Provide device-managed implementations of the request_resource() and
release_resource() functions. Upon failure to request a resource, the new
devm_request_resource() function will output an error message for
consistent error reporting.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
I have added two more functions to walk through resources.
Currently walk_system_ram_range() deals with pfn and /proc/iomem can
contain partial pages. By dealing in pfn, callback function loses the
info that last page of a memory range is a partial page and not the full
page. So I implemented walk_system_ram_res() which returns u64 values to
callback functions and now it properly return start and end address.
walk_system_ram_range() uses find_next_system_ram() to find the next ram
resource. This in turn only travels through siblings of top level child
and does not travers through all the nodes of the resoruce tree. I also
need another function where I can walk through all the resources, for
example figure out where "GART" aperture is. Figure out where ACPI memory
is.
So I wrote another function walk_iomem_res() which walks through all
/proc/iomem resources and returns matches as asked by caller. Caller can
specify "name" of resource, start and end and flags.
Got rid of find_next_system_ram_res() and instead implemented more generic
find_next_iomem_res() which can be used to traverse top level children
only based on an argument.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: WANG Chao <chaowang@redhat.com>
Cc: Baoquan He <bhe@redhat.com>
Sometimes we have a struct resource where we know the type (MEM/IO/etc.)
and the size, but we haven't assigned address space for it. The
IORESOURCE_UNSET flag is a way to indicate this situation. For these
"unset" resources, the start address is meaningless, so print only the
size, e.g.,
- pci 0000:0c:00.0: reg 184: [mem 0x00000000-0x00001fff 64bit]
+ pci 0000:0c:00.0: reg 184: [mem size 0x2000 64bit]
For %pr (printing with raw flags), we still print the address range,
because %pr is mostly used for debugging anyway.
Thanks to Fengguang Wu <fengguang.wu@intel.com> for suggesting
resource_size().
We have two identical copies of resource_contains() already, and more
places that could use it. This moves it to ioport.h where it can be
shared.
resource_contains(struct resource *r1, struct resource *r2) returns true
iff r1 and r2 are the same type (most callers already checked this
separately) and the r1 address range completely contains r2.
In addition, the new resource_contains() checks that both r1 and r2 have
addresses assigned to them. If a resource is IORESOURCE_UNSET, it doesn't
have a valid address and can't contain or be contained by another resource.
Some callers already check this or for res->start.
No functional change.
Add release_mem_region_adjustable(), which releases a requested region
from a currently busy memory resource. This interface adjusts the
matched memory resource accordingly even if the requested region does
not match exactly but still fits into.
This new interface is intended for memory hot-delete. During bootup,
memory resources are inserted from the boot descriptor table, such as
EFI Memory Table and e820. Each memory resource entry usually covers
the whole contigous memory range. Memory hot-delete request, on the
other hand, may target to a particular range of memory resource, and its
size can be much smaller than the whole contiguous memory. Since the
existing release interfaces like __release_region() require a requested
region to be exactly matched to a resource entry, they do not allow a
partial resource to be released.
This new interface is restrictive (i.e. release under certain
conditions), which is consistent with other release interfaces,
__release_region() and __release_resource(). Additional release
conditions, such as an overlapping region to a resource entry, can be
supported after they are confirmed as valid cases.
There is no change to the existing interfaces since their restriction is
valid for I/O resources.
[akpm@linux-foundation.org: use GFP_ATOMIC under write_lock()]
[akpm@linux-foundation.org: switch back to GFP_KERNEL, less buggily]
[akpm@linux-foundation.org: remove unneeded and wrong kfree(), per Toshi]
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by : Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Ram Pai <linuxram@us.ibm.com>
Cc: T Makphaibulchoke <tmac@hp.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Help clarify that this is specifically for PCI/ISA I/O ports and not for
any other similar thing.
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Tested-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Currently a bunch of I2C/SPI MFD drivers are using IORESOURCE_IO for
register address ranges. Since this causes some confusion due to the
primary use of this resource type for PCI/ISA I/O ports create a new
resource type IORESOURCE_REG.
Unfortunately the current resource types are specified as bitmasks and
there are no free bitmasks even though they really shouldn't be used as
such so we define the new type as IORESOURCE_IO | IORESOURCE_MEM.
Benjamin Herrenschmidt and Russell King have both verified that none of
the users in this series will have a problem with this, and no new code
should be affected.
This patch was written by Russell King but he found himself unable to
take the patch further.
Add resource_overlaps(), which returns true if two resources overlap at all.
Use this to replace the complicated check in coalesce_windows().
