path: root/include/linux/ipv6.h
2010-08-22header: fix broken headers for user spaceChangli Gao
__packed is only defined in kernel space, so we should use __attribute__((packed)) for the code shared between kernel and user space. Two __attribute() annotations are replaced with __attribute__() too. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-19ipv6: Make IP6CB(skb)->nhoff 16-bit.David S. Miller
Even with jumbograms I cannot see any way in which we would need to records a larger than 65535 valued next-header offset. The maximum extension header length is (256 << 3) == 2048. There are only a handful of extension headers specified which we'd even accept (say 5 or 6), therefore the largest next-header offset we'd ever have to contend with is something less than say 16k. Therefore make it a u16 instead of a u32. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-11ipv6: ip6mr: support multiple tablesPatrick McHardy
This patch adds support for multiple independant multicast routing instances, named "tables". Userspace multicast routing daemons can bind to a specific table instance by issuing a setsockopt call using a new option MRT6_TABLE. The table number is stored in the raw socket data and affects all following ip6mr setsockopt(), getsockopt() and ioctl() calls. By default, a single table (RT6_TABLE_DFLT) is created with a default routing rule pointing to it. Newly created pim6reg devices have the table number appended ("pim6regX"), with the exception of devices created in the default table, which are named just "pim6reg" for compatibility reasons. Packets are directed to a specific table instance using routing rules, similar to how regular routing rules work. Currently iif, oif and mark are supported as keys, source and destination addresses could be supported additionally. Example usage: - bind pimd/xorp/... to a specific table: uint32_t table = 123; setsockopt(fd, SOL_IPV6, MRT6_TABLE, &table, sizeof(table)); - create routing rules directing packets to the new table: # ip -6 mrule add iif eth0 lookup 123 # ip -6 mrule add oif eth0 lookup 123 Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-10Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: net/bridge/br_device.c net/bridge/br_forward.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-23IPv6: Complete IPV6_DONTFRAG supportBrian Haley
Finally add support to detect a local IPV6_DONTFRAG event and return the relevant data to the user if they've enabled IPV6_RECVPATHMTU on the socket. The next recvmsg() will return no data, but have an IPV6_PATHMTU as ancillary data. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23IPv6: data structure changes for new socket optionsBrian Haley
Add underlying data structure changes and basic setsockopt() and getsockopt() support for IPV6_RECVPATHMTU, IPV6_PATHMTU, and IPV6_DONTFRAG. IPV6_PATHMTU is actually fully functional at this point. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22IPv6: Generic TTL Security Mechanism (final version)Stephen Hemminger
This patch adds IPv6 support for RFC5082 Generalized TTL Security Mechanism. Not to users of mapped address; the IPV6 and IPV4 socket options are seperate. The server does have to deal with both IPv4 and IPv6 socket options and the client has to handle the different for each family. On client: int ttl = 255; getaddrinfo(argv[1], argv[2], &hint, &result); for (rp = result; rp != NULL; rp = rp->ai_next) { s = socket(rp->ai_family, rp->ai_socktype, rp->ai_protocol); if (s < 0) continue; if (rp->ai_family == AF_INET) { setsockopt(s, IPPROTO_IP, IP_TTL, &ttl, sizeof(ttl)); } else if (rp->ai_family == AF_INET6) { setsockopt(s, IPPROTO_IPV6, IPV6_UNICAST_HOPS, &ttl, sizeof(ttl))) } if (connect(s, rp->ai_addr, rp->ai_addrlen) == 0) { ... On server: int minttl = 255 - maxhops; getaddrinfo(NULL, port, &hints, &result); for (rp = result; rp != NULL; rp = rp->ai_next) { s = socket(rp->ai_family, rp->ai_socktype, rp->ai_protocol); if (s < 0) continue; if (rp->ai_family == AF_INET6) setsockopt(s, IPPROTO_IPV6, IPV6_MINHOPCOUNT, &minttl, sizeof(minttl)); setsockopt(s, IPPROTO_IP, IP_MINTTL, &minttl, sizeof(minttl)); if (bind(s, rp->ai_addr, rp->ai_addrlen) == 0) break ... Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13netfilter: ipv6: add IPSKB_REROUTED exclusion to NF_HOOK/POSTROUTING invocationJan Engelhardt
Similar to how IPv4's ip_output.c works, have ip6_output also check the IPSKB_REROUTED flag. It will be set from xt_TEE for cloned packets since Xtables can currently only deal with a single packet in flight at a time. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Acked-by: David S. Miller <davem@davemloft.net> [Patrick: changed to use an IP6SKB value instead of IPSKB] Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-08ipv6: Fix the size overflow of addrconf_sysctl arrayJin Dongming
