path: root/include/linux/inet.h
2008-07-09NFS: Add string length argument to nfs_parse_server_addressChuck Lever
To make nfs_parse_server_address() more generally useful, allow it to accept input strings that are not terminated with '\0'. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02[NET]: Accept wildcard delimiters in in[46]_ptonPatrick McHardy
Accept -1 as delimiter to abort parsing without an error at the first unknown character. This is needed by the upcoming nf_conntrack SIP helper, where addresses are delimited by either '\r' or '\n' characters. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Add common helper functions to convert IPv6/IPv4 address string to ↵YOSHIFUJI Hideaki
network address structure. These helpers can be used in netfilter, cifs etc. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-01-06[NET]: Endian-annotate in_aton()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
