path: root/include/linux/if_link.h
2011-05-10net: Allow setting the network namespace by fdEric W. Biederman
Take advantage of the new abstraction and allow network devices to be placed in any network namespace that we have a fd to talk about. Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-01-19net_device: add support for network device groupsVlad Dogaru
Net devices can now be grouped, enabling simpler manipulation from userspace. This patch adds a group field to the net_device structure, as well as rtnetlink support to query and modify it. Signed-off-by: Vlad Dogaru <ddvlad@rosedu.org> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22macvlan: Introduce 'passthru' mode to takeover the underlying deviceSridhar Samudrala
With the current default 'vepa' mode, a KVM guest using virtio with macvtap backend has the following limitations. - cannot change/add a mac address on the guest virtio-net - cannot create a vlan device on the guest virtio-net - cannot enable promiscuous mode on guest virtio-net To address these limitations, this patch introduces a new mode called 'passthru' when creating a macvlan device which allows takeover of the underlying device and passing it to a guest using virtio with macvtap backend. Only one macvlan device is allowed in passthru mode and it inherits the mac address from the underlying device and sets it in promiscuous mode to receive and forward all the packets. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> ------------------------------------------------------------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17ipv4: AF_INET link address familyThomas Graf
Implements the AF_INET link address family exposing the per device configuration settings via netlink using the attribute IFLA_INET_CONF. The format of IFLA_INET_CONF differs depending on the direction the attribute is sent. The attribute sent by the kernel consists of a u32 array, basically a 1:1 copy of in_device->cnf.data[]. The attribute expected by the kernel must consist of a sequence of nested u32 attributes, each representing a change request, e.g. [IFLA_INET_CONF] = { [IPV4_DEVCONF_FORWARDING] = 1, [IPV4_DEVCONF_NOXFRM] = 0, } libnl userspace API documentation and example available from: http://www.infradead.org/~tgr/libnl/doc-git/group__link__inet.html Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17rtnetlink: Link address family APIThomas Graf
Each net_device contains address family specific data such as per device settings and statistics. We already expose this data via procfs/sysfs and partially netlink. The netlink method requires the requester to send one RTM_GETLINK request for each address family it wishes to receive data of and then merge this data itself. This patch implements a new API which combines all address family specific link data in a new netlink attribute IFLA_AF_SPEC. IFLA_AF_SPEC contains a sequence of nested attributes, one for each address family which in turn defines the structure of its own attribute. Example: [IFLA_AF_SPEC] = { [AF_INET] = { [IFLA_INET_CONF] = ..., }, [AF_INET6] = { [IFLA_INET6_FLAGS] = ..., [IFLA_INET6_CONF] = ..., } } The API also allows for address families to implement a function which parses the IFLA_AF_SPEC attribute sent by userspace to implement address family specific link options. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-06-16fix typos concerning "management"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-12net: Enable 64-bit net device statistics on 32-bit architecturesBen Hutchings
Use struct rtnl_link_stats64 as the statistics structure. On 32-bit architectures, insert 32 bits of padding after/before each field of struct net_device_stats to make its layout compatible with struct rtnl_link_stats64. Add an anonymous union in net_device; move stats into the union and add struct rtnl_link_stats64 stats64. Add net_device_ops::ndo_get_stats64, implementations of which will return a pointer to struct rtnl_link_stats64. Drivers that implement this operation must not update the structure asynchronously. Change dev_get_stats() to call ndo_get_stats64 if available, and to return a pointer to struct rtnl_link_stats64. Change callers of dev_get_stats() accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Add netlink support for virtual port management (was iovnl)Scott Feldman
Add new netdev ops ndo_{set|get}_vf_port to allow setting of port-profile on a netdev interface. Extends netlink socket RTM_SETLINK/ RTM_GETLINK with two new sub msgs called IFLA_VF_PORTS and IFLA_PORT_SELF (added to end of IFLA_cmd list). These are both nested atrtibutes using this layout: [IFLA_NUM_VF] [IFLA_VF_PORTS] [IFLA_VF_PORT] [IFLA_PORT_*], ... [IFLA_VF_PORT] [IFLA_PORT_*], ... ... [IFLA_PORT_SELF] [IFLA_PORT_*], ... These attributes are design to be set and get symmetrically. VF_PORTS is a list of VF_PORTs, one for each VF, when dealing with an SR-IOV device. PORT_SELF is for the PF of the SR-IOV device, in case it wants to also have a port-profile, or for the case where the VF==PF, like in enic patch 2/2 of this patch set. A port-profile is used to configure/enable the external switch virtual port backing the netdev interface, not to configure the host-facing side of the netdev. A port-profile