path: root/include/linux/hippidevice.h
2008-11-20hippi: convert driver to net_device_opsStephen Hemminger
Convert the HIPPI infrastructure for use with net_device_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: net/802: more endian annotationsAlexey Dobriyan
The rest of endian warnings now belongs to tr.c exclusively. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Remove HIPPI private from skbuff.hStephen Hemminger
This removes the private element from skbuff, that is only used by HIPPI. Instead it uses skb->cb[] to hold the additional data that is needed in the output path from hard_header to device driver. PS: The only qdisc that might potentially corrupt this cb[] is if netem was used over HIPPI. I will take care of that by fixing netem to use skb->stamp. I don't expect many users of netem over HIPPI Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
