path: root/include/linux/if_fddi.h
2010-08-22header: fix broken headers for user spaceChangli Gao
__packed is only defined in kernel space, so we should use __attribute__((packed)) for the code shared between kernel and user space. Two __attribute() annotations are replaced with __attribute__() too. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17include linux/types.h in if_fddi.hOlaf Hering
include/linux/if_fddi.h is an exported header. It uses __be16. Include linux/types.h to get this prototype. Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] mips: if_fddi.h: Add a missing inclusionMaciej W. Rozycki
This is a change to include <linux/netdevice.h> in <linux/if_fddi.h> which is needed for "struct fddi_statistics". Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-16Remove struct fddi_statistics from user view in <linux/if_fddi.h>David Woodhouse
2005-08-29[NET]: net/802: more endian annotationsAlexey Dobriyan
The rest of endian warnings now belongs to tr.c exclusively. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
