path: root/include/linux/i2c-dev.h
2009-02-24i2c-dev: Clarify the unit of ioctl I2C_TIMEOUTJean Delvare
The unit in which user-space can set the bus timeout value is jiffies for historical reasons (back when HZ was always 100.) This is however not good because user-space doesn't know how long a jiffy lasts. The timeout value should instead be set in a fixed time unit. Given the original value of HZ, this unit should be 10 ms, for compatibility. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2007-10-13i2c: Move i2c-dev interfaces to i2c-dev.hDavid Brownell
Move the i2c-dev support into <linux/i2c-dev.h> where it should always have lived. Now <linux/i2c.h> no longer holds stuff related to the optional userspace /dev/i2c-X interface. Improve the descriptions for these ioctl requests. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2005-10-28[PATCH] i2c: Drop useless CVS revision IDsJean Delvare
CVS revision IDs are totally useless and irrelevant by now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-28[PATCH] headers: include linux/compiler.h for __userGOTO Masanori
This patch lets i2c-dev.h include linux/compiler.h so that __user is defined. Signed-off-by: GOTO Masanori <gotom@debian.or.jp> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
