Add input_register callback which gets called after
hid_configure_usage is called for all the reports
and before the input device is registered. This allows
individual drivers to do extra work like input mapping just
before device registration.
Based on discussions with David Herrmann <dh.herrmann@googlemail.com>
Change-Id: Idab6fb4f7b1e5e569bd0410967288717e9d34c98
Signed-off-by: Jaikumar Ganesh <jaikumarg@android.com>
Unfortunately, the device seems to have the same Vendor ID and Product ID
as YUREX leg-shakes sensors, and the commit 6bc235a2e2 ("USB: add driver
for Meywa-Denki & Kayac YUREX") added the ID to hid_ignore_list.
I believe that we can distinguish YUREX and the Wireless Presenter by
device type. The patch below makes the driver ignore only YUREX
(bInterfaceProtocol==0), and recognize Wireless Presenter
(bInterfaceProtocol is keyboard or mouse) as generic HID. (I don't have
the Wireless Presenter, so not yet ested.)
** YUREX lsusb information:
Bus 002 Device 007: ID 0c45:1010 Microdia
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0c45 Microdia
idProduct 0x1010
bcdDevice 0.03
iManufacturer 1 JESS
iProduct 2 YUREX
iSerial 3 10000269
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 31
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
Device Status: 0x0002
(Bus Powered)
Remote Wakeup Enabled
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=26922
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com>
Cc: Greg KH <gregkh@suse.de>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
Reported-by: Thomas B?chler <thomas@archlinux.org>
Tested-by: Thomas B?chler <thomas@archlinux.org>
'roccat', 'upstream' and 'upstream-fixes' into for-linus
When the multi input quirk is set, there is a new input device
created for every feature report. Since the idea is to present
features per hid device, not per input device, revert back to
the original report loop and change the feature_mapping() callback
to not take the input device as argument.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Tested-by: Benjamin Tissoires <benjmain.tissoires@gmail.com>
Per the HID Specification, Feature reports must be sent and received on
the Configuration endpoint (EP 0) through the Set_Report/Get_Report
interfaces. This patch adds two ioctls to hidraw to set and get feature
reports to and from the device. Modifications were made to hidraw and
usbhid.
New hidraw ioctls:
HIDIOCSFEATURE - Perform a Set_Report transfer of a Feature report.
HIDIOCGFEATURE - Perform a Get_Report transfer of a Feature report.
Signed-off-by: Alan Ott <alan@signal11.us>
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: hid-multitouch: minor fixes based on additional review
HID: Switch turbox/mosart touchscreen to hid-mosart
HID: add Add Cando touch screen 10.1-inch product id
HID: hid-mulitouch: add support for the 'Sensing Win7-TwoFinger'
HID: hid-multitouch: add support for Cypress TrueTouch panels
HID: hid-multitouch: support for PixCir-based panels
HID: set HID_MAX_FIELD at 128
HID: add feature_mapping callback
Stantums multitouch panels sends more than 64 reports and this results
in not being able to handle all the touches given by this device.
This patch is required to be able to include Stantum panels in the
unified hid-multitouch driver.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
Currently hid doesn't export the features it knows to the specific modules.
Some information can be really important in such features: MosArt and
Cypress devices are by default not in a multitouch mode.
We have to send the value 2 on the right feature.
This patch exports to the module the features report so they can find the
right feature to set up the correct mode.
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
Instead of exposing the guts of hid->ll_driver relationship to HID
sub-drivers provide these helpers to encapsulate the details.
drivers/hid/hid-ids.h
drivers/hid/hid-lg.c
drivers/hid/usbhid/hid-quirks.c
As of lately, HID devices which send per-frame data split over several
HID reports have started to emerge. This patch adds a quirk which
allows the HID driver to take over the input layer synchronization,
and hence the control of the frame boundary.
Update hid_driver's report_fixup prototype to allow changing report
descriptor size and/or returning completely different report descriptor.
Update existing usage accordingly.
This is to give more freedom in descriptor fixup and to allow having a whole
fixed descriptor in the code for the sake of readability.
Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com>
For devices with exotic HID report descriptors, it might be necessary to
make the HID core force the registration of an input device. Make that
possible by introducing a new quirk type.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
'hid-suspend' into for-linus
Add suspend/resume hooks for HID drivers so these can do some
additional state adjustment when device gets suspended/resumed.
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Add two quirks to make it possible for usbhid module options to
override whether a device is ignored (HID_QUIRK_NO_IGNORE) and
whether to connect a hiddev device (HID_QUIRK_HIDDEV_FORCE).
