path: root/include/linux/hid.h
2014-11-14HID: usbhid: add always-poll quirkJohan Hovold
commit 0b750b3baa2d64f1b77aecc10f20deeb28efe60d upstream. Add quirk to make sure that a device is always polled for input events even if it hasn't been opened. This is needed for devices that disconnects from the bus unless the interrupt endpoint has been polled at least once or when not responding to an input event (e.g. after having shut down X). Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-13HID: provide a helper for validating hid reportsKees Cook
Many drivers need to validate the characteristics of their HID report during initialization to avoid misusing the reports. This adds a common helper to perform validation of the report exisitng, the field existing, and the expected number of values within the field. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-09-06Merge branches 'for-3.12/devm', 'for-3.12/i2c-hid', 'for-3.12/i2c-hid-dt', ↵Jiri Kosina
'for-3.12/logitech', 'for-3.12/multitouch-win8', 'for-3.12/trasnport-driver-cleanup', 'for-3.12/uhid', 'for-3.12/upstream' and 'for-3.12/wiimote' into for-linus
2013-09-04HID: move HID_REPORT_TYPES closer to the report-definitionsDavid Herrmann
HID_REPORT_TYPES defines the number of available report-types. Move it closer to the actualy definition of the report-types so we can see the relation more clearly (and hopefully will never forget to update it). Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-09-04Merge branch 'for-3.11/CVE-2013-2888' into for-3.12/upstreamJiri Kosina
This one didn't make it for 3.11 due to being applied too close to release, queue it for 3.12 merge window. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-29HID: validate HID report id sizeKees Cook
The "Report ID" field of a HID report is used to build indexes of reports. The kernel's index of these is limited to 256 entries, so any malicious device that sets a Report ID greater than 255 will trigger memory corruption on the host: [ 1347.156239] BUG: unable to handle kernel paging request at ffff88094958a878 [ 1347.156261] IP: [<ffffffff813e4da0>] hid_register_report+0x2a/0x8b CVE-2013-2888 Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@kernel.org Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-27HID: do not init input reports for Win 8 multitouch devicesBenjamin Tissoires
Some multitouch screens do not like to be polled for input reports. However, the Win8 spec says that all touches should be sent during each report, making the initialization of reports unnecessary. The Win7 spec is less precise, so do not use this for those devices. Add the quirk HID_QUIRK_NO_INIT_INPUT_REPORTS so that we do not have to introduce a quirk for each problematic device. This quirk makes the driver behave the same way the Win 8 does. It actually retrieves the features, but not the inputs. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Tested-by: Srinivas Pandruvada<srinivas.pandruvada@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-27HID: detect Win 8 multitouch devices in coreBenjamin Tissoires
Detecting Win 8 multitouch devices in core allows us to set quirks before the device is parsed through hid_hw_start(). It also simplifies the detection of those devices in hid-multitouch and makes the handling of those devices cleaner. As Win 8 multitouch panels are in the group multitouch and rely on a special feature to be detected, this patch adds a bitfield in the parser. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Tested-by: Srinivas Pandruvada<srinivas.pandruvada@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-31HID: input: generic hidinput_input_event handlerDavid Herrmann
The hidinput_input_event() callback converts input events written from userspace into HID reports and sends them to the device. We currently implement this in every HID transport driver, even though most of them do the same. This provides a generic hidinput_input_event() implementation which is mostly copied from usbhid. It uses a delayed worker to allow multiple LED events to be collected into a single output event. We use the custom ->request() transport driver callback to allow drivers to adjust the outgoing report and handle the request asynchronously. If no custom ->request() callback is available, we fall back to the generic raw output report handler (which is synchronous). Drivers can still provide custom hidinput_input_event() handlers (see logitech-dj) if the generic implementation doesn't fit their needs. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-31HID: usbhid: make usbhid_set_leds() staticDavid Herrmann