Signed-Off-By: Wei Yang <weiyang@linux.vnet.ibm.com>
No user outside of setup-bus.c now. Later patches will convert
resource_list to a regular list.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k/math-emu: Remove unnecessary code
m68k/math-emu: Remove commented out old code
m68k: Kill warning in setup_arch() when compiling for Sun3
m68k/atari: Prefix GPIO_{IN,OUT} with CODEC_
sparc: iounmap() and *_free_coherent() - Use lookup_resource()
m68k/atari: Reserve some ST-RAM early on for device buffer use
m68k/amiga: Chip RAM - Use lookup_resource()
resources: Add lookup_resource()
sparc: _sparc_find_resource() should check for exact matches
m68k/amiga: Chip RAM - Offset resource end by CHIP_PHYSADDR
m68k/amiga: Chip RAM - Use resource_size() to fix off-by-one error
m68k/amiga: Chip RAM - Change chipavail to an atomic_t
m68k/amiga: Chip RAM - Always allocate from the start of memory
m68k/amiga: Chip RAM - Convert from printk() to pr_*()
m68k/amiga: Chip RAM - Use tabs for indentation
Add a function to find an existing resource by a resource start address.
This allows to implement simple allocators (with a malloc/free-alike API)
on top of the resource system.
Resource definitions that just define start, end and flags =
IORESOURCE_MEM or IORESOURCE_IRQ (with start=end) are quite common. So
introduce a shortcut for them. For completeness add macros for
IORESOURCE_DMA and IORESOURCE_IO, too and also make available a set of
macros to specify named resources of all types which are less common.
This adds arch_remove_reservations(), which an arch can implement if it
needs to protect part of the address space from allocation.
Sometimes that can be done by just putting a region in the resource tree,
but there are cases where that doesn't work well. For example, x86 BIOS
E820 reservations are not related to devices, so they may overlap part of,
all of, or more than a device resource, so they may not end up at the
correct spot in the resource tree.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
This reverts commit e7f8567db9a7f6b3151b0b275e245c1cef0d9c70.
Allocate space from the top of a region first, then work downward,
if an architecture desires this.
When we allocate space from a resource, we look for gaps between children
of the resource. Previously, we always looked at gaps from the bottom up.
For example, given this:
[mem 0xbff00000-0xf7ffffff] PCI Bus 0000:00
[mem 0xbff00000-0xbfffffff] gap -- available
[mem 0xc0000000-0xdfffffff] PCI Bus 0000:02
[mem 0xe0000000-0xf7ffffff] gap -- available
we attempted to allocate from the [mem 0xbff00000-0xbfffffff] gap first,
then the [mem 0xe0000000-0xf7ffffff] gap.
With this patch an architecture can choose to allocate from the top gap
[mem 0xe0000000-0xf7ffffff] first.
We can't do this across the board because iomem_resource.end is initialized
to 0xffffffff_ffffffff on 64-bit architectures, and most machines can't
address the entire 64-bit physical address space. Therefore, we only
allocate top-down if the arch requests it by clearing
"resource_alloc_from_bottom".
SuperIO devices share regions and use lock/unlock operations to chip
select. We therefore need to be able to request a resource and wait for
it to be freed by whichever other SuperIO device currently hogs it.
Right now you have to poll which is horrible.
Add a MUXED field to IO port resources. If the MUXED field is set on the
resource and on the request (via request_muxed_region) then we block
until the previous owner of the muxed resource releases their region.
This allows us to implement proper resource sharing and locking for
superio chips using code of the form
enable_my_superio_dev() {
request_muxed_region(0x44, 0x02, "superio:watchdog");
outb() ..sequence to enable chip
disable_my_superio_dev() {
outb() .. sequence of disable chip
release_region(0x44, 0x02);
Signed-off-by: Giel van Schijndel <me@mortis.eu>
Signed-off-by: Alan Cox <alan@linux.intel.com>
request_resource() and insert_resource() only return success or failure,
which no information about what existing resource conflicted with the
proposed new reservation. This patch adds request_resource_conflict()
and insert_resource_conflict(), which return the conflicting resource.
Callers may use this for better error messages or to adjust the new
resource and retry the request.
Add support for resource windows. This is for bridge resources, i.e.,
regions where a bridge forwards transactions from the primary to the
secondary side.
Signed-off-by: Len Brown <len.brown@intel.com>
Add support for bus number resources. This is for bridges with a range of
bus numbers behind them.
No functional change; this just makes room for another resource type.
Useful for freeing a portion of the resource tree, e.g. when trying to
reallocate resources more efficiently.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Now that we return the new resource start position, there is no
need to update "struct resource" inside the align function.
