path: root/include/linux/gpio.h
2008-03-04gpio: <linux/gpio.h> and "no GPIO support here" stubsDavid Brownell
Add a <linux/gpio.h> defining fail/warn stubs for GPIO calls on platforms that don't support the GPIO programming interface. That includes the arch-specific implementation glue otherwise. This facilitates a new model for GPIO usage: drivers that can use GPIOs if they're available, but don't require them. One example of such a driver is NAND driver for various FreeScale chips. On platforms update with GPIO support, they can be used instead of a worst-case delay to verify that the BUSY signal is off. (Also includes a couple minor unrelated doc updates.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
