path: root/include/linux/i2c-pnx.h
2010-02-12ARM: PNX4008: move i2c_adapter structure inside the drivers private dataRussell King
2010-02-12ARM: PNX4008: kzalloc i2c drivers internal dataRussell King
2010-02-12ARM: PNX4008: Make ioaddr 'void __iomem *' rather than 'u32'Russell King
This avoids unnecessary casting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: PNX4008: get i2c clock rate from clk APIRussell King
Acked-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: PNX4008: move i2c clock start/stop into driverRussell King
2010-02-12ARM: PNX4008: move i2c suspend/resume callbacks into driverRussell King
2009-11-20i2c: i2c-pnx: Made buf type unsigned to prevent sign extensionKevin Wells
Made buf type unsigned to prevent sign extension Signed-off-by: Kevin Wells <kevin.wells@nxp.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-08[ARM] fix pnx4008 build errorsRussell King
include/linux/i2c-pnx.h was missed when moving the include files. Fix it now; it doesn't really need to include mach/i2c.h at all. Successfully build tested with pnx4008_defconfig, which had failed in linux-next. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-10i2c: New Philips PNX bus driverVitaly Wool
New I2C bus driver for Philips ARM boards (Philips IP3204 I2C IP block). This I2C controller can be found on (at least) PNX010x, PNX52xx and PNX4008 Philips boards. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
