[ Upstream commit 35d2f80b07bbe03fb358afb0bdeff7437a7d67ff ]
It appears that TCP checksum offloading has been broken for
Q-in-Q vlans. The behavior was execerbated by the
series
commit afb0bc972b52 ("Merge branch 'stacked_vlan_tso'")
that that enabled accleleration features on stacked vlans.
However, event without that series, it is possible to trigger
this issue. It just requires a lot more specialized configuration.
The root cause is the interaction between how
netdev_intersect_features() works, the features actually set on
the vlan devices and HW having the ability to run checksum with
longer headers.
The issue starts when netdev_interesect_features() replaces
NETIF_F_HW_CSUM with a combination of NETIF_F_IP_CSUM | NETIF_F_IPV6_CSUM,
if the HW advertises IP|IPV6 specific checksums. This happens
for tagged and multi-tagged packets. However, HW that enables
IP|IPV6 checksum offloading doesn't gurantee that packets with
arbitrarily long headers can be checksummed.
This patch disables IP|IPV6 checksums on the packet for multi-tagged
packets.
CC: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
CC: Michal Kubecek <mkubecek@suse.cz>
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
To allow drivers to handle the features check for multiple tags,
move the check to ndo_features_check().
As no drivers currently handle multiple tagged TSO, introduce
dflt_features_check() and call it if the driver does not have
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Separate the two checks for single vlan and multiple vlans in
netif_skb_features(). This allows us to move the check for multiple
vlans to another function later.
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
vlan_get_protocol() could not get network protocol if a skb has a 802.1ad
vlan tag or multiple vlans, which caused incorrect checksum calculation
in several drivers.
Fix vlan_get_protocol() to retrieve network protocol instead of incorrect
vlan protocol.
As the logic is the same as skb_network_protocol(), create a common helper
function __vlan_get_protocol() and call it from existing functions.
The same macros are used for rx as well. So rename it.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
There's a need for helper which inserts vlan tag but does not free the
skb in case of an error.
Suggested-by: Pravin Shelar <pshelar@nicira.com>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
Use them to push skb->vlan_tci into the payload and avoid code
duplication.
Name fits better. Plus there's going to be introduced
__vlan_insert_tag later on.
Since both tx and rx paths work with skb->vlan_tci, there's no need for
this function anymore. Switch users directly to __vlan_hwaccel_put_tag.
Always returns the same skb it gets, so change to void.
Currently the functionality to untag traffic on input resides
as part of the vlan module and is build only when VLAN support
is enabled in the kernel. When VLAN is disabled, the function
vlan_untag() turns into a stub and doesn't really untag the
packets. This seems to create an interesting interaction
between VMs supporting checksum offloading and some network drivers.
There are some drivers that do not allow the user to change
tx-vlan-offload feature of the driver. These drivers also seem
to assume that any VLAN-tagged traffic they transmit will
have the vlan information in the vlan_tci and not in the vlan
header already in the skb. When transmitting skbs that already
have tagged data with partial checksum set, the checksum doesn't
appear to be updated correctly by the card thus resulting in a
failure to establish TCP connections.
The following is a packet trace taken on the receiver where a
sender is a VM with a VLAN configued. The host VM is running on
doest not have VLAN support and the outging interface on the
host is tg3:
10:12:43.503055 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27243,
offset 0, flags [DF], proto TCP (6), length 60)
10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect
-> 0x48d9), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294837885 ecr 0,nop,wscale 7], length 0
10:12:44.505556 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27244,
-> 0x44ee), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294838888 ecr 0,nop,wscale 7], length 0
This connection finally times out.
I've only access to the TG3 hardware in this configuration thus have
only tested this with TG3 driver. There are a lot of other drivers
that do not permit user changes to vlan acceleration features, and
I don't know if they all suffere from a similar issue.
The patch attempt to fix this another way. It moves the vlan header
stipping code out of the vlan module and always builds it into the
kernel network core. This way, even if vlan is not supported on
a virtualizatoin host, the virtual machines running on top of such
host will still work with VLANs enabled.
