is read via userspace tools
such as perf and trace-cmd, the conversion of the binary value to a
human string format is lost if an enum is used, as userspace does not
have access to what the ENUM is.
For example, the tracepoint trace_tlb_flush() has:
__print_symbolic(REC->reason,
{ TLB_FLUSH_ON_TASK_SWITCH, "flush on task switch" },
{ TLB_REMOTE_SHOOTDOWN, "remote shootdown" },
{ TLB_LOCAL_SHOOTDOWN, "local shootdown" },
{ TLB_LOCAL_MM_SHOOTDOWN, "local mm shootdown" })
Which maps the enum values to the strings they represent. But perf and
trace-cmd do no know what value TLB_LOCAL_MM_SHOOTDOWN is, and would
not be able to map it.
With TRACE_DEFINE_ENUM(), developers can place these in the event header
files and ftrace will convert the enums to their values:
By adding:
TRACE_DEFINE_ENUM(TLB_FLUSH_ON_TASK_SWITCH);
TRACE_DEFINE_ENUM(TLB_REMOTE_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_MM_SHOOTDOWN);
$ cat /sys/kernel/debug/tracing/events/tlb/tlb_flush/format
{ 0, "flush on task switch" },
{ 1, "remote shootdown" },
{ 2, "local shootdown" },
{ 3, "local mm shootdown" })
The above is what userspace expects to see, and tools do not need to
be modified to parse them.
Link: http://lkml.kernel.org/r/20150403013802.220157513@goodmis.org
Cc: Guilherme Cox <cox@computer.org>
Cc: Tony Luck <tony.luck@gmail.com>
Cc: Xie XiuQi <xiexiuqi@huawei.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Tested-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Normally the compiler will use the same pointer for a string throughout
the file. But there's no guarantee of that happening. Later changes will
require that all events have the same pointer to the system string.
Name the system string and have all events point to it.
Testing this, it did not increases the size of the text, except for the
notes section, which should not harm the real size any.
BPF programs, attached to kprobes, provide a safe way to execute
user-defined BPF byte-code programs without being able to crash or
hang the kernel in any way. The BPF engine makes sure that such
programs have a finite execution time and that they cannot break
out of their sandbox.
The user interface is to attach to a kprobe via the perf syscall:
struct perf_event_attr attr = {
.type = PERF_TYPE_TRACEPOINT,
.config = event_id,
event_fd = perf_event_open(&attr,...);
ioctl(event_fd, PERF_EVENT_IOC_SET_BPF, prog_fd);
'prog_fd' is a file descriptor associated with BPF program
previously loaded.
'event_id' is an ID of the kprobe created.
Closing 'event_fd':
close(event_fd);
... automatically detaches BPF program from it.
BPF programs can call in-kernel helper functions to:
- lookup/update/delete elements in maps
- probe_read - wraper of probe_kernel_read() used to access any
kernel data structures
BPF programs receive 'struct pt_regs *' as an input ('struct pt_regs' is
architecture dependent) and return 0 to ignore the event and 1 to store
kprobe event into the ring buffer.
Note, kprobes are a fundamentally _not_ a stable kernel ABI,
so BPF programs attached to kprobes must be recompiled for
every kernel version and user must supply correct LINUX_VERSION_CODE
in attr.kern_version during bpf_prog_load() call.
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1427312966-8434-4-git-send-email-ast@plumgrid.com
add TRACE_EVENT_FL_KPROBE flag to differentiate kprobe type of
tracepoints, since bpf programs can only be attached to kprobe
type of PERF_TYPE_TRACEPOINT perf events.
Link: http://lkml.kernel.org/r/1427312966-8434-3-git-send-email-ast@plumgrid.com
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"The updates included in this pull request for ftrace are:
o Several clean ups to the code
One such clean up was to convert to 64 bit time keeping, in the
ring buffer benchmark code.
o Adding of __print_array() helper macro for TRACE_EVENT()
o Updating the sample/trace_events/ to add samples of different ways
to make trace events. Lots of features have been added since the
sample code was made, and these features are mostly unknown.
Developers have been making their own hacks to do things that are
already available.
o Performance improvements. Most notably, I found a performance bug
where a waiter that is waiting for a full page from the ring buffer
will see that a full page is not available, and go to sleep. The
sched event caused by it going to sleep would cause it to wake up
again. It would see that there was still not a full page, and go
back to sleep again, and that would wake it up again, until finally
it would see a full page. This change has been marked for stable.
Other improvements include removing global locks from fast paths"
* tag 'trace-v3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer: Do not wake up a splice waiter when page is not full
tracing: Fix unmapping loop in tracing_mark_write
tracing: Add samples of DECLARE_EVENT_CLASS() and DEFINE_EVENT()
tracing: Add TRACE_EVENT_FN example
tracing: Add TRACE_EVENT_CONDITION sample
tracing: Update the TRACE_EVENT fields available in the sample code
tracing: Separate out initializing top level dir from instances
tracing: Make tracing_init_dentry_tr() static
trace: Use 64-bit timekeeping
tracing: Add array printing helper
tracing: Remove newline from trace_printk warning banner
tracing: Use IS_ERR() check for return value of tracing_init_dentry()
tracing: Remove unneeded includes of debugfs.h and fs.h
tracing: Remove taking of trace_types_lock in pipe files
tracing: Add ref count to tracer for when they are being read by pipe
If a trace event contains an array, there is currently no standard
way to format this for text output. Drivers are currently hacking
around this by a) local hacks that use the trace_seq functionailty
directly, or b) just not printing that information. For fixed size
arrays, formatting of the elements can be open-coded, but this gets
cumbersome for arrays of non-trivial size.
These approaches result in non-standard content of the event format
description delivered to userspace, so userland tools needs to be
taught to understand and parse each array printing method
individually.
This patch implements a __print_array() helper that tracepoint
implementations can use instead of reinventing it. A simple C-style
syntax is used to delimit the array and its elements {like,this}.
So that the helpers can be used with large static arrays as well as
dynamic arrays, they take a pointer and element count: they can be
used with __get_dynamic_array() for use with dynamic arrays.