(This patch fixes bug of commit f7734fdf61ec6bb848e0bafc1fb8bad2c124bb50 title "make TLLAO option for NA packets configurable") When the IPV6 conf is used, the function sysctl_set_parent is called and the array addrconf_sysctl is used as a parameter of the function. The above patch added new conf "force_tllao" into the array addrconf_sysctl, but the size of the array was not modified, the static allocated size is DEVCONF_MAX + 1 but the real size is DEVCONF_MAX + 2, so the problem is that the function sysctl_set_parent accessed wrong address. I got the following information. Call Trace: [<ffffffff8106085d>] sysctl_set_parent+0x29/0x3e [<ffffffff8106085d>] sysctl_set_parent+0x29/0x3e [<ffffffff8106085d>] sysctl_set_parent+0x29/0x3e [<ffffffff8106085d>] sysctl_set_parent+0x29/0x3e [<ffffffff8106085d>] sysctl_set_parent+0x29/0x3e [<ffffffff810622d5>] __register_sysctl_paths+0xde/0x272 [<ffffffff8110892d>] ? __kmalloc_track_caller+0x16e/0x180 [<ffffffffa00cfac3>] ? __addrconf_sysctl_register+0xc5/0x144 [ipv6] [<ffffffff8141f2c9>] register_net_sysctl_table+0x48/0x4b [<ffffffffa00cfaf5>] __addrconf_sysctl_register+0xf7/0x144 [ipv6] [<ffffffffa00cfc16>] addrconf_init_net+0xd4/0x104 [ipv6] [<ffffffff8139195f>] setup_net+0x35/0x82 [<ffffffff81391f6c>] copy_net_ns+0x76/0xe0 [<ffffffff8107ad60>] create_new_namespaces+0xf0/0x16e [<ffffffff8107afee>] copy_namespaces+0x65/0x9f [<ffffffff81056dff>] copy_process+0xb2c/0x12c3 [<ffffffff810576e1>] do_fork+0x14b/0x2d2 [<ffffffff8107ac4e>] ? up_read+0xe/0x10 [<ffffffff81438e73>] ? do_page_fault+0x27a/0x2aa [<ffffffff8101044b>] sys_clone+0x28/0x2a [<ffffffff81011fb3>] stub_clone+0x13/0x20 [<ffffffff81011c72>] ? system_call_fastpath+0x16/0x1b And the information of IPV6 in .config is as following. IPV6 in .config: CONFIG_IPV6=m CONFIG_IPV6_PRIVACY=y CONFIG_IPV6_ROUTER_PREF=y CONFIG_IPV6_ROUTE_INFO=y CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_IPV6_MIP6=m CONFIG_IPV6_SIT=m # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y CONFIG_IPV6_TUNNEL=m CONFIG_IPV6_MULTIPLE_TABLES=y CONFIG_IPV6_SUBTREES=y CONFIG_IPV6_MROUTE=y CONFIG_IPV6_PIMSM_V2=y # CONFIG_IP_VS_IPV6 is not set CONFIG_NF_CONNTRACK_IPV6=m CONFIG_IP6_NF_MATCH_IPV6HEADER=m I confirmed this patch fixes this problem. Signed-off-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07make TLLAO option for NA packets configurableOctavian Purdila
On Friday 02 October 2009 20:53:51 you wrote: > This is good although I would have shortened the name. Ah, I knew I forgot something :) Here is v4. tavi >From 24d96d825b9fa832b22878cc6c990d5711968734 Mon Sep 17 00:00:00 2001 From: Octavian Purdila <opurdila@ixiacom.com> Date: Fri, 2 Oct 2009 00:51:15 +0300 Subject: [PATCH] ipv6: new sysctl for sending TLLAO with unicast NAs Neighbor advertisements responding to unicast neighbor solicitations did not include the target link-layer address option. This patch adds a new sysctl option (disabled by default) which controls whether this option should be sent even with unicast NAs. The need for this arose because certain routers expect the TLLAO in some situations even as a response to unicast NS packets. Moreover, RFC 2461 recommends sending this to avoid a race condition (section 4.4, Target link-layer address) Signed-off-by: Cosmin Ratiu <cratiu@ixiacom.com> Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-01IPv6: Add 'autoconf' and 'disable_ipv6' module parametersBrian Haley
Add 'autoconf' and 'disable_ipv6' parameters to the IPv6 module. The first controls if IPv6 addresses are autoconfigured from prefixes received in Router Advertisements. The IPv6 loopback (::1) and link-local addresses are still configured. The second controls if IPv6 addresses are desired at all. No IPv6 addresses will be added to any interfaces. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30headers_check fix: linux/ipv6.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/ipv6.h:26: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-12-16ipv6: Add IPV6_PKTINFO sticky option support to setsockopt()Yang Hongyang