CC: Patrick McHardy <kaber@trash.net>
CC: Nithin Nayak Sujir <nsujir@broadcom.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Jiri Pirko <jiri@resnulli.us>
Acked-by: Jiri Pirko <jiri@resnulli.us>
drivers/net/bonding/bond_alb.c
drivers/net/ethernet/altera/altera_msgdma.c
drivers/net/ethernet/altera/altera_sgdma.c
net/ipv6/xfrm6_output.c
Several cases of overlapping changes.
The xfrm6_output.c has a bug fix which overlaps the renaming
of skb->local_df to skb->ignore_df.
In the Altera TSE driver cases, the register access cleanups
in net-next overlapped with bug fixes done in net.
Similarly a bug fix to send ALB packets in the bonding driver using
the right source address overlaps with cleanups in net-next.
The new function vlan_get_encap_level() uses vlan_dev_priv()
which is only conditionally avaialble when VLAN support is
enabled. Make vlan_get_encap_level() conditionally available
as well.
Fixes: 44a4085538c8 ("bonding: Fix stacked device detection in arp monitoring")
CC: Stephen Rothwell <sfr@canb.auug.org.au>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Prior to commit fbd929f2dce460456807a51e18d623db3db9f077
bonding: support QinQ for bond arp interval
the arp monitoring code allowed for proper detection of devices
stacked on top of vlans. Since the above commit, the
code can still detect a device stacked on top of single
vlan, but not a device stacked on top of Q-in-Q configuration.
The search will only set the inner vlan tag if the route
device is the vlan device. However, this is not always the
case, as it is possible to extend the stacked configuration.
With this patch it is possible to provision devices on
top Q-in-Q vlan configuration that should be used as
a source of ARP monitoring information.
For example:
ip link add link bond0 vlan10 type vlan proto 802.1q id 10
ip link add link vlan10 vlan100 type vlan proto 802.1q id 100
ip link add link vlan100 type macvlan
Note: This patch limites the number of stacked VLANs to 2,
just like before. The original, however had another issue
in that if we had more then 2 levels of VLANs, we would end
up generating incorrectly tagged traffic. This is no longer
possible.
Fixes: fbd929f2dce460456807a51e18d623db3db9f077 (bonding: support QinQ for bond arp interval)
CC: Jay Vosburgh <j.vosburgh@gmail.com>
CC: Veaceslav Falico <vfalico@redhat.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Ding Tianhong <dingtianhong@huawei.com>
CC: Patric McHardy <kaber@trash.net>
This reverts commit dc8eaaa006350d24030502a4521542e74b5cb39f.
vlan: Fix lockdep warning when vlan dev handle notification
Instead we use the new new API to find the lock subclass of
our vlan device. This way we can support configurations where
vlans are interspersed with other devices:
bond -> vlan -> macvlan -> vlan
The __vlan_find_dev_deep should always called in RCU, according
David's suggestion, rename to __vlan_find_dev_deep_rcu looks more
reasonable.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
The vlan support 2 proto: 802.1q and 802.1ad, so make a new function
called vlan_dev_vlan_proto() which could return the vlan proto for
input dev.
Replace kfree_skb with dev_kfree_skb_any in vlan_insert_tag as
vlan_insert_tag can be called from hard irq context (netpoll)
and from other contexts.
dev_kfree_skb_any is used as vlan_insert_tag only frees the skb if the
skb can not be modified to insert a tag, in which case vlan_insert_tag
drops the skb.
macvlan needs vlan_pcpu_stats so make it visible even if compiling
without VLAN_8021Q support. Otherwise a very long compiler error happens.
Fixes: cdf3e274cf1b36 ("macvlan: unify macvlan_pcpu_stats and vlan_pcpu_stats")
Cc: Li RongQing <roy.qing.li@gmail.com>
Acked-By: Li RongQing <roy.qing.li@gmail.com>
This is to avoid very silly Kconfig dependencies for modules
using this routine.
Provide a method for read-only access to the vlan device egress mapping.
Do this by refactoring vlan_dev_get_egress_qos_mask() such that now it
receives as an argument the skb priority instead of pointer to the skb.
Such an access is needed for the IBoE stack where the control plane
goes through the network stack. This is an add-on step on top of commit
d4a968658c "net/route: export symbol ip_tos2prio" which allowed the RDMA-CM
to use ip_tos2prio.