Link: http://lkml.kernel.org/r/1422449335-8289-2-git-send-email-javi.merino@arm.com
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Signed-off-by: Javi Merino <javi.merino@arm.com>
Both Linus (most recent) and Steve (a while ago) reported that perf
related callbacks have massive stack bloat.
The problem is that software events need a pt_regs in order to
properly report the event location and unwind stack. And because we
could not assume one was present we allocated one on stack and filled
it with minimal bits required for operation.
Now, pt_regs is quite large, so this is undesirable. Furthermore it
turns out that most sites actually have a pt_regs pointer available,
making this even more onerous, as the stack space is pointless waste.
This patch addresses the problem by observing that software events
have well defined nesting semantics, therefore we can use static
per-cpu storage instead of on-stack.
Linus made the further observation that all but the scheduler callers
of perf_sw_event() have a pt_regs available, so we change the regular
perf_sw_event() to require a valid pt_regs (where it used to be
optional) and add perf_sw_event_sched() for the scheduler.
We have a scheduler specific call instead of a more generic _noregs()
like construct because we can assume non-recursion from the scheduler
and thereby simplify the code further (_noregs would have to put the
recursion context call inline in order to assertain which __perf_regs
element to use).
One last note on the implementation of perf_trace_buf_prepare(); we
allow .regs = NULL for those cases where we already have a pt_regs
pointer available and do not need another.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Javi Merino <javi.merino@arm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Petr Mladek <pmladek@suse.cz>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Vaibhav Nagarnaik <vnagarnaik@google.com>
Link: http://lkml.kernel.org/r/20141216115041.GW3337@twins.programming.kicks-ass.net
Adding a trace_seq_has_overflowed() which returns true if the trace_seq
had too much written into it allows us to simplify the code.
Instead of checking the return value of every call to trace_seq_printf()
and friends, they can all be called normally, and at the end we can
return !trace_seq_has_overflowed() instead.
Several functions also return TRACE_TYPE_PARTIAL_LINE when the trace_seq
overflowed and TRACE_TYPE_HANDLED otherwise. Another helper function
was created called trace_handle_return() which takes a trace_seq and
returns these enums. Using this helper function also simplifies the
code.
This change also makes it possible to remove the return values of
trace_seq_printf() and friends. They should instead just be
void functions.
Link: http://lkml.kernel.org/r/20141114011410.365183157@goodmis.org
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Pull IPI tracepoints for ARM from Steven Rostedt:
"Nicolas Pitre added generic tracepoints for tracing IPIs and updated
the arm and arm64 architectures. It required some minor updates to
the generic tracepoint system, so it had to wait for me to implement
them"
* tag 'trace-ipi-tracepoints' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ARM64: add IPI tracepoints
ARM: add IPI tracepoints
tracepoint: add generic tracepoint definitions for IPI tracing
tracing: Do not do anything special with tracepoint_string when tracing is disabled
disabled
When CONFIG_TRACING is not enabled, there's no reason to save the trace
strings either by the linker or as a static variable that can be
referenced later. Simply pass back the string that is given to
tracepoint_string().
Had to move the define to include/linux/tracepoint.h so that it is still
visible when CONFIG_TRACING is not set.
Link: http://lkml.kernel.org/p/1406318733-26754-2-git-send-email-nicolas.pitre@linaro.org
Suggested-by: Nicolas Pitre <nico@linaro.org>
Remove ftrace_event_call->files. It has no users, and in fact even
the commit ae63b31e4d0e "tracing: Separate out trace events from
global variables" which added this member did not use it.
Link: http://lkml.kernel.org/p/20140715184827.GA20508@redhat.com
Remove destroy_call_preds(). Its only caller, __trace_remove_event_call(),
can use free_event_filter() and nullify ->filter by hand.
Perhaps we could keep this trivial helper although imo it is pointless, but
then it should be static in trace_events.c.
Link: http://lkml.kernel.org/p/20140715184816.GA20495@redhat.com
destroy_preds() makes no sense.
The only caller, event_remove(), actually wants destroy_file_preds().
__trace_remove_event_call() does destroy_call_preds() which takes care
of call->filter.
And after the previous change we can simply remove destroy_preds() from
event_remove(), we are going to call remove_event_from_tracers() which
in turn calls remove_event_file_dir()->free_event_filter().
Link: http://lkml.kernel.org/p/20140715184813.GA20488@redhat.com
Being able to show a cpumask of events can be useful as some events
may affect only some CPUs. There is no standard way to record the
cpumask and converting it to a string is rather expensive during
the trace as traces happen in hotpaths. It would be better to record
the raw event mask and be able to parse it at print time.
The following macros were added for use with the TRACE_EVENT() macro:
__bitmask()
__assign_bitmask()
__get_bitmask()
To test this, I added this to the sched_migrate_task event, which
looked like this:
TRACE_EVENT(sched_migrate_task,
TP_PROTO(struct task_struct *p, int dest_cpu, const struct cpumask *cpus),
TP_ARGS(p, dest_cpu, cpus),
TP_STRUCT__entry(
__array( char, comm, TASK_COMM_LEN )
__field( pid_t, pid )
__field( int, prio )
__field( int, orig_cpu )
__field( int, dest_cpu )
__bitmask( cpumask, num_possible_cpus() )
TP_fast_assign(
memcpy(__entry->comm, p->comm, TASK_COMM_LEN);
__entry->pid = p->pid;
__entry->prio = p->prio;
__entry->orig_cpu = task_cpu(p);
__entry->dest_cpu = dest_cpu;
__assign_bitmask(cpumask, cpumask_bits(cpus), num_possible_cpus());
TP_printk("comm=%s pid=%d prio=%d orig_cpu=%d dest_cpu=%d cpumask=%s",
__entry->comm, __entry->pid, __entry->prio,
__entry->orig_cpu, __entry->dest_cpu,
__get_bitmask(cpumask))
With the output of:
ksmtuned-3613 [003] d..2 485.220508: sched_migrate_task: comm=ksmtuned pid=3615 prio=120 orig_cpu=3 dest_cpu=2 cpumask=00000000,0000000f
migration/1-13 [001] d..5 485.221202: sched_migrate_task: comm=ksmtuned pid=3614 prio=120 orig_cpu=1 dest_cpu=0 cpumask=00000000,0000000f
awk-3615 [002] d.H5 485.221747: sched_migrate_task: comm=rcu_preempt pid=7 prio=120 orig_cpu=0 dest_cpu=1 cpumask=00000000,000000ff
migration/2-18 [002] d..5 485.222062: sched_migrate_task: comm=ksmtuned pid=3615 prio=120 orig_cpu=2 dest_cpu=3 cpumask=00000000,0000000f
Link: http://lkml.kernel.org/r/1399377998-14870-6-git-send-email-javi.merino@arm.com
Link: http://lkml.kernel.org/r/20140506132238.22e136d1@gandalf.local.home
Suggested-by: Javi Merino <javi.merino@arm.com>
Tested-by: Javi Merino <javi.merino@arm.com>
Register/unregister tracepoint probes with struct tracepoint pointer
rather than tracepoint name.
