path: root/include/linux/isdn/hdlc.h
2009-07-25ISDN: Add support for none reverse bitstreams to isdnhdcKarsten Keil
The original isdnhdlc code was developed for devices which had reversed bitorder in the byte stream. Adding code to handle normal bitstreams as well. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-07-25ISDN: Clean up isdnhdlc codeKarsten Keil
Clean up isdnhdlc to meet current code standard. Remove hint to already removed bit reversal table. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-07-25ISDN: Make isdnhdlc usable for other ISDN driversKarsten Keil
isdnhdlc is useful for other ISDN drivers as well. Move the include file to a central location and the source to the central isdn location. Signed-off-by: Karsten Keil <keil@b1-systems.de>