Signed-off-by: Eyal Perry <eyalpe@mellanox.com>
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com>
In commit 48cc32d38a52d0b68f91a171a8d00531edc6a46e
("vlan: don't deliver frames for unknown vlans to protocols")
Florian made sure we set pkt_type to PACKET_OTHERHOST
if the vlan id is set and we could find a vlan device for this
particular id.
But we also have a problem if prio bits are set.
Steinar reported an issue on a router receiving IPv6 frames with a
vlan tag of 4000 (id 0, prio 2), and tunneled into a sit device,
because skb->vlan_tci is set.
Forwarded frame is completely corrupted : We can see (8100:4000)
being inserted in the middle of IPv6 source address :
16:48:00.780413 IP6 2001:16d8:8100:4000:ee1c:0:9d9:bc87 >
9f94:4d95:2001:67c:29f4::: ICMP6, unknown icmp6 type (0), length 64
0x0000: 0000 0029 8000 c7c3 7103 0001 a0ae e651
0x0010: 0000 0000 ccce 0b00 0000 0000 1011 1213
0x0020: 1415 1617 1819 1a1b 1c1d 1e1f 2021 2223
0x0030: 2425 2627 2829 2a2b 2c2d 2e2f 3031 3233
It seems we are not really ready to properly cope with this right now.
We can probably do better in future kernels :
vlan_get_ingress_priority() should be a netdev property instead of
a per vlan_dev one.
For stable kernels, lets clear vlan_tci to fix the bugs.
Reported-by: Steinar H. Gunderson <sesse@google.com>
drivers/net/ethernet/freescale/fec_main.c
drivers/net/ethernet/renesas/sh_eth.c
net/ipv4/gre.c
The GRE conflict is between a bug fix (kfree_skb --> kfree_skb_list)
and the splitting of the gre.c code into seperate files.
The FEC conflict was two sets of changes adding ethtool support code
in an "!CONFIG_M5272" CPP protected block.
Finally the sh_eth.c conflict was between one commit add bits set
in the .eesr_err_check mask whilst another commit removed the
.tx_error_check member and assignments.
After addition of 8021AD h_vlan_proto can be either ETH_P_8021Q or
ETH_P_8021AD.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Remove the definition of HAVE_VLAN_PUT_TAG since it's not
used or exported anywhere.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Fix up some function signatures for CONFIG_VLAN=n that were missed during
the 802.1ad support patches.
Found by the kbuild robot.
Add support for 802.1ad VLAN devices. This mainly consists of checking for
ETH_P_8021AD in addition to ETH_P_8021Q in a couple of places and check
offloading capabilities based on the used protocol.
Configuration is done using "ip link":
# ip link add link eth0 eth0.1000 \
type vlan proto 802.1ad id 1000
# ip link add link eth0.1000 eth0.1000.1000 \
type vlan proto 802.1q id 1000
52:54:00:12:34:56 > 92:b1:54:28:e4:8c, ethertype 802.1Q (0x8100), length 106: vlan 1000, p 0, ethertype 802.1Q, vlan 1000, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto ICMP (1), length 84)
20.1.0.2 > 20.1.0.1: ICMP echo request, id 3003, seq 8, length 64
92:b1:54:28:e4:8c > 52:54:00:12:34:56, ethertype 802.1Q-QinQ (0x88a8), length 106: vlan 1000, p 0, ethertype 802.1Q, vlan 1000, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 47944, offset 0, flags [none], proto ICMP (1), length 84)
20.1.0.1 > 20.1.0.2: ICMP echo reply, id 3003, seq 8, length 64
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Make the encapsulation protocol value a property of VLAN devices and change
the device lookup functions to take the protocol value into account.
Change the rx_{add,kill}_vid callbacks to take a protocol argument in
preparation of 802.1ad support. The protocol argument used so far is
always htons(ETH_P_8021Q).
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for
an 802.3 frame. Frames with a lower value in the ethernet type field
are Ethernet II.
Also update all the users of this value that David Miller and
I could find to use the new constant.
Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN
should be >= not >.
As suggested by Jesse Gross.
Compile tested only.
