path: root/include/linux/isdn
2014-06-04isdn/capi: move capi_info2str to capidrv.cPaul Bolle
capi_info2str() is apparently meant to be of general utility. It is actually only used in capidrv.c. So move it from capiutil.c to capidrv.c and (obviously) stop exporting it. And, since we're touching this, merge the two versions of this function. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-17UAPI: Remove empty non-UAPI Kbuild filesDavid Howells
Remove non-UAPI Kbuild files that have become empty as a result of UAPI disintegration. They used to have only header-y lines in them and those have now moved to the Kbuild files in the corresponding uapi/ directories. Possibly these should not be removed but rather have a comment inserted to say they are intentionally left blank. This would make it easier to add generated header lines in future without having to restore the infrastructure. Note that at this point not all the UAPI disintegration parts have been merged, so it is likely that more empty Kbuild files will turn up. It is probably necessary to make the files non-empty to prevent the patch program from automatically deleting them when it reduces them to nothing. Signed-off-by: David Howells <dhowells@redhat.com>
2012-10-09UAPI: (Scripted) Disintegrate include/linux/isdnDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2010-02-16CAPI: Rework locking of controller data structuresJan Kiszka
This patch applies the mutex so far only protecting the controller list to (almost) all accesses of controller data structures. It also reworks waiting on state changes in old_capi_manufacturer so that it no longer poll and holds a module reference to the controller owner while waiting (the latter was partly done already). Modification and checking of the blocked state remains racy by design, the caller is responsible for dealing with this. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Call a controller 'controller', not 'card'Jan Kiszka
At least for our internal use, fix the misnomers that refer to a CAPI controller as 'card'. No functional changes. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-14proc_fops: convert drivers/isdn/ to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" [akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-25ISDN: Add support for none reverse bitstreams to isdnhdcKarsten Keil
The original isdnhdlc code was developed for devices which had reversed bitorder in the byte stream. Adding code to handle normal bitstreams as well. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-07-25ISDN: Clean up isdnhdlc codeKarsten Keil
Clean up isdnhdlc to meet current code standard. Remove hint to already removed bit reversal table. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-07-25ISDN: Make isdnhdlc usable for other ISDN driversKarsten Keil
isdnhdlc is useful for other ISDN drivers as well. Move the include file to a central location and the source to the central isdn location. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-06-08isdn: rename capi_ctr_reseted() to capi_ctr_down()Tilman Schmidt
Change the name of the Kernel CAPI exported function capi_ctr_reseted() to something representing its purpose better. Impact: renaming, no functional change Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08make drivers/isdn/capi/capiutil.c:cdebbuf_alloc() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] Fix buffer overflow and races in capi debug functionsKarsten Keil
The CAPI trace debug functions were using a fixed size buffer, which can be overflowed if wrong formatted CAPI messages were sent to the kernel capi layer. The code was also not protected against multiple callers. This fix bug 8028. Additionally the patch make the CAPI trace functions optional. Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-04Merge git://git.infradead.org/hdrinstall-2.6Linus Torvalds
* git://git.infradead.org/hdrinstall-2.6: Remove export of include/linux/isdn/tpam.h Remove <linux/i2c-id.h> and <linux/i2c-algo-ite.h> from userspace export Restrict headers exported to userspace for SPARC and SPARC64 Add empty Kbuild files for 'make headers_install' in remaining arches. Add Kbuild file for Alpha 'make headers_install' Add Kbuild file for SPARC 'make headers_install' Add Kbuild file for IA64 'make headers_install' Add Kbuild file for S390 'make headers_install' Add Kbuild file for i386 'make headers_install' Add Kbuild file for x86_64 'make headers_install' Add Kbuild file for PowerPC 'make headers_install' Add generic Kbuild files for 'make headers_install' Basic implementation of 'make headers_check' Basic implementation of 'make headers_install'
2006-06-29Remove export of include/linux/isdn/tpam.hDavid Woodhouse
2006-06-29[PATCH] i4l: remove unneeded include/linux/isdn/tpam.hKarsten Keil
The TPAM isdn driver was removed in 2.6.12, but include/linux/isdn/tpam.h was missed. Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-18Add generic Kbuild files for 'make headers_install'David Woodhouse
This adds the Kbuild files listing the files which are to be installed by the 'headers_install' make target, in generic directories. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-25Remove gratuitous inclusion of <linux/pci.h> from linux/isdn/tpam.hDavid Woodhouse
