path: root/include/linux/hpet.h
2009-08-27intr-remap: generic support for remapping HPET MSIsSuresh Siddha
Generic support for remapping HPET MSI's by parsing the HPET timer block device scope in the ACPI DRHD tables. This is needed for platforms supporting interrupt-remapping and MSI capable HPET timer block. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Jay Fenlason <fenlason@redhat.com> LKML-Reference: <20090804190729.477649000@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-31hpet: /dev/hpet - fixes and cleanupDavid Brownell
Minor /dev/hpet updates and bugfixes: * Remove dead code, mostly remnants of an incomplete/unusable kernel interface ... noted when addressing "sparse" warnings: + hpet_unregister() and a routine it calls + hpet_task and all references, including hpet_task_lock + hpet_data.hd_flags (and HPET_DATA_PLATFORM) * Correct and improve boot message: + displays *counter* (shared between comparators) bit width, not *timer* bit widths (which are often mixed) + relabel "timers" as "comparators"; this is less confusing, they are not independent like normal timers are (sigh) + display MHz not Hz; it's never less than 10 MHz. * Tighten and correct the userspace interface code + don't accidentally program comparators in 64-bit mode using 32-bit values ... always force comparators into 32-bit mode + provide the correct bit definition flagging comparators with periodic capability ... the ABI is unchanged * Update Documentation/hpet.txt + be more correct and current + expand description a bit + don't mention that now-gone kernel interface Plus, add a FIXME comment for something that could cause big trouble on systems with more capable HPETs than at least Intel seems to ship. It seems that few folk use this userspace interface; it's not very usable given the general lack of HPET IRQ routing. I'm told that the only real point of it any more is to mmap for fast timestamps; IMO that's handled better through the gettimeofday() vsyscall. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-02x86: get irq for hpet timerKevin Hao
HPET timer's IRQ is 0 by default. So we have to select which irq will be used by these timers. We wait to set the timer's irq until we really open it in order to reduce the chance of conflicting with other device. Signed-off-by: Kevin Hao <kexin.hao@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-04x86: revert assign IRQs to hpet timerThomas Gleixner
The commits: commit 37a47db8d7f0f38dac5acf5a13abbc8f401707fa Author: Balaji Rao <balajirrao@gmail.com> Date: Wed Jan 30 13:30:03 2008 +0100 x86: assign IRQs to HPET timers, fix and commit e3f37a54f690d3e64995ea7ecea08c5ab3070faf Author: Balaji Rao <balajirrao@gmail.com> Date: Wed Jan 30 13:30:03 2008 +0100 x86: assign IRQs to HPET timers have been identified to cause a regression on some platforms due to the assignement of legacy IRQs which makes the legacy devices connected to those IRQs disfunctional. Revert them. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10382 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: nuke a ton of dead hpet codeThomas Gleixner
No users, just ballast Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: assign IRQs to HPET timersBalaji Rao
The userspace API for the HPET (see Documentation/hpet.txt) did not work. The HPET_IE_ON ioctl was failing as there was no IRQ assigned to the timer device. This patch fixes it by allocating IRQs to timer blocks in the HPET. arch/x86/kernel/hpet.c | 13 +++++-------- drivers/char/hpet.c | 45 ++++++++++++++++++++++++++++++++++++++------- include/linux/hpet.h | 2 +- 3 files changed, 44 insertions(+), 16 deletions(-) Signed-off-by: Balaji Rao <balajirrao@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-03-26[PATCH] hpet header sanitizationRandy Dunlap
Add __KERNEL__ block. Use __KERNEL__ to allow ioctl interface to be usable. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