is an identifier known to the switch. How port- profiles are installed on the switch or how available port-profiles are made know to the host is outside the scope of this patch. There are two types of port-profiles specs in the netlink msg. The first spec is for 802.1Qbg (pre-)standard, VDP protocol. The second spec is for devices that run a similar protocol as VDP but in firmware, thus hiding the protocol details. In either case, the specs have much in common and makes sense to define the netlink msg as the union of the two specs. For example, both specs have a notition of associating/deassociating a port-profile. And both specs require some information from the hypervisor manager, such as client port instance ID. The general flow is the port-profile is applied to a host netdev interface using RTM_SETLINK, the receiver of the RTM_SETLINK msg communicates with the switch, and the switch virtual port backing the host netdev interface is configured/enabled based on the settings defined by the port-profile. What those settings comprise, and how those settings are managed is again outside the scope of this patch, since this patch only deals with the first step in the flow. Signed-off-by: Scott Feldman <scofeldm@cisco.com> Signed-off-by: Roopa Prabhu <roprabhu@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/linux/if_link.h
2010-05-16rtnetlink: make SR-IOV VF interface symmetricChris Wright
Now we have a set of nested attributes: IFLA_VFINFO_LIST (NESTED) IFLA_VF_INFO (NESTED) IFLA_VF_MAC IFLA_VF_VLAN IFLA_VF_TX_RATE This allows a single set to operate on multiple attributes if desired. Among other things, it means a dump can be replayed to set state. The current interface has yet to be released, so this seems like something to consider for 2.6.34. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16net: core: add IFLA_STATS64 supportJan Engelhardt
`ip -s link` shows interface counters truncated to 32 bit. This is because interface statistics are transported only in 32-bit quantity to userspace. This commit adds a new IFLA_STATS64 attribute that exports them in full 64 bit. References: http://lkml.indiana.edu/hypermail/linux/kernel/0307.3/0215.html Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12if_link: Add SR-IOV configuration methodsWilliams, Mitch A
Add SR-IOV VF management methods to IFLA_LINKINFO. This allows userspace to use rtnetlink to configure VF network devices. Signed-off-by: Mitch Williams <mitch.a.williams@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26macvlan: export macvlan mode through netlinkArnd Bergmann
In order to support all three modes of macvlan at runtime, extend the existing netlink protocol to allow choosing the mode per macvlan slave interface. This depends on a matching patch to iproute2 in order to become accessible in user land. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30headers_check fix: linux/if_link.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/if_link.h:9: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-09-22net: network device name ifalias supportStephen Hemminger
This patch add support for keeping an additional character alias associated with an network interface. This is useful for maintaining the SNMP ifAlias value which is a user defined value. Routers use this to hold information like which circuit or line it is connected to. It is just an arbitrary text label on the network device. There are two exposed interfaces with this patch, the value can be read/written either via netlink or sysfs. This could be maintained just by the snmp daemon, but it is more generally useful for other management tools, and the kernel is good place to act as an agreed upon interface to store it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: netlink support for moving devices between network namespaces.Eric W. Biederman
The simplest thing to implement is moving network devices between namespaces. However with the same attribute IFLA_NET_NS_PID we can easily implement creating devices in the destination network namespace as well. However that is a little bit trickier so this patch sticks to what is simple and easy. A pid is used to identify a process that happens to be a member of the network namespace we want to move the network device to. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Use rtnl_link APIPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[RTNETLINK]: Link creation APIPatrick McHardy
Add rtnetlink API for creating, changing and deleting software devices. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6] SNMP: Netlink interface.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[NETLINK]: Put {IFA,IFLA}_{RTA,PAYLOAD} macros back for userspace.David S. Miller
GLIBC uses them etc. They are guarded by ifndef __KERNEL__ so nobody will start accidently using them in the kernel again, it's just for userspace. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NET]: Move netlink interface bits to linux/if_link.h.YOSHIFUJI Hideaki
Moving netlink interface bits to linux/if.h is rather troublesome for applications including both linux/if.h (which was changed to be included from linux/rtnetlink.h automatically) and net/if.h. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