Passing HID_QUIRK_NO_IGNORE for your device means that it will
not be ignored by the HID layer, even if present in a blacklist.
HID_QUIRK_HIDDEV_FORCE will force the creation of a hiddev for that
device, making it accessible from user-space.
Tested with an Apple IR Receiver, switching it from using appleir
to using lirc's macmini driver.
Signed-off-by: Bastien Nocera <hadess@hadess.net>
'apple_magic_mouse' into for-linus
drivers/hid/Kconfig
The Apple Magic Mouse (and probably other devices) publish reports that are not
called out in their HID report descriptors -- they only send them when enabled
through other writes to the device. This allows a driver to handle these
unlisted reports.
Signed-off-by: Michael Poole <mdpoole@troilus.org>
In commit 2da31939a42 ("Bluetooth: Implement raw output support for HIDP
layer"), support for Bluetooth hid_output_raw_report was added, but it
pushes the data to the intr socket instead of the ctrl one. This has been
fixed by 6bf8268f9a91f1 ("Bluetooth: Use the control channel for raw HID reports")
Still, it is necessary to distinguish whether the report in question should be
either FEATURE or OUTPUT. For this, we have to extend the generic HID API,
so that hid_output_raw_report() callback provides means to specify this
value so that it can be passed down to lower level hardware drivers (currently
Bluetooth and USB).
Based on original patch by Bastien Nocera <hadess@hadess.net>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Extended IS_INPUT_APPLICATION to accept digitzers that are actual input
devices (touchscreens, light pens, touch pads, white boards)
Signed-off-by: Stephane Chatty <chatty@enac.fr>
NCR devices are terminally broken by design -- they claim themselves to contain
proper input applications in their HID report descriptor, but behave very badly
if treated in standard way.
According to NCR developers, the devices get confused when queried for reports
in a standard way, rendering them unusable.
NCR is shipping application called "RPSL" that can be used to drive these
devices through hiddev, under the assumption that in-kernel driver doesn't
perform initial report query.
If it does, neither in-kernel nor hiddev-based driver can operate with these
devices any more.
Introduce a quirk that skips the report query for all NCR devices. The previous
NOGET quirk was wrong and had been introduced because I misunderstood the nature
of brokenness of these devices.
HID core registers input, hidraw and hiddev devices, but leaves
unregistering it up to the individual driver, which is not really nice.
Let's move all the logic to the core.
Reported-by: Marcel Holtmann <marcel@holtmann.org>
Reported-by: Brian Rogers <brian@xyzw.org>
This is a followup patch to the one implemeting rdesc representation in debugfs
rather than being dependent on compile-time CONFIG_HID_DEBUG setting.
The API of the appropriate formatting functions is slightly modified -- if
they are passed seq_file pointer, the one-shot output for 'rdesc' file mode
is used, and therefore the message is formatted into the corresponding seq_file
immediately.
Otherwise the called function allocated a new buffer, formats the text into the
buffer and returns the pointer to it, so that it can be queued into the ring-buffer
of the processess blocked waiting on input on 'events' file in debugfs.
'debug' parameter to the 'hid' module is now used solely for the prupose of inetrnal
driver state debugging (parser, transport, etc).
It is a little bit inconvenient for people who have some non-standard
HID hardware (usually violating the HID specification) to have to
recompile kernel with CONFIG_HID_DEBUG to be able to see kernel's perspective
of the HID report descriptor and observe the parsed events. Plus the messages
are then mixed up inconveniently with the rest of the dmesg stuff.
This patch implements /sys/kernel/debug/hid/<device>/rdesc file, which
represents the kernel's view of report descriptor (both the raw report
descriptor data and parsed contents).
With all the device-specific debug data being available through debugfs, there
is no need for keeping CONFIG_HID_DEBUG, as the 'debug' parameter to the
hid module will now only output only driver-specific debugging options, which has
absolutely minimal memory footprint, just a few error messages and one global
flag (hid_debug).
We use the current set of output formatting functions. The ones that need to be
used both for one-shot rdesc seq_file and also for continuous flow of data
(individual reports, as being sent by the device) distinguish according to the
passed seq_file parameter, and if it is NULL, it still output to kernel ringbuffer,
otherwise the corresponding seq_file is used for output.
The format of the output is preserved.