usbhid_set_leds() is only used inside of usbhid/hid-core.c so no need to export it. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-22HID: fix data access in implement()Jiri Kosina
implement() is setting bytes in LE data stream. In case the data is not aligned to 64bits, it reads past the allocated buffer. It doesn't really change any value there (it's properly bitmasked), but in case that this read past the boundary hits a page boundary, pagefault happens when accessing 64bits of 'x' in implement(), and kernel oopses. This happens much more often when numbered reports are in use, as the initial 8bit skip in the buffer makes the whole process work on values which are not aligned to 64bits. This problem dates back to attempts in 2005 and 2006 to make implement() and extract() as generic as possible, and even back then the problem was realized by Adam Kroperlin, but falsely assumed to be impossible to cause any harm: http://www.mail-archive.com/linux-usb-devel@lists.sourceforge.net/msg47690.html I have made several attempts at fixing it "on the spot" directly in implement(), but the results were horrible; the special casing for processing last 64bit chunk and switching to different math makes it unreadable mess. I therefore took a path to allocate a few bytes more which will never make it into final report, but are there as a cushion for all the 64bit math operations happening in implement() and extract(). All callers of hid_output_report() are converted at the same time to allocate the buffer by newly introduced hid_alloc_report_buf() helper. Bruno noticed that the whole raw_size test can be dropped as well, as hid_alloc_report_buf() makes sure that the buffer is always of a proper size. Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Acked-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-05-06HID: debug: fix RCU preemption issueJiri Kosina
Commit 2353f2bea ("HID: protect hid_debug_list") introduced mutex locking around debug_list access to prevent SMP races when debugfs nodes are being operated upon by multiple userspace processess. mutex is not a proper synchronization primitive though, as the hid-debug callbacks are being called from atomic contexts. We also have to be careful about disabling IRQs when taking the lock to prevent deadlock against IRQ handlers. Benjamin reports this has also been reported in RH bugzilla as bug #958935. =============================== [ INFO: suspicious RCU usage. ] 3.9.0+ #94 Not tainted ------------------------------- include/linux/rcupdate.h:476 Illegal context switch in RCU read-side critical section! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 4 locks held by Xorg/5502: #0: (&evdev->mutex){+.+...}, at: [<ffffffff81512c3d>] evdev_write+0x6d/0x160 #1: (&(&dev->event_lock)->rlock#2){-.-...}, at: [<ffffffff8150dd9b>] input_inject_event+0x5b/0x230 #2: (rcu_read_lock){.+.+..}, at: [<ffffffff8150dd82>] input_inject_event+0x42/0x230 #3: (&(&usbhid->lock)->rlock){-.....}, at: [<ffffffff81565289>] usb_hidinput_input_event+0x89/0x120 stack backtrace: CPU: 0 PID: 5502 Comm: Xorg Not tainted 3.9.0+ #94 Hardware name: Dell Inc. OptiPlex 390/0M5DCD, BIOS A09 07/24/2012 0000000000000001 ffff8800689c7c38 ffffffff816f249f ffff8800689c7c68 ffffffff810acb1d 0000000000000000 ffffffff81a03ac7 000000000000019d 0000000000000000 ffff8800689c7c90 ffffffff8107cda7 0000000000000000 Call Trace: [<ffffffff816f249f>] dump_stack+0x19/0x1b [<ffffffff810acb1d>] lockdep_rcu_suspicious+0xfd/0x130 [<ffffffff8107cda7>] __might_sleep+0xc7/0x230 [<ffffffff816f7770>] mutex_lock_nested+0x40/0x3a0 [<ffffffff81312ac4>] ? vsnprintf+0x354/0x640 [<ffffffff81553cc4>] hid_debug_event+0x34/0x100 [<ffffffff81554197>] hid_dump_input+0x67/0xa0 [<ffffffff81556430>] hid_set_field+0x50/0x120 [<ffffffff8156529a>] usb_hidinput_input_event+0x9a/0x120 [<ffffffff8150d89e>] input_handle_event+0x8e/0x530 [<ffffffff8150df10>] input_inject_event+0x1d0/0x230 [<ffffffff8150dd82>] ? input_inject_event+0x42/0x230 [<ffffffff81512cae>] evdev_write+0xde/0x160 [<ffffffff81185038>] vfs_write+0xc8/0x1f0 [<ffffffff81185535>] SyS_write+0x55/0xa0 [<ffffffff81704482>] system_call_fastpath+0x16/0x1b BUG: sleeping function called from invalid context at kernel/mutex.c:413 in_atomic(): 1, irqs_disabled(): 1, pid: 5502, name: Xorg INFO: lockdep is turned off. irq event stamp: 1098574 hardirqs last enabled at (1098573): [<ffffffff816fb53f>] _raw_spin_unlock_irqrestore+0x3f/0x70 hardirqs last disabled at (1098574): [<ffffffff816faaf5>] _raw_spin_lock_irqsave+0x25/0xa0 softirqs last enabled at (1098306): [<ffffffff8104971f>] __do_softirq+0x18f/0x3c0 softirqs last disabled at (1097867): [<ffffffff81049ad5>] irq_exit+0xa5/0xb0 