This change, which vastly simplifies tracepoint.c, has been proposed by
Steven Rostedt. It also removes 8.8kB (mostly of text) to the vmlinux
size.
From this point on, the tracers need to pass a struct tracepoint pointer
to probe register/unregister. A probe can now only be connected to a
tracepoint that exists. Moreover, tracers are responsible for
unregistering the probe before the module containing its associated
tracepoint is unloaded.
10443444 4282528 10391552 25117524 17f4354 vmlinux.orig
10434930 4282848 10391552 25109330 17f2352 vmlinux
Link: http://lkml.kernel.org/r/1396992381-23785-2-git-send-email-mathieu.desnoyers@efficios.com
CC: Ingo Molnar <mingo@kernel.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Frank Ch. Eigler <fche@redhat.com>
CC: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
[ SDR - fixed return val in void func in tracepoint_module_going() ]
"Most of the changes were largely clean ups, and some documentation.
But there were a few features that were added:
Uprobes now work with event triggers and multi buffers and have
support under ftrace and perf.
The big feature is that the function tracer can now be used within the
multi buffer instances. That is, you can now trace some functions in
one buffer, others in another buffer, all functions in a third buffer
and so on. They are basically agnostic from each other. This only
works for the function tracer and not for the function graph trace,
although you can have the function graph tracer running in the top
level buffer (or any tracer for that matter) and have different
function tracing going on in the sub buffers"
* tag 'trace-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (45 commits)
tracing: Add BUG_ON when stack end location is over written
tracepoint: Remove unused API functions
Revert "tracing: Move event storage for array from macro to standalone function"
ftrace: Constify ftrace_text_reserved
tracepoints: API doc update to tracepoint_probe_register() return value
tracepoints: API doc update to data argument
ftrace: Fix compilation warning about control_ops_free
ftrace/x86: BUG when ftrace recovery fails
ftrace: Warn on error when modifying ftrace function
ftrace: Remove freelist from struct dyn_ftrace
ftrace: Do not pass data to ftrace_dyn_arch_init
ftrace: Pass retval through return in ftrace_dyn_arch_init()
ftrace: Inline the code from ftrace_dyn_table_alloc()
ftrace: Cleanup of global variables ftrace_new_pgs and ftrace_update_cnt
tracing: Evaluate len expression only once in __dynamic_array macro
tracing: Correctly expand len expressions from __dynamic_array macro
tracing/module: Replace include of tracepoint.h with jump_label.h in module.h
tracing: Fix event header migrate.h to include tracepoint.h
tracing: Fix event header writeback.h to include tracepoint.h
tracing: Warn if a tracepoint is not set via debugfs
I originally wrote commit 35bb4399bd0e to shrink the size of the overhead of
tracepoints by several kilobytes. Later, I received a patch from Vaibhav
Nagarnaik that fixed a bug in the same code that this commit touches. Not
only did it fix a bug, it also removed code and shrunk the size of the
overhead of trace events even more than this commit did.
Since this commit is scheduled for 3.15 and Vaibhav's patch is already in
mainline, I need to revert this patch in order to keep it from conflicting
with Vaibhav's patch. Not to mention, Vaibhav's patch makes this patch
obsolete.
Link: http://lkml.kernel.org/r/20140320225637.0226041b@gandalf.local.home
In event format strings, the array size is reported in two locations.
One in array subscript and then via the "size:" attribute. The values
reported there have a mismatch.
For e.g., in sched:sched_switch the prev_comm and next_comm character
arrays have subscript values as [32] where as the actual field size is
16.
format:
field:unsigned short common_type; offset:0; size:2; signed:0;
field:unsigned char common_flags; offset:2; size:1; signed:0;
field:unsigned char common_preempt_count; offset:3; size:1;signed:0;
field:int common_pid; offset:4; size:4; signed:1;
field:char prev_comm[32]; offset:8; size:16; signed:1;
field:pid_t prev_pid; offset:24; size:4; signed:1;
field:int prev_prio; offset:28; size:4; signed:1;
field:long prev_state; offset:32; size:8; signed:1;
field:char next_comm[32]; offset:40; size:16; signed:1;
field:pid_t next_pid; offset:56; size:4; signed:1;
field:int next_prio; offset:60; size:4; signed:1;
After bisection, the following commit was blamed:
92edca0 tracing: Use direct field, type and system names
This commit removes the duplication of strings for field->name and
field->type assuming that all the strings passed in
__trace_define_field() are immutable. This is not true for arrays, where
the type string is created in event_storage variable and field->type for
all array fields points to event_storage.
Use __stringify() to create a string constant for the type string.
Also, get rid of event_storage and event_storage_mutex that are not
needed anymore.
also, an added benefit is that this reduces the overhead of events a bit more:
8424787 2036472 1302528 11763787 b3804b vmlinux
8420814 2036408 1302528 11759750 b37086 vmlinux.patched
Link: http://lkml.kernel.org/r/1392349908-29685-1-git-send-email-vnagarnaik@google.com
Cc: Laurent Chavey <chavey@google.com>
Cc: stable@vger.kernel.org # 3.10+
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
The functions that assign the contents for the ftrace events are
defined by the TRACE_EVENT() macros. Each event has its own unique
way to assign data to its buffer. When you have over 500 events,
that means there's 500 functions assigning data uniquely for each
event (not really that many, as DECLARE_EVENT_CLASS() and multiple
DEFINE_EVENT()s will only need a single function).
