path: root/include/linux/hidraw.h
2009-01-04HID: add phys and name ioctls to hidrawJiri Kosina
The hiddev interface provides ioctl() calls which can be used to obtain phys and raw name of the underlying device. Add the corresponding support also into hidraw. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-04-22HID: export headers properlyMike Frysinger
I have people whining about using these headers in userspace, and they have __KERNEL__ markings which implies they're supposed to be exported. I also added the required linux/types.h include to hidraw.h since it uses the __u## kernel types. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jiri Kosina <jikos@jikos.cz> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-15HID: fix HIDIOCGRDESC memory access in hidrawJiri Kosina
Fix bogus copying of data into userspace when HIDIOCGRDESC is issued. HID-transport layer makes sure that dev->hid->rdesc is not larger than HID_MAX_DESCRIPTOR_SIZE. Noticed-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14HID: add hidraw interfaceJiri Kosina
hidraw is an interface that is going to obsolete hiddev one day. Many userland applications are using libusb instead of using kernel-provided hiddev interface. This is caused by various reasons - the HID parser in kernel doesn't handle all the HID hardware on the planet properly, some devices might require its own specific quirks/drivers, etc. hiddev interface tries to do its best to parse all the received reports properly, and presents only parsed usages into userspace. This is however often not enough, and that's the reason why many userland applications just don't use hiddev at all, and rather use libusb to read raw USB events and process them on their own. Another drawback of hiddev is that it is USB-specific. hidraw interface provides userspace readers with really raw HID reports, no matter what the low-level transport layer is (USB/BT), and gives the userland applications all the freedom to process the HID reports in a way they wish to. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