CPU: 0 PID: 5502 Comm: Xorg Not tainted 3.9.0+ #94 Hardware name: Dell Inc. OptiPlex 390/0M5DCD, BIOS A09 07/24/2012 ffffffff81a03ac7 ffff8800689c7c68 ffffffff816f249f ffff8800689c7c90 ffffffff8107ce60 0000000000000000 ffff8800689c7fd8 ffff88006a62c800 ffff8800689c7d10 ffffffff816f7770 ffff8800689c7d00 ffffffff81312ac4 Call Trace: [<ffffffff816f249f>] dump_stack+0x19/0x1b [<ffffffff8107ce60>] __might_sleep+0x180/0x230 [<ffffffff816f7770>] mutex_lock_nested+0x40/0x3a0 [<ffffffff81312ac4>] ? vsnprintf+0x354/0x640 [<ffffffff81553cc4>] hid_debug_event+0x34/0x100 [<ffffffff81554197>] hid_dump_input+0x67/0xa0 [<ffffffff81556430>] hid_set_field+0x50/0x120 [<ffffffff8156529a>] usb_hidinput_input_event+0x9a/0x120 [<ffffffff8150d89e>] input_handle_event+0x8e/0x530 [<ffffffff8150df10>] input_inject_event+0x1d0/0x230 [<ffffffff8150dd82>] ? input_inject_event+0x42/0x230 [<ffffffff81512cae>] evdev_write+0xde/0x160 [<ffffffff81185038>] vfs_write+0xc8/0x1f0 [<ffffffff81185535>] SyS_write+0x55/0xa0 [<ffffffff81704482>] system_call_fastpath+0x16/0x1b Reported-by: majianpeng <majianpeng@gmail.com> Reported-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-30Merge branch 'for-3.10/mt-hybrid-finger-pen' into for-linusJiri Kosina
Conflicts: drivers/hid/hid-multitouch.c
2013-04-30Merge branches 'for-3.10/appleir', 'for-3.10/hid-debug', ↵Jiri Kosina
'for-3.10/hid-driver-transport-cleanups', 'for-3.10/i2c-hid' and 'for-3.10/logitech' into for-linus
2013-04-30HID: protect hid_debug_listJiri Kosina
Accesses to hid_device->hid_debug_list are not serialized properly, which could result in SMP concurrency issues when HID debugfs events are accessesed by multiple userspace processess. Serialize all the list operations by a mutex. Spotted by Al Viro. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-03-27HID: input: don't register unmapped input devicesBenjamin Tissoires
There is no need to register an input device containing no events. This allows drivers using the quirk MULTI_INPUT to register one input per report effectively used. For backward compatibility, we need to add a quirk to request this behavior. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-03-07HID: ll_driver: Extend the interface with idle requestsBenjamin Tissoires
Some drivers send the idle command directly to underlying device, creating an unwanted dependency on the underlying transport layer. This patch adds hid_hw_idle() to the interface, thereby removing usbhid from the lion share of the drivers. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-03-01HID: Separate struct hid_device's driver_lock into two locks.Andrew de los Reyes
This patch separates struct hid_device's driver_lock into two. The goal is to allow hid device drivers to receive input during their probe() or remove() function calls. This is necessary because some drivers need to communicate with the device to determine parameters needed during probe (e.g., size of a multi-touch surface), and if possible, may perfer to communicate with a device on host-initiated disconnect (e.g., to put it into a low-power state). Historically, three functions used driver_lock: - hid_device_probe: blocks to acquire lock - hid_device_remove: blocks to acquire lock - hid_input_report: if locked returns -EBUSY, else acquires lock This patch adds another lock (driver_input_lock) which is used to block input from occurring. The lock behavior is now: - hid_device_probe: blocks to acq. driver_lock, then driver_input_lock - hid_device_remove: blocks to acq. driver_lock, then driver_input_lock - hid_input_report: if driver_input_lock locked returns -EBUSY, else acquires driver_input_lock This patch also adds two helper functions to be called during probe() or remove(): hid_device_io_start() and hid_device_io_stop(). These functions lock and unlock, respectively, driver_input_lock; they also make a note of whether they did so that hid-core knows if a driver has changed the lock state. This patch results in no behavior change for existing devices and drivers. However, during a probe() or remove() function call in a driver, that driver may now selectively call hid_device_io_start() to let input events come through, then optionally call hid_device_io_stop() to stop them. Signed-off-by: Andrew de los Reyes <adlr@chromium.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-25HID: Extend the interface with wait io requestHenrik Rydberg
Some drivers need to wait for an io from the underlying device, creating an unwanted dependency on the underlying transport layer. This patch adds wait() to the interface, thereby removing usbhid from the lion share of the drivers. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-25HID: Extend the interface with report requestsHenrik Rydberg