By making helper functions in the core kernel to do some of the work
instead, we can shrink the size of the kernel down a bit.
With a kernel configured with 502 events, the change in size was:
12987390 1913504 9785344 24686238 178ae9e /tmp/vmlinux
12959102 1913504 9785344 24657950 178401e /tmp/vmlinux.patched
That's a total of 28288 bytes, which comes down to 56 bytes per event.
Link: http://lkml.kernel.org/r/20120810034708.370808175@goodmis.org
The code that shows array fields for events is defined for all events.
This can add up quite a bit when you have over 500 events.
By making helper functions in the core kernel to do the work
12990946 1913568 9785344 24689858 178bcc2 /tmp/vmlinux
12987390 1913504 9785344 24686238 178ae9e /tmp/vmlinux.patched
That's a total of 3556 bytes, which comes down to 7 bytes per event.
Although it's not much, this code is just called at initialization of
the events.
Link: http://lkml.kernel.org/r/20120810034708.084036335@goodmis.org
The code for trace events to format the raw recorded event data
into human readable format in the 'trace' file is repeated for every
event in the system. When you have over 500 events, this can add up
quite a bit.
12991007 1913568 9785344 24689919 178bcff /tmp/vmlinux.orig
12990946 1913568 9785344 24689858 178bcc2 /tmp/vmlinux.patched
Note, this version does not save as much as the version of this patch
I had a few years ago. That is because in the mean time, commit
f71130de5c7f ("tracing: Add a helper function for event print functions")
did a lot of the work my original patch did. But this change helps
slightly, and is part of a larger clean up to reduce the size much further.
Link: http://lkml.kernel.org/r/20120810034707.378538034@goodmis.org
Cc: Li Zefan <lizefan@huawei.com>
The event trigger code that checks for callback triggers before and
after recording of an event has lots of flags checks. This code is
duplicated throughout the ftrace events, kprobes and system calls.
They all do the exact same checks against the event flags.
Added helper functions ftrace_trigger_soft_disabled(),
event_trigger_unlock_commit() and event_trigger_unlock_commit_regs()
that consolidated the code and these are used instead.
Link: http://lkml.kernel.org/r/20140106222703.5e7dbba2@gandalf.local.home
Acked-by: Tom Zanussi <tom.zanussi@linux.intel.com>
Tested-by: Tom Zanussi <tom.zanussi@linux.intel.com>
Add a generic event_command.set_trigger_filter() op implementation and
have the current set of trigger commands use it - this essentially
gives them all support for filters.
Syntactically, filters are supported by adding 'if <filter>' just
after the command, in which case only events matching the filter will
invoke the trigger. For example, to add a filter to an
enable/disable_event command:
echo 'enable_event:system:event if common_pid == 999' > \
.../othersys/otherevent/trigger
The above command will only enable the system:event event if the
common_pid field in the othersys:otherevent event is 999.
As another example, to add a filter to a stacktrace command:
echo 'stacktrace if common_pid == 999' > \
.../somesys/someevent/trigger
The above command will only trigger a stacktrace if the common_pid
field in the event is 999.
The filter syntax is the same as that described in the 'Event
filtering' section of Documentation/trace/events.txt.
Because triggers can now use filters, the trigger-invoking logic needs
to be moved in those cases - e.g. for ftrace_raw_event_calls, if a
trigger has a filter associated with it, the trigger invocation now
needs to happen after the { assign; } part of the call, in order for
the trigger condition to be tested.
There's still a SOFT_DISABLED-only check at the top of e.g. the
ftrace_raw_events function, so when an event is soft disabled but not
because of the presence of a trigger, the original SOFT_DISABLED
behavior remains unchanged.
There's also a bit of trickiness in that some triggers need to avoid
being invoked while an event is currently in the process of being
logged, since the trigger may itself log data into the trace buffer.
Thus we make sure the current event is committed before invoking those
triggers. To do that, we split the trigger invocation in two - the
first part (event_triggers_call()) checks the filter using the current
trace record; if a command has the post_trigger flag set, it sets a
bit for itself in the return value, otherwise it directly invoks the
trigger. Once all commands have been either invoked or set their
return flag, event_triggers_call() returns. The current record is
then either committed or discarded; if any commands have deferred
their triggers, those commands are finally invoked following the close
of the current event by event_triggers_post_call().
To simplify the above and make it more efficient, the TRIGGER_COND bit
is introduced, which is set only if a soft-disabled trigger needs to
use the log record for filter testing or needs to wait until the
current log record is closed.
The syscall event invocation code is also changed in analogous ways.
Because event triggers need to be able to create and free filters,
this also adds a couple external wrappers for the existing
create_filter and free_filter functions, which are too generic to be
made extern functions themselves.
Link: http://lkml.kernel.org/r/7164930759d8719ef460357f143d995406e4eead.1382622043.git.tom.zanussi@linux.intel.com
Signed-off-by: Tom Zanussi <tom.zanussi@linux.intel.com>
Add 'enable_event' and 'disable_event' event_command commands.
enable_event and disable_event event triggers are added by the user
via these commands in a similar way and using practically the same
syntax as the analagous 'enable_event' and 'disable_event' ftrace
function commands, but instead of writing to the set_ftrace_filter
file, the enable_event and disable_event triggers are written to the
per-event 'trigger' files:
echo 'enable_event:system:event' > .../othersys/otherevent/trigger
echo 'disable_event:system:event' > .../othersys/otherevent/trigger
The above commands will enable or disable the 'system:event' trace
events whenever the othersys:otherevent events are hit.
This also adds a 'count' version that limits the number of times the
command will be invoked:
echo 'enable_event:system:event:N' > .../othersys/otherevent/trigger
echo 'disable_event:system:event:N' > .../othersys/otherevent/trigger
Where N is the number of times the command will be invoked.
The above commands will will enable or disable the 'system:event'
trace events whenever the othersys:otherevent events are hit, but only
N times.
This also makes the find_event_file() helper function extern, since
it's useful to use from other places, such as the event triggers code,
so make it accessible.
