path: root/include/linux/ip.h
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipip_hdr(), remove skb->h.ipiphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2006-12-02[NET]: Annotate checksums in on-the-wire packets.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: headers endiannessAl Viro
2006-09-22[NetLabel]: core network changesPaul Moore
Changes to the core network stack to support the NetLabel subsystem. This includes changes to the IPv4 option handling to support CIPSO labels. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-06[NET]: Endian-annotate struct iphdrAlexey Dobriyan
And fix trivial warnings that emerged. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP_SOCKGLUE]: Remove most of the tcp specific callsArnaldo Carvalho de Melo
As DCCP needs to be called in the same spots. Now we have a member in inet_sock (is_icsk), set at sock creation time from struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and DCCP) to see if a struct sock instance is a inet_connection_sock for places like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if sk_type was SOCK_STREAM, that is insufficient because we now use the same code for DCCP, that has sk_type SOCK_DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_rsk()Arnaldo Carvalho de Melo
And inet6_rsk_offset in inet_request_sock, for the same reasons as inet_sock's pinfo6 member. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce inet_connection_sockArnaldo Carvalho de Melo
This creates struct inet_connection_sock, moving members out of struct tcp_sock that are shareable with other INET connection oriented protocols, such as DCCP, that in my private tree already uses most of these members. The functions that operate on these members were renamed, using a inet_csk_ prefix while not being moved yet to a new file, so as to ease the review of these changes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move bind_hash from tcp_sk to inet_skArnaldo Carvalho de Melo
This should really be in a inet_connection_sock, but I'm leaving it for a later optimization, when some more fields common to INET transport protocols now in tcp_sk or inet_sk will be chunked out into inet_connection_sock, for now its better to concentrate on getting the changes in the core merged to leave the DCCP tree with only DCCP specific code. Next changesets will take advantage of this move to generalise things like tcp_bind_hash, tcp_put_port, tcp_inherit_port, making the later receive a inet_hashinfo parameter, and even __tcp_tw_hashdance, etc in the future, when tcp_tw_bucket gets transformed into the struct timewait_sock hierarchy. tcp_destroy_sock also is eligible as soon as tcp_orphan_count gets moved to sk_prot. A cascade of incremental changes will ultimately make the tcp_lookup functions be fully generic. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Introduce inet_sk_rebuild_headerArnaldo Carvalho de Melo
From tcp_v4_rebuild_header, that already was pretty generic, I only needed to use sk->sk_protocol instead of the hardcoded IPPROTO_TCP and establish the requirement that INET transport layer protocols that want to use this function map TCP_SYN_SENT to its equivalent state. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Rename open_request to request_sockArnaldo Carvalho de Melo
Ok, this one just renames some stuff to have a better namespace and to dissassociate it from TCP: struct open_request -> struct request_sock tcp_openreq_alloc -> reqsk_alloc tcp_openreq_free -> reqsk_free tcp_openreq_fastfree -> __reqsk_free With this most of the infrastructure closely resembles a struct sock methods subset. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise TCP's struct open_request minisock infrastructureArnaldo Carvalho de Melo
Kept this first changeset minimal, without changing existing names to ease peer review. Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn has two new members: ->slab, that replaces tcp_openreq_cachep ->obj_size, to inform the size of the openreq descendant for a specific protocol The protocol specific fields in struct open_request were moved to a class hierarchy, with the things that are common to all connection oriented PF_INET protocols in struct inet_request_sock, the TCP ones in tcp_request_sock, that is an inet_request_sock, that is an open_request. I.e. this uses the same approach used for the struct sock class hierarchy, with sk_prot indicating if the protocol wants to use the open_request infrastructure by filling in sk_prot->rsk_prot with an or_calltable. Results? Performance is improved and TCP v4 now uses only 64 bytes per open request minisock, down from 96 without this patch :-) Next changeset will rename some of the structs, fields and functions mentioned above, struct or_calltable is way unclear, better name it struct request_sock_ops, s/struct open_request/struct request_sock/g, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
