[ Upstream commit 84bc88688e3f6ef843aa8803dbcd90168bb89faf ]
There could be a signed overflow in the following code.
The expression, (32-logmask) is comprised between 0 and 31 included.
It may be equal to 31.
In such a case the left shift will produce a signed integer overflow.
According to the C99 Standard, this is an undefined behavior.
A simple fix is to replace the signed int 1 with the unsigned int 1U.
Signed-off-by: Vincent BENAYOUN <vincent.benayoun@trust-in-soft.com>
Help of this function says: "in_dev: only on this interface, 0=any interface",
but since commit 39a6d0630012 ("[NETNS]: Process inet_confirm_addr in the
correct namespace."), the code supposes that it will never be NULL. This
function is never called with in_dev == NULL, but it's exported and may be used
by an external module.
Because this patch restore the ability to call inet_confirm_addr() with in_dev
== NULL, I partially revert the above commit, as suggested by Julian.
CC: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Previously inet devices were only constructed when addresses are added.
Therefore the default neigh parms values they get are the ones at the
time of these operations.
Now that we're creating inet devices earlier, this changes the behaviour
of default neigh parms values in an incompatible way (see bug #8519).
This patch creates a compromise by setting the default values at the
same point as before but only for those that have not been explicitly
set by the user since the inet device's creation.
Introduced by:
commit 8030f54499925d073a88c09f30d5d844fb1b3190
Author: Herbert Xu <herbert@gondor.apana.org.au>
Date: Thu Feb 22 01:53:47 2007 +0900
[IPV4] devinet: Register inetdev earlier.
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
IP sends device configuration (see inet_fill_link_af) as an array
in the netlink information, but the indices in that array are not
exposed to userspace through any current santized header file.
It was available back in 2.6.32 (in /usr/include/linux/sysctl.h)
but was broken by:
commit 02291680ffba92e5b5865bc0c5e7d1f3056b80ec
Author: Eric W. Biederman <ebiederm@xmission.com>
Date: Sun Feb 14 03:25:51 2010 +0000
net ipv4: Decouple ipv4 interface parameters from binary sysctl numbers
Eric was solving the sysctl problem but then the indices were re-exposed
by a later addition of devconf support for IPV4
commit 9f0f7272ac9506f4c8c05cc597b7e376b0b9f3e4
Author: Thomas Graf <tgraf@infradead.org>
Date: Tue Nov 16 04:32:48 2010 +0000
ipv4: AF_INET link address family
Putting them in /usr/include/linux/ip.h seemed the logical match
for the DEVCONF_ definitions for IPV6 in /usr/include/linux/ip6.h
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
After IP route cache removal, multicast applications using
a lot of multicast addresses hit a O(N) behavior in ip_check_mc_rcu()
Add a per in_device hash table to get faster lookup.
This hash table is created only if the number of items in mc_list is
above 4.
Reported-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Tested-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
There are some usecase when lifetime of ipv4 addresses might be helpful.
For example:
1) initramfs networkmanager uses a DHCP daemon to learn network
configuration parameters
2) initramfs networkmanager addresses, routes and DNS configuration
3) initramfs networkmanager is requested to stop
4) initramfs networkmanager stops all daemons including dhclient
5) there are addresses and routes configured but no daemon running. If
the system doesn't start networkmanager for some reason, addresses and
routes will be used forever, which violates RFC 2131.
This patch is essentially a backport of ivp6 address lifetime mechanism
for ipv4 addresses.
Current "ip" tool supports this without any patch (since it does not
distinguish between ipv4 and ipv6 addresses in this perspective.
Also, this should be back-compatible with all current netlink users.
Reported-by: Pavel Šimerda <psimerda@redhat.com>
This patch advertise the MC_FORWARDING status for IPv4 and IPv6.
This field is readonly, only multicast engine in the kernel updates it.
performance profiles show a high cost in the IN_DEV_ROUTE_LOCALNET()
call done in ip_route_input_slow(), because of multiple dereferences,
even if cache lines are clean and available in cpu caches.
Since we already have the 'net' pointer, introduce
IN_DEV_NET_ROUTE_LOCALNET() macro avoiding two dereferences
(dev_net(in_dev->dev))
Also change the tests to use IN_DEV_NET_ROUTE_LOCALNET() only if saddr
or/and daddr are loopback addresse.