Link: http://lkml.kernel.org/r/f825f3048c3f6b026ee37ae5825f9fc373451828.1382622043.git.tom.zanussi@linux.intel.com
Add 'stacktrace' event_command. stacktrace event triggers are added
by the user via this command in a similar way and using practically
the same syntax as the analogous 'stacktrace' ftrace function command,
but instead of writing to the set_ftrace_filter file, the stacktrace
event trigger is written to the per-event 'trigger' files:
echo 'stacktrace' > .../tracing/events/somesys/someevent/trigger
The above command will turn on stacktraces for someevent i.e. whenever
someevent is hit, a stacktrace will be logged.
echo 'stacktrace:N' > .../tracing/events/somesys/someevent/trigger
The above command will log N stacktraces for someevent i.e. whenever
someevent is hit N times, a stacktrace will be logged.
Link: http://lkml.kernel.org/r/0c30c008a0828c660aa0e1bbd3255cf179ed5c30.1382622043.git.tom.zanussi@linux.intel.com
Add 'snapshot' event_command. snapshot event triggers are added by
the user via this command in a similar way and using practically the
same syntax as the analogous 'snapshot' ftrace function command, but
instead of writing to the set_ftrace_filter file, the snapshot event
echo 'snapshot' > .../somesys/someevent/trigger
The above command will turn on snapshots for someevent i.e. whenever
someevent is hit, a snapshot will be done.
echo 'snapshot:N' > .../somesys/someevent/trigger
The above command will snapshot N times for someevent i.e. whenever
someevent is hit N times, a snapshot will be done.
Also adds a new tracing_alloc_snapshot() function - the existing
tracing_snapshot_alloc() function is a special version of
tracing_snapshot() that also does the snapshot allocation - the
snapshot triggers would like to be able to do just the allocation but
not take a snapshot; the existing tracing_snapshot_alloc() in turn now
also calls tracing_alloc_snapshot() underneath to do that allocation.
Link: http://lkml.kernel.org/r/c9524dd07ce01f9dcbd59011290e0a8d5b47d7ad.1382622043.git.tom.zanussi@linux.intel.com
[ fix up from kbuild test robot <fengguang.wu@intel.com report ]
Add 'traceon' and 'traceoff' event_command commands. traceon and
traceoff event triggers are added by the user via these commands in a
similar way and using practically the same syntax as the analagous
'traceon' and 'traceoff' ftrace function commands, but instead of
writing to the set_ftrace_filter file, the traceon and traceoff
triggers are written to the per-event 'trigger' files:
echo 'traceon' > .../tracing/events/somesys/someevent/trigger
echo 'traceoff' > .../tracing/events/somesys/someevent/trigger
The above command will turn tracing on or off whenever someevent is
hit.
echo 'traceon:N' > .../tracing/events/somesys/someevent/trigger
echo 'traceoff:N' > .../tracing/events/somesys/someevent/trigger
The above commands will will turn tracing on or off whenever someevent
is hit, but only N times.
Some common register/unregister_trigger() implementations of the
event_command reg()/unreg() callbacks are also provided, which add and
remove trigger instances to the per-event list of triggers, and
arm/disarm them as appropriate. event_trigger_callback() is a
general-purpose event_command func() implementation that orchestrates
command parsing and registration for most normal commands.
Most event commands will use these, but some will override and
possibly reuse them.
The event_trigger_init(), event_trigger_free(), and
event_trigger_print() functions are meant to be common implementations
of the event_trigger_ops init(), free(), and print() ops,
respectively.
Most trigger_ops implementations will use these, but some will
override and possibly reuse them.
Link: http://lkml.kernel.org/r/00a52816703b98d2072947478dd6e2d70cde5197.1382622043.git.tom.zanussi@linux.intel.com
Add a 'trigger' file for each trace event, enabling 'trace event
triggers' to be set for trace events.
'trace event triggers' are patterned after the existing 'ftrace
function triggers' implementation except that triggers are written to
per-event 'trigger' files instead of to a single file such as the
'set_ftrace_filter' used for ftrace function triggers.
The implementation is meant to be entirely separate from ftrace
function triggers, in order to keep the respective implementations
relatively simple and to allow them to diverge.
The event trigger functionality is built on top of SOFT_DISABLE
functionality. It adds a TRIGGER_MODE bit to the ftrace_event_file
flags which is checked when any trace event fires. Triggers set for a
particular event need to be checked regardless of whether that event
is actually enabled or not - getting an event to fire even if it's not
enabled is what's already implemented by SOFT_DISABLE mode, so trigger
mode directly reuses that. Event trigger essentially inherit the soft
disable logic in __ftrace_event_enable_disable() while adding a bit of
logic and trigger reference counting via tm_ref on top of that in a
new trace_event_trigger_enable_disable() function. Because the base
__ftrace_event_enable_disable() code now needs to be invoked from
outside trace_events.c, a wrapper is also added for those usages.
The triggers for an event are actually invoked via a new function,
event_triggers_call(), and code is also added to invoke them for
ftrace_raw_event calls as well as syscall events.
The main part of the patch creates a new trace_events_trigger.c file
to contain the trace event triggers implementation.
The standard open, read, and release file operations are implemented
here.
The open() implementation sets up for the various open modes of the
'trigger' file. It creates and attaches the trigger iterator and sets
up the command parser. If opened for reading set up the trigger
seq_ops.
The read() implementation parses the event trigger written to the
'trigger' file, looks up the trigger command, and passes it along to
that event_command's func() implementation for command-specific
processing.
The release() implementation does whatever cleanup is needed to
release the 'trigger' file, like releasing the parser and trigger
iterator, etc.
A couple of functions for event command registration and
unregistration are added, along with a list to add them to and a mutex
to protect them, as well as an (initially empty) registration function
to add the set of commands that will be added by future commits, and
call to it from the trace event initialization code.
also added are a couple trigger-specific data structures needed for
these implementations such as a trigger iterator and a struct for
trigger-specific data.
A couple structs consisting mostly of function meant to be implemented
in command-specific ways, event_command and event_trigger_ops, are
used by the generic event trigger command implementations. They're
being put into trace.h alongside the other trace_event data structures
and functions, in the expectation that they'll be needed in several
trace_event-related files such as trace_events_trigger.c and
trace_events.c.
