path: root/include/linux/hw_random.h
2015-03-16hwrng: add devm_* interfacesDmitry Torokhov
This change adds devm_hwrng_register and devm_hwrng_unregister which use can simplify error unwinding and unbinding code paths in device drivers. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-12-26hwrng: core - Use struct completion for cleanup_doneHerbert Xu
There is no point in doing a manual completion for cleanup_done when struct completion fits in perfectly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-12-22hwrng: fix unregister race.Rusty Russell
The previous patch added one potential problem: we can still be reading from a hwrng when it's unregistered. Add a wait for zero in the hwrng_unregister path. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Amos Kong <akong@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-12-22hwrng: use reference counts on each struct hwrng.Rusty Russell
current_rng holds one reference, and we bump it every time we want to do a read from it. This means we only hold the rng_mutex to grab or drop a reference, so accessing /sys/devices/virtual/misc/hw_random/rng_current doesn't block on read of /dev/hwrng. Using a kref is overkill (we're always under the rng_mutex), but a standard pattern. This also solves the problem that the hwrng_fillfn thread was accessing current_rng without a lock, which could change (eg. to NULL) underneath it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Amos Kong <akong@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-07-15hwrng: add per-device entropy deratingTorsten Duwe
This patch introduces a derating factor to struct hwrng for the random bits going into the kernel input pool, and a common default derating for drivers which do not specify one. Signed-off-by: Torsten Duwe <duwe@suse.de> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Acked-by: H. Peter Anvin <hpa@zytor.com>
2014-07-15random: add_hwgenerator_randomness() for feeding entropy from devicesTorsten Duwe
This patch adds an interface to the random pool for feeding entropy in-kernel. Signed-off-by: Torsten Duwe <duwe@suse.de> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Acked-by: H. Peter Anvin <hpa@zytor.com>
2011-05-25hwrng: fix spelling mistake in header commentSasha Levin
Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-01hwrng: core - Replace u32 in driver API with byte arrayIan Molton
This patch implements a new method by which hw_random hardware drivers can pass data to the core more efficiently, using a shared buffer. The old methods have been retained as a compatability layer until all the drivers have been updated. Signed-off-by: Ian Molton <ian.molton@collabora.co.uk> Acked-by: Matt Mackall <mpm@selenic.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19PM: Remove destroy_suspended_device()Rafael J. Wysocki
After 2.6.24 there was a plan to make the PM core acquire all device semaphores during a suspend/hibernation to protect itself from concurrent operations involving device objects. That proved to be too heavy-handed and we found a better way to achieve the goal, but before it happened, we had introduced the functions device_pm_schedule_removal() and destroy_suspended_device() to allow drivers to "safely" destroy a suspended device and we had adapted some drivers to use them. Now that these functions are no longer necessary, it seems reasonable to remove them and modify their users to use the normal device unregistration instead. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-05HWRNG: add possibility to remove hwrng devices during suspend/resumeRafael J. Wysocki
Make it possible to unregister a Hardware Random Number Generator device object in a safe way during a suspend/resume cycle. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Michael Buesch <mb@bu3sch.de> Cc: Michael Buesch <mb@bu3sch.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11[HWRNG]: move status polling loop to data_present callbacksPatrick McHardy
Handle waiting for new random within the drivers themselves, this allows to use better suited timeouts for the individual rngs. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[PATCH] Add new generic HW RNG coreMichael Buesch
Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
