path: root/include/linux/i2c-algo-pcf.h
2008-10-22i2c-algo-pcf: Add adapter hooks around xfer begin and endDavid Miller
Some I2C bus implementations need to synchronize with external entities, such as system firmware, which might also be programming the same I2C bus. In order to facilitate this add ->xfer_begin() and ->xfer_end() hooks which are invoked around pcf_xfer(). [JD: Make these hooks optional.] Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-22i2c-algo-pcf: Pass adapter data into ->waitforpin() methodDavid Miller
Pass adapter data into ->waitforpin() method. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-algo-pcf: Drop unused struct membersJean Delvare
Struct members udelay and timeout aren't used anywhere, so drop them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Eric Brower <ebrower@gmail.com>
2008-07-14i2c-algo-pcf: Multi-master lost-arbitration improvementEric Brower
Improve lost-arbitration handling of PCF8584. This is necessary for support of a currently out-of-kernel driver for Sun Microsystems E250 environmental management; perhaps others. Signed-off-by: Eric Brower <ebrower@gmail.com> Acked-by: Dan Smolik <marvin@mydatex.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-09include files: convert "include" subdirectory to UTF-8John Anthony Kazos Jr
Convert the "include" subdirectory to UTF-8. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10i2c: Discard the i2c algo del_bus wrappersJean Delvare
They are all only calling i2c_del_adapter, so we may as well do it directly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Whitespace cleanupsDavid Brownell
Remove extraneous whitespace from various i2c headers and core files, like space-before-tab and whitespace at end of line. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c-algo-pcf: Discard the mdelay data struct memberAdrian Bunk
i2c-algo-pcf: Discard the mdelay data struct member Just as i2c-algo-bit, i2c-algo-pcf has an unused mdelay struct member, which we can get rid of to spare some code and memory. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Drop unused per-i2c-algorithm adapter maxJean Delvare
There are no more per-i2c-algorithm adapter max. Last time there were was in July 1999. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Drop useless CVS revision IDsJean Delvare
CVS revision IDs are totally useless and irrelevant by now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
