path: root/include/linux/input.h
2005-11-02Input: do not register statically allocated devicesDmitry Torokhov
Do not register statically allocated input devices to prevent OOPS when attaching input interfaces since it requires class device to be properly initialized. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
2005-10-28[PATCH] INPUT: rename input_dev_class to input_class to be correct.Greg Kroah-Hartman
2005-10-28[PATCH] INPUT: remove the input_class structure, as it is unused.Greg Kroah-Hartman
2005-10-28[PATCH] INPUT: export input_dev_class so that input drivers can use it.Greg Kroah-Hartman
2005-10-28[PATCH] Input: prepare to sysfs integrationDmitry Torokhov
Input: prepare to sysfs integration Add struct class_device to input_dev; add input_allocate_dev() to dynamically allocate input devices; dynamically allocated devices are automatically registered with sysfs. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-21[PARISC] Update parisc specific input code from parisc treeMatthew Wilcox
Update drivers to new input layer changes. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Reorder code in gscps2_interrupt() and only enable ports when opened. This fixes issues with hangs booting an SMP kernel on my C360. Previously serio_interrupt() could be called before the lock in struct serio was initialised. Signed-off-by: Richard Hirst <rhirst@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-09Manual merge with LinusDmitry Torokhov
2005-09-07[PATCH] Input: Add a new switch event typeRichard Purdie
The corgi keyboard has need of a switch event type with slightly type to the input system as recommended by the input maintainer. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05Input: HID - add more consumer usagesVojtech Pavlik
Extend mapping of the consumer usage page in hid-input.c to handle more cases appearing on new USB keyboards. Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-30Input: make name, phys and uniq be 'const char *' because onceDmitry Torokhov
set noone should attempt to change them. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-27Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/dtor/input.git manuallyLinus Torvalds
Some manual fixups required due to clashes with the PF_FREEZE cleanups.
2005-06-20[PATCH] INPUT: move to use the new class code, instead of class_simplegregkh@suse.de
2005-05-29Input: add semaphore and user count to input_dev structure;Dmitry Torokhov
serialize open and close calls and ensure that device's open and close methods are only called when first user opens it or last user closes it. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-05-01[PATCH] macintosh/adbhid.c: adb buttons support for aluminium PowerBook G4Andreas Jaggi
This patch adds support for the special adb buttons of the aluminium PowerBook G4. Signed-off-by: Andreas Jaggi <andreas.jaggi@waterwave.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