Some drivers send reports directly to underlying device, creating an unwanted dependency on the underlying transport layer. This patch adds hid_hw_request() to the interface, thereby removing usbhid from the lion share of the drivers. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-21Merge branches 'for-3.9/logitech', 'for-3.9/multitouch', 'for-3.9/ntrig', ↵Jiri Kosina
'for-3.9/thingm' and 'for-3.9/upstream' into for-linus
2013-02-05HID: core: add "report" hook, called once the report has been parsedBenjamin Tissoires
This callback is called when the parsing of the report has been done by hid-core (so after the calls to .event). The hid drivers can now have access to the whole report by relying on the values stored in the different fields. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-03HID: hid.h: remove unused hid_generic_{init,exit} prototypesH Hartley Sweeten
These functions are not defined. Remove the extern declarations. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-03HID: introduce helper for hid_driver boilerplateH Hartley Sweeten
Introduce the module_hid_driver macro which is a convenience macro for HID driver modules similar to module_usb_driver. It is intended to be used by drivers with init/exit sections that do nothing but register/unregister the HID driver. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-12Merge branches 'for-3.7/upstream-fixes', 'for-3.8/hidraw', ↵Jiri Kosina
'for-3.8/i2c-hid', 'for-3.8/multitouch', 'for-3.8/roccat', 'for-3.8/sensors' and 'for-3.8/upstream' into for-linus Conflicts: drivers/hid/hid-core.c
2012-12-12HID: sensors: autodetect USB HID sensor hubsAlexander Holler
It should not be necessary to add IDs for HID sensor hubs to lists in hid-core.c and hid-sensor-hub.c. So instead of a whitelist, autodetect such USB HID sensor hubs, based on a collection of type physical inside a useage page of type sensor. If some sensor hubs stil must be usable as raw devices, a blacklist might be created. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Acked-by: "Pandruvada, Srinivas" <srinivas.pandruvada@intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-07HID: hidp: fallback to input session properly if hid is blacklistedLamarque V. Souza
This patch against kernel 3.7.0-rc8 fixes a kernel oops when turning on the bluetooth mouse with id 0458:0058 [1]. The mouse in question supports both input and hid sessions, however it is blacklisted in drivers/hid/hid-core.c so the input session is one that should be used. Long ago (around kernel 3.0.0) some changes in the bluetooth subsystem made the kernel do not fallback to input session when hid session is not supported or blacklisted. This patch restore that behaviour by making the kernel try the input session if hid_add_device returns ENODEV. The patch exports hid_ignore() from hid-core.c so that it can be used in the bluetooth subsystem. [1] https://bugzilla.kernel.org/show_bug.cgi?id=39882 Signed-off-by: Lamarque V. Souza <lamarque@gmail.com> Acked-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-15HID: add usage_index in struct hid_usage.Benjamin Tissoires
Currently, there is no way to know the index of the current field in the .input_mapping and .event callbacks when this field is inside an array of HID fields. This patch adds this index to the struct hid_usage so that this information is available to input_mapping and event callbacks. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-15HID: fix unit exponent parsingBenjamin Tissoires
HID spec details special values for the HID field unit exponent. Basically, the range [0x8..0xf] correspond to [-8..-1], so this is a standard two's complement on a half-byte. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-15HID: export hidinput_calc_abs_resBenjamin Tissoires
Exporting the function allows us to calculate the resolution in third party drivers like hid-multitouch. This patch also complete the function with additional valid axes. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-09-19HID: Allow more fields in the hid reportHenrik Rydberg
Some recent hardware define more than 128 fields in the report descriptor. Increase the limit to 256. This adds another kilobyte of memory per report. Tested-by: Ping Cheng <pingc@wacom.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2012-09-19HID: Add an input configured notification callbackHenrik Rydberg