Therefore, mark the struct resource as const.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
As suggested by Linus, align functions should return the start
of a resource, not void. An update of "res->start" is no longer
necessary.
resource_size() doesn't change the resource it operates on, so the res
parameter can be marked const. Same for resource_type().
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Greg KH <greg@kroah.com>
Originally, walk_memory_resource() was introduced to traverse all memory
of "System RAM" for detecting memory hotplug/unplug range. For doing so,
flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for
memory hotplug.
But for using other purpose, /proc/kcore, this may includes some firmware
area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the
check strict to find out busy "System RAM".
Note: PPC64 keeps their own walk_memory_resouce(), which walk through
ppc64's lmb informaton. Because old kclist_add() is called per lmb, this
patch makes no difference in behavior, finally.
And this patch removes CONFIG_MEMORY_HOTPLUG check from this function.
Because pfn_valid() just show "there is memmap or not* and cannot be used
for "there is physical memory or not", this function is useful in generic
to scan physical memory range.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
We should not assign 64bit ranges to PCI devices that only take 32bit
prefetchable addresses.
Try to set IORESOURCE_MEM_64 in 64bit resource of pci_device/pci_bridge
and make the bus resource only have that bit set when all devices under
it support 64bit prefetchable memory. Use that flag to allocate
resources from that range.
Reported-by: Yannick <yannick.roehlly@free.fr>
Reviewed-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Fix __request_region() parameter kernel-doc notation and parameter name:
Warning(linux-2.6.28-git10//kernel/resource.c:627): No description found for parameter 'flags'
Device drivers that use pci_request_regions() (and similar APIs) have a
reasonable expectation that they are the only ones accessing their device.
As part of the e1000e hunt, we were afraid that some userland (X or some
bootsplash stuff) was mapping the MMIO region that the driver thought it
had exclusively via /dev/mem or via various sysfs resource mappings.
This patch adds the option for device drivers to cause their reserved
regions to the "banned from /dev/mem use" list, so now both kernel memory
and device-exclusive MMIO regions are banned.
NOTE: This is only active when CONFIG_STRICT_DEVMEM is set.
In addition to the config option, a kernel parameter iomem=relaxed is
provided for the cases where developers want to diagnose, in the field,
drivers issues from userspace.
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
* 'core-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
do_generic_file_read: s/EINTR/EIO/ if lock_page_killable() fails
softirq, warning fix: correct a format to avoid a warning
softirqs, debug: preemption check
x86, pci-hotplug, calgary / rio: fix EBDA ioremap()
IO resources, x86: ioremap sanity check to catch mapping requests exceeding, fix
IO resources, x86: ioremap sanity check to catch mapping requests exceeding the BAR sizes
softlockup: Documentation/sysctl/kernel.txt: fix softlockup_thresh description
dmi scan: warn about too early calls to dmi_check_system()
generic: redefine resource_size_t as phys_addr_t
generic: make PFN_PHYS explicitly return phys_addr_t
generic: add phys_addr_t for holding physical addresses
softirq: allocate less vectors
IO resources: fix/remove printk
printk: robustify printk, update comment
printk: robustify printk, fix #2
Fixed up conflicts in:
arch/powerpc/include/asm/types.h
arch/powerpc/platforms/Kconfig.cputype
manually.
Add resource_type() and IORESOURCE_TYPE_BITS. They make it easier to add
more resource types without having to rewrite tons of code.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Jean Delvare <khali@linux-fr.org>
'core/printk' and 'core/misc' into core-v28-for-linus
arch/x86/kernel/cpu/common.c
arch/x86/kernel/signal_64.c
include/asm-x86/cpufeature.h
the BAR sizes
Go through the iomem resource tree to check if any of the ioremap()
requests span more than any slot in the iomem resource tree and do
a WARN_ON() if we hit this check.
This will raise a red-flag, if some driver is mapping more than what
is needed. And hopefully identify possible corruptions much earlier.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
akpm: these have no callers at this time, but they shall soon, so let's
get them right.
Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
add reserve_region_with_split() to not lose e820 reserved entries if
they overlap with existing IO regions:
with test case by extend 0xe0000000 - 0xeffffff to 0xdd800000 -
we get:
e0000000-efffffff : PCI MMCONFIG 0
e0000000-efffffff : reserved
and in /proc/iomem we get:
found conflict for reserved [dd800000, efffffff], try to reserve with split
__reserve_region_with_split: (PCI Bus #80) [dd000000, ddffffff], res: (reserved) [dd800000, efffffff]
__reserve_region_with_split: (PCI Bus #00) [de000000, dfffffff], res: (reserved) [de000000, efffffff]
initcall pci_subsys_init+0x0/0x121 returned 0 after 381 msecs
in dmesg
various fixes and improvements suggested by Linus.