Routing of 127/8 is tradtionally forbidden, we consider
packets from that address block martian when routing and do
not process corresponding ARP requests.
This is a sane default but renders a huge address space
practically unuseable.
The RFC states that no address within the 127/8 block should
ever appear on any network anywhere but it does not forbid
the use of such addresses outside of the loopback device in
particular. For example to address a pool of virtual guests
behind a load balancer.
This patch adds a new interface option 'route_localnet'
enabling routing of the 127/8 address block and processing
of ARP requests on a specific interface.
Note that for the feature to work, the default local route
covering 127/8 dev lo needs to be removed.
Example:
$ sysctl -w net.ipv4.conf.eth0.route_localnet=1
$ ip route del 127.0.0.0/8 dev lo table local
$ ip addr add 127.1.0.1/16 dev eth0
$ ip route flush cache
V2: Fix invalid check to auto flush cache (thanks davem)
Signed-off-by: Thomas Graf <tgraf@suug.ch>
I found recently that the arp_process function which handles all of our received
arp frames, is using IPV4_DEVCONF_ALL macro to check the state of the arp_process
flag. This seems wrong, as it implies that either none or all of the network
interfaces accept gratuitous arps. This patch corrects that, allowing
per-interface arp_accept configuration to deviate from the all setting. Note
this also brings us into line with the way the arp_filter setting is handled
during arp_process execution.
Tested this myself on my home network, and confirmed it works as expected.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: "David S. Miller" <davem@davemloft.net>
This will be used to optimize __ip_dev_find() and friends.
With help from Eric Dumazet.
If caller holds RTNL, we dont need a memory barrier
(smp_read_barrier_depends) included in rcu_dereference().
Just use rtnl_dereference() to properly document the assertions.
Define IPV4_DEVCONF_MAX to get rid of MAX - 1 notation.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock).
This can easily be converted to a RCU protection.
Writers hold RTNL, so mc_list_lock is removed, not replaced by a
spinlock.
Cc: Cypher Wu <cypher.w@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
ip_dev_find(net, addr) finds a device given an IPv4 source address and
takes a reference on it.
Introduce __ip_dev_find(), taking a third argument, to optionally take
the device reference. Callers not asking the reference to be taken
should be in an rcu_read_lock() protected section.
dev->ip_ptr is protected by rtnl and rcu.
Yet some places dont use appropriate primitives and/or locking rules.
Stop using the binary sysctl enumeartion in sysctl.h as an index into
a per interface array. This leads to unnecessary binary sysctl number
allocation, and a fragility in data structure and implementation
because of unnecessary coupling.
drivers/net/benet/be_cmds.h
This is to be used together with switch technologies, like RFC3069,
that where the individual ports are not allowed to communicate with
each other, but they are allowed to talk to the upstream router. As
described in RFC 3069, it is possible to allow these hosts to
communicate through the upstream router by proxy_arp'ing.
This patch basically allow proxy arp replies back to the same
interface (from which the ARP request/solicitation was received).
Tunable per device via proc "proxy_arp_pvlan":
/proc/sys/net/ipv4/conf/*/proxy_arp_pvlan
This switch technology is known by different vendor names:
- In RFC 3069 it is called VLAN Aggregation.
- Cisco and Allied Telesyn call it Private VLAN.
- Hewlett-Packard call it Source-Port filtering or port-isolation.
- Ericsson call it MAC-Forced Forwarding (RFC Draft).
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
when using policy routing and the skb mark:
there are cases where a back path validation requires us
to use a different routing table for src ip validation than
the one used for mapping ingress dst ip.
One such a case is transparent proxying where we pretend to be
the destination system and therefore the local table
is used for incoming packets but possibly a main table would
be used on outbound.
Make the default behavior to allow the above and if users
need to turn on the symmetry via sysctl src_valid_mark
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
commit 8ec1e0ebe26087bfc5c0394ada5feb5758014fc8
Author: Patrick McHardy <kaber@trash.net>
Date: Thu Dec 3 12:16:35 2009 +0100
ipv4: add sysctl to accept packets with local source addresses
Change fib_validate_source() to accept packets with a local source address when
the "accept_local" sysctl is set for the incoming inet device. Combined with the
previous patches, this allows to communicate between multiple local interfaces
over the wire.
