path: root/include/linux/hippidevice.h
2013-09-26[networking]device.h: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com>
2008-11-20hippi: convert driver to net_device_opsStephen Hemminger
Convert the HIPPI infrastructure for use with net_device_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: net/802: more endian annotationsAlexey Dobriyan
The rest of endian warnings now belongs to tr.c exclusively. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Remove HIPPI private from skbuff.hStephen Hemminger
This removes the private element from skbuff, that is only used by HIPPI. Instead it uses skb->cb[] to hold the additional data that is needed in the output path from hard_header to device driver. PS: The only qdisc that might potentially corrupt this cb[] is if netem was used over HIPPI. I will take care of that by fixing netem to use skb->stamp. I don't expect many users of netem over HIPPI Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