Added constants to hid.h for all digitizer usages (including the new multitouch
ones that are not yet in the official USB spec but are being pushed by Microsft
as described in their paper "Digitizer Drivers for Windows Touch and Pen-Based
Computers"). Updated hid-debug.c to support the new MT input constants such as
ABS_MT_POSITION_X.
drivers/hid/hid-core.c
This removal was scheduled and there is no problem with later
distros to adapt for the new bus, thanks to aliases.
module-init-tools map files are deprecated nowadays, so that
the patch which introduced hid ones into the m-i-t won't be
accepted and hence there is no reason for leaving compat stuff in.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
When hid quirks were converted to specialized driver, the HID_QUIRK_IGNORE
has been moved completely, as the hid_ignore_list[] has been moved into the
generic code.
However userspace already got used to the possibility that modprobing
usbhid with
'quirks=vid:pid:0x4'
makes the device ignored by usbhid driver. So keep this quirk flag in place
for backwards compatibility.
This uses the USB busy mechanism for aggessive autosuspend of USB
HID devices. It autosuspends all opened devices supporting remote wakeup
after a timeout unless
- output is being done to the device
- a key is being held down (remote wakeup isn't triggered upon key release)
- LED(s) are lit
- hiddev is opened
As in the current driver closed devices will be autosuspended even if they
don't support remote wakeup.
The patch is quite large because output to devices is done in hard interrupt
context meaning a lot a queuing and locking had to be touched. The LED stuff
has been solved by means of a simple counter. Additions to the generic HID code
could be avoided. In addition it now covers hidraw. It contains an embryonic
version of an API to let the generic HID code tell the lower levels which
capabilities with respect to power management are needed.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
fix the following 'make headers_check' warnings:
usr/include/linux/hid.h:69: extern's make no sense in userspace
usr/include/linux/hid.h:76: extern's make no sense in userspace
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Impact: include a prototype for the exported function in the macro
Fix about 20 of this warnings:
drivers/hid/hid-a4tech.c:162:1: warning: symbol 'hid_compat_a4tech' was not declared. Should it be static?
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Allow adding new devices to the hid drivers on the fly without
a need of kernel recompilation.
Now, one can test a driver e.g. by:
echo 0003:045E:00F0.0003 > ../generic-usb/unbind
echo 0003 045E 00F0 > new_id
from some driver subdir.
Move usbhid specific flags from global hid.h into local usbhid.h.
Usbhid structure is allocated on start invoked only from probe
of some driver. When there is no driver, the structure is null
and causes null-dereference oopses.
Fix it by allocating the structure on probe and disconnect of
the device itself. Also make sure we won't race between start
and resume or stop and suspend respectively.
References: http://bugzilla.kernel.org/show_bug.cgi?id=11827
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Andreas Schwab <schwab@suse.de>
Add type to the hid structure to distinguish to which device type
(now only mouse) we are talking to. Needed for per device type ignore
list support.
Note: this patch leaves the type as unknown for bluetooth devices,
there is not support for this in the hidp code.
Commit 8006479c9b75fb6594a7b746af3d7f1fbb68f18f introduced a spinlock in
input_dev->event_lock, which is locked when handling input events.
However, the hid-pidff driver sleeps when handling events as it waits for
reports being sent to the device before changing the report contents
again.
This causes a system lockup when trying to use force feedback with a PID
device, a regression introduced in 2.6.24 and 2.6.23.15.
Fix it by extracting the raw report data from struct hid_report
immediately when hid_submit_report() is called, therefore allowing
drivers to change the contents of struct hid_report immediately without
affecting the already-queued transfer.
In hid-pidff, re-add the removed usbhid_wait_io() to
pidff_erase_effect() instead, to prevent a full report queue from causing
the submission to fail, thus not freeing up device memory.
pidff_erase_effect() is not called while dev->event_lock is held.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
hid-ff.c now calls only pidff (generic driver), the special ones are now
in separate drivers. Invoke pidff on all non-special directly.
Move the force feedback processing into a separate module.
[jkosina@suse.cz: fix Kconfig texts a little bit]
Merge the logitech force feedback processing directly into logitech
driver from the usbhid core.
Move the handling of the leds resetting from the core to
the dell and logitech drivers.
Move connecting from usbhid to the hid layer and fix also hidp in
that manner.
This removes all the ignore/force hidinput/hiddev connecting quirks.
Remove support for both dynamic and static report descriptor
quirks. There is no longer rdesc code which it would support,
so it's useless.
Remove the file since these is no user now.