The event_command.func() function is meant to be called by the trigger
parsing code in order to add a trigger instance to the corresponding
event. It essentially coordinates adding a live trigger instance to
the event, and arming the triggering the event.
Every event_command func() implementation essentially does the
same thing for any command:
- choose ops - use the value of param to choose either a number or
count version of event_trigger_ops specific to the command
- do the register or unregister of those ops
- associate a filter, if specified, with the triggering event
The reg() and unreg() ops allow command-specific implementations for
event_trigger_op registration and unregistration, and the
get_trigger_ops() op allows command-specific event_trigger_ops
selection to be parameterized. When a trigger instance is added, the
reg() op essentially adds that trigger to the triggering event and
arms it, while unreg() does the opposite. The set_filter() function
is used to associate a filter with the trigger - if the command
doesn't specify a set_filter() implementation, the command will ignore
filters.
Each command has an associated trigger_type, which serves double duty,
both as a unique identifier for the command as well as a value that
can be used for setting a trigger mode bit during trigger invocation.
The signature of func() adds a pointer to the event_command struct,
used to invoke those functions, along with a command_data param that
can be passed to the reg/unreg functions. This allows func()
implementations to use command-specific blobs and supports code
re-use.
The event_trigger_ops.func() command corrsponds to the trigger 'probe'
function that gets called when the triggering event is actually
invoked. The other functions are used to list the trigger when
needed, along with a couple mundane book-keeping functions.
This also moves event_file_data() into trace.h so it can be used
outside of trace_events.c.
Link: http://lkml.kernel.org/r/316d95061accdee070aac8e5750afba0192fa5b9.1382622043.git.tom.zanussi@linux.intel.com
Idea-by: Steve Rostedt <rostedt@goodmis.org>
Vince's perf-trinity fuzzer found yet another 'interesting' problem.
When we sample the irq_work_exit tracepoint with period==1 (or
PERF_SAMPLE_PERIOD) and we add an fasync SIGNAL handler we create an
infinite event generation loop:
,-> <IPI>
| irq_work_exit() ->
| trace_irq_work_exit() ->
| __perf_event_overflow() -> (due to fasync)
| irq_work_queue() -> (irq_work_list must be empty)
'--------- arch_irq_work_raise()
Similar things can happen due to regular poll() wakeups if we exceed
the ring-buffer wakeup watermark, or have an event_limit.
To avoid this, dis-allow sampling this particular tracepoint.
In order to achieve this, create a special perf_perm function pointer
for each event and call this (when set) on trying to create a
tracepoint perf event.
[ roasted: use expr... to allow for ',' in your expression ]
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/20131114152304.GC5364@laptop.programming.kicks-ass.net
The trace event filters are still tied to event calls rather than
event files, which means you don't get what you'd expect when using
filters in the multibuffer case:
Before:
# echo 'bytes_alloc > 8192' > /sys/kernel/debug/tracing/events/kmem/kmalloc/filter
# cat /sys/kernel/debug/tracing/events/kmem/kmalloc/filter
bytes_alloc > 8192
# mkdir /sys/kernel/debug/tracing/instances/test1
# echo 'bytes_alloc > 2048' > /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter
bytes_alloc > 2048
# cat /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter
bytes_alloc > 2048
Setting the filter in tracing/instances/test1/events shouldn't affect
the same event in tracing/events as it does above.
After:
bytes_alloc > 8192
bytes_alloc > 8192
bytes_alloc > 2048
We'd like to just move the filter directly from ftrace_event_call to
ftrace_event_file, but there are a couple cases that don't yet have
multibuffer support and therefore have to continue using the current
event_call-based filters. For those cases, a new USE_CALL_FILTER bit
is added to the event_call flags, whose main purpose is to keep the
old behavior for those cases until they can be updated with
multibuffer support; at that point, the USE_CALL_FILTER flag (and the
new associated call_filter_check_discard() function) can go away.
The multibuffer support also made filter_current_check_discard()
redundant, so this change removes that function as well and replaces
it with filter_check_discard() (or call_filter_check_discard() as
appropriate).
Link: http://lkml.kernel.org/r/f16e9ce4270c62f46b2e966119225e1c3cca7e60.1382620672.git.tom.zanussi@linux.intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
* Update RCU documentation. These were posted to LKML at
https://lkml.org/lkml/2013/8/19/611.
* Miscellaneous fixes. These were posted to LKML at
https://lkml.org/lkml/2013/8/19/619.
* Full-system idle detection. This is for use by Frederic
Weisbecker's adaptive-ticks mechanism. Its purpose is
to allow the timekeeping CPU to shut off its tick when
all other CPUs are idle. These were posted to LKML at
https://lkml.org/lkml/2013/8/19/648.
* Improve rcutorture test coverage. These were posted to LKML at
https://lkml.org/lkml/2013/8/19/675.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Cc: stable@vger.kernel.org # 2.6.30
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Change trace_remove_event_call(call) to return the error if this
call is active. This is what the callers assume but can't verify
outside of the tracing locks. Both trace_kprobe.c/trace_uprobe.c
need the additional changes, unregister_trace_probe() should abort
if trace_remove_event_call() fails.
The caller is going to free this call/file so we must ensure that
nobody can use them after trace_remove_event_call() succeeds.
debugfs should be fine after the previous changes and event_remove()
does TRACE_REG_UNREGISTER, but still there are 2 reasons why we need
the additional checks:
- There could be a perf_event(s) attached to this tp_event, so the
patch checks ->perf_refcount.
- TRACE_REG_UNREGISTER can be suppressed by FTRACE_EVENT_FL_SOFT_MODE,
so we simply check FTRACE_EVENT_FL_ENABLED protected by event_mutex.
Link: http://lkml.kernel.org/r/20130729175033.GB26284@redhat.com
There are several tracepoints (mostly in RCU), that reference a string
pointer and uses the print format of "%s" to display the string that
exists in the kernel, instead of copying the actual string to the
ring buffer (saves time and ring buffer space).