A hid device may create several input devices, and a driver may need to prepare or finalize the configuration per input device. Currently, there is no sane way for a driver to know when a device has been configured. This patch adds a callback providing that information. Reviewed-and-tested-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Tested-by: Ping Cheng <pingc@wacom.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2012-07-09HID: Add suport for the brightness control keys on HP keyboardsKeng-Yu Lin
The keys are found on the keyboards bundled with HP All-In-One machines with USB VID/PID of 04ca:004d and 04f2:1061. Signed-off-by: Keng-Yu Lin <kengyu@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-22Merge branch 'upstream' into for-linusJiri Kosina
2012-05-01HID: hid-multitouch: Switch to device groupsHenrik Rydberg
Switch the driver over to device group handling. By adding the HID_GROUP_MULTITOUCH group to hid-core, hid-generic will no longer match multitouch devices. By adding the HID_GROUP_MULTITOUCH entry to the device list, hid-multitouch will match all unknown multitouch devices, and udev will automatically load the module. Since HID_QUIRK_MULTITOUCH never gets set, the special quirks handling can be removed. Since all HID MT devices have HID_DG_CONTACTID, they can be removed from the hid_have_special_driver list. With this patch, the unknown device ids are no longer NULL, so the code is modified to check for the generic entry instead. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-01HID: Create a generic device groupHenrik Rydberg
Devices that do not have a special driver are handled by the generic driver. This patch does the same thing using device groups; Instead of forcing a particular driver, the appropriate driver is picked up by udev. As a consequence, one can now move a device from generic to specific handling by a simple rebind. By adding a new device id to the generic driver, the same thing can be done in reverse. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-01HID: Scan the device for group info before adding itHenrik Rydberg
In order to allow the report descriptor to influence the hid device properties, one needs to parse the descriptor early, without reference to any driver. Scan the descriptor for group information during device add, before the device has been broadcast to userland. The device modalias will contain group information which can be used to differentiate between modules. For starters, just handle the generic group. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-01HID: Add device group to modaliasHenrik Rydberg
HID devices are only partially presented to userland. Hotplugged devices emit events containing a modalias based on the basic bus, vendor and product entities. However, in practise a hid device can depend on details such as a single usb interface or a particular item in a report descriptor. This patch adds a device group to the hid device id, and broadcasts it using uevent and the device modalias. The module alias generation is modified to match. As a consequence, a device with a non-zero group will be processed by the corresponding group driver instead of by the generic hid driver. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-01HID: Handle driver-specific device descriptor in coreHenrik Rydberg
The low-level driver can read the report descriptor, but it cannot determine driver-specific changes to it. The hid core can fixup and parse the report descriptor during driver attach, but does not have direct access to the descriptor when doing so. To be able to handle attach/detach of hid drivers properly, a semantic change to hid_parse_report() is needed. This function has been used in two ways, both as descriptor reader in the ll drivers and as a parsor in the probe of the drivers. This patch splits the usage by introducing hid_open_report(), and modifies the hid_parse() macro to call hid_open_report() instead. The only usage of hid_parse_report() is then to read and store the device descriptor. As a consequence, we can handle the report fixups automatically inside the hid core. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Tested-by: Nikolai Kondrashov <spbnick@gmail.com> Tested-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-27HID: hidraw: add proper error handling to raw event reportingJiri Kosina
If kmemdup() in hidraw_report_event() fails, we are not propagating this fact properly. Let hidraw_report_event() and hid_report_raw_event() return an error value to the caller. Reported-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-09Merge branch 'hid-battery' of ↵Jiri Kosina
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen into for-linus
2012-01-08hid-input/battery: remove battery_valJeremy Fitzhardinge