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Not used anywhere yet, but this complements the existing plain
'insert_resource()' functionality with a version that can expand the
resource we are adding in order to fix up any conflicts it has with
existing resources.
Avoid one-off errors by introducing a resource_size() function.
This patch adds an IORESOURCE_IRQ_OPTIONAL flag for use when
assigning resources to a device. If the flag is set and we are
unable to assign an IRQ to the device, we can leave the IRQ
disabled but allow the overall resource allocation to succeed.
Some devices request an IRQ, but can run without an IRQ
(possibly with degraded performance). This flag lets us run
the device without the IRQ instead of just leaving the
device disabled.
This is a reimplementation of this previous change by Rene
Herman <rene.herman@gmail.com>:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=3b73a223661ed137c5d3d2635f954382e94f5a43
I reimplemented this for two reasons:
- to prepare for converting all resource options into a single linked
list, as opposed to the per-resource-type lists we have now, and
- to preserve the order and number of resource options.
In PNPBIOS and ACPI, we configure a device by giving firmware a
list of resource assignments. It is important that this list
has exactly the same number of resources, in the same order,
as the "template" list we got from the firmware in the first
place.
The problem of a sound card MPU401 being left disabled for want of
an IRQ was reported by Uwe Bugla <uwe.bugla@gmx.de>.
Acked-by: Rene Herman <rene.herman@gmail.com>
PNP previously defined PNP_PORT_FLAG_16BITADDR and PNP_PORT_FLAG_FIXED
in a private header file, but put those flags in struct resource.flags
fields. Better to make them IORESOURCE_IO_* flags like the existing
IRQ, DMA, and MEM flags.
When decoding IRQ trigger mode and polarity, it is not enough to mask by
IORESOURCE_BITS because there are now additional bits defined. For
example, if IORESOURCE_IRQ_SHAREABLE was set, we failed to set *triggering
and *polarity at all.
I can't point to a failure that this patch fixes, but
bugs in this area have caused problems when resuming after
suspend, for example:
http://bugzilla.kernel.org/show_bug.cgi?id=6316
http://bugzilla.kernel.org/show_bug.cgi?id=9487
https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/152187
This is based on a patch by Tom Jaeger:
http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32
[rene.herman@keyaccess.nl: fix comment]
Done per Linus' request and suggestions. Linus has explained that
better than I'll be able to explain:
On Thu, Mar 27, 2008 at 10:12:10AM -0700, Linus Torvalds wrote:
> Actually, before we go any further, there might be a less intrusive
> alternative: add just a couple of flags to the resource flags field (we
> still have something like 8 unused bits on 32-bit), and use those to
> implement a generic "resource_alignment()" routine.
> Two flags would do it:
> - IORESOURCE_SIZEALIGN: size indicates alignment (regular PCI device
> resources)
> - IORESOURCE_STARTALIGN: start field is alignment (PCI bus resources
> during probing)
> and then the case of both flags zero (or both bits set) would actually be
> "invalid", and we would also clear the IORESOURCE_STARTALIGN flag when we
> actually allocate the resource (so that we don't use the "start" field as
> alignment incorrectly when it no longer indicates alignment).
> That wouldn't be totally generic, but it would have the nice property of
> automatically at least add sanity checking for that whole "res->start has
> the odd meaning of 'alignment' during probing" and remove the need for a
> new field, and it would allow us to have a generic "resource_alignment()"
> routine that just gets a resource pointer.
Besides, I removed IORESOURCE_BUS_HAS_VGA flag which was unused for ages.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Gary Hade <garyhade@us.ibm.com>
This patch removes the extern struct resource declarations for
data_resource, code_resource and bss_resource on x86 and declares that
three structures as static as done on other architectures like IA64.
On i386, these structures are moved to setup_32.c (from e820_32.c) because
that's code that is not specific to e820 and also required on EFI systems.
That makes the "extern" reference superfluous.
On x86_64, data_resource, code_resource and bss_resource are passed to
e820_reserve_resources() as arguments just as done on i386 and IA64. That
also avoids the "extern" reference and it's possible to make it static.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
A clean up patch for "scanning memory resource [start, end)" operation.
Now, find_next_system_ram() function is used in memory hotplug, but this
interface is not easy to use and codes are complicated.
This patch adds walk_memory_resouce(start,len,arg,func) function.
The function 'func' is called per valid memory resouce range in [start,pfn).
