path: root/include/linux/hid-sensor-ids.h
2013-12-24Merge tag 'iio-for-3.14b' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: 2nd round of new IIO drivers, features and cleanups for the 3.14 cycle. New drivers * HID inclinometer driver. * DHT11 humidity driver. Note that previous humidity drivers have been in hwmon, but no one was ever entirely happy with that, and they should find a more comfortable home in IIO (their original placement in hwmon was my fault - oops). As this is our first humidity driver, core support is also added. New features * Two of mxs-lradc channels are internally wired to a temperature sensor, make this explicit in the driver by providing the relevant temperature channel. * Add support for blocking IO on buffers. * Add a data_available call back to the interface between buffer implementations and the core. This is much cleaner than the old, 'stufftoread' flag. Implemented in the kfifo buffer. Cleanups * Last user of the old event configuration interface is converted and the old interface dropped. Nice to be rid of this thanks to Lars-Peter's hard work! * Replace all remaining instances of the IIO_ST macro with explicit filling of the scan_type structure within struct iio_chan_spec. This macro was a bad idea, that rapidly ceased to cover all elements of the structure. Miss reading of the macro arguements has led to a number of bugs so lets just get rid of it. The final removal patch is awaiting for some fixes to make their way into mainline. In a couple of drivers, no elements of scan_type were even being used so in those case, it has been dropped entirely. * Drop a couple of of_match_ptr helper uses in drivers where devicetree is not optional and hence the structures being protected by this always exist. * Fix up some cases where data was read from a device in a particular byte order, but he code placed it into a s16 or similar. These were highlighted by Sparse. * Use the new ATTRIBUTE_GROUPS macro to drop some boiler plate in the triggers core code. * ad7746 and ad7280a - stop storing buffers on the stack, giving cleaner code and possibly avoiding issues with i2c bus drivers that assume they can dma directly into the buffer. Note that this cannot currently happen as the the i2c_smbus_read_i2c_block_data function has a memcpy from the buffer actually passed to the bus driver. I missed this element of the commit message and don't think it is major enough to rebase the iio tree. * ad5791 and ad5504 stop storing buffers on the stack for an SPI driver. Unlike the i2c drivers, this is a real issue for SPI drivers which can dma directly into the buffer supplied.
2013-12-16Merge 3.13-rc4 into staging-next.Greg Kroah-Hartman
We want the fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-03iio: hid-sensors: Added Inclinometer 3DSrinivas Pandruvada
Added usage id processing for Inclinometer 3D. This uses IIO interfaces for triggered buffer to present data to user mode.This uses HID sensor framework for registering callback events from the sensor hub. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-12-02iio: hid-sensors: Fix power and report stateSrinivas Pandruvada
In the original HID sensor hub firmwares all Named array enums were to 0-based. But the most recent hub implemented as 1-based, because of the implementation by one of the major OS vendor. Using logical minimum for the field as the base of enum. So we add logical minimum to the selector values before setting those fields. Some sensor hub FWs already changed logical minimum from 0 to 1 to reflect this and hope every other vendor will follow. There is no easy way to add a common HID quirk for NAry elements, even if the standard specifies these field as NAry, the collection used to describe selectors is still just "logical". Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-11-09iio: hid-sensors: magnetometer : Add sensitivitySrinivas Pandruvada
A number of Properties that can be applied to Data Fields are per data field basis or for all data fields. Adding sensitivity field for all magnetometer fields, which is most commonly used in currently available sensor hubs. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-11-05iio: hid-sensors: light/als : Add sensitivitySrinivas Pandruvada
A number of Properties that can be applied to Data Fields are per data field basis or for all data fields. Adding sensitivity field for all als fields, which is most commonly used in currently available sensor hubs. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-11-05iio: hid-sensors: gyro : Add sensitivitySrinivas Pandruvada
A number of Properties that can be applied to Data Fields are per data field basis or for all data fields. Adding sensitivity field for all gyro fields, which is most commonly used in currently available sensor hubs. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-11-05iio: hid-sensors: accelerometer: Add sensitivitySrinivas Pandruvada
A number of Properties that can be applied to Data Fields are per data field basis or for all data fields. Adding sensitivity field for all accelerometer fields, which is most commonly used in currently available sensor hubs. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-26HID: hid-sensor-hub: fix style of commentsAndy Shevchenko
This patch fixes the style of the comments to be like following /* The commentary */ There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-06iio: Add Usage IDs for HID time sensors.Alexander Holler
These are Usage IDs for the attributes year, month, day, hour, minute and second, needed to read HID time sensors. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-12-12HID: sensors: autodetect USB HID sensor hubsAlexander Holler
It should not be necessary to add IDs for HID sensor hubs to lists in hid-core.c and hid-sensor-hub.c. So instead of a whitelist, autodetect such USB HID sensor hubs, based on a collection of type physical inside a useage page of type sensor. If some sensor hubs stil must be usable as raw devices, a blacklist might be created. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Acked-by: "Pandruvada, Srinivas" <srinivas.pandruvada@intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-06HID: sensors: introduce sensor frameworksrinivas pandruvada
Adding processing for HID Sensor usage table as defined by HID 1.12, Request #: HUTRR39, dated 05 May, 2011. This driver uses HID driver framework to register, send and receive events. This uses MFD framework, so that actual processing for a specific usage id can be done in a different driver. For example an accelerometer driver can be a separate driver and use the interface provided by this driver to register for events. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