But this has an issue with userspace tools that read the binary buffers
that has the address of the string but has no access to what the string
itself is. The end result is just output that looks like:
rcu_dyntick: ffffffff818adeaa 1 0
rcu_dyntick: ffffffff818adeb5 0 140000000000000
rcu_utilization: ffffffff8184333b
The above is pretty useless when read by the userspace tools. Ideally
we would want something that looks like this:
rcu_dyntick: Start 1 0
rcu_dyntick: End 0 140000000000000
rcu_dyntick: Start 140000000000000 0
rcu_callback: rcu_preempt rhp=0xffff880037aff710 func=put_cred_rcu 0/4
rcu_callback: rcu_preempt rhp=0xffff880078961980 func=file_free_rcu 0/5
The trace_printk() which also only stores the address of the string
format instead of recording the string into the buffer itself, exports
the mapping of kernel addresses to format strings via the printk_format
file in the debugfs tracing directory.
The tracepoint strings can use this same method and output the format
to the same file and the userspace tools will be able to decipher
the address without any modification.
The tracepoint strings need its own section to save the strings because
the trace_printk section will cause the trace_printk() buffers to be
allocated if anything exists within the section. trace_printk() is only
used for debugging and should never exist in the kernel, we can not use
the trace_printk sections.
Add a new tracepoint_str section that will also be examined by the output
of the printk_format file.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Modify soft-mode flag only if no other soft-mode referrer
(currently only the ftrace triggers) by using a reference
counter in each ftrace_event_file.
Without this fix, adding and removing several different
enable/disable_event triggers on the same event clear
soft-mode bit from the ftrace_event_file. This also
happens with a typo of glob on setting triggers.
e.g.
# echo vfs_symlink:enable_event:net:netif_rx > set_ftrace_filter
# cat events/net/netif_rx/enable
0*
# echo typo_func:enable_event:net:netif_rx > set_ftrace_filter
0
# cat set_ftrace_filter
#### all functions enabled ####
vfs_symlink:enable_event:net:netif_rx:unlimited
As above, we still have a trigger, but soft-mode is gone.
Link: http://lkml.kernel.org/r/20130509054429.30398.7464.stgit@mhiramat-M0-7522
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: David Sharp <dhsharp@google.com>
Cc: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com>
Cc: Tom Zanussi <tom.zanussi@intel.com>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
The formats of the trace events show if the type of a event field
is signed or not via a macro called is_signed_type(). This does
a trick with the type and compares a -1 to zero after typecasting
to the tested type. If it returns true, it's signed, otherwise
its not. But this unfortunately triggers a warning by gcc:
warning: comparison of unsigned expression < 0 is always false
As we know it is always false (that's why we do it), this is a
false warning. Luckily for us, the comparison works with a 1 as
well, without giving the warning.
Convert the check to compare (type)-1 < (type)0 to (type)-1 < (type)1
to determine if the type is signed or not.
Link: http://lkml.kernel.org/r/CAErSpo4YXcY9fuOKWYGDkddJwk68kmZTohsmVB6QvrhjboOh1Q@mail.gmail.com
Reported-by: Bjorn Helgaas <bhelgaas@google.com>
Reported-by: Gary Hade <garyhade@us.ibm.com>
In order to let triggers enable or disable events, we need a 'soft'
method for doing so. For example, if a function probe is added that
lets a user enable or disable events when a function is called, that
change must be done without taking locks or a mutex, and definitely
it can't sleep. But the full enabling of a tracepoint is expensive.
By adding a 'SOFT_DISABLE' flag, and converting the flags to be updated
without the protection of a mutex (using set/clear_bit()), this soft
disable flag can be used to allow critical sections to enable or disable
events from being traced (after the event has been placed into "SOFT_MODE").
Some caveats though: The comm recorder (to map pids with a comm) can not
be soft disabled (yet). If you disable an event with with a "soft"
disable and wait a while before reading the trace, the comm cache may be
replaced and you'll get a bunch of <...> for comms in the trace.
Reading the "enable" file for an event that is disabled will now give
you "0*" where the '*' denotes that the tracepoint is still active but
the event itself is "disabled".
[ fixed _BIT used in & operation : thanks to Dan Carpenter and smatch ]
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Most of the flags for the struct ftrace_event_file were moved over
to the flags of the struct ftrace_event_call, but the comments were
never updated.
Currently, the way the latency tracers and snapshot feature works
is to have a separate trace_array called "max_tr" that holds the
snapshot buffer. For latency tracers, this snapshot buffer is used
to swap the running buffer with this buffer to save the current max
latency.
The only items needed for the max_tr is really just a copy of the buffer
itself, the per_cpu data pointers, the time_start timestamp that states
when the max latency was triggered, and the cpu that the max latency
was triggered on. All other fields in trace_array are unused by the
max_tr, making the max_tr mostly bloat.
This change removes the max_tr completely, and adds a new structure
called trace_buffer, that holds the buffer pointer, the per_cpu data
pointers, the time_start timestamp, and the cpu where the latency occurred.
The trace_array, now has two trace_buffers, one for the normal trace and
one for the max trace or snapshot. By doing this, not only do we remove
the bloat from the max_trace but the instances of traces can now use
their own snapshot feature and not have just the top level global_trace have
the snapshot feature and latency tracers for itself.
Currently, when a module with events is unloaded, the trace buffer is
cleared. This is just a safety net in case the module might have some
strange callback when its event is outputted. But there's no reason
to reset the buffer if the module didn't have any of its events traced.
Add a flag to the event "call" structure called WAS_ENABLED and gets set
when the event is ever enabled, and this flag never gets cleared. When a
module gets unloaded, if any of its events have this flag set, then the
trace buffer will get cleared.
All the trace event flags have comments but the IGNORE_ENABLE flag
which is set for ftrace internal events that should not be enabled
via the debugfs "enable" file. That is, if the top level enable file
is set, it will enable all events. It use to just check the ftrace
event call descriptor "reg" field and skip those whithout it, but now
some ftrace internal events have a reg field but still need to be
skipped. The flag was created to ignore those events.
Now document it.
Move duplicate code in event print functions to a helper function.
This shrinks the size of the kernel by ~13K.