Cc: Jesse Gross <jesse@nicira.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Bart De Schuymer <bart.de.schuymer@pandora.be>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netfilter-devel@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
Cc: linux-wireless@vger.kernel.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-media@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: dev@openvswitch.org
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Simon Horman <horms@verge.net.au>
There are two places to call vlan_set_encap_proto():
vlan_untag() and __pop_vlan_tci().
vlan_untag() assumes skb->data points after mac addr, otherwise
the following code
vhdr = (struct vlan_hdr *) skb->data;
vlan_tci = ntohs(vhdr->h_vlan_TCI);
__vlan_hwaccel_put_tag(skb, vlan_tci);
skb_pull_rcsum(skb, VLAN_HLEN);
won't be correct. But __pop_vlan_tci() assumes points _before_
mac addr.
In vlan_set_encap_proto(), it looks for some magic L2 value
after mac addr:
rawp = skb->data;
if (*(unsigned short *) rawp == 0xFFFF)
Therefore __pop_vlan_tci() is obviously wrong.
A quick fix is avoiding using skb->data in vlan_set_encap_proto(),
use 'vhdr+1' is always correct in both cases.
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Jesse Gross <jesse@nicira.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
6a32e4f9dd9219261f8856f817e6655114cfec2f made the vlan code skip marking
vlan-tagged frames for not locally configured vlans as PACKET_OTHERHOST if
there was an rx_handler, as the rx_handler could cause the frame to be received
on a different (virtual) vlan-capable interface where that vlan might be
configured.
As rx_handlers do not necessarily return RX_HANDLER_ANOTHER, this could cause
frames for unknown vlans to be delivered to the protocol stack as if they had
been received untagged.
For example, if an ipv6 router advertisement that's tagged for a locally not
configured vlan is received on an interface with macvlan interfaces attached,
macvlan's rx_handler returns RX_HANDLER_PASS after delivering the frame to the
macvlan interfaces, which caused it to be passed to the protocol stack, leading
to ipv6 addresses for the announced prefix being configured even though those
are completely unusable on the underlying interface.
The fix moves marking as PACKET_OTHERHOST after the rx_handler so the
rx_handler, if there is one, sees the frame unchanged, but afterwards,
before the frame is delivered to the protocol stack, it gets marked whether
there is an rx_handler or not.
Signed-off-by: Florian Zumbiehl <florz@florz.de>
also, remove unused vlan_info definition from header
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
Just use ETH_ALEN.
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
Introduce functions handy to copy vlan ids from one driver's list to
another.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This allows to keep track of vids needed to be in rx vlan filters of
devices even if they are used in bond/team etc.
vlan_info as well as vlan_group previously was, is allocated when first
vid is added and dealocated whan last vid is deleted.
vlan_group definition is moved to private header.
[add/kill]_vid ndo calls
This patch adds wrapper for ndo_vlan_rx_add_vid/ndo_vlan_rx_kill_vid
functions. Check for NETIF_F_HW_VLAN_FILTER feature is done in this
wrapper.
As this structure is priv, name it approprietely. Also for pointer to it
use name "vlan".
Open vSwitch needs this function for vlan handling.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
commit 2425717b27eb (net: allow vlan traffic to be received under bond)
broke ARP processing on vlan on top of bonding.
eth0 --| bond0 |---bond0.103
eth1 --| |
52870.115435: skb_gro_reset_offset <-napi_gro_receive
52870.115435: dev_gro_receive <-napi_gro_receive
52870.115435: napi_skb_finish <-napi_gro_receive
52870.115435: netif_receive_skb <-napi_skb_finish
52870.115435: get_rps_cpu <-netif_receive_skb
52870.115435: __netif_receive_skb <-netif_receive_skb
52870.115436: vlan_do_receive <-__netif_receive_skb
52870.115436: bond_handle_frame <-__netif_receive_skb
52870.115436: arp_rcv <-__netif_receive_skb
52870.115436: kfree_skb <-arp_rcv
Packet is dropped in arp_rcv() because its pkt_type was set to
PACKET_OTHERHOST in the first vlan_do_receive() call, since no eth0.103
exists.
We really need to change pkt_type only if no more rx_handler is about to
be called for the packet.
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
there are no users outside vlan code