[pbadari@us.ibm.com: Error handling in walk_memory_resource()]
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Both old-IDE and libata should be able handle all controllers and
devices found using normal resource reservation methods.
This eliminates the awful, low-performing split-driver configuration
where old-IDE drove the PATA portion of a PCI device, in PIO-only mode,
and libata drove the SATA portion of the /same/ PCI device, in DMA mode.
Typically vendors would ship SATA hard drive / PATA optical
configuration, which would lend itself to slow (PIO-only) CD-ROM
performance.
For Intel users running in combined mode, it is now wholly dependent on
your driver choice (potentially link order, if you compile both drivers
in) whether old-IDE or libata will drive your hardware.
In either case, you will get full performance from both SATA and PATA
ports now, without having to pass a kernel command line parameter.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Implement device resource management, in short, devres. A device
driver can allocate arbirary size of devres data which is associated
with a release function. On driver detach, release function is
invoked on the devres data, then, devres data is freed.
devreses are typed by associated release functions. Some devreses are
better represented by single instance of the type while others need
multiple instances sharing the same release function. Both usages are
supported.
devreses can be grouped using devres group such that a device driver
can easily release acquired resources halfway through initialization
or selectively release resources (e.g. resources for port 1 out of 4
ports).
This patch adds devres core including documentation and the following
managed interfaces.
* alloc/free : devm_kzalloc(), devm_kzfree()
* IO region : devm_request_region(), devm_release_region()
* IRQ : devm_request_irq(), devm_free_irq()
* DMA : dmam_alloc_coherent(), dmam_free_coherent(),
dmam_declare_coherent_memory(), dmam_pool_create(),
dmam_pool_destroy()
* PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed()
* iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(),
devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(),
pcim_iomap(), pcim_iounmap()
Signed-off-by: Tejun Heo <htejun@gmail.com>
Since commit 368c73d4f689dae0807d0a2aa74c61fd2b9b075f the kernel will try
to update the non-writeable BAR registers 0..3 of PIIX4 IDE adapters if
pci_assign_unassigned_resources() is used to do full resource assignment of
the bus. This fails because in the PIIX4 these BAR registers have
implicitly assumed values and read back as zero; it used to work because
the kernel used to just write zero to that register the read back value did
match what was written.
The fix is a new resource flag IORESOURCE_PCI_FIXED used to mark a resource
as non-movable. This will also be useful to keep other import system
resources from being moved around - for example system consoles on PCI
busses.
[akpm@osdl.org: cleanup]
Acked-by: Alan Cox <alan@redhat.com>
Support a shadowed ROM when running with an ACPI capable PROM.
Define a new dev.resource flag IORESOURCE_ROM_BIOS_COPY to
describe the case of a BIOS shadowed ROM, which can then
be used to avoid pci_map_rom() making an unneeded call to
pci_enable_rom().
Signed-off-by: John Keller <jpk@sgi.com>
Implement the scheduled unexport of insert_resource.
ACPI supplies a "shareable" indication, but PNPACPI ignores it. If a PNP
device uses a shared interrupt, request_irq() fails because the PNP driver
can't tell whether to supply SA_SHIRQ.
This patch allows PNP drivers to test
(pnp_irq_flags(dev, 0) & IORESOURCE_IRQ_SHAREABLE)
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: Matthieu Castet <castet.matthieu@free.fr>
Cc: Li Shaohua <shaohua.li@intel.com>
Cc: Len Brown <len.brown@intel.com>
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6:
[PATCH] i386: export memory more than 4G through /proc/iomem
[PATCH] 64bit Resource: finally enable 64bit resource sizes
[PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed
[PATCH] 64bit resource: change pnp core to use resource_size_t
[PATCH] 64bit resource: change pci core and arch code to use resource_size_t
[PATCH] 64bit resource: change resource core to use resource_size_t
[PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource
[PATCH] 64bit resource: fix up printks for resources in misc drivers
[PATCH] 64bit resource: fix up printks for resources in arch and core code
[PATCH] 64bit resource: fix up printks for resources in pcmcia drivers
[PATCH] 64bit resource: fix up printks for resources in video drivers
[PATCH] 64bit resource: fix up printks for resources in ide drivers
[PATCH] 64bit resource: fix up printks for resources in mtd drivers
[PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers
[PATCH] 64bit resource: fix up printks for resources in networks drivers
[PATCH] 64bit resource: fix up printks for resources in sound drivers
[PATCH] 64bit resource: C99 changes for struct resource declarations
Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that
was changed by the 64-bit resources had been deleted in the meantime ;)
