path: root/include/linux/igmp.h
2013-07-23net: convert resend IGMP to notifier eventJiri Pirko
Until now, bond_resend_igmp_join_requests() looks for vlans attached to bonding device, bridge where bonding act as port manually. It does not care of other scenarios, like stacked bonds or team device above. Make this more generic and use netdev notifier to propagate the event to upper devices and to actually call ip_mc_rejoin_groups(). Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-12igmp: hash a hash table to speedup ip_check_mc_rcu()Eric Dumazet
After IP route cache removal, multicast applications using a lot of multicast addresses hit a O(N) behavior in ip_check_mc_rcu() Add a per in_device hash table to get faster lookup. This hash table is created only if the number of items in mc_list is above 4. Reported-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2011-03-10ipv4: Remove redundant RCU locking in ip_check_mc().David S. Miller
All callers are under rcu_read_lock() protection already. Rename to ip_check_mc_rcu() to make it even more clear. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-04net: typos in comments in include/linux/igmp.hFrancois-Xavier Le Bail
There are typos in comments in include/linux/igmp.h: 83 #define IGMP_HOST_MEMBERSHIP_QUERY 0x11 /* From RFC1112 */ 84 #define IGMP_HOST_MEMBERSHIP_REPORT 0x12 /* Ditto */ [snip] 88 #define IGMPV2_HOST_MEMBERSHIP_REPORT 0x16 /* V2 version of 0x11 */ 89 #define IGMP_HOST_LEAVE_MESSAGE 0x17 90 #define IGMPV3_HOST_MEMBERSHIP_REPORT 0x22 /* V3 version of 0x11 */ The line 88 and 90 are about REPORT messages. The IGMP_HOST_MEMBERSHIP_REPORT (IGMP V1) value is 0x12. So the comment on line 88 must be /* V2 version of 0x12 */, and the comment on line 90 must be /* V3 version of 0x12 */. Signed-off-by: Francois-Xavier Le Bail <fx.lebail@orange.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-18bonding: IGMP handling cleanupEric Dumazet
Instead of iterating in_dev->mc_list from bonding driver, its better to call a helper function provided by igmp.c Details of implementation (locking) are private to igmp code. ip_mc_rejoin_group(struct ip_mc_list *im) becomes ip_mc_rejoin_groups(struct in_device *in_dev); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12igmp: RCU conversion of in_dev->mc_listEric Dumazet
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock). This can easily be converted to a RCU protection. Writers hold RTNL, so mc_list_lock is removed, not replaced by a spinlock. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Cypher Wu <cypher.w@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02igmp: fix ip_mc_sf_allow race [v5]Flavio Leitner
Almost all igmp functions accessing inet->mc_list are protected by rtnl_lock(), but there is one exception which is ip_mc_sf_allow(), so there is a chance of either ip_mc_drop_socket or ip_mc_leave_group remove an entry while ip_mc_sf_allow is running causing a crash. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15bonding: remap muticast addresses without using dev_close() and dev_open()Moni Shoua
This patch fixes commit e36b9d16c6a6d0f59803b3ef04ff3c22c3844c10. The approach there is to call dev_close()/dev_open() whenever the device type is changed in order to remap the device IP multicast addresses to HW multicast addresses. This approach suffers from 2 drawbacks: *. It assumes tha the device is UP when calling dev_close(), or otherwise dev_close() has no affect. It is worth to mention that initscripts (Redhat) and sysconfig (Suse) doesn't act the same in this matter. *. dev_close() has other side affects, like deleting entries from the routing table, which might be unnecessary. The fix here is to directly remap the IP multicast addresses to HW multicast addresses for a bonding device that changes its type, and nothing else. Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Moni Shoua <monis@voltaire.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30headers_check fix: linux/igmp.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/igmp.h:31: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03ipv4: Do cleanup for ip_mr_initWang Chen
Same as ip6_mr_init(), make ip_mr_init() return errno if fails. But do not do error handling in inet_init(), just print a msg. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-23[NET]: include/linux/igmp.h - remove duplicate includeJoe Perches
Removed duplicate #include <linux/skbuff.h> Combined #ifdef __KERNEL__ blocks Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce igmp_hdr() & friends, remove skb->h.igmphArnaldo Carvalho de Melo
2007-03-06bonding: Improve IGMP join processingJay Vosburgh
In active-backup mode, the current bonding code duplicates IGMP traffic to all slaves, so that switches are up to date in case of a failover from an active to a backup interface. If bonding then fails back to the original active interface, it is likely that the "active slave" switch's IGMP forwarding for the port will be out of date until some event occurs to refresh the switch (e.g., a membership query). This patch alters the behavior of bonding to no longer flood IGMP to all ports, and to issue IGMP JOINs to the newly active port at the time of a failover. This insures that switches are kept up to date for all cases. "GOELLESCH Niels" <niels.goellesch@eurocontrol.int> originally reported this problem, and included a patch. His original patch was modified by Jay Vosburgh to additionally remove the existing IGMP flood behavior, use RCU, streamline code paths, fix trailing white space, and adjust for style. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] severing skbuff.h -> mm.hAl Viro
2006-12-02[NET]: Annotate checksums in on-the-wire packets.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-21[IGMP]: Fix IGMPV3_EXP() normalization bit shift value.David L Stevens
The IGMPV3_EXP() macro doesn't correctly shift the normalization bit, so time-out values are longer than they should be. Thanks to Dirk Ooms for finding the problem in IGMPv3 - MLDv2 had a similar problem that was already fixed a year ago. :-( Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: trivial igmp annotationsAl Viro
2006-09-28[IPV4]: ip_mc_sf_allow() annotatedAl Viro
ip_mc_sf_allow() expects addresses to be passed net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: struct ip_sf_list and struct ip_sf_socklist annotatedAl Viro
2006-09-28[IPV4]: IGMP on-the-wire data is net-endianAl Viro
2006-09-28[IPV4]: ip_mc_{inc,dec}_group() annotationsAl Viro
2006-09-28[IPV4]: ip_check_mc() annotationsAl Viro
annotated arguments Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPV4] igmp: Fixup struct ip_mc_list::multiaddr typeAlexey Dobriyan
All users except two expect 32-bit big-endian value. One is of ->multiaddr = ->multiaddr variety. And last one is "%08lX". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[IPV4]: multicast API "join" issuesDavid L Stevens
This patch corrects a few problems with the IP_ADD_MEMBERSHIP socket option: 1) The existing code makes an attempt at reference counting joins when using the ip_mreqn/imr_ifindex interface. Joining the same group on the same socket is an error, whatever the API. This leads to unexpected results when mixing ip_mreqn by index with ip_mreqn by address, ip_mreq, or other API's. For example, ip_mreq followed by ip_mreqn of the same group will "work" while the same two reversed will not. Fixed to always return EADDRINUSE on a duplicate join and removed the (now unused) reference count in ip_mc_socklist. 2) The group-search list in ip_mc_join_group() is comparing a full ip_mreqn structure and all of it must match for it to find the group. This doesn't correctly match a group that was joined with ip_mreq or ip_mreqn with an address (with or without an index). It also doesn't match groups that are joined by different addresses on the same interface. All of these are the same multicast group, which is identified by group address and interface index. Fixed the check to correctly match groups so we don't get duplicate group entries on the ip_mc_socklist. 3) The old code allocates a multicast address before searching for duplicates requiring it to free in various error cases. This patch moves the allocate until after the search and igmp_max_memberships check, so never a need to allocate, then free an entry. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