There are three reasons for me to add this support: 1.When no interface is specified in an IPV6_PKTINFO ancillary data item, the interface specified in an IPV6_PKTINFO sticky optionis is used. RFC3542: 6.7. Summary of Outgoing Interface Selection This document and [RFC-3493] specify various methods that affect the selection of the packet's outgoing interface. This subsection summarizes the ordering among those in order to ensure deterministic behavior. For a given outgoing packet on a given socket, the outgoing interface is determined in the following order: 1. if an interface is specified in an IPV6_PKTINFO ancillary data item, the interface is used. 2. otherwise, if an interface is specified in an IPV6_PKTINFO sticky option, the interface is used. 2.When no IPV6_PKTINFO ancillary data is received,getsockopt() should return the sticky option value which set with setsockopt(). RFC 3542: Issuing getsockopt() for the above options will return the sticky option value i.e., the value set with setsockopt(). If no sticky option value has been set getsockopt() will return the following values: 3.Make the setsockopt implementation POSIX compliant. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-21ipv6: __KERNEL__ ifdef struct ipv6_devconfDavid S. Miller
Based upon a report by Olaf Hering. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03ipv6 addrconf: add accept_dad sysctl to control DAD operation.YOSHIFUJI Hideaki
- If 0, disable DAD. - If 1, perform DAD (default). - If >1, perform DAD and disable IPv6 operation if DAD for MAC-based link-local address has been failed (RFC4862 5.4.5). We do not follow RFC4862 by default. Refer to the netdev thread entitled "Linux IPv6 DAD not full conform to RFC 4862 ?" http://www.spinics.net/lists/netdev/msg52027.html Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-07-03ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface.YOSHIFUJI Hideaki
2008-06-10inet{6}_request_sock: Init ->opt and ->pktopts in the constructorArnaldo Carvalho de Melo
Wei Yongjun noticed that we may call reqsk_free on request sock objects where the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc where we initialize ->opt to NULL and set ->pktopts to NULL in inet6_reqsk_alloc. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-13[IPV6]: IPv6 extension header structures need to be packed.YOSHIFUJI Hideaki
struct ipv6_opt_hdr is the common structure for IPv6 extension headers, and it is common to increment the pointer to get the real content. On the other hand, since the structure consists only of 1-byte next-header field and 1-byte length field, size of that structure depends on architecture; 2 or 4. Add "packed" attribute to get 2. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-05[IPV6] MROUTE: Support multicast forwarding.YOSHIFUJI Hideaki
Based on ancient patch by Mickael Hoerdt <hoerdt@clarinet.u-strasbg.fr>, which is available at <http://www-r2.u-strasbg.fr/~hoerdt/dev/linux_ipv6_mforwarding/patch-linux-ipv6-mforwarding-0.1a>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-25[IPV6]: Support Source Address Selection API (RFC5014).YOSHIFUJI Hideaki
2008-03-25[IPV6]: Use bitfields for hop_limit and mcast_hops.YOSHIFUJI Hideaki
Save some bits for future extensions. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-25[IPV6]: Convert cork.hop_limit and cork.tclass into u8 instead of int.YOSHIFUJI Hideaki
Values of those fields are always between 0 and 255 (inclusive), so use u8 and save some memory on 32bit systems. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-25[IPV4,IPV6]: Share cork.rt between IPv4 and IPv6.YOSHIFUJI Hideaki
2008-01-31[NETNS]: Tcp-v6 sockets per-net lookup.Pavel Emelyanov
Add a net argument to inet6_lookup and propagate it further. Actually, this is tcp-v6 implementation of what was done for tcp-v4 sockets in a previous patch. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPV6]: Introduce the INET6_TW_MATCH macro.Pavel Emelyanov
We have INET_MATCH, INET_TW_MATCH and INET6_MATCH to test sockets and twbuckets for matching, but ipv6 twbuckets are tested manually. Here's the INET6_TW_MATCH to help with it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Get rid of ipv6_{auth,esp,comp}_hdrHerbert Xu
This patch removes the duplicate ipv6_{auth,esp,comp}_hdr structures since they're identical to the IPv4 versions. Duplicating them would only create problems for ourselves later when we need to add things like extended sequence numbers. I've also added transport header type conversion headers for these types which are now used by the transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[IPV6]: Remove circular dependency on if_inet6.hHerbert Xu
net/if_inet6.h includes linux/ipv6.h which also tries to include net/if_inet6.h. Since the latter only needs it for forward declarations, we can fix this by adding the declarations. A number of files are implicitly including net/if_inet6.h through linux/ipv6.h. They also use net/ipv6.h so this patch includes net/if_inet6.h there. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6]: Make IPV6_{RECV,2292}RTHDR boolean options.YOSHIFUJI Hideaki