6596137 1743966 10138672 18478775 119f6b7 vmlinux.o.old
6583002 1743849 10138672 18465523 119c2f3 vmlinux.o.new
Link: http://lkml.kernel.org/r/51258746.2060304@huawei.com
Signed-off-by: Li Zefan <lizefan@huawei.com>
Pass the struct ftrace_event_file *ftrace_file to the
trace_event_buffer_lock_reserve() (new function that replaces the
trace_current_buffer_lock_reserver()).
The ftrace_file holds a pointer to the trace_array that is in use.
In the case of multiple buffers with different trace_arrays, this
allows different events to be recorded into different buffers.
Also fixed some of the stale comments in include/trace/ftrace.h
The trace events for ftrace are all defined via global variables.
The arrays of events and event systems are linked to a global list.
This prevents multiple users of the event system (what to enable and
what not to).
By adding descriptors to represent the event/file relation, as well
as to which trace_array descriptor they are associated with, allows
for more than one set of events to be defined. Once the trace events
files have a link between the trace event and the trace_array they
are associated with, we can create multiple trace_arrays that can
record separate events in separate buffers.
Ftrace has a snapshot feature available from kernel space and
latency tracers (e.g. irqsoff) are using it. This patch enables
user applictions to take a snapshot via debugfs.
Add "snapshot" debugfs file in "tracing" directory.
snapshot:
This is used to take a snapshot and to read the output of the
snapshot.
# echo 1 > snapshot
This will allocate the spare buffer for snapshot (if it is
not allocated), and take a snapshot.
# cat snapshot
This will show contents of the snapshot.
# echo 0 > snapshot
This will free the snapshot if it is allocated.
Any other positive values will clear the snapshot contents if
the snapshot is allocated, or return EINVAL if it is not allocated.
Link: http://lkml.kernel.org/r/20121226025300.3252.86850.stgit@liselsia
Signed-off-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com>
Fixed irqsoff selftest and also a conflict with a change
that fixes the update_max_tr.
Due to a userspace issue with PowerTop v2beta, which hardcoded
the offset of event fields that it was using, it broke when
we removed the Big Kernel Lock counter from the event header.
(commit e6e1e2593 "tracing: Remove lock_depth from event entry")
Because this broke userspace, it was determined that we must
keep those 4 bytes around.
(commit a3a4a5acd "Regression: partial revert "tracing: Remove lock_depth from event entry"")
This unfortunately wastes space in the ring buffer. 4 bytes per
event, where a lot of events are just 24 bytes. That's 16% of the
buffer wasted. A million events will add 4 megs of white space
into the buffer.
It was later noticed that PowerTop v2beta could not work on systems
where the kernel was 64 bit but the userspace was 32 bits.
The reason was because the offsets are different between the
two and the hard coded offset of one would not work with the other.
With PowerTop v2 final, it implemented the same interface that both
perf and trace-cmd use. That is, it reads the format file of
the event to find the offsets of the fields it needs. This fixes
the problem with running powertop on a 32 bit userspace running
on a 64 bit kernel. It also no longer requires the 4 byte padding.
As PowerTop v2 has been out for a while, and is included in all
major distributions, it is time that we can safely remove the
4 bytes of padding. Users of PowerTop v2beta should upgrade to
PowerTop v2 final.
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Sparse complains when is_signed_type() is used on a pointer.
This macro is needed for the format output used for ftrace
and perf, to know if a binary field is a signed type or not.
The is_signed_type() macro is used against all fields that are
recorded by events to automate the operation.
The problem sparse has is with the current way is_signed_type()
works:
((type)-1 < 0)
If "type" is a poiner, than sparse does not like it being compared
to an integer (zero). The simple fix is to just give zero the
same type. The runtime result stays the same.
Reported-by: Robert Jarzmik <robert.jarzmik@free.fr>
With the addition of the "tsc" clock, formatting timestamps to look like
fractional seconds is misleading. Mark clocks as either in nanoseconds or
not, and format non-nanosecond timestamps as decimal integers.
Tested:
$ cd /sys/kernel/debug/tracing/
$ cat trace_clock
[local] global tsc
$ echo sched_switch > set_event
$ echo 1 > tracing_on ; sleep 0.0005 ; echo 0 > tracing_on
$ cat trace
<idle>-0 [000] 6330.555552: sched_switch: prev_comm=swapper prev_pid=0 prev_prio=120 prev_state=R ==> next_comm=bash next_pid=29964 next_prio=120
sleep-29964 [000] 6330.555628: sched_switch: prev_comm=bash prev_pid=29964 prev_prio=120 prev_state=S ==> next_comm=swapper next_pid=0 next_prio=120
$ echo 1 > options/latency-format
$ cat trace
<idle>-0 0 4104553247us+: sched_switch: prev_comm=swapper prev_pid=0 prev_prio=120 prev_state=R ==> next_comm=bash next_pid=29964 next_prio=120
sleep-29964 0 4104553322us+: sched_switch: prev_comm=bash prev_pid=29964 prev_prio=120 prev_state=S ==> next_comm=swapper next_pid=0 next_prio=120
$ echo tsc > trace_clock
$ cat trace
$ echo 0 > options/latency-format
$ cat trace
<idle>-0 [000] 16490053398357: sched_switch: prev_comm=swapper prev_pid=0 prev_prio=120 prev_state=R ==> next_comm=bash next_pid=31128 next_prio=120
sleep-31128 [000] 16490053588518: sched_switch: prev_comm=bash prev_pid=31128 prev_prio=120 prev_state=S ==> next_comm=swapper next_pid=0 next_prio=120
$ cat trace
<idle>-0 0 91557653238+: sched_switch: prev_comm=swapper prev_pid=0 prev_prio=120 prev_state=R ==> next_comm=bash next_pid=31128 next_prio=120
sleep-31128 0 91557843399+: sched_switch: prev_comm=bash prev_pid=31128 prev_prio=120 prev_state=S ==> next_comm=swapper next_pid=0 next_prio=120
v2:
Move arch-specific bits out of generic code.
v4:
Fix x86_32 build due to 64-bit division.
Google-Bug-Id: 6980623
Link: http://lkml.kernel.org/r/1352837903-32191-2-git-send-email-dhsharp@google.com
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Signed-off-by: David Sharp <dhsharp@google.com>