hidinput_get_battery_property() now directly polls the device for the current battery strength, so there's no need for battery_val, or the code to set it on the input event path. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
2012-01-08hid-input/battery: deal with both FEATURE and INPUT report batteriesJeremy Fitzhardinge
Some devices seem to report batteries as FEATUREs, others as INPUTs. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
2012-01-08hid-input/battery: add quirks for batteryJeremy Fitzhardinge
Some devices always report percentage, despite having 0/255 as their min/max, so add a quirk for them. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
2012-01-08hid-input: add support for HID devices reporting Battery StrengthDaniel Nicoletti
I've sent an email earlier asking for help with a GetFeature code, and now I have a second patch on top of Jeremy's to provide the battery functionality for devices that support reporting it. If I understood correctly when talking to Jeremy he said his device never actually reported the status as an input event (sorry if I didn't understand it correctly), and after reading HID specs I believe it's really because it was meant to be probed, I have an Apple Keyboard and Magic Trackpad both bluetooth batteries operated, so using PacketLogger I saw that Mac OSX always ask the battery status using the so called GetFeature. What my patch does is basically: - store the report id that matches the battery_strength - setup the battery if 0x6.0x20 is found, even if that is reported as a feature (as it was meant to be but only the MagicTrackpad does) - when upower or someone access /sys/class/power_supply/hid-*/capacity it will probe the device and return it's status. It works great for both devices, but I have two concerns: - the report_features function has a duplicated code - it would be nice if it was possible for specific drivers to provide their own probe as there might be some strange devices... (but maybe it's already possible) I've talked to the upower dev and he fixed it to be able to show the right percentage. Here how the uevent file (in /sys/class/power_supply/hid-*/) looks like: POWER_SUPPLY_NAME=hid-00:22:41:D9:18:E7-battery POWER_SUPPLY_PRESENT=1 POWER_SUPPLY_ONLINE=1 POWER_SUPPLY_CAPACITY=66 POWER_SUPPLY_MODEL_NAME=MacAdmin’s keyboard POWER_SUPPLY_STATUS=Discharging POWER_SUPPLY_NAME=hid-70:CD:60:F5:FF:3F-battery POWER_SUPPLY_PRESENT=1 POWER_SUPPLY_ONLINE=1 POWER_SUPPLY_CAPACITY=62 POWER_SUPPLY_MODEL_NAME=nexx’s Trackpad POWER_SUPPLY_STATUS=Discharging Signed-off-by: Daniel Nicoletti <dantti12@gmail.com>
2012-01-05Merge branches 'hyperv', 'multitouch', 'roccat', 'upstream', ↵Jiri Kosina
'upstream-fixes', 'wacom' and 'wiimote' into for-linus
2011-12-21HID: usbhid: defer LED setting to a workqueueDaniel Kurtz
Defer LED setting action to a workqueue. This is more likely to send all LED change events in a single URB. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-28HID: hid-input: add support for HID devices reporting Battery StrengthJeremy Fitzhardinge
Some HID devices, such as my Bluetooth mouse, report their battery strength as an event. Rather than passing it through as a strange absolute input event, this patch registers it with the power_supply subsystem as a battery, so that the device's Battery Strength can be reported to usermode. The battery appears in sysfs names /sys/class/power_supply/hid-<UNIQ>-battery, and it is a child of the battery-containing device, so it should be clear what it's the battery of. Unfortunately on my current Fedora 16 system, while the battery does appear in the UI, it is listed as a Laptop Battery with 0% charge (since it ignores the "capacity" property of the battery and instead computes it from the "energy*" fields, which we can't supply given the limited information contained within the HID Report). Still, this patch is the first step. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-31include: convert various register fcns to macros to avoid include chainingPaul Gortmaker
The original implementations reference THIS_MODULE in an inline. We could include <linux/export.h>, but it is better to avoid chaining. Fortunately someone else already thought of this, and made a similar inline into a #define in <linux/device.h> for device_schedule_callback(), [see commit 523ded71de0] so follow that precedent here. Also bubble up any __must_check that were used on the prev. wrapper inline functions up one to the real __register functions, to preserve any prev. sanity checks that were used in those instances. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