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
Even though reverse path filter was changed from simple boolean to
trinary control, the loose mode only works if both all and device are
configured because of this logic error.
This adds another inet device option to enable gratuitous ARP
when device is brought up or address change. This is handy for
clusters or virtualization.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
This patch add mc_count to struct in_device and updates
increment/decrement/initilaize of this field in IPv4 and in IPv6.
- Also printing the vfs /proc entry (/proc/net/igmp) is adjusted to
use the new mc_count.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
The field was supposed to allow the creation of an anycast route by
assigning an anycast address to an address prefix. It was never
implemented so this field is unused and serves no purpose. Remove it.
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Add namespace parameter to devinet_ioctl and locate device inside it for
state changes.
Signed-off-by: Denis V. Lunev <den@openvz.org>
struct ipv4_devconf can now become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
in_dev_find() need a namespace to pass it to fib_get_table(), so add
an argument.
arp_ignore has two arguments: dev & in_dev. dev is used for
inet_confirm_addr calling only.
inet_confirm_addr, in turn, either gets in_dev from the device passed
or iterates over all network devices if the device passed is NULL. It
seems logical to directly pass in_dev into inet_confirm_addr.
These are scattered over the code, but almost all the
"critical" places already have the proper struct net
at hand except for snmp proc showing function and routing
rtnl handler.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This is essentially IN_DEV_ANDCONF with proper arguments.
AFAIS these two entries should do the same thing - change the
forwarding state on ipv4_devconf and on all the devices.
I propose to merge the handlers together using ctl paths.
The inet_forward_change() is static after this and I move
it higher to be closer to other "propagation" helpers and
to avoid diff making patches based on { and } matching :)
i.e. - make them easier to read.
When CONFIG_INET=y and CONFIG_SYSCTL=n:
In file included from net/core/netpoll.c:16:
include/linux/inetdevice.h:15: error:
'__NET_IPV4_CONF_MAX' undeclared here (not in a function)
make[2]: *** [net/core/netpoll.o] Error 1
make[1]: *** [net/core] Error 2
make: *** [net] Error 2
So #include sysctl.h from inetdevice.h.
Signed-off-by: Satyam Sharma <satyam.sharma@gmail.com>
(or rarely in ipmr). Therefore the default config values they get are
the ones at the time of these operations.
behaviour of default config values in an incompatible way (see bug
#8519).
Previously once inetdev_init has been called on a device any changes
made to ipv4_devconf_dflt would have no effect on that device's
configuration.
This creates a problem since we have moved the point where
inetdev_init is called from when an address is added to where the
device is registered.
This patch is the first half of a set that tries to mimic the old
behaviour while still calling inetdev_init.
It propagates any changes to ipv4_devconf_dflt to those devices that
have not had the corresponding attribute set.
The next patch will forcibly set all values at the point where
inetdev_init was previously called.
This patch converts the ipv4_devconf config members (everything except
sysctl) to an array. This allows easier manipulation which will be
needed later on to provide better management of default config values.
inet_confirm_addr(), inet_ifa_byprefix(), ip_dev_find(), inet_make_mask() and
inet_ifa_match() annotated, along with inferred net-endian variables
ifa_local, ifa_address, ifa_mask, ifa_broadcast and ifa_anycast are
net-endian. Annotated them and variables that are inferred to be
net-endian.
argument and return value are net-endian. Annotated function and inferred
net-endian variables in callers.
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and
introduces __in_dev_get_rcu() to cover the second case.
1) RCU with refcnt should use in_dev_get().
2) RCU without refcnt should use __in_dev_get_rcu().
3) All others must hold RTNL and use __in_dev_get_rtnl().
There is one exception in net/ipv4/route.c which is in fact a pre-existing
race condition. I've marked it as such so that we remember to fix it.
This patch is based on suggestions and prior work by Suzanne Wood and
Paul McKenney.
Add an option to make secondary IP addresses get promoted
when primary IP addresses are removed from the device.
It defaults to off to preserve existing behavior.
Signed-off-by: Harald Welte <laforge@gnumonks.org>
infrastructure for it.
Let it rip!