Because reversing RH0 is no longer supported by deprecation of RH0, let's make IPV6_{RECV,2292}RTHDR boolean options. Boolean are more appropriate from standard POV. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6]: Do not send RH0 anymore.YOSHIFUJI Hideaki
Based on <draft-ietf-ipv6-deprecate-rh0-00.txt>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6] MIP6: Loadable module support for MIPv6.Masahide NAKAMURA
This patch makes MIPv6 loadable module named "mip6". Here is a modprobe.conf(5) example to load it automatically when user application uses XFRM state for MIPv6: alias xfrm-type-10-43 mip6 alias xfrm-type-10-60 mip6 Some MIPv6 feature is not included by this modular, however, it should not be affected to other features like either IPsec or IPv6 with and without the patch. We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt separately for future work. Loadable features: * MH receiving check (to send ICMP error back) * RO header parsing and building (i.e. RH2 and HAO in DSTOPTS) * XFRM policy/state database handling for RO These are NOT covered as loadable: * Home Address flags and its rule on source address selection * XFRM sub policy (depends on its own kernel option) * XFRM functions to receive RO as IPv6 extension header * MH sending/receiving through raw socket if user application opens it (since raw socket allows to do so) * RH2 sending as ancillary data * RH2 operation with setsockopt(2) Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPV6] ADDRCONF: Fix conflicts in DEVCONF_xxx constant.YOSHIFUJI Hideaki
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipipv6_hdr(), remove skb->h.ipv6hArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6] ADDRCONF: Optimistic Duplicate Address Detection (RFC 4429) Support.Neil Horman
Nominally an autoconfigured IPv6 address is added to an interface in the Tentative state (as per RFC 2462). Addresses in this state remain in this state while the Duplicate Address Detection process operates on them to determine their uniqueness on the network. During this period, these tentative addresses may not be used for communication, increasing the time before a node may be able to communicate on a network. Using Optimistic Duplicate Address Detection, autoconfigured addresses may be used immediately for communication on the network, as long as certain rules are followed to avoid conflicts with other nodes during the Duplicate Address Detection process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-24[IPV6]: Disallow RH0 by default.YOSHIFUJI Hideaki
A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. Note: We allow RH2 by default because it is harmless. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: flowlabels are net-endianAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV6]: IPv6 headers annotationsAl Viro
2006-09-28[IPV4]: INET_MATCH() annotationsAl Viro
INET_MATCH() and friends depend on an interesting set of kludges: * there's a pair of adjacent fields in struct inet_sock - __be16 dport followed by __u16 num. We want to search by pair, so we combine the keys into a single 32bit value and compare with 32bit value read from &...->dport. * on 64bit targets we combine comparisons with pair of adjacent __be32 fields in the same way. Make sure that we don't mix those values with anything else and that pairs we form them from have correct types. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] NDISC: Add proxy_ndp sysctl.YOSHIFUJI Hideaki
We do not always need proxy NDP functionality even we enable forwarding. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Put dsthao after flags in order to pack inet6_skb_parm better.David S. Miller
2006-09-22[IPV6] MIP6: Add inbound interface of home address option.Masahide NAKAMURA
Add inbound function of home address option by registering it to TLV table for destination options header. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] MIP6: Add home address option definition.Noriaki TAKAMIYA
Add home address option definition for Mobile IPv6. Based on MIPL2 kernel patch. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] MIP6: Add routing header type 2 definition.Noriaki TAKAMIYA
Add routing header type 2 definition for Mobile IPv6. Based on MIPL2 kernel patch. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[IPV6]: Cache source address as well in ipv6_pinfo{}.YOSHIFUJI Hideaki
Based on MIPL2 kernel patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
